Polo 6R 2016 Mod.
Re: Polo 6R 2016 Mod.
I'm afraid not. :|
Look here, on a Golf VII. This way you already know what is necessary.
Btw, your wiring looms is already made. I will inform you by email. :wink: (I still have to do the installation guide)
rdasadia
Drives: Polo GT 1.2TSI DSG 6R 2016
Post by rdasadia »
ciclo wrote:I'm afraid not. :|
Ya I know these parts of PLA2.0 , i have retro fitted my Superb & Yeti and PLA 2.0 works just fine.
But I was wondering if any one has tried with the CAN lines of 7E0 BCM in 6R. I m sure it will work in 6C cause of seperate CAN.
I think the first thing to investigate is if the other units involved in this system can manage this function in your 6R. I think not, but since these units have been changing over the years I can not say that it is not possible. (I haven't done any thorough research, I don't have time as you already know :wink:)
In the tutorial for Golf VII (XaGiCo) you can clearly see all the units that need to be coded.
Hmm ... if I had a Golf VII already I would have done it. (with this guide :))
How to install 7E0937090B BCM Max in 2016 Polo 6R RHD non Bluemotion. Halogen headlights. (rdasadia)
Preview. 13 pages
:arrow: View or download here
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
Will led headlamps work with the bcm 6RU 937 087M?
Do we need to change the wiring ?
Which function of led headlamps may not support to stock BCM?
No the LEDs will not work.
smg_shardul
Drives: Polo 6R
iichel wrote: Thu Jul 20, 2017 6:51 am No the LEDs will not work.
Bcm is having option of drl s
I think only auto level function won't work.
Or I need to change bcm at any cost ?
Any other device sensor required for auto level or it's already installed due to dsg hill hold function ?
BCM must be changed. For AFS there is another thread.
rdasadia
Post by rdasadia »
ciclo wrote: Sat Apr 29, 2017 8:33 pm How to install 7E0937090B BCM Max in 2016 Polo 6R RHD non Bluemotion. Halogen headlights. (rdasadia)
Preview. 13 pages
[youtube]https://www.youtube*.com/watch?v=9ExrrmbJ82c[/youtube]
Ok!! So over the weekend I have completed the installation of Ciclo's harness exactly as per instructions. The instrucions were beautifully described by Ciclo in the installation guide 8)
Below is the scan report. Now few queries and trouble shooting.
1) My DRLs are not working !! Right now the DRLs are working more like parking lights only when the low beam switches on. Once again I will remind you that my front lights are after market Chinese ones with 10 pin connector. How do I solve this issue?
2) My interior lights (lights in the window switches, dash board buttons, light switch, mirror adjustment knob) are not working. Is it a coding issue or blown fuse problem?
3) "Coming home" function is not working. However "Leaving Home" function working perfectly.
4) I have yet not ordered the dimming light switch and hence one of the error in the BCM
5) There is an error in HVAC.
VCDS Version: 17.7.0.4 (x64)  HEX-NET CB: 0.4401.4
Data version: 20170721 DS276.1
www.Ross-Tech.com
VIN: MEXA16604GT072590   License Plate:
Mileage: 11960km-7431mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65 0B
VIN: MEXA16604GT072590   Mileage: 11960km-7431miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number: 00000000000000
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6D9229D8BC778B2EF0-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6501
   Revision: 00043014    Serial number: CU501511017434
   Coding: 0000020
   Shop #: WSC 01324 785 00200
   VCID: 3A38D28475B9EC9625-806E
   Part No SW: 6R0 907 379 BH    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422A03C2461924724251C0800908
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0542717884C7536E18-8050
   Serial number: 05061504651234
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7EB01E94E11100B659-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41CAA568D86FBF4E64-8014
1 Fault Found:
00457 - Control Module for Network (J519)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 11965 km
                    Time Indication: 0
                    Date: 2017.07.30
                    Time: 00:10:43
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 352161294
   Coding: 3AB02BBF48B30000013806917CEB9E905AC0676F600D3041200000030000
   Shop #: WSC 51200 002 104857
   VCID: 2A18E2C445195C1655-807E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 271115 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  020 2551
   Serial number: 13102848151112221545
   Coding: 030008
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  020 2551
   Serial number: 13202849151112235703
   Coding: 050008
   Subsystem 4 - Part No SW: 13 202 849 15    HW: 132 028 491 51
   Component: RLS 271115 03  37  1122
   Serial number: ÿ132028491511122357
   Coding: 353730
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  019 1552
   Serial number: 13202728151109234823
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  019 1552
   Serial number: 13202729151110091329
   Coding: 020000
6 Faults Found:
03428 - Activation of Left Adaptive Light
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 85
                    Mileage: 11965 km
                    Time Indication: 0
                    Date: 2017.07.30
                    Time: 00:11:50
03429 - Activation of Right Adaptive Light
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 11965 km
                    Time Indication: 0
                    Date: 2017.07.30
                    Time: 00:12:31
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 11965 km
                    Time Indication: 0
                    Date: 2017.07.30
                    Time: 00:10:10
02745 - Bulb for Daytime Running Light; Left
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 11965 km
                    Time Indication: 0
                    Date: 2017.07.30
                    Time: 00:10:09
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 11965 km
                    Time Indication: 0
                    Date: 2017.07.30
                    Time: 00:10:09
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 11965 km
                    Time Indication: 0
                    Date: 2017.07.30
                    Time: 00:10:09
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261224902578
   Coding: 300101
   Shop #: WSC 02756 790 50316
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 393ACD88B8BFE78E2C-806C
   Revision: --------    Serial number: 003GW012EG31
   Coding: 003036
   VCID: 49DABD48E85F770EBC-801C
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 141C01
   Shop #: WSC 12345 123 12345
   VCID: 47DEBB70FE4B817EAA-8012
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 689C58CC9B95AE0683-803C
   Component: IMMO          H05 0805
   VCID: 6A9822C48D999C1695-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014_VW12.rod
   VCID: 41CAA568D06FBF4E64-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187     HW: 6RF 035 187
   Component: Radio         013 0116
   Revision: --------    Serial number: VWZGZ1R3521196
   Coding: 0000044000000F
   VCID: 06407674B1C1587611-8052
   Serial number: 30000000054715
   ROD: EV_RDKBERU30.rod
   VCID: 373ECBB08EABF1FEDA-8062
End----------(Elapsed Time: 01:34, VBatt start/end: 13.3V/13.4V)-----------
1 --> I don't know since the OEM wiring is not made for aftermarket headlights. maybe check with the
2 , 4 and 5 are related. did you make a new cable between the dimmer and the BCM (T73b/4 and T6aa/3 iirc)? then it will be resolved after the dimmer is fit
3 --> did you pull high beam shortly, before opening the door after switching ignition off and removing key?
concerning the adaptive lights, do you have static cornering lights in the foglights?
Imageit will work?... :lol: .... hmm ... Image
rdasadia, the next thing you are going to read is in funny way, not personal, or similar ... ( myself should apply me this same story for many things I do)
Please install the appropriate parts:
1- The most urgent thing is the dimmer, your current dimmer does not have the necessary pin-terminal (T6/3). (read instructions guide :wink: )
2- Do what you said you were going to do, install the Binexon headlights and dismantle those monstrous :lol: headlamps.
The BCM coding is done based on what you said you were going to do.
Everything will work perfectly when you do what you said you were going to do.
My wiring, my coding and my instructions are correct (perfect) according to what you said you were going to do, ...remember that I insisted on this many times, here in the forum, by email, etc...
(I had the impression that you did not pay enough attention :lol:)
For example, you would know that the Coming Home function is semiautomatic if you put enough attention and read the instructions (including links)...
