benzinkopf
Posts: 862 Joined: Wed Apr 02, 2014 4:01 pm
Drives: 1.2TSI 105HP DSG7
Post
by benzinkopf » Fri Apr 06, 2018 11:06 am
ciclo wrote: benzinkopf wrote: Thu Apr 05, 2018 2:16 pm
New mod(not really new. Just a cover)
I like it, it's clear that you master this art.
Thanks Ciclo. But Not really master my friend. I’m still on the learning curve. Actually I find that the red voltmeter really bright and sometimes it does attract my eyes too much. I thot, maybe that’s why you used the white version. That’s why I need the cover solution[emoji23]
Posts: 8837 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Fri Apr 06, 2018 7:03 pm
Ok, I found that the white color was nice for reading the voltmeter, in combination with the rest of the readings, navigator and MFA +.
benzinkopf
Post
by benzinkopf » Sun Apr 08, 2018 3:24 pm
Guys. Need help. I noticed my power windows re not working after ignition off. If not mistaken, there’s a delay to operate the power windows after shutting off the engine. I’m not sure where to start looking for the coding. Maybe it’s because last time I’ve been playing around with the WRM codings but right now, I already set back to original coding.
Posts: 6685 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Sun Apr 08, 2018 4:10 pm
I'm not sure. What is your current coding? Did you re-enable comfort function after coding WRM?
Post
by ciclo » Sun Apr 08, 2018 5:31 pm
iichel wrote: Sun Apr 08, 2018 4:10 pm
+1
benzinkopf
Post
by benzinkopf » Sun Apr 08, 2018 5:35 pm
iichel wrote: I'm not sure. What is your current coding? Did you re-enable comfort function after coding WRM?
I did re enable the comfort function, and all windows can work on one touch. Even the rain closing is working while the car is unlock within few minutes.
My current coding
801AD - 08BC30
802AB - 18BC30
811G - 08BC32
812G - 08BC32
benzinkopf on Sun Apr 08, 2018 5:59 pm, edited 1 time in total.
benzinkopf
Post
by benzinkopf » Sun Apr 08, 2018 5:50 pm
Wow. I feel like crying. Super master! thanks Ciclo. I will correct that one soon for sure!
Post
by ciclo » Sun Apr 08, 2018 5:55 pm
post a complete Autoscan.
You have letter and numbers exchanged in your previous message, which caused me to make an error and delete my reply.
benzinkopf
Post
by benzinkopf » Sun Apr 08, 2018 6:01 pm
Sorry. I did manage to read your last post that my coding for front WRMs are switched. btw
here's the full scan
Sunday,08,April,2018,09:54:16:15298
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ6RZCUBENZIN License Plate: BENZIN
Mileage: 232630km-144549mi Repair Order: 180408
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 44 55 56 77
VIN: WVWZZZ6RZCUBENZIN Mileage: 232630km-144549miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HF HW: 03F 907 309 J
Component: SIMOS10.22H03 2698
Revision: --H03--- Serial number:
Coding: 002500F6202400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS02103F906070HF 004004
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6DDBC694BCAA3C2CC3-8038
Readiness: 0000 0000
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230228E3416E00B4C42C14E382D800801700
Shop #: WSC 31414 790 31414
VCID: 0717943CB216F67C59-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326115E86D14A3D4DE-8066
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 259161638
Coding: 3CB02FBFC0A10E0013380F917CEB9ED9DAC0672F600D30D0200000130800
Shop #: WSC 12345 123 12345
VCID: 2A510D8845C4EB1466-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180812 05 54 0403
Coding: 07302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030061100013270
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001071100011802
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0032
Serial number: 0122863
Coding: 830000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU030061100015373
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU001071100015810
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301119600512
Coding: 108101
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D7B36D4AC4A6CAC33-8068
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00RY8XP
Coding: 003237
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A916D08ED84CB1486-801E
Serial number: 3575HRB405H0IRE2COP8
Serial number: 3585HRB405J0ISD6C8T3
Serial number: 3515RRB405J0LMIQ6PBL
Serial number: 3525RRB405H0LMIQCGRX
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140C01
Shop #: WSC 43155 842 00000
VCID: 4797543CFE96367C99-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 68D5B7809B481904B0-803C
Component: IMMO H05 0805
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1CD888D442B14A6-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660415697
Coding: 010000
VCID: 2953F28440C2E00C6F-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F671C9CEA268E3CB1-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0316000001000000
VCID: 77F7E4FCCEF686FC29-8022
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 051 0207
Revision: 00000001 Serial number: VWZ1Z3M8355342
Coding: 09000401020001
Shop #: WSC 01357 011 00200
VCID: 234FE0AC22EE3A5C25-8076
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663752927
Coding: 0A10000000010110
Shop #: WSC 43038 123 12345
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A713DC8BD645B9416-806E
End-------------------------(Elapsed Time: 03:26)--------------------------
Post
by ciclo » Sun Apr 08, 2018 6:07 pm
BCM coding is OK
WRMs coding are OK
set the comfort function as many times as necessary.
Post
by ciclo » Sun Apr 08, 2018 6:11 pm
Enter this BCM coding
3CB02FBFC8A10E0013380F917CEB9ED9DAC0672F600D30D0200000130800
sorry...
benzinkopf
Post
by benzinkopf » Sun Apr 08, 2018 6:21 pm
noted and thanks
Byte 4 bit 3....ok!
benzinkopf
Post
by benzinkopf » Mon Apr 09, 2018 4:21 pm
ciclo wrote: Enter this BCM coding
sorry...
Thanks Ciclo. It is working now. So I guess
Byte 4 Bit 3 = Power Windows operation delay after ignition off ???
Now, maybe, I did some changes in adaptation Channel that change the bit in the long coding as well, coz I can’t remember changing anything in byte 4 before.
Post
by ciclo » Tue Apr 10, 2018 4:09 am
LC; Byte4 Bit3 Power windows/sunroof enabled when Terminal 15 transition to OFF.
benzinkopf wrote: Mon Apr 09, 2018 4:21 pm
It's highly probable, some adaptation channels have magical powers.
benzinkopf
Post
by benzinkopf » Wed Apr 18, 2018 11:50 am
managed to install the levelling sensor today. Just to be confirm, is the sensor in the right position with car park in level position and no load?
