Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
patil
Post by patil »
Hello everyone!
Presenting you all my new daily drive, VW- Troc.πŸ’–πŸ˜Ž
It is not actually new, I bought a pre owned one very well maintained from a Doctor friend who upgraded to larger MUV. I would have bought new but VW discontinued troc by later part of 2021, which was sold via CBU route in limited numbers. This is Dec 19 manufactured 2020 MY approx 15000km run. It is in factory state with no mods done whatsoever.😁
Another shade of grey...INDIUM GREY Its hard to not like VW cars with timeless designs.πŸ’Ž T-Roc was sold in India with only one model and decently equipped.πŸ‘Œ
From factory:
- 1.5TSI evo+ ACT(148hp) mated to DSG 7 DQ200 (250nm)
- Active information display (AID)
- Led projector headlights+ AFS
- KESSY
- Heated front seats🀭
- Front assist/ Lane assist/ Emergency braking
- Indirect tpms
- Electronic Park brake + Autohold
- 8k OPS
- Composition media
- Logo rear camera (Low line)
- Large panaromic sunroof
- 17" Mayfield alloys
First autoscan( untouched except VIN):
Saturday,10,September,2022,17:59:37:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WVGZZZA1ZLV0TROCK  License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 42 44 4B 52 5F 75 A5 BB
          BC CA D6 D7
VIN: WVGZZZA1ZLV0TROCK  Mileage: 15315km-9516miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 AT    HW: 05E 907 309 H
   Component: R4 1.5l TFS   H20 9640
   Revision: 8AH20000    CVN: 5E8A0C2D
   Coding: 012500322304190830000000000000000000000000000000
   Shop #: WSC 00020 043 00000
   ASAM Dataset: EV_ECM15TFS01105E906018AT 003003
   ROD: EV_ECM15TFS01105E906018AT_003_VW27.rod
   VCID: 77A8E2A6DF4F07E3D69-8022
   VINID: 9E65EAAAA441A9C9801C720314E84F2DE4
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 050 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1911
   Revision: 00005009    Serial number: CU501911185682 CVN: ABB5E1C0
   Coding: 0014
   Shop #: WSC 17734 418 534600
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 3C223D8AA6E9E4BBFBB-8068
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Q0 614 517 DK    HW: 5Q0 614 517 BN
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 63139000003538
   Coding: 46FA8A7D90272473477F060362C82562510924E26046A4733022F078D2224B0B00000523525212121035351919323200
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 7DA4F08EFD732DB38C5-8028
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0534174099
   Coding: 132C0C0723
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D4586ED523A573945-8010
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 FQ    HW: 5G0 907 044 FQ
   Component: Climatronic   H04 2401
   Revision: 00001K10
   Coding: 061200242001100D1105000000101036
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 7BA0FE96E3672383B21-802E
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DG    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H42 0312
   Serial number: 02001932500097
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: 005A897A8A81405BE73-8054
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: S6Y19M10D15H05M19S28
   Coding: 0018DD
   Anti-theft alarm system sensor:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY192950M1T
   Alarm horn:
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004  0007
   Serial number: 00000000000000754028
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 Q    HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0100221120190C400340
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058419329
   Coding: 0471151011
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 50FA793A1A6170DB373-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3204604218FF8748949C810500408500000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 43D04676DB179B43BA1-8016
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PPMRKF2
   Coding: 88CCC0C0000000005C5400CF008840000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 0B40AE56B3C71303821-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 002 910 19
   Component: SideSensor_Df  008 0887
   Serial number: 357000000004A1316142
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 454 002 810 19
   Component: SideSensor_Pf  008 0887
   Serial number: 35800000000C98B8424V
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 454 802 210 19
   Component: SideSensor_Dr  301 0148
   Serial number: 35100A0CB121A000000D
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 802 510 19
   Component: SideSensor_Pr  301 0148
   Serial number: 35200E4A8381A000000P
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 802 310 19
   Component: FrontSensor_D  304 0149
   Serial number: 35500964D2C1A000000R
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 17A 920 790 B    HW: 17A 920 790 B
   Component: KOMBI         503 4193
   Coding: 25A400186B800008018823031001000000000906
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
   VCID: 2616FFE248654E6BBDF-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000427114
   Coding: 030100046F08560023100248180F00010001070000000000000000000000
   GVL: 01463C0000000600408C80008000C80010000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW27.rod
   VCID: 70BAD9BABA2150DB173-8024
   Generator:
   Component: 5-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5NA 959 442     HW: 5NA 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H06 0025
   Serial number: 2601917550901873BZ2B
   Coding: 250000
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 3250843205
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000332474005
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 313C1CBE71AB19D358D-8064
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000397175085
   Coding: 00311220D001028000001000
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 4DC4604E0D535D335C5-8018
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000036110727
   Coding: 1D0000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 151F0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B2D5AACE396CFBF3B-8020
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17111910522941
   Coding: 000000070900204600000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372822A69FCFC7E3169-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000396858048
   Coding: 00311020DC01028000001000
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 4CC26D4AF649543B4BB-8018
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000036011483
   Coding: 050000
   Part No SW: 3Q0 035 840 C    HW: 3Q0 035 840 C
   Component: MU-S--ER      724 0876
   Serial number:
   Coding: 02720600BE00000041110001000908001F0500F60120040002
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 2B000ED653877303621-807E
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H61 8214
   Serial number: VWZ6ZJW3322738
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 02720601EA16380D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: 3D24308EBDF3EDB3CC5-8068
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 15111915K10993
   Coding: 0002070600000401000200448150A90084000E20000000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40DA497ACA01805BA73-8014
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 508040727602
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
   VCID: 75B4E8AEC54375F3C45-8020
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 025E8372848D524BF17-8056
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H07 0009
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
End----(Elapsed Time: 01:45, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Adaptation channels all modules from factory:
https://drive.google.com/drive/folders/ ... sp=sharing
I am planning mods as and when possible and post here. Any advices, suggestions and recommendations are heartly welcomed.☺️
πŸ™
Re: Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
Looks like it has keyless start or even kessy as well?
patil
Post by patil »
iichel wrote: Sun Sep 11, 2022 3:40 pm Looks like it has keyless start or even kessy as well?
