Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
It's been a good three weeks since any news... since there isn't really any. I'm travelling quite a lot, in the car, but not a lot of time for retrofits, mods and repairs.
The car had its periodical MFK (Motor Fahrzeug Kontrolle, Swiss MOT) yesterday and it passed with flying colours.
I don't have a lot of long or short-term plans with the cars, other than enjoying it.
The heated windshield is starting to pay off in this time of year now, I used it a few times and it's great.
A few weeks ago, the 16" Mallory winter wheels have already been fitted and the reduces tire noise is great.
During the winter period I'll start looking for a different set of summer wheels, despite 4mm of tread left...
Something similar happens to me and my 6R, just enjoying it (nothing else).
My 6R also passed the MOT, MFK, ITV in spain successfully... once I finished the deep overhaul (Sept).
Enjoy your 6R.
Enjoy your 6R.
Thanks Fernando. I hope you're enjoying your car as well.
Do you also have all these people asking what your next mod or retrofit will be, and you have to tell them you don't know? Happened to me a few times a week...
ciclo, may I ask for your help?
The situation is that the high beam are not working very well on my car. Now that the days are becoming shorter, I use the HBA quite often but the high beams just don't work or stop working.
The BCM should be compatible (russian 090C BCM with eeprom flashed with the help of firegrafik). When the high beams stop working, they will not come on by high beam flash or by permanent high beam. The BCM doesn't output 12V anymore to SB34 and SB36 anymore. I'm suspecting maybe faulty coding. The blue high beam light in the instrument cluster still comes on though.
The autoscan:
and the adaptation channels:
If you have any suggestions to try out, please let me know. Thanks.
The autoscan:
Thursday,06,December,2018,18:57:52:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 18.9.0.1 HEX-V2 CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
57 61 65 69 6C 77
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H06 9980
Revision: 12005001 Serial number:
Coding: 00114036033401080000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM12TDI03103P906021B 001043
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 270B06DDAF6FF1FFFFC-8073
Readiness: 0 0 0 0 0
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885432500C5841A146EC25500521505
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7B4E7D27DF89BF17C-805B
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSY_PQ35GP.rod
VCID: 372BD69D7FCF617F6FC-8063
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E07666-806D
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171327
Coding: 3CB02FBF68EB2400B33807E0FFEB9FF0F08060EF608D78D071E000030820
VCID: 2B03FAEDB307D59F1B4-807F
Component: RLHS 220816 0 42 0106
Coding: 0714DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 7 - Part No SW: 5G0 959 442 L HW: 5G0 959 442 L
Component: E221__MFL-DC1 H11 0103
Serial number: 29160001218680036325
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Serial number: KU0-KU008.06.0910897
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
4 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 254
Reset counter: 178
Mileage: 219364 km
Time Indication: 0
Date: 2018.12.03
Time: 10:22:24
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 21
Reset counter: 177
Mileage: 219364 km
Time Indication: 0
Date: 2018.12.03
Time: 10:22:22
01495 - Bulb for High-Beams; Left (M30)
007 - Short to Ground - Intermittent
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 2
Reset counter: 179
Mileage: 219974 km
Time Indication: 0
Date: 2018.12.04
Time: 18:57:10
01499 - Bulb for High-Beams; Right (M32)
Fault Priority: 3
Fault Frequency: 10
Reset counter: 179
Mileage: 219974 km
Time Indication: 0
Date: 2018.12.04
Time: 18:57:17
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231422402620
Coding: 318001
VCID: 3B23CAAD43E7451F8B4-806F
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC97002-801F
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140E01
VCID: 3333E28D6BB78D5F534-8067
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042200
VCID: 688945E162713E87366-803D
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C01000100010000
VCID: 2E05F3F98095A0B73CA-807B
Component: IMMO H04 0709
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8D3FE97CFD0C97202-803F
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9BF37C-807B
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7666620365
Coding: 010100
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB997845987774A-8063
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
Shop #: WSC 02756 790 00000
VCID: 2F3BEEFD8B1FA9BF37C-807B
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H09 0110
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 000300
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
VCID: 79AF10A5095BB70FD98-802D
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE87F66-807D
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0192000001000000
Shop #: WSC 00788 648 00255
VCID: 77AB169D3F4FA17FAFC-8023
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 57: TV Tuner Labels: None
Part No SW: 3C0 919 148 B HW: 3C0 919 148
Component: R78 DTV-JP 0250
Revision: R0H14000 Serial number: 80100800042102
Coding: 0000816
Shop #: WSC 01324 020 00200
VCID: 280905E1AEF1FE87F66-807D
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVKLeser 0010
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030F1A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058319
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9BF37C-807B
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H08000 Serial number: 525PA8-J060533
Coding: 0030115
VCID: 65974CD5996323EF0D0-8031
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Time Indication: 0
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105254406
Coding: 020100000100010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 25170CD5D563E3EFCD0-8071
End----------(Elapsed Time: 02:22, VBatt start/end: 13.1V/13.1V)-----------
;SW:7E0-937-090-C HW:7E0-937-090-C --- Cent. Elect.
;Component:BCM PQ25 Max4 H82 0752, Coding:3CB02FBF68EB2400B33807E0FFEB9FF0F08060EF608D78D071E000030820
;Thursday,06,December,2018,18:58:36:11868
;VCDS Version: Release 18.9.0 Data version: 20180927 DS296.0
;VCID: 2B03FAEDB307D59F1B4-807F
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,,ERROR:,Channel 02,Not,Available,
03,1,N/A,N/A,N/A,N/A,
04,1,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,1,N/A,N/A,N/A,N/A,
09,0,N/A,N/A,N/A,N/A,
10,1,N/A,N/A,N/A,N/A,
11,1,N/A,N/A,N/A,N/A,
12,1,N/A,N/A,N/A,N/A,
13,1,N/A,N/A,N/A,N/A,
14,0,N/A,N/A,N/A,N/A,
15,0,N/A,N/A,N/A,N/A,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,1,N/A,N/A,N/A,N/A,
21,,ERROR:,Channel 21,Not,Available,
22,1,N/A,N/A,N/A,N/A,
23,1,N/A,N/A,N/A,N/A,
24,0,N/A,N/A,N/A,N/A,
25,0,N/A,N/A,N/A,N/A,
26,1,N/A,N/A,N/A,N/A,
27,1,N/A,N/A,N/A,N/A,
28,1,N/A,N/A,N/A,N/A,
29,1,N/A,N/A,N/A,N/A,
30,2,N/A,N/A,N/A,N/A,
31,0,N/A,N/A,N/A,N/A,
32,50,N/A,N/A,N/A,N/A,
33,50,N/A,N/A,N/A,N/A,
34,20,N/A,N/A,N/A,N/A,
35,2,N/A,N/A,N/A,N/A,
36,2,N/A,N/A,N/A,N/A,
37,80,N/A,N/A,N/A,N/A,
38,21,N/A,N/A,N/A,N/A,
39,20,N/A,N/A,N/A,N/A,
40,14,N/A,N/A,N/A,N/A,
41,20,N/A,N/A,N/A,N/A,
42,1,N/A,N/A,N/A,N/A,
43,4,N/A,N/A,N/A,N/A,
44,5,N/A,N/A,N/A,N/A,
45,100,N/A,N/A,N/A,N/A,
46,1,N/A,N/A,N/A,N/A,
47,40,N/A,N/A,N/A,N/A,
48,15,N/A,N/A,N/A,N/A,
49,,ERROR:,Channel 49,Not,Available,
50,0,N/A,N/A,N/A,N/A,
51,0,N/A,N/A,N/A,N/A,
52,0,N/A,N/A,N/A,N/A,
53,1,N/A,N/A,N/A,N/A,
54,1,N/A,N/A,N/A,N/A,
55,1,N/A,N/A,N/A,N/A,
56,0,N/A,N/A,N/A,N/A,
57,0,N/A,N/A,N/A,N/A,
58,0,N/A,N/A,N/A,N/A,
59,1,N/A,N/A,N/A,N/A,
60,200,N/A,N/A,N/A,N/A,
61,200,N/A,N/A,N/A,N/A,
62,5,N/A,N/A,N/A,N/A,
63,278,N/A,N/A,N/A,N/A,
64,0,N/A,N/A,N/A,N/A,
65,0,N/A,N/A,N/A,N/A,
66,3,N/A,N/A,N/A,N/A,
67,8,N/A,N/A,N/A,N/A,
68,1,N/A,N/A,N/A,N/A,
69,0,N/A,N/A,N/A,N/A,
70,20,N/A,N/A,N/A,N/A,
71,0,N/A,N/A,N/A,N/A,
72,0,N/A,N/A,N/A,N/A,
73,0,N/A,N/A,N/A,N/A,
74,0,N/A,N/A,N/A,N/A,
75,0,N/A,N/A,N/A,N/A,
76,0,N/A,N/A,N/A,N/A,
77,0,N/A,N/A,N/A,N/A,
78,0,N/A,N/A,N/A,N/A,
79,255,N/A,N/A,N/A,N/A,
80,0,N/A,N/A,N/A,N/A,
81,0,N/A,N/A,N/A,N/A,
82,0,N/A,N/A,N/A,N/A,
83,0,N/A,N/A,N/A,N/A,
84,0,N/A,N/A,N/A,N/A,
85,0,N/A,N/A,N/A,N/A,
86,0,N/A,N/A,N/A,N/A,
87,0,N/A,N/A,N/A,N/A,
88,0,N/A,N/A,N/A,N/A,
89,0,N/A,N/A,N/A,N/A,
90,0,N/A,N/A,N/A,N/A,
91,0,N/A,N/A,N/A,N/A,
92,0,N/A,N/A,N/A,N/A,
93,0,N/A,N/A,N/A,N/A,
94,0,N/A,N/A,N/A,N/A,
95,0,N/A,N/A,N/A,N/A,
96,0,N/A,N/A,N/A,N/A,
97,0,N/A,N/A,N/A,N/A,
98,,ERROR:,Channel 98,Not,Available,
99,0,N/A,N/A,N/A,N/A,
Revision: AA001001
First suggestion:
Your 6R is LHD but you're driving on the Right side of the road. (Right Hand Driving)
I don't remember exactly the right Byte, but I think your HBA coding isn't correct. Look at the experimental label.
Heated windshield... OK
0404001C................ it's perfect for ours 6R (many test with my Bixenon and--0202001C/07/etc...-- 0404001C works better).... so, look in the following bytes.
It's just a first suggestion, tomorrow I look at it more deeply (maybe the Byte 18 BCM --- 73HEX ---)
Revision: AA001001
First suggestion:
Thanks, I'll try the new coding and let you know the results as soon as it's dark again!
BCM adaptation
Channel 55,1
What does this function do in your 6R?. What's its purpose?, do you remember if it was enabled to 1 after some coding?
It's a bit weird that you have the blue icon on the IC -56a signal- and no power output for your LED headlights -56a signal- (intermittent) when the lights system (with HBA) is working .
According to data provided and Autoscan:
- Some connection may be failing. I remember seeing many couplings in your electrical installation.
(hmm....check the good condition of T73b/8 -pin, wire, route/path- from SwSColumn to BCM)
- The codings seem to be correct.
- BCM eeprom Do you have another BCM to test the HBA system?
Channel 55,1
Hi Fernando,
about the EEPROM and the adaptation channel 55, these were set in collaboration with firegrafik. The 090C BCM is coming from russia and I set the same parameters as in his BCM.
I remember having the same problem with my old 7E0 937 090 Z4Y BCM but it didn't bother (or interest) me back then, since i was barely driving in the dark.
Channel 55 has no direct function as I can tell, I set it to 0 for now and I have not experienced any loss of function. I will drive in the dark with HBA and without HBA and high beams to see if it makes a difference.
The HBA bytes you refer to are probably these --> https://imgur.com/a/di7ECRa
I think they are set correct for left hand drive.
Checked all the wires as well, seems to be OK. I'm now experimenting with byte 29 bit 5, set to 0 now. Maybe this is causing some issues, but I doubt it...
Hi Michel
Well, I think the byte2 (left hand drive) is correct and the byte8 (left hand driving) is incorrect in your HBA coding. (6R LHD)
However, these two bytes are not factory-coded for this HBA-mirror-model in the long-code, because it is already set in the adaptation channels.
If you look at the HBA adaptation channels you will see that the default value is already set to 'Right hand driving'.
In short, not codify this two bytes in the Long Code, set both to 00 HEX.
I have the adaptation channels (untouched) from a BCM 7E0 installed in a New T6 (2016) with halogen headlights, it is the only one I have seen so far with channel 55 set to 1.
In the adaptation channels from T6 with LED headlights is set to 0.
(Maybe it's a coincidence)
- Franciswat
- Drives: 6R 1.6 Bifuel
WOW iichel I've just seen your work on buttoms lights! Result is awesome!
You have a lot of patience!
A small update with regards to my high beam issues:
Explanation from friend firegrafik about channel 55:
I have also changed the byte 18 to 73. However, this did not bring a solution to the issues I'm experiencing, so far.
I currently don't know what to do. The issues still appear with HBA on and off.
I have changed the adaptation channel in the high beam mirror to left hand drive.Hello Michel. As I have got this channel is about high beam bulb control. After 090C BCM reparametrized with 090B (T6 with LED headlights) this channel should be set to 1 to avoid the high beam faults in the 09 Centr.elect
Looks like the upcoming transporter facelift won't offer a lot of electrics that would fit to the 6r
https://www.motor1.com/news/306403/2019 ... -revealed/
- Drives: 1.2TSI 105HP DSG7
digital instrument cluster in pq25+++ ? [emoji41]
iichel wrote: ↑Sun Feb 24, 2019 7:09 am Looks like the upcoming transporter facelift won't offer a lot of electrics that would fit to the 6r
Maybe for the Golf.
