hepike
Drives: 6R 2010
Post by hepike »
Today I have installed on my 2010 1.6CRTDI polo a CCS kit. Used VCDS to code in aaaaand not working. Triple checked every connection from lever to BCM and the codes in ECU and BCM as well.
The buttons on the lever works fine I have checked it with a digital multimeter.
Checked the buttons with VCDS in measuring blocks on address 09. Every button work properly exept CANCEL. The value of 4-2 is not changing regarding its position. And I think this prevent me to turn on the CCS.
What can I do? Anybody faced with same issue?
Thanks,
Adam.
Matmaz
Drives: VW Up! TSI xtreme
Post by Matmaz »
Pablo f wrote: Fri Mar 26, 2021 3:02 pm
Matmaz wrote: Fri Mar 26, 2021 2:47 pm
Pablo f wrote: Fri Mar 26, 2021 12:39 am
Hello the number is 1K0953513 F
I correct and add photo
Regards
This is the part number of stalk that I have used in my car: 5Z0953513H
But your car is a Up! pepper and if I'm right it must have automated wipers, and because of that you need a different stalk like this 1k5953502k or something similar but with a different connector like as the first part number.
Exactly that is correct. My idea is to disassemble and change only the left stalk. Here in Argentina it has been impossible for me to get that piece.
It is also added that they stopped selling the UP from the beginning of the year.
Incredibly it is more difficult to buy from Brazil from here, than from another part of the world.
I'm also trying to get the TURY 2.18 module.
This is bad, the difficult is to found someone who that are able to export to Argentina? I have never done this, but if you need some help, maybe I can try to help you.
Matmaz
Post by Matmaz »
hepike wrote: Sat Apr 10, 2021 12:02 am Hi,
Thanks,
Adam.
The main switch shows when it's on or off? It might be a problem on switch ON/CNL/OFF
hepike
Drives: 6R 2010
Post by hepike »
Matmaz wrote: Sat Apr 10, 2021 1:27 am
Thanks,
Adam.
Yes, the car register on/off state correctly. Both ecu and bcm. And also the switch works properly: on cancel line normali there is 12V after i turn on the lever. Then if i push the switch to cancel state the voltage deop to 0V on cancel line. If I release the rocker 12V comes back. Checked its wire through the bcm and looks fine, passed the continuity test.
hepike
Drives: 6R 2010
Post by hepike »
Here is my latest full diagnostic scan:
Monday,12,April,2021,11:10:41:00009
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ6RZAY291948   License Plate: LSX253
Mileage: 273010km-169640mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZAY291948   Mileage: 273010km-169640miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYA)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 E    HW: 03L 906 023 D
   Component: R4 1.6l TDI   H13 9979
   Revision: --H13---    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023E 003017
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 285F4DA753F312C67B-807C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 210224E3417600B3842E24E582DA00421100
   Shop #: WSC 02069 000 00000
   VCID: 020B3F0F990F189605-8056
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
   Component: Climatic       25 0660
   Revision: 00 11 25
   VCID: 356194D39C417F2EF0-8060
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 129100063
   Coding: 3CB02BBF08E12400923000007D2B9CD00080410F608E0000200000000000
   VCID: 3E738BFFA977BC7621-806A
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU028.04.1015206
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU003.05.1014076
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU027.04.1011883
   Coding: 08BC32
   Subsystem 7 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU028.04.1012396
   Coding: 08BC32
   Part No SW: 6R0 959 655 D    HW: 6R0 959 655 D
   Component: VW10Airbag008 H09 0018
   Revision: --------    Serial number: 003DX0012AAT
   Coding: 003038
   Shop #: WSC 00000 384 00190
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4385FA0BCA95D19E4E-8016
   Serial number: 3572SRB40000B659323/
   Serial number: 3582SRB40000B65942A6
   Serial number: 3516GRB402BET2JT1SVO
   Serial number: 3526GRB4023EJ5R313O3
   Part No SW: 6R0 920 861 D    HW: 6R0 920 861 D
   Component: KOMBI         H13 0024
   Serial number: 00000002324941
   Coding: 140A00
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01004
   ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
   VCID: 366393DF89477436F9-8062
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 002200
   VCID: 70EF65C7A3A31A06E3-8024
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H13 X005
   Serial number:
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25_VW25.rod
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00000
   VCID: 2F6DA6BBEA1D45FEBA-807A
   Part No SW: 5M0 035 156 C    HW: 5M0 035 156 C
   Component: Radio         H30 0072
   Revision: R0000000    Serial number: VWZAZ1K0504816
   Coding: 0000020002
   VCID: 295948A340F92BCE64-807C
End-------------------------(Elapsed Time: 02:42)--------------------------
hepike
Drives: 6R 2010
Post by hepike »
I have sorted the issue out. The problem was the pin 47 of the BCM. The pin was bent. I have fixed and it started to work.
quiddi
Drives: Polo 6R
Post by quiddi »
Hello guys,
I also have some problems with the Cruise Control Retrofit. Maybe someone has an idea.
The Details of my Car are:
Polo 6R (manufacturing year 2010)
Central Electric Module (09) ia a Midline (VAG Number ends with 087)
I checked the hardware key switches of the cruise control with VCDS. I think that should be fine.
The Keys "Res/+", "Set/-", "On", "Off", "Cancel" are working. And here is my first question: Am I right, that if I get the right answer of the keys with VCDS that my wiring is fine?
On the first page of this thread is a post from ciclo showing the coding in VCDS.I set in the BCM Bit 7 in Byte 17, like ciclo shows it. For the Engine I am not getting the typical Coding Screen like ciclo is showing it on page one. For that I just opened the engine in VCDS and clicked on "Coding II - 11". I then entered the Code 11463. Is that right?
If I switch now the Cruise Control from Off to On, I get an error in VCDS. It shows me:
1 Error found:
17977 - Switch for Cruise Control (GRA/E45)
P1569 - 000 - Signal not plausible
Am I right that my mistake is in the coding process and the wires should be fine?
Thank you so much for your help.
Did you also put a wire into the engine control unit?
quiddi wrote: Thu Aug 05, 2021 11:23 pm Hello guys,
Yes, you're right in what concerns the communication of CCS switches with BCM.
It doesn't seem like it's the correct way to code the engine unit, but since it's a 2010 6R anything is possible ... :)
1 Error found:
It's one of the possibilities.
iichel wrote: Thu Aug 05, 2021 11:34 pm Did you also put a wire into the engine control unit?
+1 ... :?:
Please quiddi, show us a full VCDS scan.
It is only necessary to show the units involved, Engine and BCM. (please, copy and paste here the units, ... with faults -)
I am totally sure that this problem has an easy solution ... :wink:
quiddi
Drives: Polo 6R
Post by quiddi »
Yes.
Here are the fault codes:
The Engine:
Friday,06,August,2021,09:48:26:39744
VCDS Version: Release 17.1.3 Running on Windows 7 x86
www.Ross-Tech.com
                Address 01: Engine       Labels: None
Control Module Part Number: 03C 906 024 CM    HW: 03C 906 024 BH
  Component and/or Version:       CMAA  MM4HV G 8993
           Software Coding: 0000071
            Work Shop Code: WSC 60089 143 173740
                      VCID: 6BD21CEE491EB0192C-515A
1 Fault Found:
17977 - Cruise Control Switch (E45)
            P1569 - 000 - Implausible Signal
                    Fault Status: 01100000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 194689 km
                    Time Indication: 0
                    Date: 2061.14.31
                    Time: 00:02:58
                    Bin. Bits: 00000100
                    Load: 0.0 %
                    Lambda: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 28.0∞C
                    Absolute Pres.: 931.0 mbar
                    RPM: 0 /min
Readiness: 0110 0001
The BCM
BCM
Friday,06,August,2021,09:50:12:39744
www.Ross-Tech.com
                Address 09: Cent. Elect.       Labels: 6R0-937-08x-09.clb
Control Module Part Number: 6R0 937 087 F    HW: 6R0 937 087
  Component and/or Version: BCM PQ25 H+4  H46 0221
           Software Coding: 24B82BBF08A10000003000C07E2B0C10F0C000FF60840000200000000000
            Work Shop Code: WSC 12469 483 00190
                      VCID: 40889B42D3188341A9-8014
Thanks. :wink:
T80/24
- BCM and engine unit are well coded.👍
- CMAA MM4HV G 8993
G means GRA
- Draw your own conclusions with this info.
Hint: check the wire reaching the engine unit.
- Check that it is inserted correctly, you must remove the pink locking mechanism from T80 connector in order to insert it properly.
okay, what pin did you use on the ecu? it must be t80/24
quiddi
Drives: Polo 6R
Post by quiddi »
Thank you guys. It's working now. I assembled it now to pin 24 at the ECU.
Greeting to the Netherlans and Spain
Excellent job, gut gemacht!
8) Great! Enjoy it. Thanks for reporting.
I also want to send many greetings and kisses to Germany, more to Holland, and many more to the United Kingdom.
I take the opportunity to greet the United States, Russia, China, India, Australia and the rest small countries around the world.
Before I was born I already thought that I was going to be born in Russia or the United States, now I am clear that someone must have made a mistake when they registered my birth ... :mrgreen:
