Polo 6R 09 1.4 85KM
Re: Polo 6R 09 1.4 85KM
8) Ok, thanks a lot for the report.👌
Please, once you have installed the RLS let me know, we have to code the BCM and RLS (again), thank you.
It is recommended that you update or use another VCDS version to clear up/clarify some of the "detected bugs" in Autoscan with version 15.7.1 in other units.
However and as you can see in the real world everything works despite those bugs.
I am here in case you have new concerns about the lights.👍
dcgumis
Post by dcgumis »
ciclo wrote: Thu Mar 19, 2020 6:38 pm 8) Ok, thanks a lot for the report.👌
Thank you for your help. I was afraid to do it myself. Today I installed new steering wheel GTI POLO 6C /UP GTI,
steering wheel 6c0 419 091 cb
Airbag wiring 6C0971584
   Subsystem 6 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Coding: A4FFFF
I'm a bit worried that I can't connect to the engine
Address 01: Engine
Cannot be reached
Is ALWR in bi-xenon the same as in polo 6c lamps with full LED POLO 6C ?
Is the wiring harness the same?
https://www.ebay.pl/itm/VW-Polo-6R-ALWR ... XQH-pRB9yg
No, for ALWR in Polo 6R with LED headlights, you must have a a different module with different parameterization.
Read this with translator: https://www.drive2.ru/l/519838378447864355/
AFS
In this CNK thread you have the correct parts for your POLO 6R:
https://www.drive2.ru/l/458163472711033418/
4. Auto leveling headlight system (AFS)
a) Axle sensor (6R0 941 273 B)
b) AFS unit (6R0 907 357 C)
c) Holder on rear axle (6R0 612 405)
d) adjustment of interior lighting, without manual headlight leveling (6Q0 941 334)
LED Headlights. Wiring.
https://drive.google.com/file/d/1x2piv7 ... sp=sharing
Note
You should pay special attention to the position of the terminals on the connectors because it is not exactly the same as for Bixenon headlights.
In the link to the firegrafik thread indicated by iichel you have to take into account that he has a POLO SEDAN so the parts indicated for the AFS are not the same.
Attention:
Nobody, I repeat nobody :lol: , has been able to clarify if the parameterization (TinyQ) for the AFS unit for POLO SEDAN LED headlights is the same as for POLO 6R LED headlights.
I'm afraid it won't be the same parameterization.
However, if you buy the AFS unit with the PR code from the VW dealer, you will not have to parameterize it.
POLO 6R:
6R0907357C Z09 ... with ESP
6R0907357C Z0E ... with ABS (your case)
About your concern about the engine (CGGB), and as I already told you, you need an updated version of VCDS... 'ORIGINAL'. (everything can not be cheap or free :lol:)
However, you can read the engine by selecting 6R instead of CAN automatic detection when you make an autoscan.
It is possible that even in this way your engine is also not reached (your engine is a little out of date compared to the new BCM 7E0).
dcgumis
Post by dcgumis »
Yes, for ALWR, I bought the wiring from eBay. For LED headlights, I'd recommend to make your own wiring (a lot cheaper)
dcgumis
Post by dcgumis »
Hi :D :D , today I installed FULL LED lamps from the iichel scheme, parking lights, but DRLs do not work. The left light turns off after a while. Low and high beam work, long blinking also works.
In position 0, the low beam light up.
In the "Auto" position the low beam light up.
In position 3 it is not light up.
In position 4 the low beam does not light up.
Thanks for your help
LED stekker links
1 - AFS
2 - AFS
3 - AFS
4 - AFS
5 - Massa - Halogeen pin 5
6 - Dimlicht - Halogeen pin 6
7 - Massa - Halogeen pin 5
8 - Plus die van de hoogteregeling kwam - Stap 5!
9 - Knipperlicht - Halogeen pin 9
10 - LED module - T73b/5
11 - Groot licht - Halogeen pin 8
12 - LED module - T73b/3 - Deze zit evt al bij de DRL in de bumper!