Yes iichel, previous post edited :)
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Congratulations Patil !!!
I am sure you got one more tick box checked with steel grey color ( like GT ) too
One more "Subscribed topic"
fluidicjoy
Drives: Polo 1.0 TSI 6AT (09G)
Post by fluidicjoy »
Congratulations on your car doctor! The Indium Grey is a lovely shade. Welcome to the MQB Club! The T-Roc is a lovely car and my parents spent quite a lot of time considering this car, but sadly we missed out on it. I am sure you will fully equip this vehicle to the brim. If I had to guess, MIB 2.5 Discover Pro, Direct TPMS, Side Assist might just be the first few things you retrofit. You are tempting me to start a thread about my Dad's Tiguan :D
patil
Post by patil »
ag69 wrote: Mon Sep 12, 2022 6:20 am Congratulations Patil !!!
Thank you ag69πŸ™
fluidicjoy wrote: Mon Sep 12, 2022 2:43 pm Congratulations on your car doctor! The Indium Grey is a lovely shade.
Thank you Sujoy..I feel lucky.. I love grey colour πŸ‘ŒπŸ˜
I agree with you, Direct tpms and BSD are absolutely must have safety features, as I am used to both in my 6R.
Nice T-Roc with a nice color. Very good choice!!!😍
I have the necessary files/info to update some of your units my dear Doctor, you already know that as well as my technical support they are totally free for you and for many other millions in India, ... and other Asian countries. πŸ§™β€β™‚οΈ
IMHO the first reply in your NEW thread doesn't seem very cordial, nor very friendly, but maybe/securely I'm wrong depending on what universe or mystical state our consciousness lives in. πŸ˜‚
ciclo wrote: Wed Sep 14, 2022 8:41 pm
Yes you are indeed wrong. Patil and I already broadly discussed his new vehicle on WhatsApp and I congratulated and complimented him there. In a cordial and friendly way. Don't worry 8)
Really what matters is what is publicly displayed, you should set an example as a moderator.
Communications outside the forum are your 'personal circumstances', blah, blah, blah ...
Please, try to lead by example and not disguise reality.
We already know here who is the one who is always 'wrong', ... fortunately it is written and cannot be disguised.
Don't worry, we are usually very compassionate here and put up with all kinds of users.
patil
Post by patil »
Time heals everything.. Physical as well as Psychological wounds, I say this from experience.πŸ˜ŠπŸ‘¨πŸ»β€βš•οΈ
A hug to you bothπŸ€—β€οΈ
πŸ™
patil
Post by patil »
ciclo wrote: Wed Sep 14, 2022 8:41 pm Nice T-Roc with a nice color. Very good choice!!!😍
Thank you for your appreciation dear Master☺️
I am humbled by your generosity. πŸ™
Please tell which all modules can be updated. I am very new to MQB, but I am sure I will learn quickly and get acquainted. :)
I have original VCP, VAS 5054A ODIS-E installed on Win7. Recently I purchased VAS 6154, but not yet installed.
Do I need to buy any other tool(s) ?
Any free info by email and with special conditions.
I recommend you to have good email relations with Slavik. https://www.drive2.ru/r/volkswagen/golf ... 815645123/
Install Team Viewer on your computer.
Not everything is free as in the 6R, we have to pay some tolls external to our will, ... but the result is worth it.
patil
Post by patil »
ciclo wrote: Fri Sep 16, 2022 7:52 pm Any free info by email and with special conditions.
Got itπŸ‘
I will contact you by email shortly.
Understood everything. πŸ‘Œ
TeamViewer/ Anydesk already installed in my PC. 8)
patil
Post by patil »
Dear Master, I want your suggestion regarding drawing the power supply for my upcoming retrofits.
I saw your post about additional fusebox:
viewtopic.php?p=574274#p574274
Can I do the same way you did. My fusebox is located behind the glovebox. I have taken picture from passenger side footwell area facing upwards. I can see 3 empty slots in fusebox carrier( highlighted area), I think these are for additional fusebox- 4 fuses (6R0937530A)?
What is absolutely OEM is to use the fuse holder for two fuses 6R0937530, being able to use 2 fuse holders in the same receiving hole.
But for the same price ... πŸ˜†, you can use the fuse holder for four fuses 6R0937530A, but it is necessary to make a small and insignificant correction in one of the guides so that it fits without any effort. It can be done with a cutter very easily.πŸ‘Œ
I didn't comment on this brief explanation in my thread about cutting/sanding the fuse holder guide of 6R0937530A because I knew my idea of getting positive feed from the back of the original fuse box would be copied by one of those miserable rats (not from this forum 🀭) who did not have the decency to name the author/creator of the magnificent idea. :lol:
