Change of software in my other TPMS unit. Editing parameters
When I bought the two TPMS units, and still did not know for certain what was the reason why I could not get the tire pressure menu in my IC, something very funny happened to me.
The two units I bought:
- the right TPMS unit,
3AA 907 273 H with F software. https://i.ebayimg.com/images/g/89kAAOSw ... -l1600.jpg (ebay). This one: viewtopic.php?f=56&t=58703&start=3645#p525012
- the wrong TPMS unit (a used part),
3AA 907 273 F with H software. The seller made a mistake, or did not know what he was selling. (no need to say where I bought it)
The wrong is this one: viewtopic.php?f=56&t=58703&start=4005#p529257
In those moments of confusion I thought that nothing was going the right way, and I thought that these TPMS units was a damn joke :lol: :lol: .. "two TPMS units bought in different places with the software exchanged". As always I thought, cheap parts, bad result. :P
As you all know, I made a Kit for TPMS units. I upload the image here again.
...and yesterday I used it to load the correct software for PQ25 in the wrong TPMS unit, I also did the editing of parameters (with some parameters that a forum user sent me)
The next image is intentionally blurred. :lol:
These are the parameters that the forum user sent me. (Benji58)
And here the result of the process. 8)
And I already have another unit that works correctly for the PQ25 platform and the rest of the necessary units.
It was sold to Benji58 for a reasonable price.
Apart:
I reinstall everything by disconnecting the Kit, leaving my original VCP connected, and edit the parameters of my installed unit on rear bumper with the following configuration.
This will allow me to know if the system works correctly without having to deflate the wheels, that is, sitting in the driver's seat. :lol:
MaDwArLoCk IC (Warning TEST)
:arrow: viewtopic.php?f=56&t=58703&start=3450#p522430
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
tested the ch37! thanks. thats improved alot.and yes. i agreed. feel like it does have delay to switch the light on. which channel shud do the trick and by how much? appreciate your sharing
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
ciclo wrote: Sun Jan 21, 2018 12:14 pm H7 Laser Nightbreaker for static cornering lights
@Orion, test yours on a totally dark road at 100%. It will like you. :wink:
Yes, as I said, they do illuminate a LOT, really a lot, lol... But I don't like them being yellow. I now have some cheap chinese H7 halogens, they are white, but, as always, the more the kelvins the less the lumens... I will try to put them both at 100% and see wich one i like better. :D
Thanks for the feedback Fernando! ;)
benzinkopf wrote: Sun Jan 21, 2018 1:29 pm tested the ch37! thanks. thats improved alot.and yes. i agreed. feel like it does have delay to switch the light on. which channel shud do the trick and by how much? appreciate your sharing
Channel 35, set to 1 to test, and tell us your opinion about it.
Maybe I set this channel to 0.
ORiOn wrote: Sun Jan 21, 2018 4:34 pm
.. to get the bright white in the SCLs will have to try one of those Led lamps that mentioned gtsportms. viewtopic.php?f=56&t=58703&start=4005#p529219 with a good appearance and be really functional.
ORiOn
Post by ORiOn »
ciclo wrote: Sun Jan 21, 2018 7:39 pm .. to get the bright white in the SCLs will have to try one of those Led lamps that mentioned gtsportms. viewtopic.php?f=56&t=58703&start=4005#p529219 with a good appearance and be really functional.
Already ordered them yesterday :P
benzinkopf
ciclo wrote::arrow: Updated
i like the part where u have the Warning Test. excellent and clever!
explorer232
Drives: Seat
Post by explorer232 »
ciclo wrote: Fri Jan 19, 2018 8:50 am
explorer232 wrote: Thu Jan 18, 2018 1:42 pm
iichel wrote: Thu Jan 18, 2018 1:27 pm Ah okay, now i have a better understanding. 6R0 937 087H bcm high to 7E0 937 090B BCM Max.
I don't know whether VCP is capable of these matters, of configuring BCM max as BCM high.
