Passat Airbag
Note:
Crystal clear.
Remembering a few things for friends:
2GM880201G ... the aribag shown above.
Horn: Blue/white from T5/4 and not from T12/8... and the two Earth terminals. Perfect!
The page where the following link is found is mainly dedicated to the original CCEmulator (2019 version) ...
viewtopic.php?p=564515#p564515
Note:
Crystal clear.
6R (PQ25*). Horn via T12/8.
Before post the images of the final result of the installation of the steering wheel from the Passat 8.5 in my 6R I would like to comment on the two possible ways in which the horn can work *according to equipment -type of airbag, airbag wiring, model of multifunction buttons, steering ring, CCEmulator version-.
There are two possibilities to get the horn signal to the BCM:
1- Via LIN dedicated to buttons control unit (integrated in the buttons).
T5/4 IN
T5/3 OUT, previously posted in images and diagrams. viewtopic.php?p=588049#p588049
2- Direct connection via steering ring. Normally used for steering wheels without multifunction buttons from the factory.
T12/8.
Airbag wiring modification. Add a new wire (if needed).
Take out the T5/4 wire (blue/white in this case) and cut the terminal. Add the correct terminal, MQS.
If you own a pre-facelift Amarok you should check this more closely, the diagrams for Amarok say it is T12/7 - T41/11 - T73a/29.
Insert in the appropriate place.
Add a new wire if necessary.
Warning!
If you install the CCEmulator, you must remove the wire T5/5 to T12/8 from the aribag wiring to avoid possible conflicts or malfunctions.
Based on the experiences from other users who requested help to solve their problems due to the equipment used in their vehicles.
T5/4 IN
T12/8.
Warning!
POLO 6R. New MFSW from Passat 8.5 + CCEmulator 2021!
Why in the first image I do not have the upper cover of the steering column installed? Because it allows you to slightly correct the central position of the levers (stalks).
Note: Once corrected, the basic setting of the G85 sensor is made. Previously you can find the angle of the G85 sensor in the measurement values. (0.0º +/- 5.0º)
This way it is achieved that both the steering wheel and the levers are in a perfect and centered position.
Buttons.
All buttons work perfectly.
Very nice to recover the MUTE function.
Horn.
Or in case the button control unit is powered with +30. (6R -> 2010/2011)
Original Video
: https://www.youtube.com/embed/_Ql7nufcn ... autoplay=1
... how about we make a haptic/capacitive horn?
VCDS Autoscan.
Buttons.
Horn.
VCDS Autoscan.
Sunday,02,January,2022,16:36:05:32438
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: NEW PASSAT 8.5 MFSW + CCE 2021. OK!
Mileage: 58720km-36486mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO Mileage: 58720km-36486miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000 CVN: 9A6217E3
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
ROD: EV_ECM12TFS021_VW25.rod
VCID: 6A8D3FD44CF8023B195-803E
VINID: 9E69EAAAA1A2A94A400030C808A8E303EA
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 025D77745448FA7BB15-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5038420709E9BD5D-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3829D59C425460AB5F1-806C
Part No SW: 7E0 937 090 E HW: 7E0 937 090 E
Revision: B9084001 Serial number: 2502 179190157
Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC8670F600D39D0220400030800
Shop #: WSC 00046 123 12345
VCID: 2D07F4C8BD16D5033C7-8078
Component: RLHS 220816 0 42 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU003041440937042
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006031440656541
Coding: 1000A3
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231708304294
Coding: 308001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
VCID: 71BF28B8612EF1E358F-8024
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F542C38E23B395-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00255
VCID: 47CBA6603F2A1F5326B-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 E
Revision: B9084001
Coding: 002204
VCID: 688945DC5274302B0F1-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000000000
Shop #: WSC 03607 002 104857
VCID: 2E05F3C4B090AE1B05D-807A
Component: IMMO H04 0805
Shop #: WSC 00000 000 00000
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A0DFFD48CF8C23BD95-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 F HW: 1T0 035 686 f
Component: RNS-MID H27 6276
Revision: AB001001 Serial number: VWZ6Z7T1727264
Coding: 04000442040000A10001
Shop #: WSC 33361 790 00118
VCID: 372BD6A04F4A6FD356B-8062
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA7130EB-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77AB16A00F4AAFD396B-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30_005.rod
VCID: 372BD6A04FCA6FD356B-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B23CA9073E24BB3B23-806E
End----------(Elapsed Time: 02:05, VBatt start/end: 14.1V/14.1V)-----------
The next mod on my 6R will be in the same place where I am currently working on my wife's Golf, the room/compartment on the right side of the trunk, ... although the reason is very different.
I will be swapping out my current PDC 8K PQ25 unit...
... for a PDC 8K MQB unit ...
... something many of you have already done. E.g, viewtopic.php?p=576530#p576530
My only reason, is to achieve "Automatic" PDC activation from the front parking sensors on my RNS510 screen, which is not possible with the PQ25 unit.
