Hi reido80
About the chassis type (Byte1):
I believe, I thought previously, that for the T5.1- 2 (GP) the corresponding value is 00 Twist Link Rear Axle suspension for Bit 4-5.
It is not directly related if it is 2wd or 4wd, or number of sensors, it is more about the type of axle for the suspension in general terms or of a specific axle.
This is what I understand by a Twist link rear axle and not a Multi-link rear axle, however please correct me if I am wrong because my technical English is as good as my technical Russian.😁... 🤣
Thus:
New coding:
0206000001000000
Try this new coding and try the basic setting again, maybe now the conditions are correct.
reido80 wrote: Fri Oct 23, 2020 1:12 pm ...
There is another option is the drop down for basic settings-
IDE01475-Resetting of all adaptations
I am reluctant to do this as when it is selected it shows the following.....
WARNING
Resetting adaptations in this module is likely not reversible, and reparameterization may require the dealer tool with online connection.
Do not touch :lol: ... for now.
reido80
Drives: VW t5.1 GP bitdi 4motion
Post by reido80 »
Hi Ciclo,
Very pleased to say, we have success :D :D :D
I had the terminals in the front sensor plug in the wrong locations :oops:
scan -
Saturday,24,October,2020,15:01:25:03258
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZDH0   License Plate: FINAL!!
Mileage: 130900km-81337mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 55 56 69 0B
VIN: WV2ZZZ7HZDH0   Mileage: 130900km-81337miles
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
56-Radio -- Status: Not registered 0011
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 GK    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H37 3566
   Revision: 22H37---    Serial number: 00000000000000
   Coding: 0119401A233600080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906019GK 003003
   ROD: EV_ECM20BTD01103L906019GK_003.rod
   VCID: 7AADF0A04C5F927B1C7-802E
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108764AD19A6089626A99878BA6610
   Shop #: WSC 02756 790 49152
   VCID: 392F2FAC0959596355D-806C
   Part No SW: 7E5 907 047 BG    HW: 7E5 907 047 BG
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 75B7E39C6541FD03715-8020
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0725
   Revision: B9074001    Serial number: 0671 186141457
   Coding: B8B07DB84E61241193284EF16EAB9751F28066FF40857841320000020000
   Shop #: WSC 02739 790 12345
   VCID: 2F3B11F4C71D87D3FB9-807A
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 201114 05  54  0403
   Coding: 0630AD
   Subsystem 2 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3313
   Coding: 050000
   Subsystem 3 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3313
   Coding: 050000
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0390005
   Coding: 820000
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261217200384
   Coding: 118001
   VCID: 392F2FAC09D9596355D-806C
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00CRH9K
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3537239C25C1BD03B15-8060
   Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
   Component: KOMBI         H06 0605
   Coding: 160E01
   VCID: 2E050CF0C0978EDBF0F-807A
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2411EED892DB348B16B-8070
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0725
   Revision: B9074001
   Coding: 042300
   VCID: 70B9D2881AA3D82BA23-8024
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 130905 km
                    Time Indication: 0
                    Date: 2015.03.17
                    Time: 23:46:55
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000007
   Shop #: WSC 02756 790 00000
   VCID: 372B2994334D4F13A39-8062
   Component: IMMO          H06 0605
   Serial number:
   Shop #: WSC 12345 123 12345
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6A8DC0E03CFF22FBEC7-803E
   Revision: --------    Serial number: --------------
   Coding: 0202000001000000
   Shop #: WSC 02757 790 50316
   VCID: 77ABE9947F4D8F13639-8022
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00008030224120
   Coding: 410D000101000000
   VCID: 313F178CD1299123EDD-8064
End----(Elapsed Time: 02:18, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
Address 19,6N0 909 901 ,recoded (Installation List),from,DD0B3C080000,to,DD0B3
Great! 8)
Thank you for posting your progress as you went through the different stages of upgrades/improvements/etc... it has been very interesting for me. I hope you can enjoy your Transporter again after all the work and time invested.👍
paulmik
Drives: T5.1 + T6
Post by paulmik »
Hello and greetings from Norway! :)
Spesial thanks for Ciclo for so much information about BCM upgrade and Auto headlights retrofit.
I have H7 factory headlights, no fog/cornering lights. By now i just want to do only auto headlights and keep factory H7. Planing upgrade to T6 led later on :)
I Have upgraded BCM (following cruise control and MFSW), installed RLS with dim mirror, new auto healights 10pin auto swich and new dimmer. Wiring adaptation for BCM controled lights is done acording ciclo's guide in prevous posts.
