Polo 6R - Useful Part Numbers
Mattypologti6r14
- Drives: Polo gti 6t
Any part number for a shark fin antenna with fm and dab?? thanks
That does not exist.
I've bought a rear caliper rebuild kit with pistons. Some kits come with brass bushing, and some kits do not come. Does someone where does this brass part goes?
Edit, I have confirmed my thougts. just buy new callipers, the circlip that holds the parking brake mechanism is a nightmare to install and remove.
also, do not wire brush the part where the bajno golt goes. Do not or it will leak. I will try today to sand it flush and try it that way. If it doesnt work hoses and new callipers
the first calliper was a nightmare it took me 2h for the circlip.
The second one i dismanteld in 15 minutes, but guess what the piston wouldnt wind in witouth force from the top. So again i dismanteld it 8 times to re check everything. And i managed to slide the piston in and it was pushing out slowly applying the handbrake mechanisam. the issue was that circlip.
It took me 8 bloody hrs for 2 callipers, and i think my steel wire wheel strached the part where thencrush washer goes. So i got a leak thanks god for pressure bleeder.
really bad desing the shaft from behind was completly rusted, and water gets in from thenbackside. Nice money maker desing.
If i was to do it again id just buy new callipers.
Hello! Im new here. Can i get some help?Mart!n-GTI-DK wrote: Mon Nov 04, 2013 3:08 pm A list of special Polo R WRC parts:
Front Bumper: 6R0 807 217 AF AWA - (Comes paintet Candy White from the factory)
Cover for towing eye: 6R0 807 241 E AWA - (Comes paintet Candy White from the factory)
Middle grill: 6R0 853 677 F 041
Cover Left: 6R0 854 661 BUS
Cover Right: 6R0 854 662 BUS
Cover cap for sprinkler Left: 6R0 955 109 D GRU
Cover cap for sprinkler Right: 6R0 955 110 D GRU
Retainer for spoiler: 6R0 805 915 H 9B9
I'm not sure if any bracket pieces are needed underneath the bumper... But it doesn't look like it...
All gloss black R WRC front grill: 6R0 853 651 AC 041
Gloss black diffuser (GTI/BlueGT/R WRC): 6R6 807 568 N 041
Gloss black towing eye cover rear (GTI/BlueGT/R WRC): 6R6 807 441 A 041
Ive got european polo 6r 1.4 86hp 2010 and i want to upgrade my front bumper to a WRC one. Is 6R0 807 217 AF AWA compatible with my polo? Ive got fog lights also but there is a solution for fog lights ? Or it must be taken out?
Thanks for your help!:)
Polo 6R R WRC bumper does not support foglights, unless you do mods with aftermarket/custom LEDS.
Thanks. All 6R WRC front bumper compatible with all 6R polos ?
All polo 6r and 6c yes
hello what is this Grey piece number ? Central pillar B
The easiest way is to take it out. The part number is written on it.
You know how i do this ?iichel wrote: Sat Mar 05, 2022 10:16 pm The easiest way is to take it out. The part number is written on it.
Hello!
The stock cover caps for sprinkler are compatible with wrc bumper?
Are there any documentation on KFK transmission short shifter mods ? Something like people were doing on 1.9 TDI relocating the pin? Did anyone do it?
Or if someone has one can you take the picture with a ruler next to so I could see if modding the stock one is possible?
Edit: Never mind, i Think I have figured it out. Will check tomorrow on the car to see if its possible.
Edit its possible.
Edit its possible.
If anyone is in doubt:
Blueprint solid mass flywheel clutch set conversion from mk4 1.9 tdi (5sp) will fit on 1.6 TDI and most importantly will hold torque of 1549 turbo ~180hp.
Warning: the clutch material is soft-ish it's not for hard launches from standstill ( will wear out quickly)
Valeo solid mass conversion holding 240hp on 1.9 tdi no isssues
Noiseprojekt
- Drives: VW Polo -14 1,2 TSI R-Line
Does anyone know if these exist that fits with the R-line rear spoiler?
The ones i bought only fits the regular small spoiler
