UK-POLOS.NET - THE VW Polo Forum • Auto headlight retrofit. VW Transporter. T5 (2010-2015) - Page 18
Page 18 of 45
Posted: Fri Aug 21, 2020 5:46 pm
by reido80
Hi Ciclo,
I have put this coding into BCM just now, many thanks for this, it is like a different van :D
Fault scan below
Current state of affairs-
Relay fitted, which is supposed to be a direct replacement for genuine VW 646 relay - Bosch 0332201107 - which I think is an 30/10 Amp, this is all I could get today after being messed about by another supplier. It works though.
ALWR wired in, apart from the sensors which are on order. Seems like my suspicions were correct, I think It is either the wrong one or I need to re code it somehow. (It was a gamble anyway). It wont accept the coding for VW t5 if I try to change it.
Left headlamp will be tested tomorrow, I may as well plug the loom in before I fit it to the bumper.
RLS, mirror etc not wired in, the wiring for this will be getting started tomorrow. I have decided to fit the good old W8 light mod which I wish I had planned for before I started but never mind. 8)
It will be another week or so before any of this is sorted, I'm still trying to sort out windscreen and a few other bits.
At least I now have confidence the wiring I have carried out seems to be correct, I have varied it slightly from your standard Plug and play set up as I have started with a messed up/bodged standard loom and no kufatec T10-T14 conversion harness so I was worried I might mess it up. There is no way I could have achieved any of this without yourself and this forum and for that I thank you and everyone else in this topic that has contributed. Especially as I am gatecrashing this forum, and someone else's topic for that matter :D
I hope to post later with some more info on what I have changed in the loom and put some pictures up etc.
I was messing about with some of the coding before you gave me the bcm code, so I might have to change some more to get rid of some of these fault codes.
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 55 69 0B
VIN: WV2ZZZ7HZDH0   Mileage: 130870km-81318miles
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 GK    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H37 3566
   Revision: 22H37---    Serial number: 00000000000000
   Coding: 0119401A233600080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906019GK 003003
   ROD: EV_ECM20BTD01103L906019GK_003.rod
   VCID: 7AADF0A04C5F927B1C7-802E
3 Faults Found:
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [039] - Signal too High
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:05:05
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 16 °C
                    Intake air temperature: 18 °C
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 12.320 V
                    Exh.gas temp.sen 1: 20.0 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 21.9 °C
                    Exh.gas temp.sen 4: 20.0 °C
                    Shut-off timer: last engine shut-off time: 312 s
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [167] - Intermittent
          MIL ON - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:05:05
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Standardized airflow ratio: filtered: 3.9999
                    EGR Solen.val.: actual value: 100.01 %
                    Throttle valve adapter: actual value: 104.35 %
                    Charge air pressure specified value: 1020 hPa
                    Charge air pressure: actual value: 986.0 hPa
                    Mean injection quantity: 0.00 mg/stroke
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [039] - Malfunction
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:05:05
                    Charge air pressure: actual value: 977.4 hPa
                    Intake air pressure sensor after air cleaner: raw value: 1150 hPa
                    Sensor for charge pressure between turbochargers: raw value: 980.6 hPa
                    Engine status: COENG_READY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108764AD19A6089626A99878AA6610
   Shop #: WSC 02756 790 49152
   VCID: 392F2FAC0959596355D-806C
   Part No SW: 7E5 907 047 BG    HW: 7E5 907 047 BG
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 75B7E39C6541FD03715-8020
2 Faults Found:
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 17
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:12:48
13701968 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
                    Fault Priority: 6
                    Fault Frequency: 9
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:05:02
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0725
   Revision: B9074001    Serial number: 0671 186141457
   Coding: B8B079B80E61241193284E716EEB97554280662F60857841320000020000
   Shop #: WSC 02739 790 12345
   VCID: 2F3B11F4C71D87D3FB9-807A
   Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3313
   Coding: 050000
   Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3313
   Coding: 050000
   Subsystem 3 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No: 7E1 951 172
   Subsystem 6 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0390005
   Coding: 820000
8 Faults Found:
03591 - Control Circuit for Horn
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 00:17:23
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 00:20:56
02746 - Bulb for Daytime Running Light; Right
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 00:20:56
