ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Kiogen,
Your real problem is that your current BCM does not have the necessary pins (T73a / 1, T73a / 2, T73a / 63, T73a / 37, T73b / 1, T73b / 2, T73b / 68, etc ...) to manage automatic lights.
Conclusion, you need to change the BCM and the electrical original wires configuration.
I can not see the images from your previous reply.
To everyone: :)
I can not answer all the emails I have received (a issue of time)... I'm so sorry ... Please be patient, I have read all them (this is a crazy :lol: ), everything is controlled and managed.
Tomorrow it also is impossible, I'm traveling.
Thanks for your patience and understanding. :wink:
Kiogen
Drives: Seat Ibiza 6J
Post by Kiogen »
ciclo wrote:Kiogen,
To everyone: :)
I will remove my BCM again as soon as i can, i have the T73a/37 present and i have a wire there already that i fit, i dont remember if i have all the others but next time i will take a picture, the BCM is not a problem for me as i can get another one any time, i just want to know if im going in the right direction as i want to make all the wiring changes before fitting a new BCM.
i think that the images are already working
Kiogen wrote: I will remove my BCM again as soon as i can, i have the T73a/37 present and i have a wire there already that i fit, i dont remember if i have all the others but next time i will take a picture, the BCM is not a problem for me as i can get another one any time, i just want to know if im going in the right direction as i want to make all the wiring changes before fitting a new BCM.
Image.... :lol:
Bachecco
Drives: Polo 1.2
Post by Bachecco »
ciclo wrote:
CNK wrote:
ciclo wrote:6R GTI, BlueGT and R-line have different fog lamps.
Check it in ETKA online.
Yes, Fog lights with DRL — Polo 6R R-Line: 6R0 941 061 E + 6R0 941 062 E (https://www.drive2.ru/l/458163472711033418/) ;)
Thanks CNK.
IIRC Bachecco has bixenon headlights :?:... :lol:
In such case: Polo 6R R-Line: 6R0 941 061 F + 6R0 941 062 F (on eBay.de there is a good deal)
thank you very much, I have bixenon headlights, then I will buy the new fog
Inviato dal mio iPhone utilizzando Tapatalk
TPMS (info) only :lol:
Previously... (excellent info) :arrow: viewtopic.php?f=56&t=58703&start=2835#p516356
Now... (Found by Adam87 in ETKA)
AMAROK 2018 (preliminary study)
7K3 -- (RDK) Tire pressure control, frequency 433 MHz high level version
I suppose it will also be necessary to edit the unit/EEPROM for the wheel sizes. :arrow: Similar to this :)
7E0937090B
Works like a charm... with Bixenon Headlights. All functions: All functions that worked with the previous 7E0937090 BCM. NEW? Still to be discovered, something :lol: I have seen in the Gateway and BCM adaptation channels... this first contact was only for its installation and check its correct operation. 8)
Saturday,21,January,2017,14:10:32:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.1.2
Data version: 20170107 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: 7E0937090B
Mileage:    Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A5F3A240F181F97E7-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02F70AFC63E08FBF27-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7E6B12607F7C972307-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3821A69E5F1E4B3577-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FBF48E1240093380ED1FCEB9FD1DAC067AF600D30D0200000030800
   Shop #: WSC 12345 123 12345
   VCID: 2A1FBA6407D89F57E7-807E
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E2B92A07F3C17E307-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A3F7AC48F78DFB7E7-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   VCID: 3522A0875BE159204F-8060
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 6851462E1FEE2B85F7-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E1BB2703FCC777387-807A
   Component: IMMO          H05 0607
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 3720A49D5B1B4D327F-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F18B475AFC37D7ABF-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 7760245D535BCD727F-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B2C9CA9430F25CE1F-806E
End-------------------------(Elapsed Time: 04:15)--------------------------
My thanks to firegrafik who made the necessary arrangements and much more. Excellent! Image
По циклу :wink:
Kiogen
Post by Kiogen »
today i took my BCM out again, it confirms what Ciclo said, my BCM doesnt have the necessary pins, the other time i took it out i've mistaken myself when counting the pins as it was the first time messing with this kind of stuff, now i can see the missing pins with much ease.
im now trying to fully understand elsawin schematics and only i'll ask something if im really out of options/ideas.
Kiogen
The basic principle is the same (J331 relay) :arrow: https://drive.google.com/file/d/0B2nv91 ... ZQN1U/view , but your fuses are different (other numbering)
You do not have to make the wiring for Automatic lights (from 17 to 10 pin) because the Seat Ibiza have a 17-pin Light Switch with the 'AUTO' function.
