With byte16 set to 0xFF it still doesn't work, but it does flash quickly (once < 50ms or so) when going going from 2->1. Byte 23 does not influence issue.
Hi Jos, I've been through the wiring schemes again, maybe I messed up somewhere.
But it appears to be ok. You also don't have any errors on your VCDS autoscan? Your coding looks perfectly fine to me. Really strange. I cannot make any chocolate of it...
Could you check your fuses maybe? It's a long shot.
You have a multimeter, right? Could you check whether all wiring is intact? It probably is, since your problem shows up at both sides.
It should work, the BCM of the Bluemotion is capable of sending out the correct signals.
Somehow it appears not to be in xenon mode, if it were then I'd expect some errors about the communication with the LED module.
Could you try this coding, just as a reference?
3CB02BB808210000002809F07F2B9CD9FF80673F7EA61001A00000000000 (cornering lights in bumper)
3CB02BB808210000002809F07F2B9CD9FF80673F7E051001A00000000000 (cornering lights in headlight)
It's a few codings of my old 1.2TDI with OEM xenon. It might throw a few erros since the equipment is different but at least the lighting should be ok.
Hello,
I have checked the autoscan again and there are no errors in the CECM. Is the CECM capable of detecting faulty DRL LEDs?
I have also checked the fuses; they're fine. The halogen DRL also works fine if I connect it again. I think the 6V I measure in switch mode 1 or 2 must be due to a cold bulb detection.
I've tried to apply the codings you gave me; it won't allow me to set it due to an error ("Request out of range").
I have checked the wiring I have added myself. I actually measure a voltage so it has to be connected all the way, I think.
Jos
Jos
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
I've found out.ciclo wrote:Perhaps,firegrafik wrote: Now question is concerning headlight washer adaptation. What adaptation channels of 09 Cent.Eletr. change washer running time and frequency?![]()
Each 5 cycles (by pulling of wiper stalk) is set from factory.
It's just a suggestion (not tested), but now I have the curiosity about it. We will have to look for it.
The 09centr.electr adaptation channel 42 is define the quantity of wiper stalk's pulling to run the headlight washer. Next step is to find out how to change its running time
Iichel,
Thank you very much for your help!
I tried to apply most of your coding and found myself with partially working headlights. After modifying my coding byte by byte, I found the error in my coding.
If anyone else experiences issues with DRL, try the following:
Enable bit 4 in byte 22 (or change it to 0x10).
This fixed it for me!
graag gedaan
- R Line
- Drives: R Line TSI 1.2 (Mid 2013)
Hello Ciclo Hola, greetings from Barcelona, I`m Victor new to the forum, I have a 6R-Line June '13, to tell you I love your changes, thanks to you I replaced the MFA+Instrument cluster and MFSW R-Line. Now I want to change the automatic switch lights but not sure the part number that you used...5GG 941 431 D may be this? http://es.dhgate.com/product/olkswagen- ... 64842.html
Do you think that is compatible with the wiring they sell here?
https://www.x2car.de/Coming-Leaving-Hom ... egensensor
PD. I have from factory rain-light sensor, bi-xenon headlights, fog lights front/rear
Excuse my English
Best Regards
Gracias!
Excuse my English
Best Regards
Gracias!
karasovalye
- Drives: polo 6c papergray
hallo ciclo i bildt also a light and rain-sensor but i have a problem. i installed 3 cables 1 red+ 12 v 2 ground 3 cable to bcm T73 C 15 but i have make a connection
to B528 1 LIN-sBUS where can i find this cable. end what is line bus i now can bus but no lin- bus can jou help me please
Hello to all my dear friends around the world.
I'm still working with the renovations (reforms) at my home, I guess I'll not finish until early next month...
I just read all the messages (emails, forum replies, etc) that I have received over this month, just now it is impossible for me to answer this huge amount of emails-messages, I'm sorry honestly, without time due to different reasons it is impossible.
However, all emails are a great encouragement to finish as soon as possible with the work I am doing and come back with all you. Thank you very much to all
Regarding my car, nothing new, only to note that I passed ITV(SP) = MOT(UK) with favorable result.
This is the last autoscan I did before the ITV:
I come back soon... (early July) I guess.