00978 - Lamp for Low Beam; Left (M29)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 00:22:37
01495 - Bulb for High-Beams; Left (M30)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 01:14:35
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 01:14:35
03906 - Control Circuit for High Beam Relay
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 00:21:49
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 16
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 00:21:49
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261217200384
   Coding: 118001
   VCID: 392F2FAC09D9596355D-806C
1 Fault Found:
13632256 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Anhängererkennung-J345 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 03:28:55
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00CRH9K
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3537239C25C1BD03B15-8060
1 Fault Found:
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:05:05
   Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
   Component: KOMBI         H06 0605
   Coding: 160E00
   VCID: 2E050CF0C0978EDBF0F-807A
1 Fault Found:
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:05:03
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2411EED892DB348B16B-8070
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0725
   Revision: B9074001
   Coding: 042300
   VCID: 70B9D2881AA3D82BA23-8024
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.12
                    Time: 00:05:07
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000007
   Shop #: WSC 02756 790 00000
   VCID: 372B2994334D4F13A39-8062
   Component: IMMO          H06 0605
   Serial number:
   Shop #: WSC 12345 123 12345
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6A8DC0E03CFF22FBEC7-803E
   Revision: --------    Serial number: --------------
   Coding: 0312000001000000
   Shop #: WSC 00066 000 00000
   VCID: 77ABE9947F4D8F13639-8022
2 Faults Found:
5256725 - Rear Vehicle Height/Level Sensor
          C114E 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:06:13
5276949 - Positioning Motor for Headlight Range Left
          C1085 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.21
                    Time: 00:06:13
Address 69: Trailer
Cannot be reached
End----------(Elapsed Time: 02:07, VBatt start/end: 12.2V/12.2V)-----------
Posted: Fri Aug 21, 2020 6:59 pm
by ciclo
Hi reido80.
Well don't worry, this thread has become the auto lights and related issues thread for the Transporter, .. use it as much as you need it. :)
That Bosch relay is perfect, and it will perfectly fulfill its mission. 8)
The ALWR control unit must be parameterized for the two leveling sensors for the Transporter.
I'm afraid you have an ALWR unit for 6R and family, which have only one sensor (rear).
Unfortunately I don't have the data set to parameterize your ALWR unit for Transporter, I will look in VCP, but I think this dataset is not available.
It does not matter how many times you try to code it without success until your unit has the correct parameterization or you buy another ALWR unit in which you are completely sure that it comes from a Transporter (Bixenon).
Everything is on track, we will wait for the parts you ordered to arrive, install them, and thus see how your Autoscan improves.👍
Posted: Sun Aug 23, 2020 12:28 pm
by reido80
Nice one Ciclo, many thanks,
I have another ALWR module on its way, supposedly from a T5, so will give that a try and sell the current one.
I have tested both lights now and everything seems to be good.
I am going through all the redundant wiring to see what is live still.
I have noticed that the old SB5a and SB27a is still live when the headlamps are on.
This seems to be related to E4 dip flash switch.
I have looked at wiring diagrams 183/11 Halogen, 146/11 xenon and Fuse assignment 150/28.
It seems SB5a and SB27a are powered from E4 dip/flash T41/40. Do you think this pin can now be disconnected?
Posted: Sun Aug 23, 2020 8:06 pm
by ciclo
Yes, it is better to isolate the wire that reaches T41/40 or take out the SB5 and SB27 fuses so that the external redundant wires are not live.
With H7, Bixenon or/and Automatic lights the T41/40 wire in E4 has no function.
Posted: Wed Aug 26, 2020 11:42 am
by reido80
Thanks, that's what I will do then..perfect.
The Kufatec RLS harness instructions are telling me to wire in the Rain sensor pin3 to BCM T73b/33, however the wiring diagrams are showing to wire this in with the purple/yellow lin circuit that goes to T73b/24. (which I can connect to in various places).
T73b/33 is unpopulated and shows as "not assigned" in my BCM pinout diagram. The Kufatec instructions actually have no guidance on coding so i'm not sure if this pin 33 can be used?
Windscreen and other parts should be here by end of the week.
I noted in other posts here that there may be a need to run a wire between the bcm and reverse signal under the seat,(in order to get the reverse lights to operate or avoid fault codes i think) . I think my van already has this as my reverse lights work and also have no fault codes relating to this so hopefully this will save a bit of time etc.
Posted: Wed Aug 26, 2020 12:29 pm
by ciclo
RLS LIN = T73b/24
Regarding the reversing light, logically all the Van have this wire, but not all have it connected in the same way to the BCM.
- For BCM High the reverse signal reaches T73b/48, in this way the BCM controls only the F4 switch because that same wire is connected to the reverse light, leaving the reverse light without a BCM control of the bulb.
- For BCM Max the reverse signal enters through T73b/48 from F4 and leaves the BCM through T73b/12, in this way the light is controlled by the BCM. (plus F4)
If you do not have diagnostic problems due to the coding that I sent you, it is up to you to decide what you prefer for that bulb.
Posted: Thu Aug 27, 2020 1:04 pm
by reido80
Ahh, I see what you mean, that makes sense. I was wondering if it was because my electrics perhaps differed because I had Trailer electrics. I will run that wire then so it is also CAN controlled.
I am having a bit of trouble working out what I am supposed to do with the W8 light and the anti dazzle mirror wiring.
I have fitted the W8 light through the original T3 interior light plug as the norm for this modification. It seems to work as it should.
The Kufatec loom I have is not the correct one for some reason. The instructions say pin6 of the mirror is to be connected to pin6 of the interior light. Originally there is no pin 6 in my loom (but now there is in the W8 light) and there is no other plugs in the headlining.
The wiring diagrams 29/3 say to connect pin 6 of the mirror to the red black wire. On the W8 light mod I have the red black wire going into W8 light pin 5.
I cant work out what The W8 light pin 6 does or what I am supposed to do with the mirror wire.
I have crimped (with MQS) the RLS pin3 wire to the alarm interior monitor wire (purple yellow) which ends up at the correct bcm pin t73b/24.
Sorry to keep asking questions, I think i have fried my head looking at wiring diagrams for this part lol.
Next time I attempt something like this, I dont think I will bother with kufatec looms, so far it has cost me time and I have ended up modifying them anyway.
I have the windscreen now so will get that arranged for next week.
Posted: Thu Aug 27, 2020 7:28 pm
by ciclo
You have connected the LIN for RLS in the right place.👍
Regarding the kufatec wiring, look at the following image, but you must ignore the Adapter I made for a fabia VRS.
You have to connect the individual wire to a 58d signal.
If you look at the auto lights wiring diagram I made for T5 you will find the 58d signal. viewtopic.php?f=56&t=70736&start=45#p528663
Perhaps the best place to take this signal is the coupling.
It is used so that when you use the knurled knob of the dimmer, the intensity of the 2 red lights included in the W8 dome lights is also regulated.
Posted: Sun Aug 30, 2020 6:10 pm
by reido80
New scan -
Sunday,30,August,2020,18:07:46:03258
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZDH0   License Plate: TEST4
Mileage: 130870km-81318mi   Repair Order:
   Revision: 00H43001
   Coding: 108764AD19A6089626A99878BA6610
   Revision: 00001010
   Coding: 0000000002
   Coding: B8B079B84E61241193284EF16CAB9751F28066FF60857841320000020000
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 201114 05  54  0403
   Coding: 0230AD
   Subsystem 2 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Coding: 050000
   Subsystem 3 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Coding: 050000
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Coding: 820000
   Coding: 118001
1 Fault Found:
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Date: 2020.08.30
                    Time: 00:40:03
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.30
                    Time: 00:40:04
   Coding: 160E01
   Coding: 0000031
   Revision: B9074001
   Coding: 042300
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.21
                    Time: 00:40:06
   Coding: 0000007
   Serial number:
   Coding: 0222000001000000
   Shop #: WSC 02757 790 50316
2 Faults Found:
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Date: 2020.08.30
                    Time: 00:40:03
13705473 - Databus
          U1121 00 [137] - Missing Message
          [Timeout mNiveau_2]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Date: 2020.08.30
                    Time: 00:40:02
Address 69: Trailer
Cannot be reached
End----(Elapsed Time: 02:13, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Posted: Sun Aug 30, 2020 7:47 pm
by ciclo
Wow! ... this improves a lot! 8)
I suppose there are still some parts to arrive or not installed ...
Nice job!👍
Posted: Sun Aug 30, 2020 11:18 pm
by reido80
Yes, just now there are no level sensors connected. Still to wire in reverse wire between bcm and green plug.
Other parts like trailer electrics will be plugged back in when seats go back in. ( i will actually plug that in tomorrow to test the fault code goes away)
Roof harness very much still hanging wires waiting to be tidied up when the windscreen is fitted. I had the rls and mirror connected and tested though👍.
Getting there slowly but surely 👍
When i wired in the new T10 light switch I took a feed from the Original +15 fuse in vw wiring diagrams. This meant i could use the 2 +15(x75) black/yellow T17 wires for the new ignition fed fuses. I used a T2 connector and diverted them behind the bcm to the new fuse location.
I tapped into the 58d feed for pin 1 of W8 light at the dimmer switch as it was easier with the connectors I had left and wiring diameters.
