LC,18,3
LC,27,6~7...
LC,27,6~7...
- CNK
- Drives: 6R
what is it in byte 18 and 27? i thought we can't set LED lights eg. like in Golf.
Iichel wrote with the guy that made this gif, he can't retrofit this, here is video:
So it doesn't work like just P&P, probably because different electrical installation in 6C.
All the 6C turn signals are managed 'individually' by the BCM PQ26.
One wire for each blinker, i.e, six wires ... like the Golf. (several adaptation possibilities in its operation/features)
The mirror turn signals in 6R are managed in conjunction with all turn signals on the same side, BCM PQ25.
One wire for all blinkers of same side, i.e, two wires only, left and right.
, ...'test' with (enable/disable):
Byte 18 Bit3 and Bit4 (four possible combinations) 00 10 01 11
Byte 19 Bit3 PWM ...(Bit4 in case of reported fault)
Byte 27 Bit6 and Bit7 (four possible combinations) 00 10 01 11
Finding solutions for NOT OEM installed parts entails tests that probably don't work.
Installing non-original parts is inversely proportional to safety.
... not in all cases.
hi, ciclociclo wrote: Sun Nov 11, 2018 5:42 amBCM PQ25 7E0Adam87 wrote: Sat Nov 10, 2018 10:22 pm Thanks Fernando, I’ll get looking for his post and see if I can get them all added
Ah yes I forgot all about the hazard button illumination! I’ll be sure to add that aswel
Byte29 Bit6 enabled, operates the MFSW buttons on the right side of steering wheel when the LIN dedicated to the MFSW is wired in the terminal T73b/36, this condition is mandatory when the MFSW buttons on the left side are dedicated to the CCS/ACC, this in turn forces to have Byte17 Bit2 enabled for the CCS/ACC function.
For vehicles (PQ25 BCM 7E0) that comply with Euro6 (2015 ->), and install CCS/ACC in the MFSW.
Example, T6 2015:
Adresse 09: Zentralelektrik (J519) Labeldatei: DRV\7E0-937-BCM-V1.clb
Teilenummer SW: 7E0 937 090 HW: 7E0 937 090
Bauteil: BCM PQ25 Max4 H80 0733
Revision: B9080001 Seriennummer: 0771 334150699
Codierung: 62A0393A0A212092002809742C2B8DD48FA4690F60444960320400A30840
Betriebsnr.: WSC 02737 022 1593892
VCID: 68E63D859B1E147ED6-803C
Subsystem 1 - Teilenummer SW: 7E0 959 801 J HW: 7E0 959 801 J Labeldatei: 7E0-959-801.CLB
Bauteil: J386__TSG_FT 003 8654
Codierung: 0400A1
Subsystem 2 - Teilenummer SW: 7E0 959 802 J HW: 7E0 959 802 J Labeldatei: 7E0-959-802.CLB
Bauteil: J387__TSG_BT 003 8654
Codierung: 1400A1
Subsystem 3 - Teilenummer SW: 7E0 959 442 HW: 7E0 959 442
Bauteil: E221__MFL-DC1 H02 0103
Codierung: B0FFFF
Notes for readers, my dear friends:
The LIN dedicated to the MFSW (with CCS in the stalk, i.e. without CCS buttons in the MFSW) is established in terminal/pin T73b/17.
When someone ask me if the CCS/ACC MFSW buttons can be installed in a VW vehicle of the PQ25 platform ( "in OEM way" ), my answer is that the engine unit and the brake unit must have the right software (+ BCM, MFSW buttons, wires, and radar if ACC).
Apart:
- I have already studied ALL the diagrams/body repairs/maintenance of Golf MK 7.5 2018/2019... and previous ones.![]()
- I have already made some OEM modifications/retrofits, ... wiring/wired/wires in a God level. (I will be the first in the world to have one of them... OEM...)
- VW has committed a big production failure with a unit installed in my wife's Golf.
One clue: Mosel production, 5Q4 ... 3.3 ., does not match correctly with the other 5Q4 ... 5.2 . and all its functions. (weird behavoir)
3? ...f**king rats.
In a couple of weeks I will know exactly the reason ... it is the time in which the correct part has to arrive. I preferred not to process it under the official guarantee, Knowledge is more important to me.![]()
Living easy, living free
Season ticket on a one-way ride
Asking nothing, leave me be
Taking everything in my stride
Don't need reason, don't need rhyme
Ain't nothing I would rather do
Going down, party time
My friends are gonna be there too
I'm on the highway to hell
On the highway to hell
Highway to hell
...my last video of my 6R was blocked in all the countries, why?, the music/sound -highway to hell- comes from my car, not from a copy or something similar. As it says in the video, it was recorded with the smartphone microphone.
Yes, the whole VW amplified audio system that I installed in my 6R sounds fabulously (God level).
i read this post, and about to do this retrofit on my Fabia MKII from Chinese market with VW MFW. If the car has stalk CCS function, Does it still need a special ECU software that support this MFW CCS?
Hello, yes, it's necessary.
The problem: there is no ECU software available for our car/engine models (PQ25 - Euro5) that makes work the CCS buttons in MFSW.
tomshep
- Drives: Mk 2 Hatchback and now I have an Up!