Wednesday,08,June,2016,12:07:19:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.4.1
Data version: 20160216
http://www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: ITV
Mileage: 18790km-11675mi Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO Mileage: 18790km-11675miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 2686
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
ROD: EV_ECM12TFS02103F906070FJ.rod
VCID: 6A67323C071007E03A-803E
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 02FF02F46B1877387A-8056
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 38299E9647163342CA-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 100150209
Coding: 3CB02FBF48E1240093380E917CEB9FD0DAC0672F600D30D0200000030800
Shop #: WSC 03607 002 104857
VCID: 68593E2607E613F24A-803C
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 110215 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E338AB877341F949A-806A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A4772DC8770C7C03A-801E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405N1C4LI7929
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405B1D5MS8GS2
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB405B17ABS901.
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB405B181TUDPKC
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 572 91226
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 352A989F53194157E2-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 002200
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
VCID: 2E23AA8837C47F041A-807A
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0607
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A27B27C0FD087203A-807E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 37289C9543133545D2-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F20AC8DB7FB657D12-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77681C554B53B505D2-8022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3B3494A17B072DA9B2-806E
End-------------------------(Elapsed Time: 03:23)--------------------------
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Hi firegrafik,firegrafik wrote:Some time ago I retrofit exterior light wiring, make it through max BCM 7E0937090, installed the rain-light sensor and high-beam assistant(FLA).benzinkopf wrote:Tell us more. Havent got that working at all on mine so far.firegrafik wrote:New discovery.
Rain closing function works not only on a locked car. It works on unlocked car also.
Reports are below (unfortunately only on russian)
https://www.drive2.ru/l/8632361/
https://www.drive2.ru/l/9309752/
https://www.drive2.ru/l/10042246/
Can you share with us your coding for windows regulator motors coding?
firegrafik
No problem. There is one of my last autoscans below.benzinkopf wrote: Hi firegrafik,
Those door units are from factory
Friday,13,May,2016,15:07:39:10463
ВАСЯ -- программа для диагностики автомобилей концерна VAG запущена на Windows 7 x86
ВАСЯ Версия: 16.0.2.1
Версия данных: 20160226
VIN: XW8ZZZ61ZEGGRAFIK Номерной знак: С897ХУ
Пробег: 26340km-16366mi Номер заказ-наряда: 0013(RnClOff)
Шасси: 61 (7E0)
Список: 01 03 08 09 15 17 19 20 25 44 0B
VIN: XW8ZZZ61ZEGGRAFIK Пробег: 26340km-16366miles
01- Электроника двигателя -- Статус: OK 0000
03- Электроника тормозной системы -- Статус: OK 0000
04- Датчик угла поворота рулевого колеса -- Статус: OK 0000
08- Электроника кондиционера / отопителя -- Статус: OK 0000
09- Блок управления бортовой сети -- Статус: OK 0000
15- Подушки безопасности -- Статус: OK 0000
17- Комбинация приборов -- Статус: OK 0000
19- Диагностический интерфейс шин данных -- Статус: OK 0000
20- Ассистент управления дальним светом -- Статус: OK 0000
25- Иммобилайзер -- Статус: OK 0000
44- Усилитель руля -- Статус: OK 0000
Адрес 09: Блок управления бортовой сети (J519) Label: 7E0-937-BCM-V1.clb
Компонент: BCM PQ25 Max4 H80 0733
Ревизия: B9080001 Серийный номер: 0771 139150190
Кодировка: 22904ABF48E1240093380E007ECB16F000C8614F60842055220000030800
Мастерская #: WSC 12345 123 12345
VCID: 68D444B99B5B047D3E-803C
Подсистема 1 - Part No: 5K7 955 559 B Label: 5K7-955-559.CLB
Компонент: RLS 260215 03 37 0059
Кодировка: 0714DD
Подсистема 2 - Part No SW: 6R0 959 801 AG HW: 6R0 959 801 AG Label: 6R0-959-801.CLB
