pettman
Drives: N/A
Post by pettman »
So it seems from a scan the BCM seems to think my licence plate bulbs dont work...
Tuesday,29,December,2020,20:14:39:56750
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WV2ZZZ7HZCH089217   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 15 17 18 19 25 56 0B
VIN: WV2ZZZ7HZCH089217   Mileage: 54520km-33877miles
18-Aux. Heat -- Status: OK 0000
Address 01: Engine (J623-CCHA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X43 9133
   Revision: 26X43---    Serial number: 00000000000000
   Coding: 0125401A230400080000
   Shop #: WSC 66565 257 00032
   ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: 74B1D8C79E36F54B67A-8021
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H05 1712
   Revision: 00H05V01
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_A01_VW36.rod
   VCID: 3FDB47EBE7F066134A8-806B
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108724AD09AC089E24A49072AA6510
   Shop #: WSC 02756 790 49152
   VCID: 392F29F3F954482374C-806D
   Part No SW: 7E5 907 047 BA    HW: 7E5 907 047 BA
   Component: Climatic-T5   H19 0404
   Revision: 00001009
   Coding: 0000000002
   Shop #: WSC 02756 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 6FBBD7ABF710D6939A8-803B
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 145180214
   Coding: B8B0793A4A612403932848106C2B9FDC0000412F60840000300000000000
   Shop #: WSC 02762 022 100767
   VCID: 2B0303BB0308EAB3F60-807F
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 161012 05  54  0403
   Coding: 0330AD
   Subsystem 2 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Coding: 010000
   Subsystem 3 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 4 - Part No: 7E1 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 6 - Part No: 7E1 951 171
   Subsystem 7 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H07 0022
   Serial number: 50000000000000789372
   Coding: E20000
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 54527 km
                    Time Indication: 0
                    Date: 2015.05.22
                    Time: 20:11:13
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H06 0013
   Revision: --------    Serial number: 003HM001WJ4C
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 363522CFC8CAA75B99E-8063
   Serial number: 3495ZRB40690IAMCA9H$
   Serial number: 3505ZRB405T0IAMCI07$
   Part No SW: 7E0 920 970 E    HW: 7E0 920 970 E
   Component: KOMBI         H04 0305
   Coding: 760F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 2C0100A70686ED8BFFA-8079
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2411E88762D625CB37A-8071
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042300
   VCID: 6889BCB7D27E01ABDB2-803D
   Component: IMMO          H04 0305
   Serial number:
   VCID: 6A8DC6BFCCF233BBCD6-803F
   Component: Radio         541 5814
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 16000440040005
   Shop #: WSC 127395 840 08317
   VCID: 46D5520FB8AA37DB09E-8013
2 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.17
                    Time: 23:15:50
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
                    Fault Status: 00111011
                    Fault Priority: 5
                    Fault Frequency: 6
                    Reset counter: 235
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.17
                    Time: 23:15:42
End----(Elapsed Time: 01:49, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
But as you'll see from this picture they work fine...
Any ideas?
If you haven't installed LED license plate lights try this new BCM coding:
B8B0793A4A612403932848506C2B9FDC0000412F60840000300000000000
I apologize a million times ... I was wrong.
I wanted to say this new BCM coding:
B8B0793A4A612403932848906C2B9FDC0000412F60840000300000000000
I'm sorry. :cry:
pettman
Drives: N/A
Post by pettman »
You are eternally forgiven.
That coding has stopped the dash light coming on when side lights are on, now it comes on when headlights are on, here is the latest scan.
Says about low beam now, dipped/low beam are standard bulbs. And all are working as they should
Wednesday,30,December,2020,13:43:28:56750
www.Ross-Tech.com
   Revision: 00H05V01
   Coding: 0014
   Revision: 00H43001
   Revision: 00001009
   Coding: 0000000002
   Coding: B8B0793A4A612403932848906C2B9FDC0000412F60840000300000000000
   Coding: 0330AD
   Coding: 010000
   Coding: E20000
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 54527 km
                    Time Indication: 0
                    Date: 2015.05.23
                    Time: 13:39:21
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 54527 km
                    Time Indication: 0
                    Date: 2015.05.23
                    Time: 13:39:21
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 54527 km
                    Time Indication: 0
                    Date: 2015.05.23
                    Time: 13:39:19
   Coding: 760F00
   Coding: 0000031
   Revision: B9082001
   Coding: 042300
   Serial number:
2 Faults Found:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.17
                    Time: 23:15:50
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 8
                    Reset counter: 195
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.17
                    Time: 23:15:42
End----------(Elapsed Time: 01:48, VBatt start/end: 14.3V/14.2V)-----------
Please note I cleared all faults before re-scanning and trying the lights. As always your input is always valued!
psssst, ciclo, our moderator powers enable us to edit and delete all posts... :oops: :mrgreen:
iichel wrote: Wed Dec 30, 2020 4:46 pm psssst, ciclo, our moderator powers enable us to edit and delete all posts... :oops: :mrgreen:
Sure, but this time I wanted it to be this way ...