Separate theme:
TPMS direct for your Skoda Yeti. (suggestions and questions)
Wednesday,26,April,2017,21:44:35:58997
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4336.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: TMBKCL5L8BA7   License Plate: 359
Mileage: 59730km-37114mi   Repair Order:
Chassis Type: 5L (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 55 56 62 65 72
          77
VIN: TMBKCL5L8BA7   Mileage: 59730km-37114miles
16-Steering wheel -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CLCA)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 NH    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H25 3773
   Revision: 42H25---    Serial number:
   Coding: 00110012040500080000
   Shop #: WSC 23000 663 88866
   ASAM Dataset: EV_ECM20TDI01103L906018NH 003003
   ROD: EV_ECM20TDI01103L906018NH.rod
   VCID: 7DB21998EC171BA982-8028
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 933F200E092205FCC90E04ED901AA08A310DF0
   Shop #: WSC 59639 002 104857
   VCID: 7BB61780FA031599BC-802E
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 AK    HW: 3T0 820 047 AK
   Component: AC Manuell    H20 0709
   Revision: 00001016
   Coding: 0010001002
   Shop #: WSC 30419 002 1048576
   ASAM Dataset: EV_ACManueBHBVW36X A01010
   ROD: EV_ACManueBHBVW36X_SK35.rod
   VCID: 78BC088CC3353E81D1-802C
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 R    HW: 1K0 937 087 R
   Component: BCM PQ35  H+  110 0651
   Revision: 00110 AC
   Coding: 06190AB8E03308C0004A0080310089C007F51DAE536DC160640C40040040
   VCID: 40CCA06CD365B641A9-8014
   Subsystem 1 - Part No: 5L2 955 119 A  Labels: 1KX-955-119.CLB
   Component: SK356  26  0604
   Coding: 00F7B5
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 031011 05  54  0403
   Coding: 072B21
5 Faults Found:
00984 - Left Tail Light (M4)
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:03:40
                        Term 15 Off
                    Voltage: 12.30 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00985 - Right Tail Light (M2)
            014 - Defective
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:03:40
                        Term 15 Off
                    Voltage: 12.30 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00987 - Lamp for Brake Light; Left (M9)
                    Fault Priority: 1
                    Fault Frequency: 40
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:05:45
                        Term 15 On
                    Voltage: 13.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00988 - Lamp for Brake Light; Right (M10)
                    Fault Priority: 1
                    Fault Frequency: 38
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:05:47
                        Term 15 On
                    Voltage: 13.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02661 - Wire for Speed Signal
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:06:17
                        Term 15 On
                    Voltage: 13.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 M    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0030
   Revision: --------    Serial number: 56261220200568
   Coding: 141001
   Shop #: WSC 12345 123 123456
   ASAM Dataset: EV_EPHVA2C000000000 002011
   ROD: EV_EPHVA2C000000000_VW41.rod
   VCID: 45C2B178C44793699A-8010
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6RA4MB6J
   Coding: 00005442
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3228FAA465C914D12F-8066
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Component: LENKS.MODUL   014 0140
   Revision: FF010041    Serial number: 20120808201549
   Coding: 1082140002
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 7CB4149CF70D12A1B5-8028
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
   Part No SW: 5L0 920 840 H    HW: 5L0 920 840 HX
   Component: KOMBI         H21 0422
   Coding: 120E01
   Shop #: WSC 11111 222 11223
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   VCID: 302CF0AC6BC526C159-8064
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 261113F1003554
   Coding: 356303
   VCID: 7CB4149CFF0D12A1B5-8028
   Component: IMMO          H21 0422
   VCID: 6A9822C48D999C1157-803E
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000128461195
   Coding: 011402208001231004
   VCID: 46C0B674F141987193-8012
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   Shop #: WSC 73430 790 00074
   VCID: 3424FCBC57DD1AE13D-8060
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 D    HW: 7N0 959 792
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000120223903
   Coding: 01140020D001231003
   Shop #: WSC 73430 790 00999
   VCID: 42C8AA64DD69A451BF-8016
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 3671067
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0008
   Coding: 00000056
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0008
   Coding: 00000056
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3T0 035 156 B    HW: 3T0 035 156 B
   Component: BOLERO        008 0054
   Revision: 0A001001    Serial number: SKZ1Z3K0524841
   Coding: 090004000003
   Shop #: WSC 96034 793 698508
   VCID: 2D12E9D874F74B2972-8078
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
   Part No SW: 7N0 959 795 D    HW: 7N0 959 795
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000119425685
   Coding: 010000200001531004
   VCID: 45C2B178CC4793699A-8010
   Serial number: 30000000054012
   ROD: EV_RDKBERU30_VW51.rod
   VCID: 373ECBB08EABF1F918-8062
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-795.clb
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000119427849
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:15, VBatt start/end: 13.7V/0.0V)------------
:?: Maybe you should disable Byte17 Bit2? ... in addition to Byte16 Bit2...
