benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Dont have the bit 3 tick box doesnt mean you cant change the coding. Just change the fourth last binary digit to 1. Read the binary backwords.
76543210
favi wrote: Sun Jun 11, 2017 7:30 pm Little problem with The two static cornering lights turn on with reverse
Don't have BIT3 :(
Dammit. :lol: favi, all BCMs have such Bit.
You have to change the Bit in the Binary.
How to do it?
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
I will just put it here :D
New unit comes with Polo Sedans (Vento) from Russian VW factory.
Suspect this one is for MX market with 315MHz. I suppose we will see european 7E0937090D soon.
favi
Drives: 6R
Post by favi »
ciclo wrote: Sun Jun 11, 2017 7:57 pm Dammit. :lol: favi, all BCMs have such Bit.
I know how it works (change BIT 3 in BYTE 21), but after changing BIT3 from 0 to 1 I have not seen the option, just like yours screenshot "Static cornering light ...."; D
But ... I saw today that everything works though :)
Hard days at work and such effects; D
So, thank u very much again ciclo :)
58 sec... (benji58 :wink: )
*****XML GENERATOR*****
http://htmlpreview.github.io/?https://r ... rator.html
*****TIRE PRESSURE*****
http://blobs.continental-tires.com/www8 ... e-data.pdf
There are still many things to test. (Play with CAN lines)
More information next week ... or ... when be possible. :)
firegrafik wrote: Sun Jun 11, 2017 9:17 pm I will just put it here :D
Good info!! thanks firegrafik. Hmm... I want it!!! :lol:
Hmm2 :lol: ...as far as I know for 7E0:
433 MHz 7E0 937 090 Max4
315 MHz 7E0 937 190 Max3
However, it is always necessary to verify it in the ETKA to be totaly sure. :wink:
firegrafik
ciclo wrote: Thu Jun 15, 2017 5:48 am
As I have got for 090 units:
7E0937090 - 434 MHz
7E0937090A - 315 MHz
7E0937090B - 434 MHz
7E0937090C - 315 MHz
so possible
7E0937090D - should have 434MHz
Guy, who sent me that photo,had tried to install that 090C on his Polo, keys adaptation wasn't success.
Okay. Thanks again.
I'll keep you informed by email about TPMS progress.
By the way, yesterday I went to my VW dealer to update the instrument cluster software and VW estimated that the software for my IC is correct and was not updated ... I had to pay for the diagnostic session (logically) ...
:evil: 1000x
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00788 219 00200
VCID: 35A22007DB61D9A0FD-8060
rdasadia
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140E01
Shop #: WSC 12345 123 12345
VCID: 47DEBB70FE4B81781C-8012
govindsharma
Component: KOMBI H03 0805
Coding: 140A00
Shop #: WSC 17218 938 12345
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 479D317AFE6CDE7A21-8012
New CAN lines. TEST MODE
:arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Images for TPMS wiring installation, the others CAN-lines are widely known. :)
Wednesday,14,June,2017,11:29:20:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: With indirect TPMS OFF (ABS & IC)
Mileage: 24890km-15465mi   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage: 24890km-15465miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A57422C17E0178FDD-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401500
   Shop #: WSC 40308 002 104857
   VCID: 02EF12E47BE887B71D-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7E631A684744AF1B3D-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3819AE8657E6432D4D-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FBF48E12400B3380F916CEB9FD0DAC0672F600D30D0200000030800
   VCID: 2A17C26C1FA0974FDD-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E239AA847042FDB3D-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A3782CC9740D7AFDD-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Coding: 140E00
   VCID: 351AA88F23E9511865-8060
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 68494E1617F623FDCD-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E13BA7807D48F6BBD-807A
   Component: IMMO          H05 0607
   Shop #: WSC 00000 000 00000
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 3718AC8553E3452A75-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F10BC7DA7CB7572B5-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77582C455B23C56A75-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_VW51.rod
   VCID: 3718AC855BE3452A75-8062
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B24A4914B173DC655-806E
End-------------------------(Elapsed Time: 04:25)--------------------------
More information when possible... :wink:
Adam87
Drives: T5.2
Post by Adam87 »
At last one with TPMS (J502) can now compare auto scans,
Adam87 wrote: Sat Jun 17, 2017 12:23 pm At last one with TPMS (J502) can now compare auto scans,
Exactly!! :wink:
I will be back soon. :mrgreen:
Saturday,24,June,2017,14:41:06:06516
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: INDIRECT TPMS ON (DIRECT TPMS INSTALLED)
Mileage: 24920km-15484mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 24920km-15484miles
Readiness: 0000 0000
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Coding: 01
   Revision: V0000000
   Coding: 0728DD
   Coding: 0200A3
   Coding: 1000AB
   Coding: A4FFFF
   Coding: 18BC32
   Coding: 18BC32
   Coding: 308001
   Coding: 00314D
   Serial number: 358
   Coding: 140E01
   Revision: B9081001
   Coding: 002200
   Revision: AA001001
   Coding: 010100
   Coding: 11221
   Shop #: WSC 00788
End-------------------------(Elapsed Time: 04:28)--------------------------
Everything works fine/perfectly in the TPMS unit (Advanced Measuring Values -VCDS) without faults after a Drive Test, but still the information is not displayed on the MFA +. :lol: (Ah! yes, the CAN lines via powertrain)
More information when possible ...
PS: During the summer (vacations, etc...) I hardly have enough time to read the new topics of the forum (6R / 6C), I apologize for it.
patil
Post by patil »
ciclo wrote: Sun Jun 11, 2017 5:54 pm
patil wrote: Sat Jun 10, 2017 8:15 pm Master Ciclo... I have a question regarding trunk light wiring.
Actually Indian Polo 6R does not come fitted with trunk light. I have retrofitted the trunk light and tapped the wiring from front dome light. So whenever any of the doors are opened trunk light will turn on, same way as footwell lights. I want to wire it like oem, so that light should lit only when trunk is opened and go off when trunk is closed. Is it possible?
I looked into wiring diagram, mentioned during your 2nd trunk light installation.
Pin 1 tapped from Pin1 T5h(Rear lid lock) RED/BLUE color wire.
Pin 2 from +30
Now the problem.. The RED/BLUE color wire in my car is in pin4, and a white wire is on pin1... please see picture.
How to proceed from here? :roll:
... in your case (6R IND), the winner ('ground wire') for trunk light is purple/violet wire. You can check with a diagnostic lamp/multimeter before splice or damage this wire.
Power supply is right (from the dome light).
Master Namaste :D
Bang on!!! You are right..... purple/violet wire is indeed winning wire... Brilliant :lol:
I have rewired the trunk light connection, and now trunk light work exactly like OEM as I wished. :lol: :lol:
Thanks a lot again, Master :D
Hahaha ... perfect !! 8)
I have to comment that it took me some time to review the diagrams to conclude that it was the purple wire, and taking into account that I do not have the diagrams for the Polo 6R IND :mrgreen: is a good find. :lol:
Thank you for the report!!. Namaste.
:lol:
Locked
