Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
gtsportms
Drives: Polo 6R
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
Post by gtsportms »
MaDwArLoCk wrote: Sun Jan 07, 2018 11:51 am
gtsportms wrote: Fri Jan 05, 2018 8:33 pm Hey i have a quick question,
will a 6R IC Fit in a 6C IC Housing? Or Only the front of the 6C IC ?
thx
Hi gtsportms,
It will not fit without adjustments!
It's necessary to cut a lot of plastic inside..
thanks for the answer, have you done it ?
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Post by MaDwArLoCk »
gtsportms wrote: Wed Jan 10, 2018 8:55 pm
U r welcome! 🙂
Yep, check the first post.
MaDwArLoCk
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
Which version of Super VAG do you use?
MaDwArLoCk
Hi federicodrdpro,
I’m using version 2016.3
gtsportms
Drives: Polo 6R
Post by gtsportms »
To bad i dont speak the russian or polish language
spacewalker
Drives: Just a VW
Post by spacewalker »
gtsportms wrote: Thu Jan 25, 2018 7:01 pm To bad i dont speak the russian or polish language
I can talk PL.
what you want ?
MaDwArLoCk
Direct TPMS / RKDS
Finally i can remove this mod from my wishlist! :D
Necessary parts:
  • 4x Universal TPMS sensors with programming PAD
    Those sensors could be programmed for almost any EU car.
    Interesting solution and cheapper then original sensors
    I found some good reviews and decided to try
  • Wiring loom
    I ordered it from AliExpress
  • TPMS unit itself
    As we know correct TPMS unit shoul be 3AA907273F but it's pretty hard to find and new one is a bit expensive.
    So i found used unit from VW Tiguan on local auto-demontage for very good price.
    This unit has different OE nuber but HW is the same like 3AA907273F, what means that it simply could be reflashed.
    Fernando helped me a lot! He offered to help me with the re-flashing, and literally in a week I had module with correct firmware! 8)
    For this I am very grateful to him! Thank you Fernando!
  • Notice!
    To make it all work, should be installed BCM 7H0/7E0 with available
    65 address in the gateway list.
    And MFA+ Instrument cluster with FW 0709 or higher!
As expected, my Seat cluster with firmware 0607 does not support TPMS.
But by a lucky chance I found BlueGT cluster 6R0920870E with firmware 0709 :)
TPMS module was placed behind the rear bumper
Programming sensors
With MaxiTPMS PAD we can read wirelessly (even from mounted sensor) this info:
Sensor ID
Temperature
Pressure
Battery voltage (by my mind it's the most useful)
Mounting sensor into the wheel!
and finally I've got the long-awaited picture on the screen!
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
MaDwArLoCk wrote:Direct TPMS / RKDS
Necessary parts:
  • Wiring loom
  • TPMS unit itself
  • Notice!
Programming sensors
With iTPMS PAD we can read wirelessly (even from mounted sensor) this info:
Sensor ID
Temperature
Pressure
Excellent job...[emoji106]
Do we need to program sensor before installation?
What device u have used for programming sensor?
Sent from my Pixel 2 using Tapatalk
MaDwArLoCk
Thanks, Shardul!
If you installing OEM sensors, it's not necessary in programming!
But if you are going to install Universal sensors (like i did) you need to programm them!
Part number you can choose from the list. In my case it was 3AA907275D
I bought a set 4x sensor + Programming device (MaxiTPMS PAD) :wink:
Good Job! 8) 8)
3AA907275D sensors were replaced by 3AA907275F sensors.
In case you want to change the software to your sensors with the magic tool ... :lol: :wink: .
(Warning TEST...Image)
MaDwArLoCk
Thank you, Fernando! :)
There wasn’t such option to programm 3AA907275F.
Available only 3AA907275 and 3AA907275D.
3AA907275D works well, so I do not see any problem in this. Maybe later Autel will update their software and “F” also will be available.
But for now I am happy that everything works! :D
Later I will try to update Seat IC with VW firmware, hope I will not brick it! :roll:
Warning Test - was good idea! 🙂👍
Ok, understood. Good luck with the Seat IC firmware update/adaptation.
Nice video, I'm going to insert it in my topic to show how the 'Warning TEST' works. :)
:arrow: viewtopic.php?f=56&t=58703&p=529334#p529334
spacewalker
Drives: Just a VW
MaDwArLoCk wrote: Fri Mar 16, 2018 5:58 am
when you kill IC, let me know, I can fix it
MaDwArLoCk
ciclo wrote: Fri Mar 16, 2018 7:22 am Ok, understood. Good luck with the Seat IC firmware update/adaptation.
Hahaha 😄👍, I’m glad that it is useful!
spacewalker wrote: Fri Mar 16, 2018 8:07 am
So you predict that IC will be bricked?
Maybe you can suggest me how to avoid it? :shock:
