Fog light retrofit
Gadgetman
Drives: SE
Re: Fog light retrofit
Post by Gadgetman »
Looking at retrofitting fogs to my late 64 plate 6C SE.
The FOG/DLR assembly looks (from the outside) like it has a hole already for a bulb. I assume the holder is missing but the unit is the same?
Then I assume the BCM wiring kit and new switch are all that's needed?
Probably not. You'll need new fog lights too.
:arrow: viewtopic.php?f=10&t=42713&p=517050#p466570
Take a picture to clarify.
Gadgetman
Drives: SE
Post by Gadgetman »
ciclo wrote: Tue May 16, 2017 11:33 am Probably not. You'll need new fog lights too.
Thanks.
Looks like I might just need item 5?
Item 5 is a fog light bulb.
You currently have a 3, you'll need a 1, which includes a 4 and a 6.
Don't forget a new light switch and some wiring from your BCM to the fog lights. And you'll need to do some coding in your BCM as well, to activate the function.
Gadgetman
Drives: SE
Post by Gadgetman »
Thanks.
I have vcds so it's just following the coding earlier in the thread. Assuming I have the right BCM.
Sippy
Drives: '15 Polo 6C TSi
Re: RE: Re: Fog light retrofit
Post by Sippy »
chisyelamos1 wrote: Thu Aug 25, 2016 10:09 am
JaegerStriker wrote:
chisyelamos1 wrote:Hello
I installed the fog lights on my polo 6c and want to know how and where to connect the cables are marked like this
Enviado desde mi LG-H815 mediante Tapatalk
where did you get the fog light kit from?
Here http://www.carsystems.pl/vw-polo-6c-fog ... d2161.html
Hi there, just wanted to find out if these connectors to the BCM numbers 3&40 are 1.5mm or 0.5mm ??
Sippy
Post by Sippy »
ciclo wrote: Mon Jun 05, 2017 5:30 pm Hi, 1,5mm
:arrow: viewtopic.php?f=56&t=68682&start=15#p514322
Thank you very much.
just for info....
I have the white/black wire already as i have rear fog installed.
i also have fog lamps that i retrofitted but pulled signal from PARK lamps with a 12v RELAY.
So i need to join the 2 wires from the BCM pin3 $ pin40 to the current wiring harness positive (+ve) of the lamps and bypass the relay. will let you know how it goes :lol:
Sippy
Post by Sippy »
Guys, just an update.
I would like to thank you all and especially @chisyelamos1 + @Jussu + @ciclo
Combining all the information on this forum and a bit of VCDS knowledge i managed to tap into the BCM (pin 3 & 40) and run the wires.
After coding it on VCDS and it works fine on my car (2015 POLO 1.2TSi Trendline with aftermarket 10pin rotary switch + autolight sensor). :lol:
You guys are most helpful.
Mods to follow will be getting the cornering lights to work as well but that will be after my wiring harness gets delivered :D
