Polo 6R ABS CODING
Re: Polo 6R ABS CODING
He stood without electricity for a long time. The battery is missing. Same zeros show VCDS.
Brake size is different but otherwise your coding is OK
210228E3216D00BA842E14E484D600400000 OR 210228E3216D00BA842E14E484D600401000
manjuhonnur
- Drives: POLO GT 1.2 TSI MK5 6R
Hello guys,
Need help with ABS Coding, Recently upgraded Front stock Disc Brake 256mm to 288mm and rear Remains stock 200 mm drum brakes.
Polo GT TSI 1.2 6R (Indian) RHD - AUTO TRANS (DSG) - XDS - HHC - NO TPMS - CBZB
This is the Auto-Scan:
Thursday,04,May,2023,18:32:30:00009
VCDS Version: 23.3.0.0
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: MEXE17606HT134158 License Plate:
Mileage: 86330km-53642mi Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: MEXE17606HT134158 Mileage: 86330km-53642miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: CVN: 9408DB59
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6DD17CB3BC91F7FB18-8038
VINID: 755A150471801989010C40452015DCA730
Readiness: 0110 0101
Part No SW: 0AM 300 041 D HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 052 2602
Revision: 00005026 Serial number: CU501703026786
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 2A5BB7AF85FF20C3BD-807E
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Serial number: --------------
Coding: 62DD2463422603C44615246E4259C0800908
Shop #: WSC 00000 000 08192
VCID: 000F35079B030A93C3-8054
Serial number: 20031713471055
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C63B1-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F003D889C39B8C-8014
Part No SW: 6RU 937 087 P HW: 6RU 937 087
Component: BCM IM H+4 H41 0444
Revision: BZ041001 Serial number: 8700 144170371
Coding: 3BB82BFF48A10000013800007EAB969000C0600F608E0100220000000A00
Shop #: WSC 00046 123 12345
VCID: 6FED66BBBE9D05EB2A-803A
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 170217 04 42 0106
Coding: 0368DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Serial number: 13102848170216131341
Coding: 050000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2551
Serial number: 13102849170216062028
Coding: 050000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 0301707132700780AB1B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Serial number: 13202728170228123206
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Serial number: 13102729170309214913
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW01A0C5- Dataset Number: 00000000000 0001
Coding: 003036
VCID: 4999E823E8B90BDB54-801C
Part No SW: 6RF 920 861 D HW: 6RF 920 861 D
Component: KOMBI H02 5006
Coding: 1108000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 4C97D137E7CB1EF36F-8018
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H41 0444
Revision: BZ041001
Coding: 002300
VCID: 193978631099BB5B24-804C
Component: IMMO H02 5006
Serial number:
VCID: 6ADB77AF8D7FE0C37D-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Dataset Number: 6RF074v____ 0120
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 4189F003D089C39B8C-8014
Address 56: Radio Labels: None
Part No SW: 3TD 035 156 HW: 3TD 035 156
Component: RadioSK46MID 006 0010
Coding: 01000424041000
Shop #: WSC 00078 790 00000
VCID: 7F0DB6FBEEFD756BBA-802A
End-------------------------(Elapsed Time: 02:33)--------------------------
www.Ross-Tech.com
Coding: 0000020
Coding: 01
Revision: V0000000
Coding: 0368DD
Coding: 050000
Coding: 050000
Coding: 240000
Coding: 003036
Coding: 1108000000
Revision: BZ041001
Coding: 002300
Serial number:
patil
Hi manjuhonnur,
Welcome to the forum. I see that you are trying to contact me.
If this is the reason for which you are trying to get help from me:
Below is the new ABS coding for your new front 288mm disc + 200mm rear drums.
62DD4463422603C44615226E4259C0800908
If you are looking for help regarding something else then please post here or open a new thread. I am sure you will get help
Thank you.
You got lucky, you got the latest ABS module SW version (CB) from factory which supports 288mm front discs.manjuhonnur wrote: Thu May 11, 2023 4:01 pm Hello guys,
Thank you.
Piyush7243
- Drives: Vento 1.5TDi DSG
@iichel @patil
Finally i got a dongle ODIS Engineering and CB firmware and updated my ABS unit to the supported version and was able to do the long coding ad given by@iichel
62DD4C63422B07C54614326A4256E0820908
Thanks @patil for the guidance on the firmware version and the guidance to update
Mcdonald1993-
- Drives: 2013 1.2tdi polo
Hi I am wondering can anyone figure out the long coding for the abs module on my 2013 polo 1.2tdi cwfa.
I plugged in a different set of dash clocks and it cleared the coding off the abs module.
vin:WVWZZZ6RZDU020923
Has TPMS
Drums on the rear.