I need only reconfigure gpio port functions or reconfigure dtc masking for lights. VCP pq25 param editor is editing eeprom in cpu. 6R0 937 087H and 7E0 937 090B is still similar hw only part number in eeprom, fw version, populated pins in connector and eeprom config is difference so I think that its possible write firmware from 7E0937090B to 6R093708x. I am waiting for bcm connectors and then I will to make some research.
Try it with the fw of a BCM 7E0..090 /B/C from Transporter T6, not all firmwares of 7E0..090 /B/C are equal.
Please keep us informed.
Hi, my bcm is from 2017 beetle. Firmware 0744. I think that firmware 0744 is similar as 0744 from another bcm but can be difference in eeprom content. I have already connected new bcm to pc. Transfered coding from original bcm in car. I can see 3 virtual ecu in new bcm:
- 09 Central electronics
- 19 Gateway
- 61 Battery management
So 61 battery management must be added to gateway list. Otherwise there will be error in can gateway.
At the evening I will try to connect 5f module on the confort can bus of this bcm.
At the moment there are standard DTCs
- terminal 30 for left light not connected
- terminal 30 for right light not connected
ant too much errors because I have connected only bcm.
http://i64.tinypic.com/34i0482.jpg
BUT I cant read eeprom data from new bcm, vcp param editor is not working. Problem with security access.
Is there security access code 31347 in 7E0937090b bcm ? Yesterday evening I didnt have free time to make some research with access code.
Do you have 7E0937090B bcm with 0744 firmware?
Could you like to test if in your configuration is possible establish security access with bcm?
I see that you have VCP.
I do not know how many security accesses these 7E0 BCMs will have, this is the only one I know:
It is not necessary to add address 61 if your car is non Bluemotion.
Your 7E0 BCM from Beetle 2017 support Discover Media. It's right for your tests.
explorer232
Drives: Seat
Hi, ok, thanks.
If there isnt 61 address enabled in gw list, gw throw error with incorrect configuration because device 61-BM is active on the can bus.
Yes, but beetle is pq25 platform and discovery media in beetle is MIB-PQ.
I have MIBstd from MQB platform so I must try if its working correctly in PQ25 platform :)
VCDS is creating standard session with bcm. But for fw/eeprom reading, writting is needed engineering session.
Could you like to test in VCP > Guided Functions > BCM PQx5 programmer if security access will be established in your case?
Thanks.
... If your VCP is not original I'm afraid you will not be able to access the PQ25 BCM parameters edition. No security access is necessary to this.
Mi current BCM is 7E0937090C BCM PQ25 Max4 H82 0752 and to access the parameter edition I have to configure my VCP in English, in Spanish it does not work. And yes it works like a charm with all 7E0 BCMs (.../B/C/...)
Saturday,20,January,2018,17:15:29:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: New Battery and Test
Mileage: 29280km-18193mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage: 29280km-18193miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A87125C2730E7B8F5-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 021FE2148B385760B5-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7E93EA9897947FCC95-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38497EB6673613DA45-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
   VCID: 2B44949153F76D01FD-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E536AD89754FF8C95-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A6752FCA790A758F5-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00000
   VCID: 47585CE5AB63B54DDD-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68791E462706F3AAC5-803C
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   ROD: N/A
   VCID: 2E438AA857E45F1C15-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A47929C2FF06778F5-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5274
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37487CB5633315DD5D-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F408CADD71B45251D-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 7788FC756B73951D5D-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30.rod
   VCID: 37487CB56B3315DD5D-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B5474C19B270DF17D-806E
End-------------------------(Elapsed Time: 04:29)--------------------------
Please, share your current BCM/Gateway codings.
explorer232
Drives: Seat
Hi, ok, thanks I will try it at evening.
For params editing vcp establish service mode (engineering session) automatically, authentification via seed key algo (vcp log for info)
explorer232
Drives: Seat
Hi, so I have connected 5F module (from MQB) to komfort can bus in pq25 bcm in my config and result was very bad. Gateway throw error communication is deffective and no communication with 5f and other devices on this can bus (as when I connect 5f module to my car)
I found that problem is can bus baudrate. Infotainment module 5F from mqb is originally connected to infotainment can bus with baud rate 512kbps but komfort can bus in pq25 gw have only 128kbps. So then I reconnect 5F to drive (powertrain) can bus (this can bus have 512kbps baudrate) and viola 5f module is working now.Tomorrow I will to play with bcm params.
Chassis Type: 7E0
Scan: 01 03 04 08 09 15 17 19 25 44 4B 5F 61 0B
4B-Multifunc. Module -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 89007225160941
   Coding: 3C880BE888610100003000007F0B1CC800C0400F608C0000300000000000
   Shop #: WSC 00066 123 12345
   VCID: 2A5A3A3445FF281197-807E
16 Faults Found:
03430 - Terminal 30 for Turn Signals and Brake Lights
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
03428 - Activation of Left Adaptive Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
03429 - Activation of Right Adaptive Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
03435 - Terminal 30 for Interior Light and Parking Light
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
00329 - Control Circuit for Unlocking Rear Lid
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
00975 - Heated Rear Window (Z1)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
03585 - Terminal 30 for Windshield Wiper
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
03444 - Ignition Starter Switch
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
01334 - Door Control Module; Rear Right (J389)
            004 - No Signal/Communication
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
01333 - Door Control Module; Rear Left (J388)
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
01332 - Door Control Module; Passenger Side (J387)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
03591 - Control Circuit for Horn
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
Address 15: Airbags
Cannot be reached
Cannot be reached
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 322200
   VCID: 68DE803C9B73DA0141-803C
4 Faults Found:
01336 - Company Data Bus for Comfort System
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
01312 - Powertrain Data Bus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
00381 - Databus Instrument Cluster
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
03406 - Control Module for Battery Monitoring
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
Address 25: Immobilizer
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 4B: Multifunc. Module
Cannot be reached
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5F0 035 846 A    HW: 5F0 035 846
   Component: MU-S-N-ER     039 0480
   Serial number: E1F01011120288
   Coding: 04730001D70A000021110001000800002F01010401000100C6
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 2642CE0459E70C71B3-8072
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H45 0022
   Serial number: SEZ8Z9N5600SJR
   Data medium:
   Subsystem 2 - Part No SW: 5F0 060 884 AP    HW: -----------
   Component:  ECE 2017/18  --- 0067
19 Faults Found:
1553 - Function Restriction
          B200D F0 [008] - due to Internal Communcations Error
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 30: 12.1 V
1555 - Check Software Version Management
          B201A 00 [009] -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [008] - Missing message
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0512 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0518 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0532 - Loudspeaker Channel 5
          B13A4 01 [009] - Electrical Failure
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0537 - Loudspeaker Channel 6
          B13A5 01 [009] - Electrical Failure
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
0004 - Antenna 2 for radio
          B111A 11 [009] - Short to Ground
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 30: 12.5 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [008] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 40
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
1564 - Microphone 1
          B129B 13 [009] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
1024 - Interface for External Media Devices (MEDIA-IN)
          B1288 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 00000000
   Shop #: WSC 00066 790 00180
1 Fault Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
End-------------------------(Elapsed Time: 01:56)--------------------------
Adam87
Drives: T5.2
Post by Adam87 »
explorer232 wrote:Hi, so I have connected 5F module (from MQB) to komfort can bus in pq25 bcm in my config and result was very bad. Gateway throw error communication is deffective and no communication with 5f and other devices on this can bus (as when I connect 5f module to my car)
Chassis Type: 7E0
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
16 Faults Found:
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
Address 15: Airbags
Cannot be reached
Cannot be reached
   Revision: B9081001
   Coding: 322200
4 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Time Indication: 0
Cannot be reached
Cannot be reached
Cannot be reached
   Data medium:
19 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
          B201A 00 [009] -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 12
                    Reset counter: 40
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
2565 - GPS Antenna
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
1564 - Microphone 1
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
   Coding: 00000000
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
Very clever work, I always wondered if MQB was possible to work on PQ cars, you should start a separate topic with these tests
Locked
