Yes (7E0937090B)
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
iichel wrote:...
PS, ciclo, does your 7E0 937 090 B BCM have the adress 65 (TPMS) available in the CAN gateway?
my 7E0 937 090 does not have it
iichel, you, me, CNK should search BCM 7E0937090B from T6 if we would like to have RKDS system. Ciclo's BCM is for Russian Polo Sedans with bixenon headlights and it doesn't work properly with LED headlights. The DRL has only one mode with full LED brightness, the parking-lights doesn't work at all.
Yes, with Bixenon headlights it works great. (All functions)
That's why I asked you to test my new BCM with your LED headlights. :wink:
Edit (PR-codes)
7E0937090B ZWM
8AA,8DU,8K0,8K1,8K3,8IG,8YU,9AA,9AB,9AK,I6F,I7E,I7F,I7G
http://vwtech.pl/kody-wyposazenia or http://igorweb.org/equidec.aspx
8AA = Without radio
8DU = Radio Entry-G (type 2)
8K0 = Without special headlight activation
8K1 = Separate daytime running lights
8K3 = Separate daytime running lights with low beam assistant and "Coming Home" feature
8IG = Gas discharge headlamp (D1/D3 system)
8YU = Radio preparation for commercial goods
9AA = Manually controlled heating system
9AB = Manually controlled air conditioning
9AK = Climatronic with impact pressure control free of cfc
I6F = MIB-G Standard 2 DIN (Asia) Export
I7E = MIB2-G Entry PQ/MQB radio ROW :)
I7F = MIB2-G Standard PQ/MQB radio ROW :)
I7G = MIB2-G Standard Plus PQ/MQB radio ROW/China :)
Monday,30,January,2017,15:14:59:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.2.0
Data version: 20170109 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate:
Mileage:   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6ACFCA949F68AF074F-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02679A6CF3701F2F8F-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EDBA2D0CFCC2793AF-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3891360EAF6EDBA5FF-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FBF48E1240093380FD1FCEB9FD0DAC067AF600D30D0200000030800
   Shop #: WSC 12345 123 12345
   VCID: 2A8F4AD497282FC74F-807E
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E9B2210CF8CA753AF-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4AAF0A341FC86F274F-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   VCID: 359230F7AB71E990E7-8060
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 68C1D69E6F7EBB757F-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E8B42E08F5C07E32F-807A
   Component: IMMO          H05 0607
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 3790340DAB6BDDA2F7-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F8844E51F530DEA37-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77D0B4CDA3AB5DE2F7-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B9C2C19D39FB5BED7-806E
End-------------------------(Elapsed Time: 04:14)--------------------------
CNK
Drives: 6R
Post by CNK »
iichel wrote:the A1 is based on the PQ35 electronics, for sure :(
All the time I thought that Audi is also on the BCM PQ25. But you're right. This is BCM from Audi A1:
ImageImage Image
Source: http://allegro.pl/modul-sterownik-audi- ... 37297.html#
But.. on Golf MK5 it's possible to change old CECM + CCM to new BCM PQ35. It's very popular mod on Golf's and Tourans in Poland (guide in Polish language: http://www.oknabramy-ostrow.pl/forum_mk ... cm&bcm.htm )
firegrafik
ciclo wrote: I7E = code not found :-(
I7F = code not found :-(
I7G = code not found :-(
I7E = RAO MIB2-G Entry PQ/MQB radio ROW
I7F = RAO MIB2-G Standard PQ/MQB radio ROW
I7G = RAO MIB2-G Standard Plus PQ/MQB radio ROW/China
Thanks!, edited at the same time. :lol:
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
Hola Fernando.
Do you know if it is possible to code the bi-Xenon headlights so the LED DRL's turn of when the Xenon projectors turn on??
Hej Martin
DRLs are already turned off when the Bixenon projectors are turned on.
If you mean front parking/side lights, it's unknown to me.
However it should be possible due to they are separated from rear parking/side lights. Maybe through some BCM adaptation channel, but it wouldn't be legal to drive in that way. :|
Mart!n-GTI-DK
I was the sidelights I meant.
I know it's not legal. But I would really like them off when the Xenon is on.
Maybe if we could get this menu...
...but since DRLs are mandatory I'm afraid it will be difficult.
DRLs are only mandatory here after January 1st 2011. Before that, when DRL was not mandatory, there was already bi-xenon with LED DRL (even though probably not on the Polo).
So maybe it's somewhere :-)
CNK
Drives: 6R
Post by CNK »
firegrafik wrote:
iichel wrote:...
So RKDS is available only in latest version of BCM? :cry:
Adam87
Drives: T5.2
Post by Adam87 »
Is there no way to enter a value In gateway installation, like in LongCoding when check box is not available? I haven't ever seen a way but have never looked.
Only other way - gateway update/flash
CNK wrote:
firegrafik wrote:
iichel wrote:...
CNK, If you mean Reifendruckkontrolle, so RDK, in such case :mrgreen: , yes, only available in 7E0 BCM Max lastest version. 7E0937090B
(you know I would prefer it to be possible with your current BCM, as well as the ones from firegrafik and iichel for LED Headlights)
You'll have to scratch your pocket to find the solution... (again)
I think that the best BCM is the one from Adam87. 8) (LED and Bixenon, RDK, HBA, etc...)
Adam87 wrote:Is there no way to enter a value In gateway installation, like in LongCoding when check box is not available? I haven't ever seen a way but have never looked.
Maybe by updating, but the last few times I went to the VW dealer this new BCM software was already available and my BCM 7E0937090 was not updated.
BCM for HBA, etc...
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001
BCM for :lol: , etc...
Revision: B9081001
Adam87
Drives: T5.2
Post by Adam87 »
I would say VCP is the best option for a flash/update of the gateway, maybe an email or a post on the VCP forum
Locked
