peter_dk25
- Drives: Blue GT
Agree. The same in my 6R Blue GT
Perfect! (viewtopic.php?f=56&t=58703&start=330#p481352)
(viewtopic.php?f=56&t=58703&start=3330#p520980)
BTW, the hazard lights button illumination can be clearly seen in the previous video of the VIM. It's possible with (from) BCM 7E0937090B.
benzinkopf
- Drives: 1.2TSI 105HP DSG7
wow. ESC high!
Thank you very much Michel!!.iichel wrote: Wed Dec 20, 2017 3:15 pm Polo AW autoscan --> http://forums.ross-tech.com/showthread. ... -0-TSI-DSG
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q0 937 090 HW: 2Q0 937 090
Component: BCM A0 Std+ H97 0915
Serial number: 07001720700212
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_BCMA0 204001
ROD: N/A
VCID: 6FE7D5C3B66F7E52553-803A
Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S9Y17M07D05H02M43S47
Coding: 0038DD
The RLHS viewtopic.php?f=56&t=58703&p=519664#p519710
External/separated GW:
Address 19: CAN Gateway (J533) Labels:. 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 22071710522631
Coding: 030100046F085600F800025C1C0F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: N/A
VCID: 336F19B39AC71AB271B-8066
Subsystem 2 - Part No SW: 2G0 959 442 F HW: 2G0 959 442 F
Component: E221__MFL-DC1 H02 0040
Serial number: 39170002074970097303
Coding: 2DFFFF
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 1000C1A2
Very interesting.
2+4=6
6+6=12
12/12/12
It's related? or do I have a twisted mind?
... up to infinity and beyond.
peter_dk25
- Drives: Blue GT
ciclo wrote: Wed Dec 20, 2017 11:24 am BTW, the hazard lights button illumination can be clearly seen in the previous video of the VIM. It's possible with (from) BCM 7E0937090B.
benzinkopf
Hi guys, today i found out that if locking the car with one or more interior lighting switch ON and open glovebox with the glovebox light ON, all the lights will be flashing together with hazard button and MFD showing/flashing the front pax door open? is this normal?
If im not mistaken, before, even if i switch on any interior lights, once I lock the car remotely, it will still shut off all the lights.
Hi benzinkopf, it is not normal, take a video and show us that behavior of your interior lights. Please...benzinkopf wrote: Thu Dec 21, 2017 12:55 pm Hi guys, today i found out that if locking the car with one or more interior lighting switch ON and open glovebox with the glovebox light ON, all the lights will be flashing together with hazard button and MFD showing/flashing the front pax door open? is this normal?
Seriously, take the video, it will be fun for the future.
Although we have to take into account that you have made some installations that they aren't normal and of which we do not have a detailed information in your topic (Bixenon headlights with T10 connectors, door warning lights, etc...)
The interior light that you turned on manually stays on for a while (15 minutes or so) once you lock the car with remote.benzinkopf wrote: Thu Dec 21, 2017 12:55 pm If im not mistaken, before, even if i switch on any interior lights, once I lock the car remotely, it will still shut off all the lights.
benzinkopf
Hi Ciclo.
Yes. Now I’m sure its not normal and I found the culprit for the funny disco light. Heres the video!
https://youtu.be/APFIeAFJNN8
Btw, Ive reverted back to original H7 headlights now as I’m going to install the complete Bixenon/ALWR by next 2 weeks. Parts just arrived.[emoji41]
The only mod left is my testing on Door Exit/Warning Light in the front passenger Door. This is the culprit, thats why the MFD is showing the front passenger door is open. This ONLY happen when I lock the car with interior light switch ON. After i took out the Door Light module, everything will be switch off like normal (directly after lock, not after 15mins like u said)
I just found out this error because I managed to install the glovebox light and I tested to lock the car with open glovebox to make sure the light to go off when I lock the car.
I’m suspecting the ground wire for the door contact is not the right one so I have to check again.
Ok, understood, please keep me informed, it is important for me to know everything about the electrical systems of your 6R.
Many thanks for the video.
benzinkopf
Just opened my door panel again to check the wiring.
here’s the door lock T8 connector from my front passenger door
1) There re actually 7pins inside the connector and there’s only 6 wires available. According to the diagram, pin 7 is connected to bcm T73b/28. (unless im referring to the wrong diagram)
2) I connect the GND wire from the door light to Wire Pin 2, which is Green/White. With this, the light only switch On when door is open, but this brings me to the disco light issues.
The positive wire is connected to the same positive from footwell, interior lighting, glovebox etc.
Front passenger side central locking lock unit, Onboard supply control unit
F3 - Front passenger door contact switch
F221 - Front passenger side central locking lock unit
J519 - Onboard supply control unit
V57 - Front passenger seat central locking motor
V162 - Front passenger door central locking SAFELOCK function motor
206 - Earth connection, in front passenger door wiring harness
benzinkopf
Thanks a lot for your time Ciclo. Really appreciate it. But, Ive test connected the ground wire to the wire pin5, but the light still switch ON after door close. Thats why i tried pin2 and it works (i thought earlier)ciclo wrote:
Well, I have reviewed the diagrams of all the 6R models that I have (I do not have the diagrams of your 6R, built in South Africa plant).
It is not the same pin assignment for all 6R models, that's why you should use the multimeter to locate the pins for your front passenger door contact switch.