Thanks to ciclo for your recent help with my Up! I now have parking distance control! Wiring was reasonably straightforward and for the help of those who follow in my footsteps, the best place to tap into the powertrain CANBUS is at the ABS module which is in front of the centre console. That allows you to run the power in to the back of the lighter/ power socket. A cheaper way to fit the sensors than buying an expensive hole cutting kit is to buy an 18.6mm Q-max cutter for about £11.
This is 0.2mm larger than the correct cutter. A coat of paint takes that up.
Currently have the PDC module coded 100001 and will report progress towards OPS once I have found the right codes but for now, I'm happy with that. Thanks, ciclo!
Thanks to you for this report.
VW UP!
Address 10
New coding: 108004
VW UP!
Address 10
New coding: 108004
A small example of how additional wires should be connected.
My Volksrriquito 6R works like a charm
Now I'm testing this HBA coding for a month.
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0202000700000000000000
Shop #: WSC 03607 002 104857
VCID: 2E05F3C4B090AE173C9-807A
The purpose of this test is to know more about our Golf MK7.5, maybe I'll open a new thread
here to show some interesting things about this Golf MK7.5. (in a few weeks)
Thursday,06,December,2018,20:44:44:32438
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: VOLKSRRIQUITO: WORKS LIKE A CHARM
Mileage: 35820km-22257mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO Mileage: 35820km-22257miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6A8D3FD44CF80237201-803E
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 025D77745448FA77881-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5038420709E97EC9-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3829D59C425460A7665-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D30D0200000030800
VCID: 2B03FAD08302DB3F1B7-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU003041440937042
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006031440656541
Coding: 1000A3
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231708304294
Coding: 308001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
VCID: 71BF28B8612EF1EF61B-8024
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F542C38E237001-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00000
VCID: 47CBA6603F2A1F5F1FF-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002200
VCID: 688945DC52743027365-803C
Revision: AA001001
Component: IMMO H04 0805
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A0DFFD48CF8C237E01-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5274
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 372BD6A04F4A6FDF6FF-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA71F37F-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77AB16A00F4AAFDFAFF-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30_005.rod
VCID: 372BD6A04FCA6FDF6FF-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B23CA9073E24BBF8B7-806E
End----------(Elapsed Time: 01:59, VBatt start/end: 14.0V/13.9V)-----------
Revision: AA001001
Thursday,13,December,2018,20:22:49:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: My perfect 6R in its maximum possible expression. ☺
Mileage: 35880km-22294mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 35880km-22294miles
Readiness: 0110 0101
Revision: --------
Coding: 01
Revision: V0000000
Coding: 0728DD
Coding: 0200A3
Coding: 1000A3
Coding: A4FFFF
Coding: 18BC32
Coding: 18BC32
Coding: 308001
Coding: 00314D
Coding: 140E01
Revision: B9082001
Coding: 002200
Revision: AA001001
Coding: 0404001C00000000000000
Coding: 010100
Coding: 11250
Shop #: WSC 00788
End----------(Elapsed Time: 01:59, VBatt start/end: 14.1V/14.0V)-----------
https://www.youtube.com/watch?v=-0M4k0W ... pY-Q&t=126
Happy new year 2019 to everyone!
A little advice:
LED interior lights/bulbs (Highly recommended)
https://www.aliexpress.com/item/20pcs-C ... 1adc168d54
You must try them just out of curiosity.
... OMGAAAH! the best I've tried so far in this LED bulb model -T10-. for glovebox, dome/ceiling, footwell, etc... white, nice and power illumination.
Even better
Revision: AA001001
Coding: 0404000000000000000000
Revision: AA001001
Wednesday,19,December,2018,06:52:34:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: WLTFC
Mileage: 35950km-22338mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 35950km-22338miles
Revision: --------
Coding: 01
Revision: V0000000
Coding: 0728DD
Coding: 0200A3
Coding: 1000A3
Coding: A4FFFF
Coding: 18BC32
Coding: 18BC32
Coding: 308001
Coding: 00314D
Coding: 140E01
Revision: B9082001
Coding: 002200
Revision: AA001001
Coding: 010100
Coding: 11250
Shop #: WSC 00788
End----------(Elapsed Time: 01:59, VBatt start/end: 14.1V/14.1V)-----------
-------------------------------------------------------------------------------- iichel
Does your instrument show the communication error with the direct TPMS module? Mine has it, but after clearing it, it will stay away until the ignition is cycled.
Installing the direct TPM/RDK system in ours 6R far exceeds the expectations and reasons for which were created our instrument clusters and ABS systems. A small bug in ignition cycle with priority 6 (VCDS, VCP, VAS, etc) doesn't matter at all. You can clear it whenever you want, now or within 20 years of system operation. No additional problem will arise from this 'bug' during those 20 years.
In my 6R both TPM systems - direct, indirect - work perfectly. IMHO, it's a luxury to have available the wheels pressure information in real time.
Humanity lives in the edge of the universe, but still doesn't know it.
-by ciclo-
-by ciclo-
