Polo 6R by RekinPoznan
Re: Polo 6R by RekinPoznan
From 0:30 to 0:38 sec.
The rest is explained in the diagram (diode).
RekinPoznan wrote: Tue Oct 24, 2017 4:33 pm Hello
Lookong ....
RekinPoznan
Drives: 6R
Post by RekinPoznan »
Hi
Lookong hehehe sory for errors....
Thanks for fast answer so make now wire ;) , looking for BCM , stalks are buyed , mirror with camera are installed ;).
Best regards Chriss
RekinPoznan wrote: Wed Oct 25, 2017 4:42 pm Lookong hehehe sory for errors....
I thought you meant LOL KONG. Yes, "o" and "i" are near on the keyboard.
:lol:
RekinPoznan
Drives: 6R
Tooday stalks received , preparing to install ;)
7E0937090B are good for HBA , and new type of MFSW from 6C ?
Best regards Chriss
Yes. (both)
BCM adaptation channel 54 , from 0 to 1, to make work the highbeam stalk with return spring.
RekinPoznan
Drives: 6R
Thanks one day I must make toogether MFSW , HBA and replace BCM. ;)
RekinPoznan
Drives: 6R
Hi friends
Preparing to replace ABS8.2 to ESP9.0i
I looking for coding ESP9.0 for 6R0 907 379AS H03 SW03 i try with this program on screen but no sure the coding is realy correct ?
second question what brake pipe is recomended for my polois i see on ETKA many types.... 6R1614739G and 6R1614740G ??
And for this ESP Unit i have 6R1 614 235 D
Many thanks for help
I'll help out with the coding of ESP9.0i, no problem.
RekinPoznan
Drives: 6R
Thanks IIchel , What do you think of coding from the screen, there are my data entered there is correct ?
looks to be OK but you cannot be sure until you try it :) the ESP calculator is for sure a great program.
RekinPoznan
Drives: 6R
What can coding be rejected or does ESP not work properly?
yes, coding can be rejected, especially for the ABS. all the parameters need to be correct (brand, type, VIN, engine type). and then it's sometimes still a little puzzle.
RekinPoznan
Drives: 6R
Hi
When change BCM from 7H0937090 to 7E0937090B is recomended copy and paste long codnig , or must be step by step coded ?
Best regards Chriss
RekinPoznan
Drives: 6R
Hi
Why after change BCM I have active adress: 61 ? with 7E0 907 534 , in gateway list is not marked.
Many thanks Chriss
