Page 4 of 8
Re: Polo 6r GTI - Bi-Xenon installation Issues
Posted: Sun May 21, 2023 6:53 pm
by ciclo
Substantial improvement.
I assume you mean channel 54 (obviously), you wrote 58.
Hand switch = I assume you mean left lever/stalk.
- Check with a multimeter the +30 wire that reaches T16/10 (there should be +/-12V), it is the one that should make the high beam flash work when the light switch is in position 0. Check that the contact terminal is well inserted into the connector.
- You must change the combination switch of the steering column (STALKS) from 6RA to 2Q0, without cruise control (left stalk) and with buttons for MFI (right stalk) 2Q0953513G, that is to say as currently but 2Q0 (search in Skoda Rapid 2019 onwards). This will make your high beam hand switch work correctly and not strangely.
Based on the information in this thread
viewtopic.php?p=596481#p596481
Undoubtedly you have to parameterize the parking lights (POS) with VCP or ODIS.
Temporarily activate Scandinavian lights (BCM: Byte12 Bit0 , parking lights ON with terminal 15 ON) to make your 'LED' taillights work, although we must find some OEM solution (I'll revisit BCM coding)...
Posted: Sun May 21, 2023 8:02 pm
by Rapid
maybe yes maybe no
i need recheck
2Q0953513G
another 100$
If i find it in Israel for 20$-50, i think about.
Nobody mentioned about change stalk in drive2
< no polo no rapid 2015-16-17-18 owner who intall bi-led headlight on pq25.
where he's going from t16/10, to SB fusebox?
- Capture.JPG (51.59 KiB) Viewed 5498 times
i try with china vcp only next week or in next 2-3 day, if no i go to local vcp owner with crazy price for coding
Scandinavian lights
with my weather I'm far from Scandinavia, i nearby to Sahara
Now i se i didn't need 2 cable from sb17 to B3 A5 drl?rear fog to bcm,all rear light to bcm and salone light?
I did a lot of extra wires impractical
and didnโt harness rear fog
I just couldn't find where it splits before SB38 to L and R, but this is a new project, fog with drl section
Posted: Mon May 22, 2023 1:29 am
by ciclo
- B3 A5 wires from the BCM to the headlights for the DRLs (TFL) are essential, the removal of the original SB17 fuse is correct.
Same as B5 B6 wires for parking lights. This is indisputable.
Trying to solve the problem of the hight beam flashing in position 0 of the light switch.
New BCM coding (fifth test):
6C980F2000210400000808313E4B0CC00F40730F600338C0060000164800
BCM adaptation:
54 channel = 1
Clear all DTCs, Check the faults. Report the results.
-T16/10 is powered from the SA4 (40A) fuse, usually located near the Battery. I see you still haven't learned how to use the diagrams.
-On drive2.ru they do their thing, and I do my thing... sometimes we even do the same things.
However, I would like to see a thread on drive2.ru where they have done the same headlight installation as yours... including the LED taillights.
Posted: Mon May 22, 2023 2:07 pm
by Rapid
Hello
BCM adaptation:
54 channel = 1
nothing change,
No lo no hi, when I switch it it flashing a bit and stop working. the high beam indicator is constantly on on cluster, I noticed that it blinks while i driving
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 003200040
Coding: 6C980F2000210400000808313E4B0CC00F40730F600338C0060000164800
Shop #: WSC 18752 008 00032
VCID: 68DF0DA79B73D2CD2A-803C
Subsystem 1 - Part No SW: 5E0 919 719 C HW: 5E0 919 719 C Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0184150513
1 Fault Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 195654 km
Time Indication: 0
Date: 2017.10.12
Time: 15:41:36
where they have done the same headlight installation as yours... .
fev rapid pq25+bixenon done as i know ,from one i read about vcp parametric,, zero info about wire connectio
topick with trillion photos of end result only
I take info from Rapid Fabia and Polo owner who make autolight, some autor helped me alot, in the end 50% of my connection unneeded
I was terribly confused by many explanations when it came to a disassembled car
this part no need max Bcm or extra wire, work from the box,maybe few code
Posted: Mon May 22, 2023 6:02 pm
by ciclo
Those/your LED taillights need to be coded correctly if you have a 7E0/7H0 BCM Max fitted in a pq25 model.
I honestly don't understand what you write. fev?
