RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Jerryncg93
- Drives: Volkswagen Vento 1.2 tsi
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Confirmed have wires in all 10 slots.
Jerryncg93
can you guide me on this?Jerryncg93 wrote: Mon Jul 08, 2019 11:13 am As the previous set of rls doesn't work very well, the seller has sent me another set of rls. This time it's 5k7 955 559b, but the sensor seems to be very dirty, may I know how can I clean it up?
What kind of glue should I use to paste the bracket to my windscreen? I'm planning to stick a black sticker with the shape of the cover then paste the bracket onto the sticker, dunno if it works?
Clean the gel foil for the rain sensor with distilled/clean water.
-Do not use cloth, use your finger moistened abundantly with distilled water.
-Do not touch the gel foil with dry fingers.
-Prevent water from coming into contact with the electronic part of the sensor.
-Dry with air if required.
The procedure you have in mind to stick the bracket is not appropriate, it will not work. The black sticker can not hold the weight of the mirror.
Examples:
viewtopic.php?f=56&t=58703&p=502496#p502568
viewtopic.php?f=56&t=70545&hilit=slavik ... 90#p534599
Look for more information with your browser.
Primer and glue (2k).
Examples:
Jerryncg93
Is the primer makes the area black in color? I can't find the original 2k glue here in Malaysia, perhaps i'll go for aftermarket brands for it.ciclo wrote: Wed Jul 10, 2019 8:20 am Clean the gel foil for the rain sensor with distilled/clean water.
Examples:
Jerryncg93
Can I have your email or telegram/whatsapp please? Easier to communicate.ciclo wrote: Wed Jul 10, 2019 8:20 am Clean the gel foil for the rain sensor with distilled/clean water.
Examples:
You are hijacking this thread, please open your thread.
There are many people who can help you, I dont have to be the only one to help you.
Jerryncg93
For Shardul's friend:
1- IMP: Please read the information contained in the previous image. Thanks.
2- Installation guide: https://drive.google.com/file/d/1a85zOl ... sp=sharing.
All the information of payment and shipping processes by email. (as always)
Shardul, now I will send the information to your email. Greetings.
About the new codings for Vishwajeet 6R
New RLS coding (5K7)
0728DD
New BCM Max coding (LED headlights)
When the new wiring looms has been installed you have to tell me the type of bulbs/lights installed just at that moment.
I can do a BCM coding for LED headlights at this time, but it makes no sense because it all depends on the moment of the installation process that you have completed.
0728DD
Jerryncg93
I've tried the coding 0728DD on the 5k7955559B rls, it says code accepted, but when I close and reopen, it remains the same coding as before. Is there any problem with my rls?
Also, when I put it on auto mode, the headlight will switch on, but the instrument cluster, and some other lights wouldn't switch on as the previous thread.
I will not give you help until you open a new thread. I've told you three times.
Your problems with RLS have easy answers.
Please don't use the threads of other users. Thank you.
Jerryncg93
Sorry, I don't understand you previously. I will open a new thread.ciclo wrote: Sat Aug 03, 2019 10:06 am I will not give you help until you open a new thread. I've told you three times.
smg_shardul
- Drives: Polo 6R
ciclo wrote: Thu Aug 01, 2019 6:16 am About the new codings for Vishwajeet 6R
0728DD
Hey ciclo how are you?
Due to floods in our city installation is delayed
Today we finished with all wiring, car assembly is in progress
Few terminals of bcm are not getting locked in T73 Connector , I am attaching pic of the the terminal. I am about to receive LED Light BCM, can I use regular BCM Max till I receive the led BCM?
If so what coding I should use to work led lights with BCM Max
Some reason is there for the terminals not to be blocked. No matter, with a cutter, slightly open the terminal locking tabs so that they perform their blocking function in the connector slot.
New BCM Max coding for LED headlights, etc (Vishwajeet):
3AB02BBF48A10000013806906CEB96900000604F60CD3961210000030020
New RLS coding:
0728DD
Nothing will break if you install a BCM Max that does not support LED headlights.
New RLS coding:
0728DD
Email from shardul.
Hello Shardul, everything is correct regarding the electrical installations and coding mentioned.
Except:
- The CCS is activated in the BCM, but not in the ECU.
- Please, can you explain to me why you have Byte0 Bit4 enabled in the Gateway?
I ask you my sincere apologies for the time it took to answer your request by email, I am trying to respond to all those emails that have a technical character.