Pin6 for dimming mirror did indeed connect to pin 6 on the w8 light. I dont actually need the mirror to dim at all as i have no back window! All wired in just incase I decide to fit a back window in the future👍 The mirror will be handy to keep an eye on the little one.
I found more lazy installation of cables as i peel back interior panels, some bad routing of reverse camera and bodged stereo wiring etc, takes more time to sort these things out than anything else. Worthwhile job to sort it out though.
Many thanks for your help 👍
Posted: Mon Aug 31, 2020 7:20 pm
by reido80
still no level sensors plugged in, running the rear wiring just now.
RLS and mirror unplugged.
Trailer module plugged in to test
Reverse wire between t73b/12 and under seat plug now done. old pin isolated.
Edit* Just checked battery voltage and it is low so going to give it a charge.
Edit2* The brake light fault is the centre high level brake light unit. looking into that now.
Scan-
VIN: WV2ZZZ7HZDH0   License Plate: TEST5
69-Trailer -- Status: Sporadic communication error 1000
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
   Coding: 050000
   Coding: 050000
   Coding: 820000
4 Faults Found:
01758 - Bulbs for Brake Lamps
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.22
                    Time: 00:00:03
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.22
                    Time: 00:00:02
03432 - Activation of Right Parking Light
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.22
                    Time: 00:00:02
01520 - Rain and Light Recognition Sensor (G397)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.22
                    Time: 01:16:48
   Coding: 118001
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.31
                    Time: 00:40:04
   Coding: 160E01
   Coding: 0000031
   Revision: B9074001
   Coding: 042300
1 Fault Found:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.22
                    Time: 00:40:06
   Coding: 0000007
   Serial number:
2 Faults Found:
5275220 - Headlight
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Date: 2020.08.31
                    Time: 00:40:03
13705473 - Databus
          [Timeout mNiveau_2]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Date: 2020.08.31
                    Time: 00:40:02
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00008030224120
   Coding: 410D000101000000
   VCID: 313F178CD1299123EDD-8064
End----(Elapsed Time: 01:56, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
Posted: Tue Sep 01, 2020 1:15 pm
by reido80
So after a charge and a reset of DTC codes the trailer fault in can gateway has gone, hopefully it was just because it had been disconnected and reconnected etc.
The centre brake light fault is corrosion in the plug so a new light and T2 plug has been ordered.
I have still to determine the best route for rear level sensor wiring. Not sure what the OEM route is. Just now I am bringing it up A pillar and along roof to the rear then it will drop down and come out through the wheel arch, hopefully there is enough length in the loom.
latest scan-
Tuesday,01,September,2020,13:03:41:03258
www.Ross-Tech.com
VIN: WV2ZZZ7HZDH0   License Plate: TEST6
69-Trailer -- Status: OK 0000
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
   Coding: 050000
   Coding: 050000
   Coding: 820000
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.23
                    Time: 18:49:53
   Coding: 118001
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.09.01
                    Time: 18:49:51
   Coding: 160E01
   Coding: 0000031
   Revision: B9074001
   Coding: 042300
   Coding: 0000007
   Serial number:
2 Faults Found:
5275220 - Headlight
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Date: 2020.09.01
                    Time: 18:49:50
13705473 - Databus
          [Timeout mNiveau_2]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 130877 km
                    Date: 2020.09.01
                    Time: 18:49:49
End----------(Elapsed Time: 01:54, VBatt start/end: 12.7V/12.6V)-----------
Posted: Fri Sep 04, 2020 3:35 am
by ciclo
... good tests, everything progresses properly.👍
Posted: Mon Sep 14, 2020 12:27 am
by bropasiek
Hi guys,
I hope you can help me, I did retrofit Xenon + auto lights to my 2011 Caravelle. I did follow Ciclo’s guide for Graylscott and I am getting some issues. I dont know if they might be related to that I still waiting for a new dimmer switch 6Q0941334 or bad coding. All the wiring is definitely connected as I Ciclo’s giude
Issues:
DRL work when light switch on 0
Only one LED lights up very slightly when light switch on AUTO or main beam position
DRL’s dont work at all on sidelight position
High beam dont stay on, both ways it flashes, no DRL’s as well
Fog lights front + corner lights work
Rear fog works
Number plate light works
Rear lights stay on when I remove key from ignition, unless switch was on 0, then its fine
All buttons ilumination stays on as well
I have to disconnect negative terminal every time and put it back on for them to switch off
Thanks in advance
Lucas