I am still waiting to receive the adapter wiring from Ali.
A priority 6 fault will hang on diagnosis, like the one that hangs from the Direct TPMS unit.
This does not affect the operation of all the functions of the vehicle. We will also live happily with this new priority 6 fault.
Harness adapter received...
Routine maintenance
before PDC unit swap from PQ to MQB.
After 10 years (+/-) with the Original RVC retrofitted in the VW emblem, ...
... the factory 325N Gas filled struts for tailgate have lost a bit of punch and sometimes the tailgate stops midway up.
I have decided to change them for other 350N Gas filled struts of homo-ABILUS STABILUS brand.
WWW.AUTODOC.EU
It is something I should have thought of ten years ago, but since I'm a bit slow, it has taken me 10 years to ponder this decision.
For my tailgate setup they work like the Originals without Original RVC installed on the tailgate
, however, it will take another 10 years to decide if I've taken the right decision for this change.
WWW.AUTODOC.EU
POLO 6R with "RNS510". Automatic activation of the PDC 8K system from the front parking sensors. OK!
To achieve it, the PDC 8K PQ25 unit must be swapped for the new PDC 8K MQB unit -5Q0- (see some info in previous post).
The new MQB unit must be flashed, parameterized, coded and adapted with the correct data. The identification of the correct data is included in the images below.
My new MQB unit was a nice gift from my dear friend Slavik.
Installation of the new unit and Adapter harness.
Flashing the new unit. VCP.
Parameterization. VCP.
Coding and adaptation depends on your vehicle and personal tastes. See VCDS Autoscan, and Adaptation channels, at the end of this post.
With RNS510, and as far as I know, only the automatic activation of the front PDC sensors is possible without showing the OPS on the screen.
Video.
Original Video
: https://www.youtube.com/embed/FElTwZB0j ... autoplay=1 [----]
Right at the beginning of the video the car goes forward towards a wall, the parking button lights up bright yellow and the mini front speaker for front sensors start beeping.
If your wish is to silence that continuous beep, you just have to press the parking button, ... so in my humble opinion the parking button still has an important function.
(@Patil ->
With RNS510 you also don't get the Park menu on the IC's MFD+.
See Patil's 6R post, with Discover Media PQ25, ...for comparisons.
At this point just comment that we both have the same Instrument Cluster with the same SW, Patil did not edit the eeprom to display the new menu (park/maneuver).
Seems the old/new RNS510 (firmware) does not understand the data from the new MQB unit for front Optical Parking System (BAP protocol).
The automatic activation of the rear OPS works as before, when engaging the reverse gear.
Adaptation channels.
VCDS Autoscan.
Super happy with my new Priority 6 bug.
I conclude this modification as a total success, I achieved exactly what I was looking for.
I think I'm pretty sure I'm not going to swap my RNS510 for a DM PQ25, my wife's golf mods are more exciting now...
Video.
(@Patil ->
SW:1K8-919-472-C HW:5Q0-919-294-A --- Park/Steer Assist
Component:PARKHILFE 8K H03 0480, Coding:0011191001
EV_EPHVA18VW364GP00,001007,EV_EPHVA18VW364GP00_VW32.rod
Monday,07,February,2022,11:57:52:32438
VCDS Version: Release 21.9.0 (x64) Data version: 20210903 DS330.0
IDE00001-Production mode,Deactivating ,3
IDE01165-Park assist activation tone,On ,1
IDE01169-Audio lowering request,On ,1
IDE01170-Visual display for park assist,automatic ,1
IDE02332-Deactivate production mode,0 ,3
IDE03782-Switch-off speed for parking assist,15 km/h,1
MAS01426-Rear parking aid buzzer: volume,Stage 8 ,1
MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 6 ,1
Elapsed Time: 00:05
VCDS Autoscan.
Monday,07,February,2022,12:51:03:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: PDC. MQB UNIT INSTALLED (FL,PARAM,COD/ADAP) TEST OK.
Mileage: 59600km-37033mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 59600km-37033miles
Revision: --------
Coding: 01
Revision: V0000000
Coding: 0228DD
Coding: 0200A3
Coding: 1000A3
Coding: 18BC32
Coding: 18BC32
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331426800051
Coding: 0011191001
Shop #: WSC 00049 770 00107
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
U1121 00 [009] - Missing Message
[Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 59602 km
Date: 2022.02.07
Time: 12:48:57
Coding: 00314D
Coding: 140E01
Revision: B9084001
Coding: 002204
Revision: AA001001
Coding: 010100
Coding: 11260
Shop #: WSC 00788
End----------(Elapsed Time: 02:04, VBatt start/end: 14.1V/14.0V)-----------
6R 60000 km. Oil change and inspection.
