POLO 6R. HEATED SEATS. OEM.
Re: POLO 6R. HEATED SEATS. OEM.
I've Ordered the loom from Kufatec, Bought the original heated seat switches and Module.
Connected Wire A36 to Connector A (pin 36) to BCM module, Power and earth to appropriate points. Plugged in switches and connected up aftermarket heat pads to the connectors that run under each seat, switch lights up for a moment and then doesn't work.
1. do I need original skoda heated seat elements
2. did not understand the heating regulator part, is this part of original heating element
3. Can I use aftermarket heating elements
4. any additional wiring required
Model Year of your...? 6R or 6C?emmanuel.hadji wrote:Hi,
I did the retrofit as well and would thanks for all the info found here.
I'm now stuck with the same step than the one mentionned by Lukas : seats able to work while ignition is off.
I my case slot 47 was not feed in the fuse-box and the only free slots available were permenent plus.
I'm a bit lost on how to get electrical connection in a clean way with an ignition switched plus within the fuse box ??
Hoppe this isn't a to naive question.
Help would be greatly appreciated.
Do you have a pic from your fusebox?
1. Surely.r7jay wrote:I've Ordered the loom from Kufatec, Bought the original heated seat switches and Module.
2. What exactly do you mean by the heating regulator part?
3. Probably not.
4. No, only the one indicated in the diagrams (first page).
In this case the original parts are highly recommended. (VW, Skoda, etc...)
- habib_123
- Drives: Polo 6R 2012 1.2TDI RHD
Could anyone help me, I've purchased the loom from Kufatec, however, there are two connectors on there which I do not understand where they go. One has no connector on there and the other has a connector but I think it goes into BCM, could anyone confirm? If it does which pin does it go into?
I have attached the photos. Any help will be greatly appreciated.
https://www.youtube.com/watch?v=uT1l6eQA-PA
0.55 - connector 1
1:10 - Connector 2 (The exposed cable)
20mb image hosting
Thank You
0.55 - connector 1
20mb image hosting
Thank You
- habib_123
Thanks Ciclo!
I really appreciate it!
Grizzlydean
- Drives: Polo 6n2
Ive read your post alot, i have a few questions..
Can this be done in a 6c?
Have you got a list of part numbers i need like control modules etc?
POLO 6C
ETKA, etc... (parts)
viewtopic.php?f=10&t=42713#p466570
VCDS
Polo 6C is totally unknown to me in terms of coding, adaptation, etc...
VCDS
Very interesting wiring of VW for the Polo 6C.
One seperate fuse for the switches on terminal 75
Two fuses, one terminal 30 (always live 12V), one terminal 15 (12V by ignition).
It appears the wiring loom of the Polo 6R is not directly compatible with the Polo 6C.
Even though the connectors are compatible, the wiring layout is not. The power supply is different.
Even more interesting:
The Polo 6C switches work in the 6R
The Polo 6C seats work in the Polo 6R
The Polo 6R and Polo 6C share the control electronics for the heated seats: 6R0959772A
- habib_123
**Update**
I have now received the Skoda heated seats elements.
http://www.ebay.co.uk/itm/SKODA-RAPID-o ... 2061118880?
I have tried to work out how it's going to go together in the seat including the wiring which is where I got stuck.
The Kufatec wiring for each seat has the same connector as the heated elements (the one that joins the top to the bottom)
There is also another connector to which I do not understand where it goes.
I have attached photos any help will be greatly appreciated!
Thank You
I do not understand this connector
This connector which has a sticker is the same connector as kufatec wiring for each seat
Kufatec seat heating connector:
Thank You
This connector which has a sticker is the same connector as kufatec wiring for each seatKufatec seat heating connector:
Join these wires
with these
with a compatible connector (male-female).
To others
prior info: https://www.kufatec.de/shop/media/image ... /40013.jpg
with these
To others
- habib_123
Would anyone know the part number of what I need to join the connectors?
To replace the red connector.
1J0972712
Terminals
000 979 129 (1,0 mm²)
By the way, the electrical resistances of the heated elements from Skoda Rapid, Toledo are in parallel, those from 6R are in series.
This is neither good nor bad, they are fully compatible. Both models have their advantages and disadvantages.
Terminals
