Page 3 of 20
Re: Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
Posted: Mon Feb 13, 2023 9:41 am
by Maarten
Nice upgrade that Blind Spot Detection with RTA
End of next month my Polo AW 2021 Facelift will get it too :D
Can't wait
Posted: Wed Feb 15, 2023 4:55 pm
by patil
Maarten wrote: Mon Feb 13, 2023 9:41 am Nice upgrade that Blind Spot Detection with RTA
Can't wait
Thank you Marteen.. you got a nice Polo and colour too👌
Good luck for your Blind spot retrofit 👍
Posted: Wed Feb 15, 2023 7:57 pm
by Maarten
Thanks! :D
Posted: Sat Feb 18, 2023 9:14 pm
by patil
log#09
Replaced Keyfob battery+ New VW logo+ new R steel cap
Had to replace keyfob battery because my clever T-roc told me to do so 😁
Posted: Sat Feb 18, 2023 9:35 pm
by Maarten
Very very very nice.
Ordered from the dealer?
Price?
Posted: Sun Feb 19, 2023 9:11 am
by patil
Maarten wrote: Sat Feb 18, 2023 9:35 pm Very very very nice.
Price?
Yes ordered from dealer from your country:))
Logo-- 7euro
metal cap-- 14euro
Posted: Sun Feb 19, 2023 9:17 am
by patil
Log#10
Windshield washer fluid level sensor(G33) installed ✅
Parts:
1. Level sensor -- 7M0 919 376
2. Seal ring-- 7M0919382
3. Level sensor connector-- 1J0973202
4. Drill bit-- 26mm
Bought readymade kit from AliExpress:
There is already premarked area for level sensor on the tank.
The washer fluid tank is small.. only 3L capacity :x cost cutting by VW, Even my Polo has 5L tank.!
Wiring Diagram:
I routed the wiring below the battery into the factory firewall opening behind the battery. Forgot to take pictures of this part of installation.
Signal wire connected to BCM T46b/28 ( MQS pin) and GND wire to dash panel metal frame along with BSD ground.
Coding the BCM:
SA - 31347
adaptation to enable washer fluid level sensor.
AID warning, once the tank is filled the warning goes off.
Posted: Sun Feb 19, 2023 6:43 pm
by Maarten
Nice functional upgrade.
Did this to my polo 9N3 in the time.
That car had headlightwashers so 4.6L tank.
The polo AW (2021) does not have headlightwashers so smaller tank.
I believe that the T-Roc does not have them aswell?
Hence the smaller tank?
Posted: Sun Feb 19, 2023 6:44 pm
by Maarten
patil wrote: Sun Feb 19, 2023 9:11 am
Logo-- 7euro
metal cap-- 14euro
Thanks, will contact them tomorrow.
This metal R piece fits every new VW key right?
Posted: Wed Feb 22, 2023 5:54 pm
by patil
Maarten wrote: Sun Feb 19, 2023 6:43 pm Nice functional upgrade.
My T-roc too doesn't has headlight washers. There is no rule in my country to have headlight washers. May be it's a EU rule to have headlight washers, but then again I have seen few EU car models having it and few don't. I feel the washer fluid will stain the dome of headlights rather than cleaning them. :mrgreen:
Maarten wrote: Sun Feb 19, 2023 6:44 pm
Should fit I think, compare your key with my stock key and you should get an idea.
Posted: Wed Feb 22, 2023 6:38 pm
by patil
Log#11
BCM upgrade from BCM M+ to BCM H ✅
My Stock BCM 5Q0 937 084 DG even though supports many features, it doesn't have necessary LIN bus pin (T73c/29) to support multicolour ambient lights, which I am planning to retrofit. So it was necessary to upgrade the BCM which supports multicolour ambient lights.
According to ETKA, 5Q0937084EC is the latest higher version BCM installed in latest T-roc's and other MQB models. The new BCM has T73c/29 pin as well as all the pins present in my stock BCM. Apart from T73c/29 there are also few extra pins in new BCM viz..T73a/42, T73c/35,36,37&61. I tried to find the assignment for these extra pins, but couldn't find any information. If anyone knows, please add the information.
I purchased the new unused high version BCM from AliExpress.