Nothing changes? I see only one fault in that 'semi-Autoscan' when at first there were five and then three.
If you want, you can tell me the author who helped you a lot, you can also post a link with those final results. Currently, the world in general is smaller than it seems...
I think that the real problem with your installation lies in those connections that you made that you say were unnecessary.
If you allow me some advice:
I guess your comments are very limited because you don't understand half of the things you've done, but if I were you, I'd try harder to explain things more correctly.
Posted: Mon May 22, 2023 6:19 pm
by Rapid
Update
I change bit 18 from 73 to 66 and now i can flash with hi on switch zero
On parking switch
Lo work stable
the story with stalk still here.
Led drl only as drl.
and the right turn signal works with a fast frequent
Regarding to light work I mean, nothing change from last coding.
And few no fev sorry
Authors who some how helped me only with few wire connections no more.Those who made a project bixenon on max bcm on rapid 2013 are not many, and no one has a complete record of how.
Posted: Mon May 22, 2023 7:21 pm
by ciclo
Perfect! so you only have to parameterize the parking lights (POS) and install the new stalks, right?
Please post a fresh VCDS Autoscan (FULL), maybe it will be helpful for many others reading this thread.
The right turn signals work with a fast frequency because the BCM detects that there is not enough power consumption.
About the stalks with normal arrow (6RA), you can do this test, like Alexander did:
https://www.youtube.com/watch?v=X07mdIauRRE
.. being you who returns the lever to the central position.
Stalks that have the empty arrow (2Q0) return the lever to the center position automatically, but the high beams remain on until the next push or switch to the high beam flash. (BCM channel 54)
Posted: Mon May 22, 2023 7:28 pm
by Rapid
Maybe later i order from ebay! parameterize next week
i post it tomorrow
i chech that thanks
and it seems there is a problem now with left tail after lock
,LED continues work
- 56565656.JPG (30.23 KiB) Viewed 5330 times
and I'll look into solutions for the right turn signal
earlier, when I install the bixenon for first time on the old BCM, some friends gave me this coding
20- 07 , 23 โ 28, 25 โ 06, 18 โ 40, 19-56, 22 โ A7, 24 โ ะก0 and they helped me with solving the problem of turn signal
i need to recheck one bu one tomorrow , may you know with bit i need from this list?
This maybe solution for tail, i recheck that and edit this post with full scan
Thank you so much
Posted: Mon May 22, 2023 8:30 pm
by ciclo
Posted: Mon May 22, 2023 8:40 pm
by Rapid
https://youtube.com/shorts/1o-mFceaEKE?feature=share
high beam indicator
flashes or stays on while i driving
Hibeam turned of in this moment for understanding.
And right turn signal work the same way as left
why is this happening?not because of my new battery I hope? 50am
Speaking of the wires that I stretched in vain, I had in mind
1)SB37 Rear fog T17/9 to T73A\6.
2)Illuminated buttons in the cabin.
from the connector of the T17/16 switch Grey-green thin wire to T73B\4.
3)Revers light and license plate lamps, T73B\7.
I just changed my mind in the process. Because the light sensor
5JA907451B that I planned to instal as I understand not installed on PQ25.
Maybe yes maybe no i didnt find solution)so I decided to stay without auto light and with the old T17 switch.