All looks very promising, just ran into some small problems and i think it just codding issue.
1. When swich is set to auto or lowbeam high beam indicator allways stays on on instrument cluster. High beam works as it should.
2. When swich is set on auto, low beam is allways on, no matter if it's light or dark outside. Same with Leaving home function.
I was looking to test RLS output, but could not find it how on VCDS. Just wanted to make sure that ligt sensor is working. Rain sensor working as it should.
3. Missing rear fog lights. Can activate it by VCDS but nothing happens from swich.
I would apriciate any help for solving this :roll:
Here is my latest scan
Monday,02,November,2020,08:30:50:02642
www.Ross-Tech.com
VIN: WV2ZZZ7HZAH272398   License Plate:
Mileage: 145590km-90465mi   Repair Order:
Scan: 01 03 04 08 09 15 17 18 19 25 6E 0B
VIN: WV2ZZZ7HZAH272398   Mileage: 145590km-90465miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CAAB)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CD    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X35 9118
   Revision: 26X35---    Serial number: 00000000000000
   Coding: 0111401A230400080000
   Shop #: WSC 66565 257 00032
   ASAM Dataset: EV_ECM20TDI01103L906022CD 002013
   ROD: EV_ECM20TDI01103L906019AM_002.rod
   VCID: 698FBB7359F94763E5D-803C
   Part No SW: 7E0 907 379 F    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0104
   Revision: 00H43001
   Coding: 108724AD09AB089724A5907A6A6610
   VCID: 353727034541D383B15-8060
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 H    HW: 7E5 907 040 H
   Component: ClimatronicT5 H10 0101
   Revision: 00002001
   Coding: 0004000102
   Shop #: WSC 17851 000 1048576
   ASAM Dataset: EV_ClimatronicT5 A01002
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 2D070F63AD919B43C95-8078
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0010302120015159
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 340133098
   Coding: 62A039BA4A21201301280F316CEB8ED40290600F7E0178E1320000020000
   Shop #: WSC 02736 790 12345
   VCID: 2D070F63AD119B43C95-8078
   Component: RLS 270812 05  54  0403
   Coding: 0730AD
   Subsystem 2 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Serial number: 40000000000000199814
   Coding: E20000
   Component: VW10Airbag003 H05 0013
   Revision: --------    Serial number: 003HL00020GG
   Coding: 000000000000000000000000000000003033
   VCID: 3537270345C1D383B15-8060
   Part No SW: 7E0 920 870 A    HW: 7E0 920 870 A
   Component: KOMBI         H16 0111
   Coding: 160E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   VCID: 270BFD4B8F6DB113339-8072
   Part No: 7E0 815 071 A
   Component: J737__Standheizung  0404
   Revision: 00085000    Serial number: 09019275D00000
   Coding: 0000031
   VCID: 2313E95BF7D55D336F1-8076
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 042200
   VCID: 70B9D6177AA3B6ABA23-8024
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H16 0111
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0185
   Revision: 10100011    Serial number: 280246
   Coding: 000102
End----(Elapsed Time: 01:40, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Hello paulmik, between today and tomorrow I will review your BCM coding. :wink:
paulmik wrote: Mon Nov 02, 2020 5:03 pm Hello and greetings from Norway! :)
www.Ross-Tech.com
   Revision: 00H43001
   Revision: 00002001
   Coding: 0004000102
   Slave 1:
   Coding: 0730AD
   Coding: E20000
   Coding: 160E00
   Coding: 0000031
   Revision: B9074001
   Coding: 042200
   Serial number:
   Coding: 000102
Hello again, I have already checked your BCM coding.
Due to your current BCM coding you have to confirm the following:
- Do you have the start / stop system installed on your T5?
- Do you have bi-xenon headlights installed?
The answers seem obvious from your comments, but I am currently making no assumptions. :)
It is not necessary, but it would be convenient for you to post an autoscan before any modification for automatic lights, that is, with the old BCM installed with everything OK. It would help tremendously and give you a perfect coding for your current BCM, lighting system, etc ... The current one appears to be a disaster (nothing worrisome ... :lol:).
paulmik
Drives: T5.1 + T6
Post by paulmik »
Thanks Cisco that you have found some time to check it. I think more disastrous it is more interesting it is for you :D
The BCM MAX came used from 2017 mod transporter. That one had start/stop, and was giving some errors for me. After reading some posts i have disabled it, just don't remember how :)
I think i was some think it was something with batery regulator controler.
