Retrofitting OEM Xenon on a POLO 6R BlueMotion.
Re: Retrofitting OEM Xenon on a POLO 6R BlueMotion.
For example, 088B and 088D do support xenon yes. But with the 088B, you also need an external gateway.
If you are going to retrofit xenon with BCM change, do it properly and go with BCM Max. Follow the link that ciclo sent.
Sven6r
Drives: Polo 6R
Post by Sven6r »
Ok.Thanks for info ;)
Andrea 6r
Drives: 6r
Post by Andrea 6r »
hello, the connection of the self-leveling, there is information?
sorry for the OT
ps not for BlueMotion
it's the same in all Polo 6R. module connects to powertrain CAN, module connects to sensor at the rear axle, module connects to the headlights and module connects to the ACC and GND
Andrea 6r
Drives: 6r
Post by Andrea 6r »
in broad terms, the connection, are "clear."
but there is something that you can follow, a guide?
because, as I am there, I am considering if taking bi-xenon or LEDs, and also wanted to understand the workload that I expect.
my link to the dutch forum in the LED headlight topic, shows you the wiring.
it is not very much work extra, if you are installing OEM xenon with OEM wiring diagram.
the difficult part is, the wires from the module to the headlights. But you are doing that anyway for the headlights to BCM.
so the extra effort is not so big.
Andrea 6r
Drives: 6r
Post by Andrea 6r »
therefore, the connections for the self-leveling, are the same for xenon headlights and the LED lights?
yes, LED and Xenon are the same connections for the self-leveling system
Andrea 6r
Drives: 6r
Post by Andrea 6r »
thanks a lot, I study the connections then :)
if I have problems I can write you here or on the forum?
you can always write me here.
or start a new topic 'installation of OEM auto leveling headlights in OEM Xenon 6R' or something.
i'm happy to help you out.
it's better to do it public, so everyone can learn.
iichel wrote:you can always write me here.
+ 1 Million
Andrea 6r
Drives: 6r
Post by Andrea 6r »
sure, I will assess on the basis of difficulty, whether to open a new topic
I'd like to make a pattern such as those making ciclo
OEM Xenon on 6R non bluemotion. :arrow: BCM Max :wink:
Andrea 6r
Drives: 6r
Post by Andrea 6r »
edit
Andrea 6r
Drives: 6r
Post by Andrea 6r »
ciclo wrote:For Andrea, Federico, Jay-Jay, Sven6r and many others ... about xenon headlights, Bcm Max, automatic lights, light assist, or other equipment.
In the Polo 6R (2009-2014) there are many combinations of electrical installations depending on the year of manufacture and factory equipment. Thus it is impossible to make an installation guide for everyone and it is impossible to provide technical advice without a prior information. Nor is possible to determine whether the wirings that they are for sale in many places are correct for all vw Polo 6R without this prior information.
Necessary information:
Autoscan and images like these.
Image Image Image Image Image
missing scan
if you give me your email, ciclo, you send it;)
Inviato dal mio iPhone utilizzando Tapatalk
