UPGRADING BCM 6R
Re: UPGRADING BCM 6R
EXCELLENT results. 8) Read the topic from the start.
Saturday,22,April,2017,07:38:09:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3
Data version: 20161010 DS255
http://www.Ross-Tech.com
VIN: MEXD16603GT0GOVIND License Plate:
Mileage: Repair Order:
Chassis Type: 60 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 44 56 0B
VIN: MEXD16603GT0GOVIND Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CJLA) Labels: None
Part No SW: 03E 906 019 AQ HW: 03E 906 019 AQ
Component: SIMOS11.2 H04 1968
Revision: --H04--- Serial number:
Coding: 00110016032400000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12MPI02103E906019AQ 001001
ROD: N/A
VCID: 73E5B5AADA7402DAAD-8026
No ASAM data for: "EV_ECM12MPI02103E906019AQ" (VW25)
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BP HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 60DD2763212B18C20618E46B845818000000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0D11C352DC90742ADB-8058
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Component: LENKW.SENSOR H06 0060
Serial number: 090465LEA0003X
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3949EE1365FB2D2-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41892F62D848E04AEF-8014
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 352161207
Coding: 3AB02BBF48A3000001380FB07CEB9E901BC0614F60AC2000200000030800
Shop #: WSC 12345 123 12345
VCID: 2A5B68CE453E0312DE-807E
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 311215 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Serial number: 13202848160111221608
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 020 2551
Serial number: 13202849160107223746
Coding: 040000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 0111607164000748AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Serial number: 13102728160108150857
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Serial number: 13202729160111111032
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 35821404004439
Coding: 308001
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K.rod
VCID: 3A7B588EBD9EB392AE-806E
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW013KE03
Coding: 003036
VCID: 49993742E878280A37-801C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6RF 920 861 B HW: 6RF 920 861 B
Component: KOMBI H01 0215
Coding: 1108000000
Shop #: WSC 12345 123 08192
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 4A9B084EED7E23123E-801E
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 68DFD2C69BB2F10208-803C
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
VCID: 2E5364DE71D66F3202-807A
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H01 0215
Serial number:
VCID: 6ADBA8CE8DBEC3121E-803E
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000001000000
ROD: EV_SteerAssisNSK_VW12.rod
VCID: 41892F62D048E04AEF-8014
Address 56: Radio (J503) Labels: User\6RD-035-187.clb
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 12765GD0082357
Coding: 00000440000000
Shop #: WSC 00081 790 00184
VCID: 45813B72CC60CC6AD3-8010
End-------------------------(Elapsed Time: 02:54)--------------------------
They are a lot of new functions (Auto lights, CH/LH, single parking lights, parking lights, Dimmer, HBA, SCL with SW, etc...) , I guess govindsharma will report on all of them.
Especially the G85 sensor for the Static Cornering Lights function through the steering wheel in addition to the indicators. :twisted:
The instrument cluster with MFA+ needs to be installed (for HBA icon on screen) ... but everything works like a charm. 8) 8) 8)
I suppose govindsharma will have learned many things during these days, well, I have learned more from him than he did from me. That is why I want to tell you publicly: You are another excellent person in this wonderful world in which we live. Thank you. :D
Good job you two. Very good job. The steering angle sensor without esp is an interesting finding
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
So hba works w/o MFA+? [emoji1360]
Many thanks iichel.
If you need that I verify things :) you are doing. :wink:
benzinkopf wrote:So hba works w/o MFA+? [emoji1360]
You need to have the icon present on IC for your own safety. I hope you understand my reply. :wink:
benzinkopf
ciclo wrote:Many thanks iichel.
Yes. For sure. But i find it interesting that the system is actually independent as the IC only gets the CAN for display.
he he, i need to figure out how to get the ODIS to work. My diagnosis head will not connect to my pc...
and then i need to figure out how to adapt kessy key for central locking... my expert (spacewalker, on the ross tech forum) told me to use VAS PC V19.
things to come... things to come... :mrgreen: for now I will not stalk you (yet) with the kessy stuff.
first is to make the immobiliser work correctly:
OK :lol: :wink:
govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma »
Here is the results for single side parking,HBA, G85 sensor,auto headlight,manual dimmer,CL,LH etc in whole you can say Ciclo type "C" wiring with G85 sensor.It takes one whole day to make this installation.I will thanks to Ciclo Sir for this installation because he is the person who takes care in every moment.He guide me till the end of installation. I am also thankful to firegrafik Sir he arrange BCM max for me and this BCM reached to my home within 10 days from Russia to India.In my opinion Installation is not so much difficult if every installer remember ciclo sir words which he said to me (for this installation think like a watchmaker, not like a car mechanic.).There is no need do worry about installation just follow Ciclo Sir user guide and installation PDF.
I will explain how i had installed in few days for the time being see the results
1.when i pull left stalk up only right side parking lights and rear right tail light is glowing with three time beeping sound
2.When i pull left stalk down only left parking lights and rear left tail light is glowing with three time beeping sound.
3.When i am unlocking car low beam and parking lights with tail lights are glowing.(LH)
4.When I turn off ignition of car and flash high beam and open door light is glowing for 15 sec(CH)
5.When I am turn steering wheel to right, right fog light is glowing and vise versa.I think G85 sensor is working great.
6. When I am engaging rear gear, rear wiper starts working.
7. HBA also Installed but result will come when i will install MFA +.
8. Dimmer is working now, I am able control dash lights manually.
9.Front fog lights activate as i engage reverse gear.
These are the instant results other result will be after few days.with Pictures and clips.
Thank you.
graaja
Drives: Polo GT TSi
Post by graaja »
govindsharma wrote:Here is the results for single side parking,HBA, G85 sensor,auto headlight,manual dimmer,CL,LH etc in whole you can say Ciclo type "C" wiring with G85 sensor.It takes one whole day to make this installation.I will thanks to Ciclo Sir for this installation because he is the person who takes care in every moment.He guide me till the end of installation. I am also thankful to firegrafik Sir he arrange BCM max for me and this BCM reached to my home within 10 days from Russia to India.In my opinion Installation is not so much difficult if every installer remember ciclo sir words which he said to me (for this installation think like a watchmaker, not like a car mechanic.).There is no need do worry about installation just follow Ciclo Sir user guide and installation PDF.
Congratulations on the successful installation! Looking forward to more details on the HBA function.
As you have rightly said, with Master Ciclo's extensive installation details and excellent support over mail, the result is always predictable :D
patil
Post by patil »
Dear Govind... Heartly congratulations :D Enjoy the fruits of your hardwork 8)
When Master Ciclo is there around... Anything is possible on 6R :mrgreen:
Such Mods will leave VW dealers here in India in utter disbelief.... ha ha ha :mrgreen:
Truly inspirational ... A beautiful example :lol:
hmthakur
Drives: Polo gt tsi 1.2 dsg
Post by hmthakur »
Congrats Govind, happy to hear your installation worked[emoji1303]
benzinkopf
govindsharma wrote: 3.When i am unlocking car low beam and parking lights with tail lights are glowing.(CH)
4.When I turn off ignition of car and flash high beam and open door light is glowing for 15 sec(LH).
Btw. Some minor corrections:
No. 3 is LH Leaving Home.
No. 4 is CH Coming Home.
govindsharma
Thank you for information minor error rectified
It is very nice to read all your comments, but you should keep in mind that this would not be possible without all of you.
Thank you for your passion, it is inspiring.
govindsharma
HBA light sign in IC.