Mine T5 has no start/stop system and no Xenon lights, eaven i do have som coding on bit 23 :)
But i just becouse have tryed a looot of diferent coding on my BCM max, stange that is still alive :lol:
This one should be original codding of my BCM 086:
Monday,14,September,2020,18:38:38:02642
www.Ross-Tech.com
Scan: 01 03 04 08 09 15 17 18 19 25 37 56 69 0B
   Revision: 00H43001
   Revision: 00002001
   Coding: 0004000102
   Slave 1:
   Part No SW: 7H0 937 086 B    HW: 7H0 937 086 B
   Component: BCM T5GP M++4 H46 0207
   Revision: BM046001    Serial number: 0154 120100517
   Coding: A8F06D3A2E232002002006803F6B8DD40000410F60044040300000000000
   Shop #: WSC 02756 790 12345
   VCID: 323D1C1FB42FC4BB947-8066
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Coding: 160E00
   Coding: 0000031
   Part No SW: 6N0 909 901     HW: 7H0 937 086 B
   Component: GW-K-CAN TP20 0207
   Coding: 042200
   Serial number:
End----(Elapsed Time: 02:06, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Good morning paulmik.
Thanks for the autoscan with the old BCM, 'same mileage' as the last autoscan with the new BCM, ... just perfect.
New BCM coding: (Automatic lights, CH/LH)
A8F06DBA2E232002012006A03FEB8FD40000610F60046041300000020000
It is based on the BCM coding of your old BCM.
Please try the above BCM coding and tell us the results.
Check all lights, including interior lights, license plate lights, reversing light, rear fog light.
Note: I leave the lights for Scandinavian countries activated, as they were previously active, which is so that the parking/side lights always remain on.
Note 2: Errors may arise depending on the electrical installation and other factors. Do not panic, it will be solved later. :wink:
The AUTO function will work, in dark, shady areas (garages, tunnels, etc.) and after activating the windscreen wiper (there are on and off times in these circumstances).
The CH function is semi-automatic, it is necessary to remove the key from the ignition switch, pull the HB lever once (flash) and open or keep the driver's door open.
The LH function is automatic, when you press the unlock button with the remote control.
paulmik
Drives: T5.1 + T6
Post by paulmik »
Thanks Ciclo!
ciclo wrote: Tue Nov 03, 2020 5:19 am Thanks for the autoscan with the old BCM, 'same mileage' as the last autoscan with the new BCM, ... just perfect.
Yeah, i just drive in and out of garage for last two months now after i starting retrofiting :cry: However i got +1km today :D :D
Hopefully i can start use van more soon, specialy in winter season for going skiing with kids. It starts to look promissing with your help Ciclo!
ciclo wrote: Tue Nov 03, 2020 5:19 am The AUTO function will work, in dark, shady areas (garages, tunnels, etc.) and after activating the windscreen wiper (there are on and off times in these circumstances).
I was lucky with sunny weather today, so could test light sensor properly :)
Sensor works like it should. Only park lights then it is light and sunny. I have covered sensor and than Low beam kicked in and CH function became active.
Have checked all lights both in auto and manual.
Parking - OK
License - OK
High beam - OK
Low beam - OK
Breaks - OK
Indicators - OK
Rear foglights - not working.
High beam blue indicator light at my instruments is still allways on. Both on auto and manual.
Rear fog light still not working.
I have dobbel checked wiring for fog light. Like it is now, i have ran new direct cable from pin7 from 10 pin conector light swich to 73b/43 for rear fog lights input and output from 73a/6 to original t17/9. Ran output test from VCDS again and it fig light ligts up. Thinking must be something between swich and bcm...
Here is my BCM scan after your codding. Came an error message of incorect codding of BCM. Everything else like MFSW, RLS... looks ok and working.
And by a way, sorry for my English, it's not my native language... :oops:
Tuesday,03,November,2020,04:29:46:02642
www.Ross-Tech.com
   Revision: 00H43001
   Revision: 00002001
   Coding: 0004000102
   Slave 1:
   Coding: A8F06DBA2E232002012006A03FEB8FD40000610F60046041300000020000
   Coding: 0730AD
   Coding: E20000
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 145591 km
                    Time Indication: 0
                    Date: 2015.03.27
                    Time: 04:48:29
   Coding: 160E00
   Coding: 0000031
   Revision: B9074001
   Coding: 042200
   Serial number:
   Coding: 000102
End----------(Elapsed Time: 01:24, VBatt start/end: 12.3V/12.3V)-----------
In case you had to enable any Bit in the BCM when you installed the J702 unit (Ctrl Head Roof) re-enable them.
