UK-POLOS.NET - THE VW Polo Forum • Polo 6R ABS CODING - Page 22
Page 22 of 35
Re: Polo 6R ABS CODING
Posted: Sun Sep 20, 2020 9:34 pm
by iichel
I don't know, sorry.
Posted: Mon Sep 21, 2020 3:17 pm
by By_soner
Heyy lichel In this way, error happens. Do you know what does it mean? Multimedya 5F
Posted: Mon Sep 21, 2020 3:26 pm
by iichel
Without an extended view, it's very difficult to say what exactly is happening.
Does this error dissappear after you put back your ABS coding? Perhaps you can share a full scan of the vehicle?
Posted: Mon Sep 21, 2020 5:52 pm
by By_soner
When I encode it for multimedia esc menu, I get this error. Maybe something has opened defixient, can you please help me?
don't think it's a mistake to do with Abs coding.
5F I found these ref to the brake:
Car_Function_Adaptations_Gen2:
menu_display_Brake_Function: activated
menu_display_Brake_Function_clamp_15_off: Not activated
menu_display_Brake_Function_over_threshold_high: activated
menu_display_Brake_Function_standstill: Not activated
menu_display_Brake_Function_after_disclaimer: Not activated
Car_Function_List_BAP_Gen2:
Brake_0x26: activated
Brake_0x26_msg_bus: Databus drivetrain
by By_soner
Posted: Mon Sep 21, 2020 6:37 pm
by iichel
Perhaps check this one in your ABS unit:
MAS00120-Anti-slip regulation (ASR) activated 1
This is from a polo 6c with ESP off via 5F:
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function activated 60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer not activated 60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off not activated 60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high activated 60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill not activated 60
Source:
https://forums.ross-tech.com/index.php? ... ost-106160
Posted: Mon Sep 21, 2020 7:59 pm
by By_soner
Not active multimedya Low probability of vesion I guessI guess :( thx For everything
Posted: Tue Sep 22, 2020 3:55 pm
by legendaryzz
iichel wrote: Sun Sep 20, 2020 4:44 pm
legendaryzz wrote: Sun Sep 20, 2020 4:41 pm
iichel wrote: Sun Sep 20, 2020 1:36 pm Strange. I believe your updated coding should be:
210248E3216F00B3842712E984D100401300
Perhaps type it manually or only change byte 2 & 10?
Both ways it gives error 22. Conditions not correct or request sequence error.
I also tried with 02 instead of 00 (for gti model)
Only the 28 byte 2 / 14 byte 10 is accepted. Very strange.
This is indeed unusual.
Update : When to the vw dealer. But they also couldnt change it. To bad.
Posted: Tue Sep 22, 2020 4:00 pm
by iichel
yeah I think the 6R 1.2 TSI engines with 105hp and 90hp have the same ABS coding in terms of engine type etc. Oh well, one of those things.... sorry it didn't work out.
Posted: Thu Oct 22, 2020 10:48 am
by Koukou24
Salut, je besoin codage abs pour polo sedan indian d'un moteur 1.4 essence année 2013
Vin:WVWZZZET083814
6R0907379AQ
ABS 9.0 front
Merci d'avance
Posted: Thu Oct 22, 2020 12:21 pm
by iichel
I'm going to need you to communicate in English please and I'm going to need more information:
LHD/RHD
Engine
Gearbox
ESP
TPMS
VIN
Why is the coding lost?
Posted: Thu Oct 22, 2020 1:11 pm
by Koukou24
Polo berline
made in india
Gearbox manuelle
Posted: Thu Oct 22, 2020 1:21 pm
by iichel
Why was the coding lost?
Posted: Thu Oct 22, 2020 1:29 pm
by Koukou24
Change ecu + instrument
Posted: Thu Oct 22, 2020 1:33 pm
by iichel
LHD/RHD --> ???
Engine --> CLPA
Gearbox --> Manual
ESP --> No
TPMS --> ???
VIN --> WVWZZZ60ZET083814
Why is the coding lost? --> new instrument and cluster
I need to know LHD/RHD and TPMS
