ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
ciclo wrote: Sat Dec 23, 2017 6:23 am viewtopic.php?f=56&t=58703&start=3915#p527991 Anyone? :lol:
Had seen first image/diagram few times. But really could not stretch my mind over second :(
May be not as much as computation power as you.
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
ciclo wrote: Sat Dec 23, 2017 6:22 am
peter_dk25 wrote: Thu Dec 21, 2017 12:50 pm
ciclo wrote: Wed Dec 20, 2017 11:24 am BTW, the hazard lights button illumination can be clearly seen in the previous video of the VIM. It's possible with (from) BCM 7E0937090B. :lol:
(viewtopic.php?f=56&t=58703&start=3330#p520980)
:wink:
You will need my help, for coding and adaptation. :)
I know :D
iichel wrote: Sat Dec 23, 2017 7:06 am you're going to buy yourself a new polo?
:lol:
ag69 wrote: Sat Dec 23, 2017 7:14 am
Let's see, I'm making a question for someone to enlighten me.
In any case, I see the infinite symbol inside the VW logo. :)
Perhaps it is necessary to read/learn a little about the nine numbers represented in the last image with pulses.
..for example,
It's awesome for its simplicity and purity.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
what is it that i missed here?[emoji848]
Nothing important, talking about symbology.
sharan1988
Drives: Polo sedan
Post by sharan1988 »
Ciclo, I have a vento tsi ..Would like to go for the maxidot cluster . Whats the model number that I should look for as it based on polo 6r . The Volkswagen service centre said that they will code or for me .
I.e. 6R0 920 870C from polo GT 1.4 TSI 140hp
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
ciclo wrote: Thu Dec 14, 2017 8:35 am The manufacture place it's not related, depends on the PR codes.
Example: 8IT = LED headlamps.
It's difficult (but not impossible) to know the PR codes if you buy a used BCM and you do not know the extras (optional equipment) of the donor car.
How can I know the PR codes of an used BCM?
- It is necessary to have the VCDS readings of all adaptation channels, also from parameters that must be read with a VCP function.
- Have a database of these PQ25 BCMs.
But as the PQ25 platform owners do not share this data, especially the 6R owners, it is necessary to have experiences in modifications and tests with this data. (e.g. iichel, firegrafik, ross-tech, vag-tech, me, etc ...)
federicodrdpro
Ok, if I buy a new BCM there aren't problems with the LED compatibility?
If you want to install 6C LED headlights you need a new BCM Max 7E0 from T6 with PR-code 8IT.
Therefore, if you buy a new BCM 7E0 with PR-code 8IT you will not have any problem with any type of headlight.
federicodrdpro
Ok! I can't know if the BCM have the PR-code 8IT if I buy a new (not coded) BCM from a private person. Right? :?
unless you're very lucky and it's bought new from dealer and the information is kept, it's impossible to know
sunilsoft
Drives: Polo 6R Tdi 2015
Post by sunilsoft »
Hi ciclo,
Is it possible to install vw alarm system 1K0951605C in indian polo.
It is available on https://goo.gl/MQm6Nx .
Locked