Компонент: ------------- 006 5530
Кодировка: 000000
Подсистема 3 - Part No SW: 6R0 959 802 AM HW: 6R0 959 802 AM Label: 6R0-959-802.CLB
Кодировка: 000000
Подсистема 4 - Part No: 1K8 951 171 A
Компонент: DWA-Sensor 00 001 0103
Кодировка: 000000
Подсистема 5 - Part No: 1K0 951 605 C
Компонент: LIN BACKUP HO H05 1501
Кодировка: 000000
Подсистема 6 - Part No: 1K8 951 171 A
Кодировка: 000000
Подсистема 7 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Компонент: E221__MFL-TAT H04 0019
Кодировка: 240000
Подсистема 8 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Кодировка: 020000
Подсистема 9 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Кодировка: 020000
Неисправности не найдены.-
benzinkopf
Oh. Now i can see ur door motor coding is all zero... Accept for the rear doors which is 020000. Hurmfiregrafik wrote:No problem. There is one of my last autoscans below.benzinkopf wrote: Hi firegrafik,
Friday,13,May,2016,15:07:39:10463 ВАСЯ -- программа для диагностики автомобилей концерна VAG запущена на Windows 7 x86 ВАСЯ Версия: 16.0.2.1 Версия данных: 20160226 программа для диагностики автомобилей концерна VAG запущена на Windows 7 x86 VIN: XW8ZZZ61ZEGGRAFIK Номерной знак: С897ХУ Пробег: 26340km-16366mi Номер заказ-наряда: 0013(RnClOff) -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Шасси: 61 (7E0) Список: 01 03 08 09 15 17 19 20 25 44 0B VIN: XW8ZZZ61ZEGGRAFIK Пробег: 26340km-16366miles 01- Электроника двигателя -- Статус: OK 0000 03- Электроника тормозной системы -- Статус: OK 0000 04- Датчик угла поворота рулевого колеса -- Статус: OK 0000 08- Электроника кондиционера / отопителя -- Статус: OK 0000 09- Блок управления бортовой сети -- Статус: OK 0000 15- Подушки безопасности -- Статус: OK 0000 17- Комбинация приборов -- Статус: OK 0000 19- Диагностический интерфейс шин данных -- Статус: OK 0000 20- Ассистент управления дальним светом -- Статус: OK 0000 25- Иммобилайзер -- Статус: OK 0000 44- Усилитель руля -- Статус: OK 0000 ------------------------------------------------------------------------------- Адрес 09: Блок управления бортовой сети (J519) Label: 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 HW: 7E0 937 090 Компонент: BCM PQ25 Max4 H80 0733 Ревизия: B9080001 Серийный номер: 0771 139150190 Кодировка: 22904ABF48E1240093380E007ECB16F000C8614F60842055220000030800 Мастерская #: WSC 12345 123 12345 VCID: 68D444B99B5B047D3E-803C Подсистема 1 - Part No: 5K7 955 559 B Label: 5K7-955-559.CLB Компонент: RLS 260215 03 37 0059 Кодировка: 0714DD Подсистема 2 - Part No SW: 6R0 959 801 AG HW: 6R0 959 801 AG Label: 6R0-959-801.CLB Компонент: ------------- 006 5530 Кодировка: 000000 Подсистема 3 - Part No SW: 6R0 959 802 AM HW: 6R0 959 802 AM Label: 6R0-959-802.CLB Компонент: ------------- 006 5530 Кодировка: 000000 Подсистема 4 - Part No: 1K8 951 171 A Компонент: DWA-Sensor 00 001 0103 Кодировка: 000000 Подсистема 5 - Part No: 1K0 951 605 C Компонент: LIN BACKUP HO H05 1501 Кодировка: 000000 Подсистема 6 - Part No: 1K8 951 171 A Компонент: DWA-Sensor 00 001 0103 Кодировка: 000000 Подсистема 7 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Компонент: E221__MFL-TAT H04 0019 Кодировка: 240000 Подсистема 8 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L Компонент: ------------- 006 5530 Кодировка: 020000 Подсистема 9 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L Компонент: ------------- 006 5530 Кодировка: 020000 Неисправности не найдены.
firegrafik
Yes, this fact embarrassed me to. Many polo owners in Russia tried to retrofit a high line door motors, changing the whole door harnesses, but stlill have not a positive result. Somebody wrote a guess that when you provide the door motor retrofitting, the door unit's correct coding not the most important procedure, it has to be adapted basically and in theory the official dealer this could provide.benzinkopf wrote: Oh. Now i can see ur door motor coding is all zero... Accept for the rear doors which is 020000. Hurm
benzinkopf
High line door motors? What that offers?
i guess the electric adjustable mirrors and the comfort function.
you probably already tried the many codings available in the autoscans. and the bcm 7E0 in firegrafiks car should support it for sure
