Restoring lost abs long code with new vcds hex v2 pro
Glen
Drives: Vw polo 6r 1600tdi
Re: Restoring lost abs long code with new vcds hex v2 pro
Post by Glen »
The car was replaced with a used abs pump without the original long code being recorded. In a situation like this, the vw tool is unable to retrieve the long code via svm, and in many cases according to him, the vw tool is unable to code a used pump. Thank you for providing additional solutions, I will go and try them and give you feedback. Yesterday, I was exhausted and fell asleep early and also it does not seem like a notification was sent to me for your post. My fault, I did not tick the block to receive a notification in the options panel.
Glen
Post by Glen »
from information I have gathered, it does not look like the official tool can retrieve the correct long code or code a used abs pump. a mechanic I know asked me to help him after he found out that the code you worked out for me was accepted and the problem solved on my car. i will hear from him on monday, if he still wants me to continue. according to the guy they are moving into the 5th week with this problem. thank you for all your help .if they come back to me, I will go try the additional codes you have provided.
Glen
Post by Glen »
hi iichel, I finally received the abs pump for my polo 6r sedan it's in the car and responding to vcds. i have been attempting to generate a new code from the reference chart you provided me for the other polo 6r you helped me with, so far unsuccessfully. please help. 2013 polo 6r sedan, rhd,clna engine 1600tdi, 105bhp, front discs 288mm,rear drums 200mm, vin number- wvwzzz60zdt014294.
Autoscan please.
Glen
Post by Glen »
Thank you very much.
Glen
Post by Glen »
thank you iichel and ciclo for the esp calculator link I will download tonight. i emailed the autoscan directly to iichel please feel free to upload it on this forum.i will only be able to upload after getting a permanent internet connection for my laptop. the internet connection on my handset is unusually slow today.
I got the autoscan. The problem with the ESP calculator is, that it works very well for the models in Russia. I like the tool a lot. In South Africa, it RHD rather than LHD and the engines are sometimes different too.
Saturday,28,October,2017,22:15:20:54965
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ60ZDT014294   License Plate:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 04 09 15 17 19 25 44 56
VIN: WVWZZZ60ZDT014294   Mileage: 50360km-31292miles
Address 01: Engine
Cannot be reached
Unable to communicate with address 01,
and "Force K on engine" is activated.
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 31414 790 31414
   VCID: 074A6B5AAF605F6F1A0-8052
4 Faults Found:
01042 - Control Module; Not Coded
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 06:12:37
                    Hex Value: 0x0007
                    Hex Value: 0x0003
                    Hex Value: 0x1213
                    Hex Value: 0x1472
                    Hex Value: 0x007D
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            012 - Electrical Fault in Circuit
                    Fault Status: 01101100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 06:12:37
                    Hex Value: 0x0007
                    Hex Value: 0x0003
                    Hex Value: 0x12B1
                    Hex Value: 0x0872
                    Hex Value: 0x007D
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 06:12:39
                    Hex Value: 0x0002
                    Hex Value: 0x0002
                    Hex Value: 0x1251
                    Hex Value: 0x1B7E
                    Hex Value: 0x007D
                    Hex Value: 0x7F80
                    Hex Value: 0x7C00
00493 - ESP-Sensor Unit (G419)
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 06:12:39
                    Hex Value: 0x0002
                    Hex Value: 0x0002
                    Hex Value: 0x12E1
                    Hex Value: 0x207E
                    Hex Value: 0x007D
                    Hex Value: 0x7F80
                    Hex Value: 0x7C00
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 213110808
   Coding: 3A904ABF08E12400923800002C0B04900080414F60040000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 42DCBA4EC482BA470DE-8016
   Subsystem 1 - Part No SW: 6R0 959 802 D    HW: 6R0 959 802 D  Labels: 6R0-959-802.CLB
   Component: -------------  002 3424
   Coding: 010000
   Subsystem 2 - Part No SW: 6R0 959 801 F    HW: 6R0 959 801 F  Labels: 6R0-959-801.CLB
   Coding: 010000
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 5 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0171050
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 811 E    HW: 6R0 959 811 E
   Component: J388__TSG_HL  002 3424
   Coding: 020000
   Subsystem 7 - Part No SW: 6R0 959 812 E    HW: 6R0 959 812 E
   Component: J389__TSG_HR  002 3424
   Coding: 020000
2 Faults Found:
00907 - Intervention load Management
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 145
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 01:23:11
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 00:05:46
   Component: VW10AirbagU06 H09 0020
   Revision: --------    Serial number: 003GX00XTRY3
   Coding: 003036
   Shop #: WSC 01383 785 00200
   VCID: 4ACC926EFC326207C5E-801E
   Serial number: 3495RRB40570TQMA9PT.
   Serial number: 3505RRB40550TQMA9G4-
4 Faults Found:
12670208 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 185
                    Mileage: 50367 km
                    Date: 2017.10.28
                    Time: 00:29:55
12854016 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 254
                    Reset counter: 185
                    Mileage: 50367 km
                    Date: 2017.10.28
                    Time: 00:01:57
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 185
                    Mileage: 50367 km
                    Date: 2017.10.28
                    Time: 00:01:57
12674816 - Immobilizer Control Module
          U0167 00 [008] - No Communications
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 185
                    Mileage: 50367 km
                    Date: 2017.10.28
                    Time: 00:29:55
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 140A00
   Shop #: WSC 00793 648 00255
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A2CC2AEACD2F28755E-806E
3 Faults Found:
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 50367 km
                    Date: 2017.10.28
                    Time: 00:00:04
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 50367 km
                    Date: 2017.10.28
                    Time: 00:00:30
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 50367 km
                    Date: 2017.10.28
                    Time: 00:02:09
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002300
   VCID: 70B82086BAAE78D7ABA-8024
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8C32EE9CF28207E5E-803E
Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 J    HW: 6RF 909 144 J
   Component: EPS_ECU       H28 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 53F28F0A2B7823CFB68-8006
   Part No SW: 5M0 035 156 D    HW: 5M0 035 156 D
   Component: Radio         553 0555
   Revision: R0553006    Serial number: VWZ5Z1L0594054
   Coding: 0500040001
   VCID: 2A0CF2EE5CF2420725E-807E
6 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 00:14:20
00625 - Vehicle Speed Signal
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 00:14:20
01704 - Terminal 58 (Dimming)
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 00:14:20
01317 - Control Module in Instrument Cluster (J285)
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 185
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 00:14:20
01299 - Diagnostic Interface for Data Bus (J533)
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 00:14:20
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 50367 km
                    Time Indication: 0
                    Date: 2017.10.28
                    Time: 03:46:32
End----(Elapsed Time: 01:48, VBatt start/end: 9.6V/10.0V. VIgn 10.0V)------
First thing, very important, charge the battery. 9.6V is way way too low. Many modules will stop working very soon and coding will be impossible, voltage needs to be minimum 12V.
Glen
Post by Glen »
thanks iichel, then please generate it manually. It' my first experience with all this esp long coding. hopefully soon I will be able to figure out the process. Please let me know if you would like me to email you the pre and post scans of the first one you helped me with for the benefit of other members. when I have a permanent internet connection for my laptop I will be able to upload files.
I have the information I need.
ESP8.2i Front
Polo 6R
RHD
288mm/200mm front discs rear drums
Manual transmission
CLNA 1.6 TDI 105hp engine
VIN WVWZZZ60ZDT014294
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Empty code
23 02 48 E3 41 6E 00 B6 C4 27 12 EB 82 D5 00 82 11 00 First guess
230244E3416E00B6C42722EB82D500821100
Try this code and tell us the results. if it's accepted, you can try the basic settings.
iichel wrote: Sun Oct 29, 2017 10:10 am I got the autoscan. The problem with the ESP calculator is, that it works very well for the models in Russia. I like the tool a lot. In South Africa, it RHD rather than LHD and the engines are sometimes different too.
Provide your database to the ESP calculator creator (free tool)... :lol:
Done that already ;)
Great!!, long ago had the data and a study for RHD (someone asked me here in the forum), but now I do not find the file.Image :cry:
It's OK, the internet has all the information. The task is simply to re-find it (or add 2 to the HEX values of byte 0... ;) )
The engines are a bit trickier, I admit.
Glen
Post by Glen »
It's rejecting both codes. the abs pump is from the uk part number 6r0614517af, it has the same engine as the other one you helped me with. the only difference is that this one is a sedan model not hatch back
