Greek tdi bluemotion
Re: Greek tdi bluemotion
Ok. Thanks to you. :wink:
6C IC?
Rocco-85
Drives: 1.2 tdi bluemotion
Post by Rocco-85 »
Yes, i will try the 6c ic
I think it's impossible, but if you succeed, enlighten us.
Same with that AFS module.
Once you have installed...
- the T10-T14 kufatec harness for Bixenon headlights.
- wiring for RLS and auto dimming mirror.
- wiring for automatic lights.
...these will be your new codings:
New BCM coding
22B02BBF08FB2400B3380F916CEB0ED05A80672F60053041200000030000
RLS coding
- with AFS system
07302D
- without AFS system
06302D
Check out the first page of my topic for other changes/adaptations in the lights (if you want). Hmm ... better ask me about them by email, I've deleted them from the first page of my topic. Who needs them can look for them among all the pages of my topic ...
(post an Autoscan if you have any problem after your installations)
Rocco-85
Post by Rocco-85 »
Will 1K0955559AH work or do I need any other rls ?
Mirror I buy 3G0857511E 9B9 I mean it’s the right
what mount do you have?
3G0 mirror needs 5K7 RLS, 1K0 is square. 5K7 is round sensor...
The wiring for the auto dimming mirror and RLS that I made for you has a T6 connector installed for the dimming mirror.
The mirror that you now want to install needs a T8 connector.
I asked you about this and I told you that all the mirrors did not have the same connectors to be able to manufacture your wiring for RLS and auto dimming mirror. (check private messages)
If you now install 3G0857511E mirror you need to change the T6 connector for a T8 connector.
The pin assignment is the same, but the pins (contact terminals) are not the same.
T6 connector .... MQS
T8 connector .... MCON
https://www.a4-freunde.com/showwiki.php ... uebersicht
iichel wrote: Tue Mar 06, 2018 9:40 am what mount do you have?
His bluemotion has a 3AA mount for 1K0 sensor due to the humidity sensor (old model), which involves a mirror 1K0857511E with T6 connector.
Rocco-85
Post by Rocco-85 »
ciclo it’s not a problem to change the pin. Don’t worry.
Here the mirror mount
Perfect :wink: , then you will have to do a process similar to this :arrow: viewtopic.php?f=56&t=58703&p=502496#p502505 to change the 3AA retaining plate ("mount" according iichel :lol:) or change the windshield with the correct retaining plate.
Rocco-85
Post by Rocco-85 »
Why? Will 1K0955559AH not work??
Please explain
1K0 RLS will work fine in your current setup, but then the 3G0 mirror will not fit the retaining plate mount bracket on current the windshield
Different retaining plates for different mirrors, as simple as that.
1K0857511E with 3AA845543B
and
3G0857511E with 4M0845543
viewtopic.php?f=10&t=42713#p466570
Rocco-85
Post by Rocco-85 »
Ok i changed the mirror with a 1K0857511D 9B9
Now I will be ok with the pin and the rls right?
Yes