So if someone only wants to adapt the bixenon only, on pq25 with maxBCM, then he will have enough of those connections and coding that are in this thread
Posted: Tue May 23, 2023 8:10 pm
by Rapid
Hi
Hello
i'm finishing today just the left fog and it didn't work as a corner. so we only have one fault code, fog lights
and I did not solve the problem of turn signal, this change helped me before upgrade to max bcm
18-40 \19-56\20-07 \22-A7\23-28\24-CO\25-06
not today or am i doing something wrong
Tuesday,23,May,2023,21:32:24:00009
Scan: 01 02 03 04 08 09 15 17 19 25 44 56 0B
VIN: TMBAT6NH7D4035792 Mileage: 195740km-121627miles
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 CR HW: 03C 906 016 CR
Component: 1.4l R4 TSI H02 4874
Revision: LJH02--- Serial number: CVN: 761A8B19
Coding: 00250012000400000000
Shop #: WSC 73430 031 00125
ASAM Dataset: EV_ECM14TFS01103C906016CR 001004
ROD: EV_ECM14TFS01103C906016CR.rod
VCID: 71E960C3A0A913057D-8024
VINID: 91D4919067981D41000C51C9086C1421BB
Readiness: 1110 0101
Part No SW: 0AM 300 060 E HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6203
Revision: 00043014 Serial number: CU501601216604
Coding: 0000020
Shop #: WSC 08643 002 1048576
VCID: 2C57B1B78F0B3EED0E-8078
Address 03: ABS Brakes (J104) Labels: 6R0-614-517-TRW460.clb
Part No SW: 6R0 614 517 BK HW: 6R0 614 517 BK
Component: EBC 460 ESP H08 0004
Serial number: A00AWQ1
Coding: 4129481409B400B9824E12DB90A200404B0800
ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
ROD: EV_Brake1ESPAEntryTRW.rod
VCID: 7DF14CF3ECF16765E9-8028
Part No SW: 6RA 959 654 HW: 6RA 959 654
Component: LENKW.SENSOR H02 0020
Serial number: 28051304210234
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005002
ROD: EV_LWSKLOVW25X.rod
VCID: 0F2D063BD65D65F50B-805A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 5JA 820 045 HW: 5JA 820 045
Component: Man AC H06 0101
Revision: 2013SH06
VCID: 73E56ACBD2B521158F-8026
Coding: 6C980F2000210400000808317F4B0CC00F40660F608718D0060600164800
1 Fault Found:
03429 - Activation of Right Adaptive Light
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 195744 km
Time Indication: 0
Date: 2017.10.13
Time: 21:29:14
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 34D 959 655 B HW: 34D 959 655 B
Component: AirbagVW20 004 0365
Serial number: 003K7R016UMU
Coding: 88CCC00000000000540000C8000000000045
Shop #: WSC 73430 790 00125
ASAM Dataset: EV_AirbaVW20SMEVW253 001108
ROD: EV_AirbaVW20SMEVW253.rod
VCID: 3467A9D79F3B662D56-8060
Subsystem 1 - Part No SW: ----------- HW: 480 411 805 13
Component: SideSensor_Df 003 0148
Serial number: 349650A25E62A7233EDW
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 480 411 805 13
Component: SideSensor_Pf 003 0148
Serial number: 350650A25E6C6F22AF6
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 480 411 805 13
Component: SideSensor_Dr 003 0148
Serial number: 351650A25E62ADF2AF1$
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 411 805 13
Component: SideSensor_Pr 003 0148
Serial number: 352650A25E62A2F4EC4Z
Coding: 2D2D2D
Part No SW: 5JA 920 810 B HW: 5JA 920 810 B
Component: KOMBI H04 0709
Coding: 110A01
ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
VCID: 366393DF8947743D68-8062
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 332200
Component: IMMO H04 0709
VCID: 6ADB77AF8D7FE0DD3C-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11230
Shop #: WSC 73430
VCID: 306FA5C7F7235A0D32-8064
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:31)--------------------------
Posted: Wed May 24, 2023 8:58 am
by ciclo
To operate the SCLs (static cornering lights) the wiring for the front fog lights must be under BCM control:
The SCLs function and all its variants on higher platforms is great!
On the PQ25, depending on the factory equipment, the front fog lights may be installed without BCM control, which makes SCLs impossible through these lamps:
In your current circumstance, which is very favorable, going from a T17 (large) connector to a T10 (small) connector is the same child's game we have been playing up to now.
If I remember correctly, T73b/7 is for the output of the license plate lights, and T73b/12 for the output of the reversing light or lights. T73a/37 is for the input signal from the light switch for auto lights (AUTO position).
However, with a BCM Max the Coming Home function can be activated without the need to have a Rain/Light Sensor (RLS) installed. For Automatic Lights and the Leaving Home function an RLS is required.
In pq25 the CH function can only be a semi-automatic function. With the ignition switch OFF, pull once from the high beam lever, when you open the door the corresponding lights will turn on to guide/illuminate your path.
Posted: Wed May 24, 2023 11:08 am
by Rapid
So only my sb connection wrong
Posted: Wed May 24, 2023 2:54 pm
by ciclo
I will always support any kind of creativity and innovation, I am starting to like your 'pictograms' ...
Posted: Wed May 24, 2023 6:48 pm
by Rapid
Thanks, i have 2 more;) maybe next of sunsensor connecton, if that possible on my car.
And a A7 is okay?
