Polo 6R ABS CODING
Re: Polo 6R ABS CODING
Lhd
TPMS=»» No
Abs 9.0 front
Engine ==» 1.4L. gasoline 85 ch
TPMS=»» No
Abs 9.0 front
Maybe try: 60DD2763212B18C3061CE46A845518000000
you are genius
Thank you
I am grateful to you
Thank you
you are genius
Thank you
Thank you
Was it accepted?
Yes
Thank you
you are genius
Great, enjoy your car again.
Please how did you do that
There is some logic into the codings of all ABS units. They contain the VIN, engine type, brake size, gearbox type etc.
theautohouse
- Drives: seat ibiza
Hi
i am new to this form, is there any one can help me for coding.
i have replacedabs pump on seat ibiza 2009 vin VSSZZZ6JZAR039267
1.4L PETROL, BXW ENGINE, 86BHP 4CYLENDR new abs 6R0907379AB
privous code abs8.2 was 100200db007000bb082700e800d800000000
esp 9.0 was 13dd287d287d212500c8c81d1470845100880905
both of them not working i copied from old moudule but they didnt work.
if anyone can help me much appricated . thanks
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Does anybody know what these channels in Adaptation (ESP 8.2i) are for?
- 21: 0 - 1 - 2 (default value "1")
- 51: 0 - 1 (default value "1")
- 73: 0 - 1 (default value "1")
- 99: 0 - 255 (default value "0")
There are some channels for the hill hold assist strength and the brake drying, but I don't know what channels they correspond to.
I think there is basic setting for the ESP unit that covers all the sensors. The G202 and G251 are integrated into the ABS block.
So my comment is probably not adding much, sorry.
- Jay-Jay
Thank you anyway, iichel.
I hope someone else knows the answer (maybe firegrafik?).
Hello guys,sorry for bringing a Fabia to this forum,but i need desparate help,maybe i can get it here since i have identical ABS from Polo.
Short story,Fabia 2012 with engine swap to CBAB DSG fom CAYC manual,now ABS needs coding.Below are my logs from car,i managed to write Fabia VIN nr to ECU(from passat). Need to mention ABS is working,but MIL is on blinking(ABS and ESP),any conding that i put says Error 31.Thanks
Thursday,10,December,2020,00:58:54:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.1.0 (x64)
www.Ross-Tech.com
VIN: TMBEL25J7C3023269 License Plate: B112BXR
Mileage: 207280km-128797mi Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 37 44 56
VIN: TMBEL25J7C3023269 Mileage: 207280km-128797miles
02-Auto Trans -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 CL HW: BXR GARAGE
Component: R4 2,0L EDC G201AG 6222
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 71E960C368A9130EF4-8024
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 057 P HW: 02E 927 770 AL
Component: GSG DSG AG6 521 3128
Revision: 05652104 Serial number: 00001402060937
Coding: 0000020
Shop #: WSC 20294 210 01865
VCID: 2643439F91E704B651-8072
1 Fault Found:
18261 - Powertrain Data Bus
P1853 - 000 - Implausible Message from ABS Controller
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 207286 km
Time Indication: 0
Date: 2015.05.03
Time: 00:37:58
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AA HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0003
Revision: --------
Coding: 410148DB416F00B5822712E882DA00421300
Shop #: WSC 13765 790 00019
VCID: 7DF14CF3E0F1676E60-8028
5 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 6
Reset counter: 0
Mileage: 207284 km
Time Indication: 0
Date: 2015.05.02
Time: 21:25:51
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1051
Hex Value: 0x1B97
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7FF9
01314 - Engine Control Module
Fault Priority: 0
Fault Frequency: 6
Reset counter: 0
Mileage: 207284 km
Time Indication: 0
Date: 2015.05.02
Time: 21:25:51
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1024
Hex Value: 0x1497
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7FF9
03306 - Coding Not Valid
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 0
Mileage: 207284 km
Time Indication: 0
Date: 2015.05.02
Time: 21:25:51
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1003
Hex Value: 0x2597
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7FF9
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 207286 km
Time Indication: 0
Date: 2015.05.03
Time: 00:44:26
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x32E7
Hex Value: 0x25B2
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7EF9
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Fault Status: 00100101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 207286 km
Time Indication: 0
Date: 2015.05.03
Time: 00:47:35
Hex Value: 0x0003
Hex Value: 0x0000
Hex Value: 0x3202
Hex Value: 0x25B2
Hex Value: 0x00FF
Hex Value: 0x807F
Hex Value: 0x7EF9
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H08 0103
Revision: K0000000
VCID: 2A5BB7AF45FF20D675-807E
Part No SW: 6R7 937 087 H HW: 6R7 937 087 H
Component: PQ25 BCM H12 0022
Revision: -1------ Serial number: 1002480801
Coding: 7C988B3F0801000000300E003E2B88C20080400F600400400000
VCID: 4999E823E0B90BCE9C-801C
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3211
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
1 Fault Found:
00901 - Back-Up Lamps
011 - Open Circuit
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0003
Revision: --H10--- Serial number: 32901116200455
Coding: 100001
ASAM Dataset: EV_SK25XParkiAssis2 S01002
ROD: EV_SK25XParkiAssis2.rod
VCID: 72EB6FCFA5AF28160D-8026
Component: VW10AirbagT20 H09 0020
Revision: -------- Serial number: 003GX00PR3L%
Coding: 003230
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00D695-801E
Serial number: 3495RRB405J0K4DOO91.
Serial number: 3505RRB405J0K4DOAGP3
Part No SW: 5J0 920 841 D HW: 5J0 920 841 D
Component: KOMBI H03 0305
Coding: 120800
Shop #: WSC 13765 031 00019
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
VCID: 2B55B2AB420539DE8E-807E
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 087 H
Component: GW-K-CAN TP20 0022
Revision: -1------
Coding: 032200
VCID: 70EF65C7A3A31A06FB-8024
Component: IMMO H03 0305
Shop #: WSC 00000 000 00000
VCID: 6ADB77AF8D7FE0D6B5-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3T0 035 192 C HW: 3T0 035 192 C
Component: RNS315-EU H32 0263
Serial number: SKZAZ2L9205475
Coding: 000004110406000000000001
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 2E53BBBF71174CF6A9-807A
2 Faults Found:
1048582 - GPS Antenna
B1054 13 [009] - Open Circuit
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 207286 km
Date: 2020.12.10
Time: 00:37:58
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [009] - General memory failure
Fault Priority: 4
Fault Frequency: 1
Mileage: 81326 km
Date: 2016.06.22
Time: 19:27:39
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11220
Shop #: WSC 01992
VCID: 306FA5C7F7235A06BB-8064
1 Fault Found:
49-10 - No Communications - Intermittent
End-------------------------(Elapsed Time: 02:05)--------------------------
www.Ross-Tech.com
Coding: 0000078
Coding: 0000020
1 Fault Found:
Fault Priority: 0
Reset counter: 40
Mileage: 207286 km
Time Indication: 0
Date: 2015.05.03
Time: 00:37:58
Revision: --------
5 Faults Found:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 0
Mileage: 207284 km
Time Indication: 0
Date: 2015.05.02
Time: 21:25:51
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1051
Hex Value: 0x1B97
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7FF9
Fault Priority: 0
Fault Frequency: 6
Reset counter: 0
Mileage: 207284 km
Time Indication: 0
Date: 2015.05.02
Time: 21:25:51
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1024
Hex Value: 0x1497
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7FF9
Fault Priority: 0
Fault Frequency: 8
Reset counter: 0
Mileage: 207284 km
Time Indication: 0
Date: 2015.05.02
Time: 21:25:51
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1003
Hex Value: 0x2597
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7FF9
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 207286 km
Time Indication: 0
Date: 2015.05.03
Time: 00:44:26
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x32E7
Hex Value: 0x25B2
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7EF9
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 207286 km
Time Indication: 0
Date: 2015.05.03
Time: 00:47:35
Hex Value: 0x0003
Hex Value: 0x0000
Hex Value: 0x3202
Hex Value: 0x25B2
Hex Value: 0x00FF
Hex Value: 0x807F
Hex Value: 0x7EF9
Revision: K0000000
Coding: 020000
Coding: 020000
Coding: 020000
Coding: 020000
1 Fault Found:
011 - Open Circuit
Coding: 100001
Coding: 003230
Coding: 120800
Revision: -1------
Coding: 032200
2 Faults Found:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 207286 km
Date: 2020.12.10
Time: 00:37:58
Fault Priority: 4
Fault Frequency: 1
Mileage: 81326 km
Date: 2016.06.22
Time: 19:27:39
Coding: 11220
Shop #: WSC 01992
1 Fault Found:
Perhaps it can be queried using the VAS.Jay-Jay wrote: Wed Dec 09, 2020 11:25 am Thank you anyway, iichel.![]()
