UK-POLOS.NET - THE VW Polo Forum • Polo 6R ABS CODING - Page 34
Page 34 of 35
Re: Polo 6R ABS CODING
Posted: Wed May 21, 2025 3:06 pm
by 747aqw
I was hoping someone could assist with calculating the long code using my vin so the abs pump can accept.
Posted: Wed May 21, 2025 7:16 pm
by ciclo
20DD2C85212400C60415346D885700000000
Posted: Wed May 21, 2025 9:08 pm
by 747aqw
Getting the same error will attach screen shot now
Posted: Wed May 21, 2025 9:19 pm
by iichel
If you have a legitimate VCDS, you could try the ross tech forum.
Posted: Wed May 21, 2025 9:24 pm
by 747aqw
I am not the owner of the VCDS cable or device however it is the original cable I think from what I can see. I have sent an email requesting assistance
Posted: Wed May 21, 2025 9:25 pm
by ciclo
20DD2C85212400C60815346D885700000000
This long coding should work "based on the data provided", I don't know why the previous long coding I posted had a different/wrong Byte.🤷‍♂️ :) (sorry)
Posted: Thu May 22, 2025 5:04 am
by amer6R
worse case scenarion, find someone with odis online account and grab coding directly from vag servers.
Posted: Thu May 22, 2025 9:51 am
by 747aqw
No success 🫣😵‍💫
Posted: Thu May 22, 2025 10:01 am
by ciclo
So there's something beyond my control.🤷‍♂️
Does the equipment of that POLO Vivo include TPMS?
Coding must be done with IGN ON / ENG OFF.
Posted: Thu May 22, 2025 10:25 am
by iichel
Tire pressure monitoring system
7K0
Without tire pressure monitoring system
Doors
0A2
4 doors
Front stabilizer bar
0AQ
Rear stabilizer bar
0BA
Without rear stabilizer bar
CO2 variant
0C0
Standard
Installation differentiation for
vehicle parts
0EM
transmission MQ 200
-- vehicle components --
Emission standard
0GV
Emission standard EU2
(critical vapor pressure)
Labels (customer specific or campaigns)
0KA
Without decals and emblems
Rear axle
0N2
Heavy-duty rear axle
Nameplate set
0NA
Without nameplate set
(without model designation)
Tailpipes
0P6
Rear tailpipe
Ignition locking system/electronic
steering column lock
0RA
Without ignition/starter switch locking
system
Special labels
0SS
Labels in English and French
foot mats
0TA
Ohne Fußmatten
Differentiation for manufacturing
process
0V6
South Africa manufacturing sequence
Owner's manuals
0VF
Information kit in English
Climate zones
0Y2
Tropical zones
Weight category for rear axle
0YL
Weight range 11
installation control only, no
requirement forecast
Fuel systems
1A3
Fuel system for fuel-injected SI engine,
injection system without fuel return
and modified injection pressure
Brake systems
1AC
Anti-lock brake system (ABS)
Antifreeze agent
1C1
Antifreeze up to -25 degree Celsius
tolerance up to -30 degree C
Trailer hitch
1D0
Without trailer hitch
Activated carbon canister/gasoline
particulate filter
1E1
Identification labels
1EY
Special identification label
with weight data, but without general
operating permit (ROW)
Spare wheel/breakdown kit
1G1
Space-saving spare wheel
Shock absorption in rear
1JA
Rear shock absorption, basic version 1
Rear brakes
1KM
Drum brakes in rear
Air filter (engine)
1L1
Air filter for dusty regions
Front brakes
1LR
Disc brakes in front, with integrated
brake carrier
Steering wheels
1MM
Steering wheel
Steering system
1N3
Speed-related variable steering assist
(Servotronic)
Wheel trims
1NC
Wheel trims
Lockable wheel bolts
1PA
Standard wheel bolts
Counterweights for steering wheels
1Q0
steering wheel without balance weight
Vehicle tools and jack
1S1
Front-end underbody cladding
1SL
Underbody stone guard
First aid kit/warning triangle
1T2
Warning triangle
Cool box
1W0
Without refrigerator/glove compartment
cooling system
Fuel filling volume
1Z0
Initial standard fuel filling
Delivery equipment
2A0
Without delivery equipment
Steering column systems
2C5
Axial and vertical adjustable steering
column
Tank filler neck for unleaded fuel/fuel
type
2G7
Filler neck module 1 with insert
Bumper
2JF
Painted bumpers
Fuel tank material treatment
2LA
Fuel tank without special material
treatment
Loading edge protector
2P1
Plastic loading edge protection
Fresh air intake for vehicle interior
(with particle filter)
2V1
dust and pollen filter
Additional tires (snow tires)
2WA
Ohne zusätzliche Bereifung
Additional child seat anchorage
3B4
Child seat anchors for
child seat system ISOFIX
Center seat belts in rear
3C1
Static lap belt, center rear
Roof insert/convertible top
3FA
Without roof insert (standard roof)
Luggage/load compartment floor in rear
3GA
Without luggage/load compartment floor
Backrest release
