I just got it off ebay a while ago mate.
Clive's new Polo
Re: Clive's new Polo
A google search for ‘double sided tape for car number plates’ and you should find what you want.mjsaville wrote: ↑Fri Mar 20, 2020 10:20 pmWhere did you source the double sided tape from?POLO Clive wrote: ↑Thu Mar 19, 2020 11:22 am First modification, new number plates stuck on with double-sided tape (I hate them attached with screws), and the front one cut down by approximately 15mm to fit properly in the bumper recess.
MJ
- Drives: Limestone Grey GTI+ (Finallly arrived)
Superb, thanks for that.....SRGTD wrote: ↑Sat Mar 21, 2020 9:23 amA google search for ‘double sided tape for car number plates’ and you should find what you want.mjsaville wrote: ↑Fri Mar 20, 2020 10:20 pmWhere did you source the double sided tape from?POLO Clive wrote: ↑Thu Mar 19, 2020 11:22 am First modification, new number plates stuck on with double-sided tape (I hate them attached with screws), and the front one cut down by approximately 15mm to fit properly in the bumper recess.
MJ
MJ
I tend to use the 3M versions. I had used cheaper ebay specials a few years age and the number plate gradually started to slide off during the summer and i didnt notice the front plate had fallen off until after I got pulled over for itmjsaville wrote: ↑Fri Mar 20, 2020 10:20 pmWhere did you source the double sided tape from?POLO Clive wrote: ↑Thu Mar 19, 2020 11:22 am First modification, new number plates stuck on with double-sided tape (I hate them attached with screws), and the front one cut down by approximately 15mm to fit properly in the bumper recess.
MJ
