ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
As you all know, when it's combined a 55W ballast with a 35W 5500K xenon lamp the final color will be around 4300K-5000K (depends on several factors). It's a good combination, but I also want to try to get a whiter color.
To try to achieve this whiter color I have also bought these xenon lamps D2H 35W 6500K Yeaky (1 pair) , this way I can continue with the festival of tests that I am doing.🤷‍♂️
I received the Quick Start 55W-35W 5500K xenon kit, which is a lot better (HQ) than the monstrous xenon kit included in the purchase of the Replica LED Headlights.
I suppose the monstrous xenon kit is like those gifts we see and we immediately would return them... :) (slow start, super decoder with WTF Resistors, etc)
Yes, there are many high quality brands for a good xenon kit, but, finding the perfect combination (projectors-lenses, ballasts, and xenon lamps) according to our needs is like finding the perfect audio system, it requires some time and Tests, because we all don't see or hear the same. :lol:
At the moment, these Replica LED headlights have the correct structure for the tests.
Improvements so far:
- VW Holder for xenon lamps.
- Rubbers for the Headlight corner.
- HID xenon Kit a lot of better quality.
vs
Comparison
Yeaky and DLT installation
Yeaky Tests when possible
Well, the best explanation:
https://www.youtube.com/watch?v=8v4QgnPLjVU[/youtube]
While I'm waiting for the Yeaky D2H 6500K xenon lamps arrive to do the Tests and my wife choose if she wants the 6500k or 5500K, this is the way of How I installed the TPMS unit.
Golf 7.5 Direct TPMS (RDKS)
viewtopic.php?p=574274#p574274
Coding:
-Direct TPMS
 Address 19:
 Installation List, enable Address 65
 Adaptation
 SECURITY ACCESS ---> 20103
 Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32 (coded)
 Indirect TPMS deactivation / Direct TPMS activation
 Address 17: Instruments
 Coding
 Byte4 Bit0 (disable)
 Byte3 Bit7 (enable)
 Byte11 Bit2 (enable)
 Address 03: ABS Brakes
 Coding
 Byte27 Bits 4/5/6 (disable)
 Byte28 Bit7 (disable)
 Address 5F: Information Electr.
 SECURITY ACCESS---> 20103
 Adaptation
 Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64  (Databus extended)
 RDKS editor / VCP
 Generate and load zdc file (comfort/standard/fully loaded)
Autoscan:
Sunday,17,February,2019,14:35:37:32438
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: TPMS OK!
Mileage: 10621km-6599mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 42 44 52 5F 65 BB BC
VIN: WVWZZZAUZKPCICLOW   Mileage: 10621km-6599miles
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
Address 01: Engine (J623-DKRF)       Labels: None
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032232415082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92FE93-807C
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733020F0084002430B00000012121212B835351919323200
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6D7B41-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011005004000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6C8139CC460C1C07525-8038
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 084 DA    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H38 0273
   Serial number: 00001820800697
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7AAD0F943C58B2B7D09-802E
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0E4DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: SBY18M08D06H04M32S34
   Coding: 03A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018193
   Coding: 0471151001
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4CC1994C264CFC07325-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00600111FFC728949C810500400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C3447FA5-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F605869BEA92FC93-805C
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Side Sensor Driver Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 740 D    HW: 5G1 920 740 D
   Component: KOMBI         211 2500
   Coding: 07A52A802280000801883A051401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 270B06E09F6AFF5FFF7-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 14071810801894
   Coding: 030100047F085700FA000248080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D27C4886DF6458FB5B-8068
   Alternator:
   Component: 1-01-02-01-04
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180001255750088264
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
   Part No SW: 3G0 857 511 BD    HW: 3G0 857 511 BD
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0101000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B833AD043021B3F5BF-803E
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        005 0240
   Serial number: 42018727800277
   Coding: 00150320D000048000001000
   Shop #: WSC 17301 666 28888
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 48C9A55C3234102716D-801C
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 011F0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3FF93F-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150320DE00048000001000
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 47CBA6603F2A1F5F1F7-8012
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      724 0890
   Serial number:
   Coding: 02731000FF0000005111000100080A001F0500D40120010003
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D07F4C8BD96D50F05B-8078
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV2140047
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84C74A5-8060
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
End----------(Elapsed Time: 01:21, VBatt start/end: 14.6V/14.6V)-----------
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Ventilation of these "Replica" LED headlights.
Ducts vent x3
Front
Middle
Rear
Speculation:
I'm not sure because it's hard to see, but I think this Replica headlight has an electronic ventilation system, inside there is a box with a cover that belongs to the headlight structure, I opened it and seems to be a temp sensor or related with the temperatures. On the other hand in the headlight center in the inner bottom part seems to have a fan or a valve. Difficult to see or remove (I did not). Their locations are shown in the following image.
I've taken a precautionary measure that is not necessary to do, but I prefer to make sure that the ventilation ducts are not lost, the foam that is seen in the following image is very important.
:lol:
In addition, inside these Replica LED headlights brings a bag of desiccant silica gel, IMHO is perfect, clearly it's to absorb the moisture condensation inside the headlight.
Yeaky 5500K 35W xenon lamps + 55W DLT ballast. Test and BCM adaptation.✅
- Fast Bright. Quick start OK!✅
- After adaptation, NO BCM faults.✅
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/CPDHANyWc ... autoplay=1
More information in OP when the tests with Yeaky 6500K 35W xenon lamps finish. (waiting for them)
- VW Holder for xenon lamp.
- Rubber for the Headlight corner.
- Plastic Clamps for ducts vent.
VCDS
Golf 7.5. Active Window Switch when Ignition Switch goes from ON to OFF and opening the doors.
09
SA 31347
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8 ...to not active
Note: ... until you start a new operative cycle by closing one of the front doors. Rear doors status does not influence.
Golf mk7.5 removing / installing headlights. PDF 1 page
I've made the adjustment of the light patterns with the wall method, applying the 1% ECE, at no time the oncoming traffic warned me of being dazzled by my headlights.
However, I will make an adjustment of the light patterns with a regloscope in a workshop. Once done I will show more images.
At the moment everything works correctly with these Replica LED headlights, including the Light Assist function (HBA). 8)
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/1fzBxv-C7 ... autoplay=1
Halogen Headlights
There are circumstances in daylight conditions in which the turn signal in that place/position is not seen laterally by pedestrians, cyclists, or rest of people that circulate by the asphalt jungle... :lol:
Many thanks. 👍
The beam pattern of my Replica LED headlights were adjusted with a BOSCH regloscope, ... just perfect, just like this, Bosch HTD 815. 8)
Coincidentally, it's raining where I live and taking pictures with my poor tools doesn't make sense, I still haven't washed the car after installing these headlights and do the tests.
When be possible...
"to infinity and beyond" :lol:
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/ZDAzWvl4o ... autoplay=1
In my first attempt to take pictures of my Replica LED headlights without success because of the rain, a fast snail that was circulating at the speed of light come through near my. Afortunalely I had the camera in my hand and I was fast enough to take the image shown in the video. :)
:lol:
Locked