Comparison of stock vs new BCM:
Unlike in Polo PQ25 BCM's, which can be swapped straight and programmed offline, the MQB BCM's have component protection and whether the BCM is used or new, must be programmed online by connecting to VW servers aka FAZIT, the VW mothership :mrgreen:
Dealer experience:
It is very important to make back up of adaptation channels of stock BCM either using VCDS( adphex format) or ODIS-E(.xml format). I made backup in both. The new BCM will be empty so we need to load our current adaptations later after successful programming.
First I tried to program the new BCM with the help of my dealer. The steps involved in online programming of BCM can be seen in picture below.
The first step, software configuration involves downloading the dataset, adaptations, and calibration adjustment settings. Once started..SVM online threw following error at the first step itself.
Error ERP0617E
The error is self explanatory.. VW server only stores the data of BCM installed in my T-roc according to VIN number. So obviously new BCM is a mismatch and VW server throws the above error. We can skip the first step and proceed with CP removal and key programming which are mandatory online procedures. If we have correct dataset, then we can load it offline using ODIS-E or VCP and then load saved adaptations using VCDS or ODIS-E. Everything should work.
Even though I tried, but couldn't get the correct dataset for my new BCM. Here I would like to thank dear Master Ciclo for helping and guiding me in the right way.❤️🙏
Finally, with the help of Slavik( madwarlock) the new BCM was successfully installed in my T-roc. Everything was done online by connecting to VW mothership)))) I enjoyed the entire process of downloading and loading correct dataset, removing CP, programming keys and systematically clearing the errors. I must say, I learnt a lot from Slavik... for which my heartfelt thanks to him😍🤝🙏
Online programming was done entirely with my VAS 6154 clone, which worked flawlessly with newer ODIS versions I had installed on Windows 11.👌
After driving for 2-3 weeks with new BCM, I can say, everything is working perfectly without any errors.
It is preferable to load the backup adaptations using VCDS, as ODIS-E missed to transfer few adaptations after BCM was programmed online. Some lights were not working correctly, after retransferring adaptations using VCDS, everything was ok.
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 EC HW: 5Q0 937 084 EC
Component: BCM MQBAB H H44 0511
Serial number: B2701012207200
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
VCID: 7DA4F08EFD732DB3804-8028
Autoscan:
Wednesday,01,February,2023,02:27:50:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WVGZZZA1ZLVTRooCK  License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 65 75
          A5 BB BC CA D6 D7
VIN: WVGZZZA1ZLVTRooCK  Mileage: 23443km-14566miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 AT    HW: 05E 907 309 H
   Component: R4 1.5l TFS   H20 9640
   Revision: 8AH20000    CVN: 5E8A0C2D
   Coding: 012500322304190830000000000000000000000000000000
   Shop #: WSC 00020 043 00000
   ASAM Dataset: EV_ECM15TFS01105E906018AT 003003
   ROD: EV_ECM15TFS01105E906018AT_003.rod
   VCID: 77A8E2A6DF4F07E3DA8-8022
   VINID: 9E65EAAAA441A9C9801C720314E84F2DE4
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 050 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1911
   Revision: 00005009    Serial number: CU501911185682 CVN: ABB5E1C0
   Coding: 0014
   Shop #: WSC 17734 418 534600
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 3C223D8AA6E9E4BBF7A-8068
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Q0 614 517 DK    HW: 5Q0 614 517 BN
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 63139000003538
   Coding: 46FA8A7D90272473477F060362C82562510924E26046A4733022F00852A24B0B00000523525212121035351919323200
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0534174099
   Coding: 132C0C0723
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D4586ED523A573984-8010
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 FQ    HW: 5G0 907 044 FQ
   Component: Climatronic   H04 2401
   Revision: 00001K10
   Coding: 061200242001100D1105004012101836
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 7BA0FE96E3672383BE0-802E
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: S6Y19M10D15H05M19S28
   Coding: 0018DD
   Anti-theft alarm system sensor:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY192950M1T
   Alarm horn:
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000754028
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 Q    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100221120190C400340
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058419329
   Coding: 0471155011
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 50FA793A1A6170DB3B2-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3204604218FF8748949C810500408500000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 43D04676DB179B43B60-8016
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PPMRKF2
   Coding: 88CCC0C0000000005C5400CF008840000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 0B40AE56B3C713038E0-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 002 910 19
   Component: SideSensor_Df  008 0887
   Serial number: 357000000004A1316142