Doesn’t have isg.
Manual 5 speed transmission.
VAG number 6R0907379BE
System designation ESP8.2i front
Software version 0001
Hardware part number 6R0907379AF
Hardware version H05
Any help would be greatly appreciated
Has TPMS
Drums on the rear.
Doesn’t have isg.
I don't think it's necessary to post the same message in three topics.
A full diagnostic scan, i.e. from VCDS, if available would be very handy on the other hand.
Mcdonald1993-
Hi Iichel,iichel wrote: Tue Aug 22, 2023 6:52 am I don't think it's necessary to post the same message in three topics.
Apologies for the three posts. Unfortunately I don’t have access to vcds full scan at the moment
Some more information:
RHD
185/60/15 tyre size
No hill assist
Device 0031414
ECU protocol KWP2000CAN16
Fault codes : 03306 coding invalid.
01042 control module not coded.
Is there any other information that’s is needed for you to generate the long coding.
Thanks,
William
Yes I'll need a diagnostic scan to be accurate.
Mcdonald1993-
Here is the auto scan.
Hope this helps.
Thanks.
Tuesday,22,August,2023,13:37:38:00009
VCDS Version: 20.12.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDU020923 License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 AK HW: 03P 907 425 A
Component: R3 1.2l TDI H10 9978
Revision: 11002002 Serial number: 00000000000000
Coding: 00114014000500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TDI03103P906021AK 001009
ROD: N/A
VCID: 71E38806A0A9130CFC-8024
No ASAM data for: "EV_ECM12TDI03103P906021AK" (VW25)
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 31414 790 31414
VCID: 0201D7CA990F189415-8056
2 Faults Found:
03306 - Coding Not Valid
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 13
Reset counter: 31
Mileage: 241986 km
Time Indication: 0
Date: 2058.14.09
Time: 12:25:57
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x149A
Hex Value: 0x0083
Hex Value: 0x7F7F
Hex Value: 0x7F00
01042 - Control Module; Not Coded
000 - -
Fault Priority: 0
Fault Frequency: 13
Reset counter: 31
Mileage: 241986 km
Time Indication: 0
Date: 2058.14.09
Time: 12:25:57
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1211
Hex Value: 0x149A
Hex Value: 0x0083
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Component: LENKW.SENSOR H06 0060
Serial number: 090465LHF00081
Coding: 01
ROD: N/A
VCID: 7EF9A33AE1F77C7471-802A
No ASAM data for: "EV_LWSKLOVW25X" (VW25)
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 39737026B0599B4C04-806C
7 Faults Found:
00706 - Relay for Coolant Fan; Stage 2 (J513)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 8
Reset counter: 31
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.03
Time: 01:08:54
00705 - Relay for Coolant Fan; Stage 1 (J279)
Fault Priority: 2
Fault Frequency: 8
Reset counter: 31
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.03
Time: 01:08:54
01314 - Engine Control Module
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.06
Time: 23:21:13
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 7
Reset counter: 68
Mileage: 178241 km
Time Indication: 0
Date: 2059.14.05
Time: 00:08:55
00532 - Supply Voltage B+
Fault Priority: 3
Fault Frequency: 4
Reset counter: 68
Mileage: 178241 km
Time Indication: 0
Date: 2059.14.05
Time: 00:08:55
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.06
Time: 00:00:09
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.06
Time: 00:02:04
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 216121042
Coding: 24B02BBF08A10000003008002D2B0CD00000410F60060000200000000000
VCID: 458B0CD6CCA1EFAC70-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU024081200013914
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 K HW: 6R0 959 801 K Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 005 0803
Serial number: KU0-KU020.10.0913455
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU020081200016764
Coding: 18BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU022081200010865
Coding: 18BC32
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Component: VW10Airbag027 H10 0020
Revision: -------- Serial number: 003GX01C780.
