UK-POLOS.NET - THE VW Polo Forum • Polo 6r 2010 Building a small rocket. - Page 4
Page 4 of 4
Re: Polo 6r 2010 Building a small rocket.
Posted: Mon Apr 13, 2026 3:48 am
by ciclo
It's obvious that the Skoda instrument cluster isn't receiving the correct signals from the buttons that are supposedly malfunctioning in this case. I think it's expecting signals from the rotary buttons on the Skoda steering wheel, but I can't tell you if the corresponding buttons for the malfunctioning ones are on the right or left side of the Skoda steering wheel because I'm completely unfamiliar with how they work in Skodas.
Only you, through testing, will be able to find the solution... As far as I know, and under normal circumstances—all VW parts—I haven't seen this specific problem. I've seen other known issues—poor installation and others—but not this.
Installation/LIN = OK
Coding = BCM, MFSW, ICluster... ???
Parts Compatibility = ?
Note:
Once the CCE is installed, MFSW cannot be accessed, so the MFSW buttons must be correctly coded beforehand.
If you need help, get into the habit of uploading an autoscan every time you install a new control unit, otherwise, instead of building a rocket 🚀, you might end up building an explosive firework. 🧨🎉 :lol:
Posted: Thu Apr 16, 2026 8:26 pm
by GreatBoss
Hi, the thing is, the cluster is picking up my steering wheel button presses as if they were coming from the trip stalk. It looks like the guy who modded it tried to make everything mimic an Amarok setup. Pretty weird stuff, hahaha. I’ll send you the scan in a sec.
Posted: Thu Apr 16, 2026 8:36 pm
by GreatBoss
VCDS Version: AKP 24.7.1.0 V2PLUS CB: 0.4660.4
Data Version: 20241028 DS356.3
www.vcds.pl
VIN: WVWZZZ6RZAY126841 License Plate:
Chassis Type: 6R-VW25 (XXX)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 5F 77
VIN: WVWZZZ6RZAY126841 Mileage: 465820km
08-Auto HVAC -- Status: Fault 0010
09-Cent. Elect. -- Status: Fault 0010
5F-Information Electr. -- Status: Fault 0010
61-Battery Regul. -- Status: Fault 0010
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 G HW: 03L 906 023 D
Component: R4 1.6l TDI H13 9978
Revision: --H13--- Serial number: CVN: B2D63831
Coding: 00114014002400080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023G 003014
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 2A0D02B5EC7CD78A21F-807E
VINID: 9E69EAAAA1A2A91A4108620404F3AB5256
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 210248E3416F00B8842D12E682D200421100
Shop #: WSC 02069 123 12345
VCID: 4DC76929BD92E0B2E4D-8018
Address 08: Auto HVAC
Cannot be reached
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 159180512
Coding: 3CB02BBF08A10000003800003D2B04D09080410F60060000200000000000
Shop #: WSC 02762 534 137682
VCID: 2B0307B1E306CE82DA9-807E
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0902
Coding: 08BC30
No fault code found
or the controller does not allow reading them
or a communication problem occurred
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 HW: 6R0 919 475
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 71390931003464
Coding: 100001
ASAM Dataset: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2.rod
VCID: 7BA3F7F153669E020A9-802E
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag008 H09 0018
Revision: -------- Serial number: 003DW008X3EK Dataset number: v00301656R0 0001
Coding: 003038
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 42DD4A15740C2FCA09F-8016
Side airbag crash sensor, driver side:
Serial number: 3572SRB40000A365210S
Side airbag crash sensor, passenger side:
Serial number: 3582SRB40000A0E0C285
Rear side airbag crash sensor, driver side:
Serial number: 3516GRB4025CCFTAS38P
Rear side airbag crash sensor, passenger side:
Serial number: 3526GRB4025CCFTATSLM
Part No SW: 5JA 920 840 E HW: 5JA 920 840 E
Component: KOMBI H04 0709
Coding: 140C01
Shop #: WSC 73430 031 00015
VCID: 3C2134ED16E8593A433-8068
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 00220F
VCID: 6889B8BD3270259AF7B-803C
No fault code found
Component: IMMO H04 0709
Shop #: WSC 00000 000 00000
VCID: 6A8DC2B52CFC178AE1F-803E
Address 37: Navigation
Cannot be reached
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 11220
Shop #: WSC 00163
VCID: 6FBBD3A11EDEF2A2B61-803A
Posted: Fri Apr 17, 2026 3:24 am
by ciclo
GreatBoss wrote: Thu Apr 16, 2026 8:26 pm Hi, the thing is, the cluster is picking up my steering wheel button presses as if they were coming from the trip stalk. It looks like the guy who modded it tried to make everything mimic an Amarok setup. Pretty weird stuff, hahaha. I’ll send you the scan in a sec.
Yes, that's the behavior from stalk with a 'TRIP' button.
I suppose someone will have to take a look at the EEPROM...
My ICluster 💎:
With the MM-007, it can be checked and modified in a snap/sec.
Thanks for 'that' Autoscan... :lol:
Re: Polo 6r 2010 Budowanie małej rakiety.
Posted: Sun Apr 19, 2026 6:15 pm
by GreatBoss
Great, thanks for the answer, ciclo! I'll look into it once my EEPROM programmer arrives or if I find someone who has the right gear. Is there any other way to read the EEPROM data besides doing a bench setup for the instrument cluster? Best regards!
Posted: Sun Apr 19, 2026 6:58 pm
by ciclo
Yes, as I mentioned, for example, with the Xhorse Iscancar VAG-MM007 you can read the EEPROM of your IC through the OBD2 port. It downloads to the SD card, you modify it, and then you rewrite it in a flash.
The programmer/reader CH341A also works well, but it involves disassembling the IC.
Posted: Tue Apr 21, 2026 9:03 pm
by GreatBoss
Hi, I have a friend who can check this for me next week, so I’ll see if that value has been changed. Currently, the logo and all commands are set to VW, which I assume has no impact on what you wrote above. Either way, I need to verify if those values in the EEPROM are correct.
One more thing that’s been on my mind: I mentioned earlier that I want to swap Climatic for Climatronic. After a preliminary look at the CNK guide, I understand everything, but the fact is that my Polo is already equipped with the G191 sensor as well as the G192 sensor. Does this have any impact on what is covered in the CNK guide?
Best regards, and may the force be with you! 🤭
Posted: Wed Apr 22, 2026 3:00 am
by ciclo
If you already have these sensors/senders, you will only need to connect them according to the Climatronic diagrams.
- In Climatic systems, they connect directly to the unit, the flaps adjustment is manual.
- In Climatronic systems, they connect to both the unit and the flap control motors for automatic adjustment according to selection.
