UK-POLOS.NET - THE VW Polo Forum • Polo 6R ABS CODING - Page 17
Page 17 of 35
Re: Polo 6R ABS CODING
Posted: Tue May 19, 2020 10:30 am
by joergleimbach
iichel wrote: Tue May 19, 2020 10:25 am Kannst Du bitte diese Kodierung probieren?
100228DB016E00B9082B14E480D600000000
not accepted
Posted: Tue May 19, 2020 10:35 am
by iichel
Okay, pity. Next try please: 110224db416E00B9882B24E482D600400700
Posted: Tue May 19, 2020 10:40 am
by joergleimbach
iichel wrote: Tue May 19, 2020 10:35 am Okay, pity. Next try please: 110224db416E00B9882B24E482D600400700
no
Posted: Tue May 19, 2020 10:45 am
by iichel
Next 110224db216E00B9882B24E484D600400700
Posted: Tue May 19, 2020 10:50 am
by joergleimbach
iichel wrote: Tue May 19, 2020 10:45 am Next 110224db216E00B9882B24E484D600400700
no, also got disc at the rear
Posted: Tue May 19, 2020 10:54 am
by iichel
Can you please read the advanced ID of the engine and the immobiliser using VCDS and post it?
What happened to this car to lose ABS coding?
Posted: Tue May 19, 2020 10:57 am
by joergleimbach
iichel wrote: Tue May 19, 2020 10:54 am Can you please read the advanced ID of the engine and the immobiliser using VCDS and post it?
Tried to change the instrument to the facelift one
Dienstag,19,Mai,2020,11:55:56:00009
VCDS Version: PCI 19.6.2
Adresse 01: Motorelektronik
Steuergerät-Teilenummer: 03E 906 023 M
Bauteil und/oder Version: SIMOS91 1.2l 4VG 2602
Codierung: 0000071
Betriebsnummer: WSC 06402
VCID: 295948A383F92B07D1-515A
Erweiterte Identifikation
Seriennummer:
Identifikation: SJ8-FST
Revision: --H04---
Datum: 02.03.09
Prüfstandsnummer: F405
Herstellernummer: 1237
Sonstiges
VCDS Info:
Labeldatei: DRV\03E-906-033-AZQ.lbl
Readiness: Skript nicht verfügbar
Dienstag,19,Mai,2020,11:56:41:00009
Adresse 25: Wegfahrsperre
Steuergerät-Teilenummer: 6J0 920 800 K
Bauteil und/oder Version: IMMO 017 0018
Codierung:
Betriebsnummer:
VCID: 2E53BBBF71174C3F04-807A
Erweiterte Identifikation/FAZIT
Seriennummer:
Identifikation: VO3-041
Datum: 25.02.09
Herstellernummer: 2070
Prüfstandsnummer: 0192
Flash Status
Flash Datum: 00.00.00
Software
BAP: 01.04.01
OSEK-OS: 03.14.00
Sonstiges
Hardwarenummer: 6J0 920 800 K
Systemkurzzeichen: J334
Bandende-Ausrüstungsstufe: ------------------
ASAM Datensatz: EV_Immo_UDS_VDD_RM09
ASAM Datensatz Revision: A03002
Fahrzeug Informationen
Fahrzeug-Ident.-Nr.: VSSZZZ6JZ9R117625
Wegfahrsperre
Transponder ID (Akt. Wert): B75EE9FD
Transponder ID 1: B78C7413
Transponder ID 2: B75EE9FD
VCDS Info:
Labeldatei: DRV\5K0-920-xxx-25.clb
ROD: EV_Immo_UDS_VDD_RM09.rod
Posted: Tue May 19, 2020 11:00 am
by iichel
Hm, did you align the instrument cluster so that the immobiliser starts the car? Is the car starting?
Try this as well: 110224db216E00B9882B24E484D600401700
Posted: Tue May 19, 2020 11:03 am
by joergleimbach
iichel wrote: Tue May 19, 2020 11:00 am Hm, did you align the instrument cluster so that the immobiliser starts the car? Is the car starting?
also not working
doesnt start with the new cluster, putted the old one back. car starts, runs fine ecept abs.
Posted: Tue May 19, 2020 11:09 am
by iichel
Have a look in your C:\Ross-Tech\VCDS\Logs folder to see if you have any scans there.
Posted: Tue May 19, 2020 11:11 am
by joergleimbach
iichel wrote: Tue May 19, 2020 11:09 am Have a look in your C:\Ross-Tech\VCDS\Logs folder to see if you have any scans there.
no, havent done a scan before :roll:
Posted: Tue May 19, 2020 11:13 am
by iichel
That's f****d up.
100224DB216E00B9082B24E484D600401100
130224DB216E00B9C82B24E484D600401100
Posted: Tue May 19, 2020 11:16 am
by joergleimbach
iichel wrote: Tue May 19, 2020 11:13 am That's f****d up.
doesnt work, you're right totally f....up. maybe the only way is to let do the seat dealer
Posted: Tue May 19, 2020 11:19 am
by iichel
Yes. Please tell me the coding if they can restore it.
Re: Polo 6R ABS CODING - 310 mm front and Drum at the rear
Posted: Fri May 22, 2020 5:21 pm
by theweekendmech
Hello Polo legends!
I have been a silent spectator so far since I always got answers by just reading through the posts but for this question, I'm not able to find a solution and I need your help! Please hear me out Firegrafik and Ciclo! or anybody that could answer my question.
So I just swapped the front brakes on my Right hand drive polo 6R GT TSI DSG 77KW here in india with the 310mm big brake kit. The rear are stock drums at this point ( would change them to dics sometime down the line) but im not able to figureout what coding matches this setup. My car has ESP 9.0. Please help! :?
Below is the logfile.
Friday,22,May,2020,07:35:23:39430
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WVWL14605FT045788 License Plate: TS07EH4714
Mileage: 36260km-22530mi Repair Order:
Chassis Type: 60-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWL14605FT045788 Mileage: 36260km-22530miles
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056230400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FD_004.rod
VCID: 6DDA367ABC0BF8EED0-8038
Readiness: 0000 0000
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6561
Revision: 00043014 Serial number: CU501406017060
Coding: 0000020
Shop #: WSC 57555 002 1048576
VCID: 3A70CD2675C59F5605-806E
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422703C5461B24714259C0800904
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 050A6EDA84BB20AE38-8050
Serial number: 13081404650582
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF80136E16D737679-802A
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 4084BFCED319C5864B-8014
Part No SW: 6R0 937 087 R HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0424
Revision: BF034001 Serial number: 0681 239142777
Coding: 3AB02BBF08A10000003800007C2B1C900040414F608C0000200000000000
Shop #: WSC 124697 483 00190
VCID: 4C9C9BFEEF5111E6A7-8018
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13102576140721151354
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13102579140827231158
Coding: 010000
Subsystem 3 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Serial number: 1131819474601393AJ1B
Coding: 250000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13102580140818085816
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581140821152328
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00VHBWD
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4992A2EAE82304CE9C-801C
Part No SW: 6RF 920 860 Q HW: 6RF 920 860 Q
Component: KOMBI H02 0152
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
VCID: 58B477AE23896D4613-800C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BF034001
Coding: 002300
VCID: 70E42F0EA3391506FB-8024
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 12
Reset counter: 255
Mileage: 28918 km
Time Indication: 0
Date: 2017.02.13
Time: 15:15:34
Component: IMMO H02 0152
Serial number:
VCID: 6AD03D668DE5EFD6B5-803E
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54AC839E3F614926FF-8000
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 V857
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 1E000440040000
Shop #: WSC 127395 840 08317
VCID: 4688A9D6F13DEBB671-8012
3 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 48
Reset counter: 43
Mileage: 34798 km
Time Indication: 0
Date: 2017.04.16
Time: 14:06:25
02873 - Control Module for Back-Up Camera (J772)
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 15
Mileage: 35886 km
Time Indication: 0
Date: 2017.05.18
Time: 16:57:37
01336 - Company Data Bus for Comfort System
Fault Priority: 6
Fault Frequency: 19
Reset counter: 40
Mileage: 29587 km
Time Indication: 0
Date: 2017.03.10
Time: 16:19:59
End-------------------------(Elapsed Time: 02:30)--------------------------
Address 19: DTCs cleared