3H0
Without backrest release for front seats
Head restraints
3J1
Hight-adjustable head restraints for
front seats
Seat adjustment
3L0
Without special seat adjustment
Special approval measures
3M0
Without special measures
Rear seats
3NB
Rear seat bench/backrest, completely
folding
Brackets
3P0
Without bracket for first aid kit and
warning triangle
Head restraints in rear
3Q1
Roof rails/roof rack
3S0
Without roof rails/roof load rack
Luggage compartment cover
3U1
Folding trunk cover
Sound insulation measures for interior
noises
3W0
Without additional noise suppression
measures for passenger compartment
Outer seat belts in rear
3ZB
3-point seat belts, outer rear with ECE
label
seat heater
4A0
Without seat heater
Door and side trim panels
4AP
Door and tailgate/trunk lid locking
mechanism
4I2
Central locking w/ radio remote control,
interior controls, without SAFELOCK
Side and rear windows
4KC
Side and rear windows in heat-insulating
glass
Breakaway interior rearview mirror
4L2
Breakaway interior rearview mirror,
dimming
Controls (steering wheel/steering column)
4LA
Ohne Bedienelement
Beverage holders
4M0
Without beverage holder
Dashboard
4N2
Standard dashboard
Rear floor panel platform module
4P2
Rear floor panel module, type 3
Restraint systems in front
4QV
3-point seat belts in front, with
electric pretensioner and height
adjustment
Window regulator
4R2
Power windows in front, mechanical
window regulators in rear
Luggage net/bag on backrest(s)
4U0
Without luggage nets/pockets
on backrests
Airbag
4UE
Airbag on driver and front passenger
side, without knee airbag, without
front passenger airbag deactivation
Side airbag
4X0
without side airbag
Adhesive film
51A
Without adhesive film
Luggage compartment trim
5A6
Full nonwoven luggage compartment trim
Body measures
5C6
Additional body measures
Carrier frequency for remote control
5D1
Trägerfrequenz 433,92 bis 434,42 MHz
Paint preservation/transport protection
5K0
Without surface protection, with
additional transport protection measures
Right exterior mirror
5RV
Right exterior mirror, aspherical
Left exterior mirror
5SJ
Left exterior mirror, convex
Fire extinguisher
6A0
without fire extinguisher
sun visors
6DG
Sun visors with mirror on front
passenger side, without cover
Center armrest
6E0
Without center armrest in front
Additional body protective covers, side
6EA
Without additional side body covers
(stone guard)
Components with special surfaces
6FA
Components without special surface
appearance
Radiator grille
6KA
Radiator grille
Molded headliner
6NA
Unsplit molded headliner
Rear license plate carrier
6P1
Rear license plate carrier (ECE)
Hand brake lever
6PA
Hand brake lever handle in plastic
Gearshift knob/gearshift handle
6Q1
Gearshift knob/handle in plastic
Gearshift boot/gearshift trim
6R1
Leatherette gearshift lever boot
Luggage compartment floor covering
6SC
Luggage compartment floor covering in
needle-punched nonwoven
Interior lighting in footwell
6T0
Without interior light in footwell
Additional dust seals
6U1
Additional dust seal outside
License plate carrier in front
6W1
Front license plate carrier (large)
Exterior mirror adjustment
6XB
Exterior mirrors, adjustable from inside
Speed alert system/speed limiter
6Y0
Without cruise control warning system
CD changer/CD player
7A0
Without CD changer/CD player
Theft protection system
7AC
Electronic immobilizer, with anti-theft
alarm system and interior monitoring
Outlet
7B0
Without socket
Thermal energy storage system/auxiliary
heater
7E0
Without heat accumulator/auxiliary
heater
7K0
Start-stop system/regenerative braking
7L3
Without start-stop system without
Vehicle class differentiation
powertrains/platform parts
7LN
Vehicle class differentiation -6C0-6RS-
for build status South Africa (national)
Scuff plates
7M5
Without protective film for scuff plate
Lumbar support in backrests
7P0
Without lumbar support
in seat backrests
Platform group class
7PA
Platform group class 1
Navigation system
7Q0
not with navigation system
CD-ROM/DVD/SD card
7QA
Without CD/DVD for navigation
Dashboard illumination
7V1
Standard dashboard illumination
Park distance control
7X0
Without park distance control
Main headlamps
8BK
Twin headlamps for driving on the left,
with integrated high beam
Speedometer cable and seal
8CC
Speedometer sensor without seal
(electronic speedometer sensor)
Alternators
8GG
Alternator 110 A
Headlight control
8K0
Without special headlight control
Wiper and washer system for rear windows
8M1
Rear window wiper and washer system
with intermittent control
Intermittent windshield wiper control/
light/rain sensor
8N4
Windshield wiper intermittent control
with potentiometer (four speeds)
Headlight range control
8Q0
Without headlight range control
Loudspeaker installation
8RE
4 speakers (passive)
reading light
8S1
Reading light in front
Rear combination lamps
8SG
Rear combination lamps, standard design
(type 2)
cruise control system
8T0
Without cruise control system (CCS)
rear fog lamp
8TA
without rear fog lamp
Washer fluid level indicator
8W0
Without washer fluid level indicator
Front fog lamps/additional headlamps
8WA
Ohne Nebelscheinwerfer
Headlamp washer system
8X0
Without headlamp washer system
Horns
8Y4
High-tone horn
Engine cooling
8Z4
Moderate hot country
Antennas
8ZG
Antenna for AM/FM reception
Heating system/air conditioning system
9AB
Manually controlled air conditioning
system
Luggage compartment lighting
9E0
Without luggage compartment lighting
Interior light in cab
9GA
Interior light with contact switches on
the doors
Smoker's/non-smoker's version
9JA
Non-smoker version
Seat belt reminder
9P1
Seat belt reminder, electric contact in
buckle
Multi-function display/trip computer
9Q0
Without multi-function display/
trip computer
Heated washer nozzles
9T0
Without heated washer nozzles
Brake pad wear indicator
9U0
without brake wear indicator
Telephone/telematics
9W0
Without car phone preparation/
installation
Multimedia/video/DVD/notebook connection
9WL
Jack for external audio source
Equipment lines
A8C
Comfort equipment
Vehicle type
AZ0
Vehicle with production equipment
Part set for country-specific
prescriptive standards
B2E
Part set, complying with
vehicle type for South Africa, various
parts
Type-approval testing countries/
countries with specific requirements
B53
Type approval country South Africa
General operating license additions
C00
Operating permit, initial registration
Wheels
C0D
Steel wheels 5J x 14
Special editions
E0A
No special edition
Vehicle specifications
F0A
No special purpose vehicle, standard
equipment
Customized installation
FC0
Without customized installation
Shock absorption in front
G08
Transmission specification
G0C
5-speed manual transmission
Model upgrade measures
GP0
Vehicles without special upgrade
measures
Tires 215/45 R16 86V
H0G
Tires 185/60 R14 H
Radios
I7E
MIB2-G Entry PQ/MQB radio
rest-of-the-world
Batteries
J0A
Battery 175 A (36 Ah)
Body forms
K8G
Hatchback
Camera systems/surround sensors
KA0
without camera systems/environment sensors
License plate lighting
KL0
Standard license plate lighting
Steering system setup
L0R
Right-hand drive
Weight category for front axle
L37
Suspension range 37
Engine specification
MN7
4-cylinder SI engine 1.4 l/55 kW (16V)
MPI
base engine is T1Q/T99/TK0
Seat trim covers
N2E
Seat trim covers in fabric
Battery/alternator capacities
NY0
Standard battery/alternator capacity
Front seats
Q1A
Standard seats in front
LongLife Service Regime
QG0
Without LongLife Service Regime
Service indicator
QI4
Service indicator 15 000 km or 1 year
( fix )
Chrome package
QJ0
Without aluminum/chrome package
Drawers under front seats
QN0
Without drawers under front seats
TV reception/digital radio reception
QV0
Without TV reception/digital radio
reception
Base engine
TK0
unit 03C.1
Dashboard inserts
U0C
Instrument cluster with tachometer,
clock and km/h speedometer
Electric interface for external use
UF0
Without external electric interface
Hill start assist
UG0
Without hill start assist/hill descent
control/comfort driving assist
Tire suppliers
V0A
Tires without specification of tire
brand
Pedal cluster
VF0
Fußhebelwerk "Standard"
Ventilation duct in front
VK0
Air duct, standard
Pedestrian protection
VL1
Extended pedestrian protection
Posted: Thu May 22, 2025 10:51 am
by ciclo
Thanks, Michel.
As expected, ...my latest Long Coding is the only one I can set with the info provided for ABS non-ESP.🤷‍♂️
These ABS modules have their mystery...
Posted: Thu May 22, 2025 1:18 pm
by 747aqw
I am coding with engine off
Ignition on.
Posted: Thu May 22, 2025 5:50 pm
by ciclo
If you're able to get it to accept a new coding with VCDS via Ross-tech or with ODIS via a VW dealer, please let us know the results/coding, this will benefit other users in the future. Thank you.
Posted: Thu May 22, 2025 7:24 pm
by prtvrk
Non OE vcds? Use a proper loader.
Posted: Thu May 22, 2025 7:26 pm
by 747aqw
I am using a OE Vcds loader yes however I'm going to try odis online tomorrow then will give update
