cheers matey, i think i was being a plum and didn't have the ignition switched on. il have a go during the day.dub6n2 wrote:plug the cable, switch the ignition and then from the options check that you have the working COM Port chosen by running the test. if it is giving you that error either the ignition is not switched on or the wrong port is chosen. and preferably always choose the same USB port or else you will have to continually change the COM port setting
thanks for the help