13 - leeg
14 - LED module - T73b/28
LED stekker rechts
1 - AFS
2 - AFS
3 - AFS
4 - AFS
10 - LED module - T73b/6
12 - LED module - T73a/5 - Deze zit evt al bij de DRL in de bumper!
13 - leeg
14 - LED module - T73b/56
Friday,27,March,2020,19:24:31:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZ6RZ
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 15 17 19 25 37 44 56
VIN: Mileage: 172340km-107087miles
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 AC    HW: 6R0 907 379 AC
   Component: ABS8.2 front  H04 0001
   Revision: --------
   Coding: 200228E3016F00B2042C14E280D800000200
   Shop #: WSC 02069 123 12345
   VCID: 7F0A9BD3EAEEDBC624-802A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 A    HW: 6R0 820 045 A
   Component: Climatic       23 0500
   Revision: 00 09 23
   VCID: 2C509C9F4F18905ED1-8078
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 2234 km
                    Time Indication: 0
                    Date: 2020.01.11
                    Time: 17:45:52
Address 09: Cent. Elect. (J519)       Labels: None
   Revision: B9080001    Serial number: 0771 014162029
   Coding: 3DB02BB828F3240092380090BC2B1CD01BC0610F60802049200000030000
   Shop #: WSC 02737 022 00190
   VCID: 68D8208F9B607C7EF5-803C
   Subsystem 1 - Part No SW: 6R0 959 801 H    HW: 6R0 959 801 H  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 0803
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 K    HW: 6R0 959 802 K  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 0803
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 5 - Part No: 1K8 951 171 A
   Coding: A4FFFF
   Subsystem 7 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Coding: 08BC32
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 172344 km
                    Time Indication: 0
                    Date: 2020.03.27
                    Time: 01:52:10
00979 - Lamp for Low Beam; Right (M31)
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 172344 km
                    Time Indication: 0
                    Date: 2020.03.27
                    Time: 01:52:10
01134 - Alarm Horn (H12)
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 172344 km
                    Time Indication: 0
                    Date: 2020.03.27
                    Time: 01:51:07
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag005 H09 0018
   Revision: --------    Serial number: 003DW003YHK-
   Coding: 003035
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_AirbaWV10BPAVW250 A01001
   ROD: N/A
   VCID: 428CD227D59C762E0B-8016
   Subsystem 1 - Serial number: 3572SRB40000911C8A98
   Subsystem 2 - Serial number: 3582SRB4000091185980
   Subsystem 3 - Serial number: 3516GRB401V9F7IH9SA3
   Subsystem 4 - Serial number: 3526GRB40219F7IH1K1-
No ASAM data for: "EV_AirbaWV10BPAVW250" (VW25)
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0607
   Coding: 140A00
   Shop #: WSC 00788 648 00255
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 346084FF9F28C89E89-8060
   Revision: B9080001
   Coding: 002200
1 Fault Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 172344 km
                    Time Indication: 0
                    Date: 2020.03.27
                    Time: 01:50:41
   Component: IMMO          H05 0607
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_DUS_VDD_RM09 A03709
   ROD: N/A
   VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Immo_DUS_VDD_RM09" (VW36 *)
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H24 6276
   Revision: AB001001    Serial number: VWZ6Z7S0418589
   Coding: 00010000010000A00000
   Shop #: WSC 01357 011 00200
   VCID: 3D76A1DBA46209D676-8068
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V15  8522
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10150
   Shop #: WSC 00000
   VCID: 2E549697ED04E24EFF-807A
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
End-------------------------(Elapsed Time: 02:39)--------------------------
Please try this coding for your BCM
3DB02BB828F3240092380090BC2B1CD01BC0660F60813041200000030000
dcgumis
Post by dcgumis »
iichel wrote: Fri Mar 27, 2020 8:23 pm Please try this coding for your BCM
Hello
Thank you iichel! works: D :o :o :lol:
Is it possible to turn off the lamp when using a turn signal?DRL? :D
Position 0 DRL OK
DRL item OK
Position 3 OK
Position 4 OK
The left lamp switches on with the passing beam delay.I'll see in the evening how dark it will be
The headlamp washer fuse SB 46 must be connected to the existing fuse SB 46 (20A) ?