The service expired by "time" due to the low use of the vehicle during the pandemic. I increased the time interval for the service by changing the values in the adaptation channels of the instrument cluster.
Today I decided to change the oil and check all the inspection points according to the maintenance indicated in erWin. I also reset the values for the next service with VCDS' SRI Reset.
Before...
After...
As I head to the recycling point, I check and add oil until I reach the MAX level on the dipstick.
Autoscan
From now on I allow all kinds of faults in the Autoscan related to improvements in the SW for better performance, Component Protection, and other inventions and fantasies...
https://www.youtube.com/watch?v=GXUvCON ... DMM&t=170s
Before...
After...
Autoscan
Monday,21,February,2022,12:30:13:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: 60000 KM OIL CHANGE / INSPECTION
Mileage: 60000km-37282mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 60000km-37282miles
Revision: --------
Coding: 01
Revision: V0000000
Coding: 0228DD
Coding: 0200A3
Coding: 1000A3
Coding: 18BC32
Coding: 18BC32
Coding: 0011191001
1 Fault Found:
12718592 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 60000 km
Date: 2022.02.21
Time: 12:27:08
Coding: 00314D
Coding: 140E01
Revision: B9084001
Coding: 002204
Revision: AA001001
Coding: 010100
Coding: 11260
Shop #: WSC 00788
End----------(Elapsed Time: 02:04, VBatt start/end: 13.8V/13.9V)-----------
Enough for the 125 HP of my 6R.
Tomorrow.
60000km
I tried both, I recommend the Iridium ones, a slight improvement is noticeable
Ready2enjoy...🏎
NEW Airbag model. Test.
Autoscan.
3G0880201L ヾ(⌐■_■)ノ♪
Autoscan.
Tuesday,26,April,2022,09:47:34:32438
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDYOCICLO License Plate: NEW MODEL OF MFSW AIRBAG. OK!
Mileage: 62190km-38643mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 62190km-38643miles
VCID: 6A8D3FD44CF8023B71B-803E
Revision: --------
VCID: 025D77745448FA7BD9B-8056
Coding: 01
VCID: 7EA5038420709E9BBD3-802A
Revision: V0000000
VCID: 3829D59C425460AB37F-806C
VCID: 2D07F4C8BD16D503549-8078
Coding: 0228DD
Coding: 0200A3
Coding: 1000A3
Coding: 18BC32
Coding: 18BC32
Coding: 0011191001
VCID: 372BD6A04FCA6FD33E5-8062
1 Fault Found:
12718592 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 77
Mileage: 62199 km
Date: 2022.04.26
Time: 09:44:24
Coding: 00314D
VCID: 4ACD9F542C38E23B51B-801E
Coding: 140E01
VCID: 47CBA6603F2A1F534E5-8012
Revision: B9084001
Coding: 002204
VCID: 688945DC5274302B67F-803C
Revision: AA001001
VCID: 2E05F3C4B090AE1B6D3-807A
Coding: 010100
VCID: 2A0DFFD48CF8C23BB1B-807E
VCID: 372BD6A04F4A6FD33E5-8062
Coding: 11260
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA713665-807A
VCID: 77AB16A00F4AAFD3FE5-8022
VCID: 3B23CA9073E24BB3DAD-806E
End----------(Elapsed Time: 02:03, VBatt start/end: 14.1V/14.0V)-----------
6R (PQ25) / Golf 7.5 (MQB)
Reconditioning of Passat 8.5 multifunction steering wheel. Leather, Buttons frame and R-line logo.
During my winter/spring projects 2022 I purchased several/many MFSWs of the last models for one reason or another. Some of them not shown in my 6R and G7.5 topics.
Among all of them the one I show you below. Purchased on eBay, and according to the description, new but with some damage to the buttons frame and leather.
Renewed.
Leather.
I receive it at home, disassemble it and check the damages.
It feels new, unused.
- The damage to the leather is considerable and I decide to try to solve it. Recycle it, Renew it to be Reused later.
I buy the appropriate leather pattern (synthetic leather) with blue thread, also a logo R-line (old model).
Result of my work:
This blue stitching leaves a special feeling...
Let's see how it looks when installed...
Tests in 6R (PQ25)
It looks gorgeous (IMHO)...
For proper operation the CCEmulator must be installed.
https://www.youtube.com/watch?v=nIwnWiBxOBY
It works like this...
All buttons work perfectly, as indicated in the image above.
Test in Golf 7.5 (MQB)
In the Golf (MQB) it is not necessary to install any emulator
, it is only necessary to have the appropriate equipment installed.
On my Golf, everything works perfectly after testing that the steering wheel contact detection works without problems due to the installation of the new leather... in fact, it works quite a bit better.
(... another diamond ...)
Original Video
: https://www.youtube.com/embed/ssCCpbdEN ... autoplay=1
Renewed.
Leather.
Result of my work:
Tests in 6R (PQ25)
Updated previous post.