Some users sometimes make comments as if we were stupid or little angels ... iichel, you already know that we walk through the very bowels of hell as if it were our own home and in turn we have great respect for the work that others do.
pettman wrote: Wed Dec 30, 2020 1:47 pm You are eternally forgiven.
www.Ross-Tech.com
   Revision: 00H05V01
   Coding: 0014
   Revision: 00H43001
   Revision: 00001009
   Coding: 0000000002
   Coding: 0330AD
   Coding: 010000
   Coding: E20000
3 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 54527 km
                    Time Indication: 0
                    Date: 2015.05.23
                    Time: 13:39:21
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 54527 km
                    Time Indication: 0
                    Date: 2015.05.23
                    Time: 13:39:21
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 54527 km
                    Time Indication: 0
                    Date: 2015.05.23
                    Time: 13:39:19
   Coding: 760F00
   Coding: 0000031
   Revision: B9082001
   Coding: 042300
   Serial number:
2 Faults Found:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.17
                    Time: 23:15:50
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 8
                    Reset counter: 195
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.17
                    Time: 23:15:42
It is clear that you do not understand why the adaptation for BCM Max is made. If you don't do the work you have to do, what result do you hope to get?
I already read it when you posted it earlier ... how many times do I have to tell you that your electrical installation is not correct?
Please do not answer this question. Thank you.
pettman
Drives: N/A
Post by pettman »
I now understand.
“He who asks is a fool for five minutes, but he who does not ask remains a fool forever.”
If you want to do the adaptation of the BCM Max wire by wire 💩 and you ask here every time ... thethREAD ... it will be enough to answer all your unnecessary questions.
Once you have ALL the wires installed, if you wish, I will code your BCM altruistically.
Note:
Disable diagnostics for all lights where you have retrofitted aftermarket LEDs. (with BCM Max)
"Unfortunately one cannot be a fool forever, our time is not eternal". (ciclo proverb)
pettman
Drives: N/A
Post by pettman »
I certainly do not want to do that, that would be a waste of both of our time.
Let me explain.....from reading the thread I understood that to complete the BCM max upgrade I needed to install the 2 CAN wires plus the 2x30amp ones.
From talking to others and now fully understanding BCM Max, this expects the lights to go via it, ie adaptation. I misinterpreted the instructions as I thought that part was only necessary for auto lights.
I now just need some terminals for my connector block, as I got the same one as you, in my effort to become you.
I will complete ALL adaptation and then I will scan and report back.
Happy new year ciclo, many happy returns.
pettman
Drives: N/A
Post by pettman »
Looms are made now, some ends are deliberately left in-terminated to cut them to a better length in the bus.
P.S ciclo hope you like my carpet
P.P.S I dont
bropasiek
Drives: Caravelle T5.1
Post by bropasiek »
Hi Ciclo,
Flip flops are the best, slip ring could work out better, maybe next one will be better :)
Few mods still to go
Target is simple, Caravelle with top spec, only two bits missing now, genuine air suspension - like in California van and radar sensor
Thank you guys for all help without you, it will never work out
Happy New Year and plenty of mods in New Year
pettman, those wires look really good, I'm sure we'll make everything work as it should on your T5. :wink:
hahaha, nice carpet ... those little details that appear in the images and that I like to observe to know the uses and customs of people from other places, without the intention of qualifying them or making an assessment about them. It is simple curiosity. :oops:
bropasiek, improving what is already good is great, ... we will continue in the personal struggle with our projects...
I wish you all a very good and Happy Year 2021!
reido80
Drives: VW t5.1 GP bitdi 4motion
Post by reido80 »
Hello, and a Happy New Year to you all.
I just wanted to say hello and say thank you again to Ciclo and all that have contributed to this thread without your help I would not have been able to carry out these modifications.
I am pleased to report that my installation, which by no means was done quickly 8) has been successful.
After a few months with the van off road during lockdown, carrying out various repairs and upgrades including new EGR cooler, upgraded clutch and intercooler, I then discovered that my Cylinder head gasket was leaking exhaust gas into the coolant system! Thankfully it was just the head gasket and the head was fine!
I had that sorted out at a VW main dealer and finally got it back into use properly in November. (I had a new Polo as a courtesy car, a 1.0TSI which was fully loaded with extras and was a joy to drive for such a small engine)
I have to say that the modification has made the world of difference to the function of the lights. The previous bodge job and state of wiring was unbelievable and undoubtedly affected the light output, especially when on full beam.
The extra functions of auto lights/wipers, CH/LH lights and properly functioning DRL LED's are great and the BCM max has opened up a few other extras in coding including TPMS and being able to reset the service reminder through the MFD, which is a function that is also new.
I have not carried out a Scan since my last post when I corrected my mistake with the level sensor wiring but will do that soon and give everything a check over.
All the best for the new year.
pettman
Drives: N/A
Post by pettman »
ciclo, I do have one question before I begin my wiring adaption.
I read on one of these posts about fog lights, but the context was if they were being retro fitted, I have factory fog lights, is there any other wiring needed for fog lights/cornering lights?
