RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
smg_shardul
Drives: Polo 6R
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Post by smg_shardul »
ciclo wrote:
smg_shardul wrote: Wed Aug 30, 2017 7:43 pm Image
This sensor does not work with the PQ25 platform. 5Q0 955 547B (tested).
Right now I can not confirm the DM and RLS wiring, you have to wait for the dates that I indicated to make all your wiring B.
Is this sensor compatible with my car ?
Yes.
smg_shardul
Drives: Polo 6R
7E0937089A
Will this bcm support auto light and bixenon?
antardaksh04
Drives: TSI
Post by antardaksh04 »
smg_shardul wrote: Thu Sep 07, 2017 4:44 pm 7E0937089A
This is the same BCM that is installed in Vento HL Plus with LED lights sold in India. This does support LED with AFS module but I am not sure if this can be called BCM Max since the last two digits are 89 instead of 90.
https://www.team-bhp.com/forum/attachme ... 693862.jpg
Regards.
smg_shardul
Drives: Polo 6R
Regards.
Thanks a lot for reply..
ВСМ — 7E0937090С
Will this bcm support both led and bixenon headlamps?
bi-xenon yes. LED is impossible to say. you need to know the Z-code, that is not possible to determine when you buy a second-hand module.
smg_shardul
Drives: Polo 6R
iichel wrote:bi-xenon yes. LED is impossible to say. you need to know the Z-code, that is not possible to determine when you buy a second-hand module.
Thanks iichel is there any bcm which supports led and bixenon headlamps both?
yes there are, for example 7E0 937 090 Z4Y but I'm sure there are many more.
smg_shardul
Drives: Polo 6R
I want to install bixenon headlamps, Bcm max, auto dimming Mirror, Rls sensor , Auto switch , & AFS module .
Can I install this in three steps as follows
1) bixenon headlamps + BCM Max
2) auto dimming mirror + Rls sensor + auto switch
3) AFS module & its sensor
Is it necessary to install all this at one time or I can do it in three steps ?
please do it one by one. this makes it much easier to find any problems that may occur.
my suggestion
first BCM max
then auto dimming mirror with RLS
then auto light
then bi-xenon
then AFS
smg_shardul
Drives: Polo 6R
iichel wrote:please do it one by one. this makes it much easier to find any problems that may occur.
my suggestion
first BCM max
then auto light
then bi-xenon
then AFS
Thanks iichel
I can't install bixenon before auto dimming mirror with Rls ?
No problem either
Hi smg_shardul
Please tell me / remember me the reference number of the parts you have already bought:
BCM
RLS
Dimming mirror
Dimmer
Light Switch (AUTO)
... so I can make your wiring for BCM Max adaptation + Automatic lights + LH/CH.
I will also make the wiring for your new RLS, and Dimming mirror.
Hmm...
Sorry, it can not be for HBA (responding to your private message)...once again...
The problem is that I want to finish making cables for others this month. And from what I can intuit from your knowledge, if I make the wiring for HBA for you it would take me more than a year with thousands of questions from you through the email, and this is totally impossible, I can not provide this technical support.
So it will be the wiring B. If you want... ?
Exactly like this: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
This is the guide that you have to study and learn to install the wiring.
smg_shardul
Drives: Polo 6R
ciclo wrote:Hi smg_shardul
BCM
RLS
Dimming mirror
Dimmer
Light Switch (AUTO)
Hmm...
I have drop plan of HBA
And I will update you part numbers
smg_shardul
Drives: Polo 6R
BCM
RLS
Dimming mirror
Dimmer
Light Switch (AUTO)
Hmm...
Mirror - 3G0.857.511.АС 9В9
The upper cover is 6С0.868.438
The lower case is 6С0.858.548
auto switch - 3С8941431А
ВСМ - 7E0937090C / 7E0937090B whichever available
RLS Sensor : 5K7 955 559B