I'm sorry with all my heart.
smg_shardul wrote: Mon Sep 09, 2019 10:40 am
We have installed your wires in Vishwajeet Polo in august itself but full installation was pending due to shortage of auto light switch & RLS Sensor & BCM Max for LED lights.
Finally we have arranged all required parts & installation is completed today
We have upgraded following things
1) BCM Max
2) GTi Full LED Headlamp.
3) Frameless Auto dimming mirror
4) RLS Sensor.
5) Auto Switch.
6) Coming home / Leaving Home
7) Dimmer Switch.
Please find the attached file for latest VCDS Scans report and let me know if i require any changes in coding of BCM.
Thursday,21,May,2020,17:50:12:00009 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.1.0 (x64) Data version: 20190529 DS308.0 www.Ross-Tech.com VIN: WVWE1460XFT0XXXXX License Plate: VISHWAJEET LATEST Mileage: 72490km-45043mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 60-VW25 (7E0) Scan: 01 03 08 09 15 17 19 25 44 VIN: WVWE1460XFT0XXXXX Mileage: 72490km-45043miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CWXA) Labels: None Part No SW: 03L 906 023 QT HW: 03L 907 425 B Component: R4 1.5l TDI H33 9977 Revision: --H33--- Serial number: Coding: 00110116030500080000 Shop #: WSC 01234 785 00200 ASAM Dataset: EV_ECM15TDI02103L906023QT 001004 ROD: EV_ECM15TDI02103L906023QT.rod VCID: 081F2D27B333320FD1-805C No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: Redir Fail! Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ Component: ABS9.0 front H01 0001 Serial number: -------------- Coding: 60DD2763412418C0061CE46B825218020000 Shop #: WSC 01234 785 00200 ASAM Dataset: EV_Brake1ABS90BOSCH 003017 ROD: EV_Brake1ABS90BOSCH_VW25.rod VCID: 03053A0B8A15115784-8056 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb Part No SW: 6R0 907 044 P HW: 6R0 907 044 P Component: Climatronic H12 0614 Revision: V0000000 VCID: 408FF507D383CA4FD9-8014 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 E HW: 7E0 937 090 E Component: BCM PQ25 Max4 H84 0772 Revision: B9084001 Serial number: 2502 179190141 Coding: 3A904BBF48A10000013807007ECB9E901080606F60CD79F1210400030020 Shop #: WSC 12345 123 12345 VCID: 2D51BCB37411372702-8078 Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB Component: RLS 220517 04 42 0106 Coding: 0728DD Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB Component: ------------- 006 5550 Serial number: 13102576140311183853 Coding: 010000 Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB Component: ------------- 006 5550 Serial number: 13202579140318223016 Coding: 010000 Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Component: E221__MFL-TAT H03 0015 Serial number: 1181417463701494AB1B Coding: 240000 Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L Component: ------------- 006 5550 Serial number: 13102580140305104947 Coding: 020000 Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L Component: ------------- 006 5550 Serial number: 13102581140325052359 Coding: 020000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 6R0 959 655 J HW: 6R0 959 655 J Component: VW10AirbagU06 H10 0020 Revision: -------- Serial number: 003GW00SWL58 Coding: 003036 Shop #: WSC 01234 785 00200 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250.rod VCID: 4999E823E8B90B070E-801C No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 6RF 920 860 P HW: 6RF 920 860 P Component: KOMBI H02 0152 Serial number: 00000000000000 Coding: 150800 Shop #: WSC 01234 785 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719 ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod VCID: 57BD3E5B2E0D6DF788-8002 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb Part No SW: 7E0 909 901 HW: 7E0 937 090 E Component: GW-K-CAN TP20 H84 0772 Revision: B9084001 Coding: 102300 Shop #: WSC 12345 123 12345 VCID: 68DF0DA79B73D20F31-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H02 0152 Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709 ROD: EV_Immo_UDS_VDD_RM09.rod VCID: 6ADB77AF8D7FE01F27-803E No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb Part No SW: 6RF 909 144 K HW: 6RF 909 144 J Component: EPS_ECU H44 0401 Coding: 0000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SteerAssisUDSNSK 005005 ROD: EV_SteerAssisUDSNSK.rod VCID: 54A7C9573FFB46EF6D-8000 No fault code found. End-------------------------(Elapsed Time: 02:07)--------------------------
Except:
