Polo 6c Composition touch possible rear camera retrofit
Re: Polo 6c Composition touch possible rear camera retrofit
are you trying with engine on or off? does it make a difference?
can you make an adapmap of 5f please?
giannis20vt
The engine was running when i tried this.iichel wrote: Mon Dec 11, 2023 10:14 pm are you trying with engine on or off? does it make a difference?
I will post the adaptation map to 2 separate posts because it is too big to fit to only one post.
I am starting from this post
SW:6C0-035-869-F HW:6C0-035-869-F --- Information Electr.
Component:MU-E--ER 050 7064, Coding:026200003C00000041110001010000001F0000940000010001
EV_MUEnt4CGen2LGE,001032,EV_MUEnt4CGen2LGE_VW26.rod
Monday,11,December,2023,19:23:04:16365
VCDS Version: Release 22.10.0 Data version: 20221026 DS344.0
VCID: 2E050EA5D094BBAB49E-807A
IDE00001-Production mode,00 00 00 ,3
IDE00346-Summertime-automatic,Europe ,1
IDE00758-Base volume of telephone,50 %,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00769-Call number 1 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE02063-Time display for start screen,2.0 s,1
IDE02121-CD eject button,Enabled ,1
IDE02122-Developer mode,not activated ,1
IDE02330-Call number 2 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02332-Deactivate production mode,0 ,3
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,42 ,49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,42 ,49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,42 ,49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,42 ,49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,42 ,49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,42 ,49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,42 ,49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,42 ,49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,42 ,49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,42 ,49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,42 ,49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,42 ,49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,42 ,49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,42 ,49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,42 ,49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,42 ,49
IDE02502-Confirmation of installation change,89 09 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,OFF ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,locked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,OFF ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,OFF ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,not installed ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,not installed ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,not installed ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,locked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
IDE04550-Bluetooth: Sniff mode,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 ,40
IDE11122-Country identification: country of sale HMI,SE ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,21
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
ENG117917-BAP_Debug_Mode_Release,not_released ,1
giannis20vt
Second part
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,not activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Powertrain data bus ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Powertrain data bus ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Powertrain data bus ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Extended data bus ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Extended data bus ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Powertrain data bus ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Extended data bus ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Powertrain data bus ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Extended data bus ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Comfort data bus ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Not available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Comfort data bus ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Powertrain data bus ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,available. ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,13 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,35 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,70 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %,12
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0 ,2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0 ,2
Re: Polo 6c Composition touch possible rear camera retrofit
does it make a difference if you have engine off, and put car in reverse?
giannis20vt
I didn't try that.iichel wrote: Tue Dec 12, 2023 7:25 am does it make a difference if you have engine off, and put car in reverse?
I will do that and post the results. I appreciate your interest and effort.
what happens is, reverse light will receive 12V. if engine starts, battery voltage is 13-14V. BCM will control reverse light voltage from 14 to 12V. This is with a PWM process.
The camera's power supply will turn into PWM and camera's don't like that. Solution is to change dimming value for reverse light from 100 to 127.
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64 --> activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64 ---> ok
giannis20vt
All right, that's very useful.iichel wrote: Tue Dec 12, 2023 8:26 am what happens is, reverse light will receive 12V. if engine starts, battery voltage is 13-14V. BCM will control reverse light voltage from 14 to 12V. This is with a PWM process.
I should mention that I have already connected an aftermarket parking sensor module to the reverse wire. I also installed a LED bulb for the reverse light, but I don't remember if I changed the dimming value from 100 to 127. I'll probably check that today.
Is it so that the screen shows the camera shooting when I engage the reverse gear?iichel wrote: Tue Dec 12, 2023 8:33 am ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64 --> activated
I believe so yes
giannis20vt
Well, i did some tests.
First I tried to put it in reverse with the engine off. I got the same result from what I expect from the engine.
i made this video:
https://youtube.com/shorts/SKEYH7FDG0c?feature=share
And those are the faults from the 5F module
I change the adaptations changes but without any different result.
So I changed everything back to how it was before messing with anything and I'll wait to connect the camera to do the tests again with real data.
i made this video:
Address 5F: Information Electr. Labels: 5G0-035-MIB-ENT2.clb
Control Module Part Number: 6C0 035 869 F HW: 6C0 035 869 F
Component and/or Version: MU-E--ER 050 7064
Software Coding: 026200003C00000041110001010000001F0000840000010001
Work Shop Code: WSC 00788 648 00255
ASAM Dataset: EV_MUEnt4CGen2LGE 001032 (VW26)
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2E050EA5D094BBAB49E-807A
2 Faults Found:
7178 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 68484 km
Date: 2023.12.11
Time: 21:22:25
Voltage terminal 30: 12.4 V
BAP-BAP_Function_ID: 00
6720 - Rear View Camera
B1102 31 [008] - No Signal
Fault Priority: 6
Fault Frequency: 2
Reset counter: 249
Mileage: 68438 km
Date: 2023.12.10
Time: 19:18:49
Voltage terminal 30: 13.3 V
giannis20vt
update:
I connected the camera to constant 12V power and test it with the infotainment system.
Works fine !!!
So the only coding needed is the Byte19-bit4 from 0 to 1. (rear view low activated)
Now when i put the reverse gear i can see the view from the camera in the screen. Super. When I shift from reverse to another gear the screen still shows the view from the camera for another 2 or 2 seconds.
This is nice. But I wonder: If by pulling out the reverse gear the camera doesn't get power, the screen will show blank for those 2 to 3 seconds. Is there a need for a device that supplies the camera with power for a little while longer?
Something like that:
Works fine !!!
giannis20vt
update:
I installed the rear view camera. I bought another type of camera. I got one that mounts on the license plate light so I don't have to drill a hole in the bumper.
I did the wiring throught the car. I connected the power to the reverse light (both +12 and -12V).
I know this is not the most suitable way to connect because as soon as I disengage the reverse gear, the error message "no reversing camera" comes on the screen.
Naturally, this happens because the power to the camera cuts off as soon as I disengage the reverse gear, while the infotainment waits for a few seconds for a signal from the camera.
I know I can connect the camera power permanently to 12v but that scares me. I am afraid that the camera will burn out, because it is constantly powered
What is your opinion? Should I dare to connect it permanently to 12V voltage?
Ah, it is like the BCM changes the reverse light voltage via PWM, which is causing problems with the camera's power supply. Adjusting the dimming value for the reverse light may alleviate this match issue.iichel wrote: Tue Dec 12, 2023 8:26 am what happens is, reverse light will receive 12V. if engine starts, battery voltage is 13-14V. BCM will control reverse light voltage from 14 to 12V. This is with a PWM process.
Hi Giannis20vt. I am trying to do the exact same thing to my polo from 2014. My radio unit is: 6C0 035 869A . I dont have access to ETKA website to check the PR if its support the reverse camera function or not. Do you have any idea if I can install a reverse camera same as you did on my unit? I will buy NTSC camera and all the wirings. I also have VCDS for programing. I am just stuck at the first stage and need to know if my head unit supports reverse camera or notgiannis20vt wrote: Tue Apr 18, 2023 7:30 pm I am willing to buy this one.
The Pr Code KA1 is for Rear View Camera (type1)
For sure this unit can have rear camera.
What Type1 is ? I mean what kind of camera i should buy ?
This is the original code
I know the solution for your issue. You need to get what is called: filtering and timer relay. What is basically does: filters the signal that comes from reverse light and at the same time it gives another 10 seconds of preview after you remove your car from reverse. Those relays are really cheap and they are made for this purposegiannis20vt wrote: Sat Feb 10, 2024 3:09 pm update:
