RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
smg_shardul
Drives: Polo 6R
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Post by smg_shardul »
ciclo wrote: Fri May 29, 2020 2:46 am Email from shardul. :wink:
smg_shardul wrote: Mon Sep 09, 2019 10:40 am
We have installed your wires in Vishwajeet Polo in august itself but full installation was pending due to shortage of auto light switch & RLS Sensor & BCM Max for LED lights.
Finally we have arranged all required parts & installation is completed today
We have upgraded following things
1) BCM Max
2) GTi Full LED Headlamp.
3) Frameless Auto dimming mirror
4) RLS Sensor.
5) Auto Switch.
6) Coming home / Leaving Home
7) Dimmer Switch.
Please find the attached file for latest VCDS Scans report and let me know if i require any changes in coding of BCM.
 Thursday,21,May,2020,17:50:12:00009
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWE1460XFT0XXXXX   License Plate: VISHWAJEET LATEST
Mileage: 72490km-45043mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 08 09 15 17 19 25 44
VIN: WVWE1460XFT0XXXXX   Mileage: 72490km-45043miles
Address 01: Engine (J623-CWXA)       Labels: None
   Part No SW: 03L 906 023 QT    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116030500080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM15TDI02103L906023QT 001004
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 081F2D27B333320FD1-805C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 BF    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0001
   Serial number: --------------
   Coding: 60DD2763412418C0061CE46B825218020000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 03053A0B8A15115784-8056
   Part No SW: 6R0 907 044 P    HW: 6R0 907 044 P
   Component: Climatronic   H12 0614
   Revision: V0000000
   VCID: 408FF507D383CA4FD9-8014
   Revision: B9084001    Serial number: 2502 179190141
   Coding: 3A904BBF48A10000013807007ECB9E901080606F60CD79F1210400030020
   Shop #: WSC 12345 123 12345
   VCID: 2D51BCB37411372702-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 220517 04  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5550
   Serial number: 13102576140311183853
   Coding: 010000
   Subsystem 3 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH  Labels: 6R0-959-801.CLB
   Serial number: 13202579140318223016
   Coding: 010000
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H03 0015
   Serial number: 1181417463701494AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Serial number: 13102580140305104947
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581140325052359
   Coding: 020000
   Revision: --------    Serial number: 003GW00SWL58
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999E823E8B90B070E-801C
   Part No SW: 6RF 920 860 P    HW: 6RF 920 860 P
   Component: KOMBI         H02 0152
   Coding: 150800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
   VCID: 57BD3E5B2E0D6DF788-8002
   Revision: B9084001
   Coding: 102300
   VCID: 68DF0DA79B73D20F31-803C
   Component: IMMO          H02 0152
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB77AF8D7FE01F27-803E
Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 K    HW: 6RF 909 144 J
   Component: EPS_ECU       H44 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 54A7C9573FFB46EF6D-8000
End-------------------------(Elapsed Time: 02:07)--------------------------
8) 8)
Hello Shardul, everything is correct regarding the electrical installations and coding mentioned.
Except:
- The CCS is activated in the BCM, but not in the ECU. :?:
- Please, can you explain to me why you have Byte0 Bit4 enabled in the Gateway?
I ask you my sincere apologies for the time it took to answer your request by email, I am trying to respond to all those emails that have a technical character.
I'm sorry with all my heart.💗
I will check about CCS , it must be activated from first in BCM .
I will check this & revert you, CCS is not installed in the car .
What should be gateway coding it should be 052300?
BCM coding without CCS:
3A904BBF48A10000013807007ECB9E901000606F60CD79F1210400030020
GW coding:
002300
or 002304 with fatigue detection (MKE).