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 454 002 810 19
   Component: SideSensor_Pf  008 0887
   Serial number: 35800000000C98B8424V
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 454 802 210 19
   Component: SideSensor_Dr  301 0148
   Serial number: 35100A0CB121A000000D
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 802 510 19
   Component: SideSensor_Pr  301 0148
   Serial number: 35200E4A8381A000000P
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 802 310 19
   Component: FrontSensor_D  304 0149
   Serial number: 35500964D2C1A000000R
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 17A 920 790 B    HW: 17A 920 790 B
   Component: KOMBI         503 4310
   Coding: 65BC00986A88080C0188370F1001000000000906
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
   VCID: 2616FFE248654E6BB1E-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000427114
   Coding: 030100046F08560023100248180F00010001070000000000000000000000
   GVL: 014E3C000000060040CC80008000C80010000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW27.rod
   VCID: 70BAD9BABA2150DB1B2-8024
   Generator:
   Component: 5-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5NA 959 442     HW: 5NA 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H06 0025
   Serial number: 2601917550901873BZ2B
   Coding: 250000
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 3250843205
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000332474005
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 313C1CBE71AB19D354C-8064
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520011985865
   Coding: 92A54640
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 392C249EA9DBD193ECC-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520011913860
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000397175085
   Coding: 00111220D001028000001000
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 4DC4604E0D535D33504-8018
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000036110727
   Coding: 1D0000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 151F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B2D5AACE396CFBFFA-8020
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17111910522941
   Coding: 000000070900204600000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372822A69FCFC7E31A8-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000396858048
   Coding: 00111020DC01028000001000
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 4CC26D4AF649543B47A-8018
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000036011483
   Coding: 050000
   Part No SW: 3Q0 035 840 C    HW: 3Q0 035 840 C
   Component: MU-S--ER      724 0876
   Serial number:
   Coding: 02720600BE0000004111000100090A001F0500F60120040002
   Shop #: WSC 12345 123 12345
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 2B000ED6538773036E0-807E
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H61 8214
   Serial number: VWZ6ZJW3322738
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000255241
   ROD: EV_RDKBERU30_005.rod
   VCID: 343215AA8EB92CFB3FA-8060
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 02720601EA16380D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: 3D24308EBDF3EDB3C04-8068
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 15111915K10993
   Coding: 0002070600000401000200568150A90084000E20002000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40DA497ACA01805BAB2-8014
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 508040727602
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
   VCID: 75B4E8AEC54375F3C84-8020
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 025E8372848D524BFD6-8056
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H07 0009
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
End----(Elapsed Time: 01:53, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
With this crucial BCM upgrade, now I can add colourful ambient lights in my T-roc OEM way🌈😎
Posted: Wed Feb 22, 2023 9:18 pm
by Maarten
Only automatic leveling is/was mandatory with led/xenon.
No headlightwashers in polo AW afaik.
Posted: Sun Feb 26, 2023 5:36 am
by ciclo
Hi my dear Doctor, thank you very much for sharing the improvements (logs) of your T-Roc, they have entertained me during the repairs that I have suffered in the hospital🙄💔, ...now I am in the recovery phase 🥧🍦🍧🍨🧁😁.
As you already know, I will resume my DCC project in the spring.
Posted: Tue Feb 28, 2023 5:10 am
by patil
ciclo wrote: Sun Feb 26, 2023 5:36 am Hi my dear Doctor, thank you very much for sharing the improvements (logs) of your T-Roc, they have entertained me during the repairs that I have suffered in the hospital🙄💔, ...now I am in the recovery phase 🥧🍦🍧🍨🧁😁.
I wish you speedy recovery, take adequate rest and get well soon dear Master🤗
Posted: Tue Feb 28, 2023 4:48 pm
by patil
Log#12
OEM Door wind deflectors+ OEM Sunblinds
Officially summer has started here.. even though heat insulated glasses are installed all around in my T-roc, but it is not enough for our frying summers.🔥🥵
Part numbers:
Wind deflectors ( front set): 2GA 072 193
Wind deflectors ( rear set): 2GA 072 194
Sunblinds ( rear set): 2GC 064 365 SUN
The parts were bought and installed from my dealer. The sunblinds are manufactured for rear glasses only for T-roc, missed out on tailgate glass.. typical VW goof up.🙈