Coding: 003237
ROD: N/A
VCID: 4A913FEAEDBF00D49D-801E
Subsystem 1 - Serial number: 3575HRB405N1HGMU1P7B
Subsystem 2 - Serial number: 3585HRB404P1HAR2AH5Q
Subsystem 3 - Serial number: 3515RRB401G4UH24E9LT
Subsystem 4 - Serial number: 3525RRB401G4UH24FQ1S
No ASAM data for: "EV_AirbaVW10BPAVW250" (VW25)
3 Faults Found:
12670208 - ROD - Unknown Error Code
- 00 [008]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Date: 2122.14.06
Time: 00:02:03
12854016 - ROD - Unknown Error Code
- 00 [008]
Fault Priority: 6
Fault Frequency: 27
Reset counter: 68
Mileage: 241971 km
Date: 2122.14.06
Time: 00:05:00
12674816 - ROD - Unknown Error Code
- 00 [008]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Date: 2122.14.06
Time: 00:02:03
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6R0 920 961 K HW: 6R0 920 961 K
Component: KOMBI H04 0605
Coding: 440A01
ROD: N/A
VCID: 3E79633AA177BC7431-806A
No ASAM data for: "EV_Kombi_UDS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002300
VCID: 70E58D02A3A31A04F3-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H04 0605
Serial number:
ROD: N/A
VCID: 6AD19F6A8D7FE0D4BD-803E
No ASAM data for: "EV_Immo_UDS_VDD_RM09" (VW36 *)
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663352958
Coding: 010100
VCID: 2A515F6A45FF20D47D-807E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F674E7EEA1D45FCAA-807A
Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
Component: Radio RCD310 004 0119
Revision: 01000001 Serial number: VWZ1Z2M2184419
Coding: 01000400020001
VCID: 356B7C169C417F2CE0-8060
1 Fault Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 242047 km
Time Indication: 0
Date: 2058.14.19
Time: 13:34:46
End-------------------------(Elapsed Time: 02:26)--------------------------
Hope this helps.
Thanks.
www.Ross-Tech.com
ROD: N/A
Revision: --------
2 Faults Found:
000 - -
Fault Priority: 0
Fault Frequency: 13
Reset counter: 31
Mileage: 241986 km
Time Indication: 0
Date: 2058.14.09
Time: 12:25:57
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x149A
Hex Value: 0x0083
Hex Value: 0x7F7F
Hex Value: 0x7F00
000 - -
Fault Priority: 0
Fault Frequency: 13
Reset counter: 31
Mileage: 241986 km
Time Indication: 0
Date: 2058.14.09
Time: 12:25:57
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1211
Hex Value: 0x149A
Hex Value: 0x0083
Hex Value: 0x7F7F
Hex Value: 0x7F00
Coding: 01
ROD: N/A
Revision: 0003SH02
7 Faults Found:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 31
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.03
Time: 01:08:54
Fault Priority: 2
Fault Frequency: 8
Reset counter: 31
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.03
Time: 01:08:54
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.06
Time: 23:21:13
Fault Priority: 6
Fault Frequency: 7
Reset counter: 68
Mileage: 178241 km
Time Indication: 0
Date: 2059.14.05
Time: 00:08:55
Fault Priority: 3
Fault Frequency: 4
Reset counter: 68
Mileage: 178241 km
Time Indication: 0
Date: 2059.14.05
Time: 00:08:55
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.06
Time: 00:00:09
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Time Indication: 0
Date: 2058.14.06
Time: 00:02:04
Coding: 18BC30
Coding: 08BC30
Coding: 18BC32
Coding: 18BC32
Coding: 003237
ROD: N/A
3 Faults Found:
- 00 [008]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Date: 2122.14.06
Time: 00:02:03
- 00 [008]
Fault Priority: 6
Fault Frequency: 27
Reset counter: 68
Mileage: 241971 km
Date: 2122.14.06
Time: 00:05:00
- 00 [008]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 241971 km
Date: 2122.14.06
Time: 00:02:03
Coding: 440A01
ROD: N/A
Revision: BF046001
Coding: 002300
Serial number:
ROD: N/A
Coding: 010100
Coding: 11230
Shop #: WSC 31414
1 Fault Found:
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 242047 km
Time Indication: 0
Date: 2058.14.19
Time: 13:34:46
Try with:
https://skodapilot.com/espcalculator-bosch/
Use the translator.
Download the program and install it.
Use the translator.
Mcdonald1993-
Hi ciclo, thanks for your replyciclo wrote: Wed Aug 23, 2023 8:50 pm Try with:
Use the translator.
I got the long coding as 21022402216F0082842524Е4840400520200
The only problem I’m having is it does not give me the option to pick engine code CFWA right hand drive.
Which bit of coding do I change to make it RHD
Hi Mcdonald1993-, try this coding for your ABS unit:
RHD, TPMS w/o HHC.
230224E3416F00B2C42E24E482D400821200
RHD, TPMS with HHC.
230224E3416F00B2C42E24E482D400821300
Please, it is important that you report the result. Thanks.
RHD, TPMS w/o HHC.
RHD, TPMS with HHC.
Mcdonald1993-
This coding worked:
Thanks again.
Thanks again.
I guess someone will have to improve the Skodapilot program (ESPcalculator).
Don't forget to back up your 6R data...
Thanks for the report. Enjoy it!
