1 Complete darkness. No lights at the sides of the road (city, villages, streetlights, etc).
2 Light switch in Auto.
3 Activated the system with the stalk (icon on the screen)
4 Higher speed of 40 Km/h.
Re: UPGRADING BCM 6R
Posted: Thu May 04, 2017 8:27 pm
by ciclo
govindsharma wrote:Ambient light sensor in VW polo High line Cluster.
The original screen protector decreases the sensor performance. Remove it.
Posted: Mon May 08, 2017 3:29 am
by govindsharma
VW polo 6R High Beam Assist that works very charm.Its small clip because its very difficult to upload big one. https://youtu.be/do03XmX79Qc
Thanks to Ciclo Sir for making my POLO so unique and only one in North India i think.
Posted: Mon May 08, 2017 7:26 am
by ciclo
govindsharma wrote:VW polo 6R High Beam Assist that works very charm.Its small clip because its very difficult to upload big one.
Despite the lighting circumstances and low speed is a perfect video. Thank you for sharing.
(I know it's difficult to make a good video without the right tools and conditions)
Your 6R is now safer and comfortable to drive. Enjoy it.
Posted: Tue May 09, 2017 5:29 pm
by govindsharma
Ciclo Sir please tell me what is W in circle in this IC can i also get this and what i need to get this.I think as i saw it is sign of direction.
Posted: Tue May 09, 2017 5:34 pm
by ciclo
Westward
It is the compass, coming from the navigation unit (usually).
Posted: Fri May 12, 2017 1:49 pm
by govindsharma
Good Evening Sir
Sir Is my car has this function ? Static cornering light activation threshold changed from 40 to 55kph
If no please tell me how can i activate it ?
Thank you.
Posted: Fri May 12, 2017 7:18 pm
by ciclo
Yes. I sent you all the information by email. (long ago)
However, I send it to you again. Check your email.
Posted: Tue Jul 04, 2017 12:13 pm
by Shishir
Hello Sir,
Thanks for the PM. Since I am newbie here, could not reply to your PM. Request you to PM me your email id or mobile number to discuss further.
Posted: Tue Aug 22, 2017 7:49 am
by ciclo
To install DRLs on your 6R IND with BCM Max and automatic lights, etc ... you need:
- the signal wire to activate DRLs, from the light switch to the BCM, which is already installed (included in my wiring that I sent you ).
- the wires from the BCM to the DRLs. http://www.ebay.de/itm/VW-Polo-6R-6C-Ka ... 2ed2ccbfc4
- fog lights with additional bulb for DRLs. 6C0941661, 6C0941662 ... e.g search here
- bulb carrier (4) + bulb (6) for DRLs.
Hmm... bulb, search for 'w21w white Led error free (osram, philips)'
Posted: Tue Aug 29, 2017 4:25 am
by govindsharma
Dear Sir Good Morning tell one thing that if i will deploy new fog light with drls and static cornering light, then i have to remove present fog light harness and install new one or new harness is separate for DRLS.
Thank you.
Posted: Tue Aug 29, 2017 5:59 am
by ciclo
govindsharma wrote: Tue Aug 29, 2017 4:25 am
Thank you.
New harness is separate for DRLS
All you have to do is connect the wiring from the BCM to the new daytime running lights, and install your new foglamps with DRLs.
The original wiring for the fog lights/cornering lights remains intact.
New BCM coding is required, but you know this is not a problem for us.
Posted: Sun Sep 03, 2017 2:58 pm
by govindsharma
Dear Sir I had purchased fog lights with static cornering lights and day time running lights 6C0941661 and 6C0941662. Now tell me in which bcm connector wire must be connected and coding for it.