Thank you for your help :D
This coding will make the DRL go off with indiator on
3DB02BB828F3240092380090BC2B1CD01BC0660F608130C1200000030000
Yes, correct about the headlamp washer. It can be connected to SB46 (existing for horn). Perfect OEM installation.
dcgumis
Post by dcgumis »
iichel wrote: Sat Mar 28, 2020 10:28 am This coding will make the DRL go off with indiator on
thank you iichel works
I have a problem with blinking long lights in position 1.2.3 - when I blink with traffic lights, the left lamp does not blink, in position 4 the blinking with long lights works but the right dipped beam lamp switches on and off alternately.
right lamp - low beam switched on, the lights turn on and off
Video
https://youtu.be/DgP13nU0tB8
I also connected the headlamp washers :D :D
dcgumis
Post by dcgumis »
Today I took a closer look at my problem with lights.
My BCM coding
DRL-OK
Parking light-OK
Low Beam -the left lamp turn on 1 second later than the right.The right lamp flashes two three times. This also happens while driving. Once in a while
https://www.youtube.com/watch?v=ve5KxfEkD6s
https://www.youtube.com/watch?v=cdEjUeVcnq8
High Beam= in position 4 OK
I also have a problem with blinking long traffic lights stallks.In the DRL position, Parking light-Long blinking works only on the right side:
https://www.youtube.com/watch?v=PXwFZwxO6LQ
Parking light and pulling the stalks into high beam and switching to the passing beam the left lamp turns on immediately. No delay.
https://www.youtube.com/watch?v=pu6icGTrR90
When coding
the same as above, but the right lamp flashes more often
Is this a broken light module 7PP941571AE?Tomorrow I will change headlight electronics power module - from left to right and from right to left
No it has nothing to do with the change in coding I provided. Perhaps you can code byte 18 differently to 66/73
There is only one correct BCM coding for LED headlights that are factory installed.
This BCM coding depends entirely on the installation of the wiring, which must be in the same way as from factory... of the following components ... the fuse box, stalks, dimmer (if), BCM, headlights (modules) and AFS.
For a better understanding:
With BCM Max, there is two possible wiring installations.
- BCM Max until 2014 (7H0 except D)
- BCM Max from 2015 onwards (7E0). ...required for LED headlights...
Example:
- My 6R with Bixenon headlights and retrofitted automatic lights (7H0 wiring installation).
- My 6R with Bi+AL+ HBA (7E0 wiring installation).
Note: It is possible to make an electrical installation type 7H0 with a BCM Max 7E0 installed (which is more cheap and easy), but this type of wiring installation is not indicated for LED headlights.
BTW, I have yet to see anyone in the world who has retrofitted the LED headlights into a 6R with the correct BCM coding. Yes, yes... they work, but they don't have the correct BCM coding.
The first BCM codings for LED headlights on the 6R family PQ25 were seen online thanks to my good India friends. 8)
I do not know what are the reasons why the LED headlights that have been retrofitted in the 6R have these problems shown in the videos, (many people report these problems), as you all know, I dont have LED headligths and I have not been able to study these problems with LED headlights in detail (in the real world), so I cannot provide correct coding depending on the installed wiring.
My recommendation is to ask for help from all those who retrofitted LED headlamps in the 6R family and solved all these reported problems.
dcgumis
Post by dcgumis »
Hello :)
I was able to solve the problem with the flashing light :D The module turned out to be a problem 7PP941571AE It probably had a different value than 7PP941571AE (Z01) :) I bought a used module extracted directly from the lamp
FULL LED polo 6c :) Waiting for one more module for the left lamp :)
thank you for all your help 8) 8)