e.g
:?: Does the BCM have the correct coding for direct TPMS?
e.g
(Note that this BCM (above image) is from a Golf/Jetta, I do not know if the Bits descriptions are the same)
rdasadia
Post by rdasadia »
ciclo wrote: Mon Jul 31, 2017 12:01 pm Imageit will work?... :lol: .... hmm ... Image
Separate theme:
www.Ross-Tech.com
          77
   Revision: 00H31001
   Revision: 00001016
   Coding: 0010001002
   Revision: 00110 AC
   Coding: 00F7B5
   Coding: 072B21
5 Faults Found:
            014 - Defective
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:03:40
                        Term 15 Off
                    Voltage: 12.30 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
            014 - Defective
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:03:40
                        Term 15 Off
                    Voltage: 12.30 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
                    Fault Priority: 1
                    Fault Frequency: 40
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:05:45
                        Term 15 On
                    Voltage: 13.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
                    Fault Priority: 1
                    Fault Frequency: 38
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:05:47
                        Term 15 On
                    Voltage: 13.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:06:17
                        Term 15 On
                    Voltage: 13.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 141001
   Coding: 00005442
   Coding: 1082140002
   Coding: 820000
   Coding: 120E01
   Coding: 356303
   Revision: 00H20000
   Coding: 3671067
   Coding: 00000056
   Coding: 00000056
Cannot be reached
e.g
e.g
I agree absolutely your instruction , harness and coding is perfect. Ofcourse I will be installing the dimmer switch and have already ordered the original bi xenon front lights.
I also agree sometimes I don read all instructions completely. Impatient that I am :oops: :? Please tell why is "coming home" function semi automatic?
Well, as far as I know the BCM PQ25 is not ready for the automatic Coming Home function. On pq25 platform this feature is not dependent on the light sensor (such as the leaving home function), depends (among others) on the door signals, and needs the driver action (pull from stalk).
Hmm... imagine that you park at night in a lit area (with streetlights), the illumination power from streetlights is not enough to prevent that works the Coming Home function in case it was automatic (through the light sensor), if it was automatic your lights would be working unnecessarily...
... not in all cases...
or
Image :mrgreen:
If you have to pull from stalk, you decide if you need this function...
On other VW models it is possible to code as automatic, but for the pq25 platform we need a genius (with lamp :lol:) to figure out how to make this function automatic (e.g, when removing the key from the ignition switch).
rdasadia
Post by rdasadia »
Separate theme:
www.Ross-Tech.com
          77
   Revision: 00H31001
   Revision: 00001016
   Coding: 0010001002
   Revision: 00110 AC
   Coding: 00F7B5
   Coding: 072B21
5 Faults Found:
            014 - Defective
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:03:40
                        Term 15 Off
                    Voltage: 12.30 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
            014 - Defective
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:03:40
                        Term 15 Off
                    Voltage: 12.30 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
                    Fault Priority: 1
                    Fault Frequency: 40
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:05:45
                        Term 15 On
                    Voltage: 13.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
                    Fault Priority: 1
                    Fault Frequency: 38
                    Reset counter: 92
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:05:47
                        Term 15 On
                    Voltage: 13.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 59621 km
                    Time Indication: 0
                    Date: 2017.04.23
                    Time: 19:06:17
                        Term 15 On
                    Voltage: 13.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 141001
   Coding: 00005442
   Coding: 1082140002
   Coding: 820000
   Coding: 120E01
   Coding: 356303
   Revision: 00H20000
   Coding: 3671067
   Coding: 00000056
   Coding: 00000056
Cannot be reached
e.g
e.g
Hi Ciclo!! Checked all coding as above , ABS & BCM both of correct coding as suggested by you. Any more ideas
Not for the moment, now I do not have all the information within my reach ...
As for your Polo, thank you very much for all the information you provided me by email, it is of great value to me ...
Please, can you do a test on your 6R?, with VCDS uncheck Byte2 Bit1 from your instrument cluster and tell me if the direct TPMS is still working without vcds faults.
If you need a new BCM coding for your 6R tell me what lights and wires (all) you currently have installed, please one by one (better by email), It will be a provisional coding until you install the dimmer and Bixenon headlights.