Do not hesitate to ask if you have problems with the diagrams. :wink:
You must keep in mind that the final result is a combination between the wires correctly installed and BCM coding.
Edit, more info:
You do not have to modify the original wiring installation of your front fog lamps (T17/8).
You also need the Additiotinal Relay (J828) for headlights - search on elsawin this relay-
For the rest of the Wires/Pins/Slots also look here:
Kiogen
Post by Kiogen »
So, if im not wrong you're comparing on the same year but different PR codes? 7L3 are for cars without start/stop like mine, 7L6 are cars with start/stop, does it mean that every car with start/stop got "AUTO"?
Today i've made some printscreening on ELSA, so that i can see how big the differences are and i think i've got a decent JPEG with only the wires that i have to add or modify, can you check it?
https://drive.google.com/file/d/0B6FlhY ... sp=sharing
Does the PDF guide that you post only serves for polo or if i follow it will also work?
The thing confuses me is when there are multiple wires in the same spot, like fuse SC7b that right now is connected to A88 that is connected to T6/6 and T32/13.
When doing the changes i should add a wire from A88 to T73a/6 right?
But if following the SC7a it connects to T17/9 right now i must also add a wire from T73b/43?
Example for rear fog light:
https://drive.google.com/open?id=0B2nv9 ... ExRMlR2VlU
Kiogen wrote:So, if im not wrong you're comparing on the same year but different PR codes? Yes
7L3 are for cars without start/stop like mine, 7L6 are cars with start/stop, does it mean that every car with start/stop got "AUTO"? The explanation would be too long ... Three years of knowledges.
Depends on the equipment installed, Model Year, etc...
It's OK but no it's full (DRLs, Coming home from factory -Relay/control unit J665-?), you must open a new topic in the Ibiza section. Example: Kiogen's Ibiza SC 2.0TDI
Post there all possible info, pictures from your Ibiza, Autoscan, etc ... Please, also post the pictures of connectors, relay carrier, fusebox, etc ... (logically, I'm not soothsayer :lol: ). It is necessary to know the factory equipment that your Ibiza has installed and that it is not possible to know it with the Autoscan because it depends on other factors. (MY, mods, etc...). For example, I can guess that the xenon headlight model has changed over the years in your Ibiza model, right?
If you have patience and time this will be solved. We'll do the same like example above with all lights.
Does the PDF guide that you post only serves for polo (yes) or if i follow it will also work? No
Look the above example.
Please, post here the link to your new topic.
seinarith nou
Drives: polo 6R 1.6 tdi dsg7 90cv---140cv
Post by seinarith nou »
Hello ciclo I would buy AUTO lights. CH / LH. OEM. I live in France . I could pay by paypal thank you cordially
seinarith nou wrote:Hello ciclo I would buy AUTO lights. CH / LH. OEM. I live in France . I could pay by paypal thank you cordially
Hello seinarith nou. Welcome.
Ok, but first, please, can you send me a VCDS autoscan to my email? Thank you.
...and please read here :arrow: A- Automatic lights wiring + CH/LH for you to know the price, shipping details, installation guide, tool, etc ...
Kiogen
Post by Kiogen »
Thank you very much ciclo, you have been very helpfull.
I don't think the xenon has changed, there are 3 different headlights. Mine, one with half black background and other with full black background, then came the facelift that has a completly different headlight with LED drl, mine are halogen drl.
But not 100%sure.
I do have CH on mine but have to flash the highbeam before opening the door. My CH uses the fogs.
Im working on the Ibiza topic, just need to take some pictures then will leave the link.
Kiogen wrote:Thank you very much ciclo, you have been very helpfull.
But not 100%sure.
Right. They were changed to LED drl's from February 2012.
Kiogen wrote: I do have CH on mine but have to flash the highbeam before opening the door. My CH uses the fogs.
The function of the relay/control unit J665 can be managed by the BCM Max. So you will have to remove this relay, it will have to be studied carefully.
CH function is also semiautomatic with the BCM Max (in the same way). Only LH function is automatic, apart from the Automatic Lights.
Kiogen wrote: Im working on the Ibiza topic, just need to take some pictures then will leave the link.
Excellent! I'll subscribe. It is something new and very interesting. :wink:
I'll have you know that it took me the best part of three years to figure out that 'ciclo' is basically 'bike' in English.
And I have a t-shirt and a pillow with a bike on it. And secretly a headwarmer with "I [heart] [bike]'.
I guess I'm secretly a big fan....
:oops:
edit:
Locked