The reason the high beam indicator light is always on is because there is something wrong with the wiring installation. Fuse 28 (fuse 27), wire going to T73a/62, or something close to ...
Something strange is happening here, the wire that goes to the high beam indicator light is not touched in the BCM adaptation.
This wire is connected to the supply that leaves from T41/39 (Stlaks) and that goes to the SC28 fuse to later supply the high beam for the right headlight and the indicator light on the instrument panel.
If you do not find the problem, remove and isolate the wire that goes to the instrument panel T32/14, install-attach a new wire 0.5mm2 from SC28b (output) to T32/14.
What AUTO light switch are you using?
Test unchecking Byte22 Bit6 and check if the rear fog lights work. (in my 6R the rear fog light stops working when this Bit6 is enabled)
paulmik
Drives: T5.1 + T6
Post by paulmik »
ciclo wrote: Tue Nov 03, 2020 5:45 pm In case you had to enable any Bit in the BCM when you installed the J702 unit (Ctrl Head Roof) re-enable them.
I haven't done any changes in codding for J702 appart that i have added it to installation list.
ciclo wrote: Tue Nov 03, 2020 5:45 pm The reason the high beam indicator light is always on is because there is something wrong with the wiring installation. Fuse 28 (fuse 27), wire going to T73a/62, or something close to ...
:oops: :oops: ...uff, i have done total rookie mistake here. I have ran High beam signal from wrong fuse. I have ran wire to T73a/62 from SC28, not from SB28 as you described. Now it fixed and no more constant high beam indicator :roll:
ciclo wrote: Tue Nov 03, 2020 5:45 pm What AUTO light switch are you using?
Bytte 22 bit 6 didn't made any diference. Rear foglight still not working.
I don't have front fog lights yet, but my switch is for both foglights, so i have ran wire from pin 5 light swich to T73a/7 just in case. No change...
Here images from my light switch. It's from 2020mod T6.1 transporter.
Image Image
Perfect! 8)
Even I have made a mistake in my previous post when writing SC28 when I wanted to tell you SB28, as described in the installation guide that I made.
Belonging to the select group of rookies makes us better ... Image
The light switch is not correct, it belongs to other platforms (Golf VII, etc) and it is the reason why your rear fog light does not work. The management of the rear and front fog lights is managed by electronic signals through a single communication wire with the BCM.
You must buy the correct light switch:
- 3C8 941 431A XSH
or
- 5ND 941 431B XSH
or 5ND 941 431E XSH
This is the light switch I have on my 6R, with a more updated look, it is very hard to find.
It is the original VW light switch that was installed on the 2016 Tiguan for the Chinese market.
Note: be very careful if you search on Aliexpress, they can send you a switch for Golf VII, Polo 6C, etc ... which is not compatible with the PQ25, just like the one you currently have.
BCM coding is totally correct, I do not know the reason for that 'fault' being generated.
Did you have the J702 enabled in the GW installation list with old BCM?
What you also can do is take the internals from a PQ25 light switch and put it into the housing of the MQB switch. That's what I did with my own light switch.
But then you'll notice that the rotation of the light switch is slightly off, it's rotated. So I put in the dashboard of a Polo 6C.
So it's probably best to take the light switch with the part numbers as mentioned by ciclo.
paulmik
Drives: T5.1 + T6
Post by paulmik »
That was it! Thank you so much Ciclo!
I did had new 3C8 941 431A XSH switch laying aroud, brought from aliexpress long time ago. Changed it and fog light everything else is working now :wink: Sad, i liked that one becouse of white lid :) Looks like T6.1 has some big changes in electrical system for all new functions added in latest models. Maby switch will work on mine T6 2017mod :idea: :D
ciclo wrote: Wed Nov 04, 2020 4:17 am BCM coding is totally correct, I do not know the reason for that 'fault' being generated.
No, i didn't. I have added J702 after upgrading BCM. But i have't got it working yet. If i understant right my Aux.heater C 7E0 815 071 A needs a new firmware from or similar to 7E0 815 071 C to get it working with J702 so i have put it on hold for now...
Ok, ok, everything is settled for now. Great! 👌
paulmik wrote: Wed Nov 04, 2020 3:45 pm
... Maby switch will work on mine T6 2017mod :idea: :D
I'm afraid not, the VW T6 still belongs to the PQ25 platform, in fact, we got a lot of hints to make further modifications to our PQ25s after the launch of the VW T6, a real gift for us. :lol:
The VW T6.1 8) belongs to a different platform, more aimed at the electronics of the latest models.
