Locked
Logically Crave98.
- You must remove the T14/10 cable from the adapter harness both xenon headlights. Isolate completely.
- Remove the T2/1 cable from both current DRL.
- Hook 0.5mm cable from the T2/1 cable to the T14/10 connector slot xenon headlights.
"Replace the coding I submitted you"
Your LED DRL will work like a charm, as in the factory xenon. This is the best and most OEM solution.
Your current DRL, never run more. Image
Little scheme:
crosspolo2014 wrote: Hello Ciclo,
I have the same setup on my crosspolo 6r everythin works fine exept my leds.
Please, VCDS auto-scan. :wink:
crosspolo2014
Post by crosspolo2014 »
Hello Ciclo,
Many many thanxs!
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56
VIN: WVWZZZ6RZEU018004
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number:
Coding: 001100D6202400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS02103F 004007
ROD: N/A
VCID: 6ADB24238D8A324E2A7-803F
No ASAM data for: "EV_ECM12TFS02103F" (VW25)
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0003
Serial number: --------------
Coding: 21DD2885222400C884141469445500400905
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_AU21.rod
VCID: 8F2DD5B756A837669D9-80DA
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 387FCE6B8BA650DE6C3-806D
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 P HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0411
Revision: BF034001 Serial number: 0581 207131010
Coding: 22B02B3F08E12400923008002D2B0CD0F0C041FF60060000200000000000
Shop #: WSC 31414 790 31414
VCID: 4A9B84A3E54AD24E0A7-801F
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Coding: 18BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 7 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361324900472
Coding: 108003
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E73D873A1826EEEA6F-806B
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01UPZS%
Coding: 00314D
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A9B84A3ED4AD24E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB400O50KF04HB3
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB400I50JEC9GIJ
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB401250M2C9I4T
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB400Q50L2UQPAE
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 M HW: 6R0 920 860 M
Component: KOMBI H04 0709
Coding: 140A01
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BF034001
Coding: 002200
VCID: F0EFB64B2356489EE43-80A5
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H04 0709
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7665251563
Coding: 020100
VCID: 2B55E1274AF0EB46111-807E
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 L HW: 3C8 035 279 L
Component: RNS315-EU H73 0407
Serial number: VWZAZ2N0458945
Coding: 040004110200010000001308
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3467FA5B9FCEB4BE40B-8061
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V4 0050
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11250
Shop #: WSC 31414
VCID: 306FF64BF7D6889E243-8065
End ---------------------------------------------------------------------
crosspolo2014
Hello Ciclo,
Do u need a short video what i mean?
98octaneblood wrote:Really impressed about your skills and your upgrades :shock:
I expect my Blue GT arrives home next week. By the way, did you painted the black outer plastics from the bumpers? They look satin.
Cheers from Spain :D
Hola, grateful for your comments.Image
The outer plastic bumpers are satin, for the moment.
Excellent choice, a BlueGT 6C. Take some pictures when you get it and shows us. :wink:
crosspolo2014 wrote:Hello Ciclo,
Yes please, shows us the video.
I can not find faults in your autoscan, your retrofit xenon headlights should work fine.
The car is very new, but perhaps you have low battery, Image check it out.
crosspolo2014
https://vimeo.com/111099351
This is the video Ciclo.
The oem xenon is retrofitted whit a 14 to 10 pins adapter.
jobbercete
Drives: Polo 6R 1.2 TSI 90cv Sport
Post by jobbercete »
could it be the alternator?
crosspolo2014
jobbercete wrote:could it be the alternator?
i dont thinks so,
car is now 6 months old drove 20.000km and this is al the time i have retrofitted the xenon.
i think somewhere in VCDS is a adjusting of the voltage for the led's. but where??
it's like he is getting not enough power when i turn my steering wheel.
Crave89
Drives: Bluemotion 6R 1.2TDI 2010
Post by Crave89 »
ciclo wrote:Logically Crave98.
Little scheme:
I understand! For now i have removed the connector of the halogen drl. Once i get a chance i will rework the wiring as you have drawn.
Thanks Ciclo for the great help!
jobbercete
Well, at least in cars with halogen from factory, when the low beams are On and you turn the steering wheel, the light fluctuates as your leds...that's why I suggested the alternator (let's say, it's not powerful enough when the revs are low), but maybe it's something else :wink:
crosspolo2014
jobbercete wrote:Well, at least in cars with halogen from factory, when the low beams are On and you turn the steering wheel, the light fluctuates as your leds...that's why I suggested the alternator (let's say, it's not powerful enough when the revs are low), but maybe it's something else :wink:
Yes thats what i had before installing oem xenon headlights.
But i think every polo 6r has that.
crosspolo2014 wrote: i think somewhere in VCDS is a adjusting of the voltage for the led's. but where??
You should consider that your LED module is powered by the wiring of the side lights. Therefore, with harness adapters would not be possible to change the voltage of the LED module.
Considering that all parts are new and they are working properly, let's start by more simple way to discard electronic bugs or bad contacts between connectors:
Soft Reset :lol: : Unplug the harness adapters and reconnect. From T14 and T10 only.
Check LEDs.
Hard Reset :lol: : Disconnect the battery for a few minutes. (5 minutes is enough)
Check LEDs.
Remember that after you have to enter the PIN code of the radionavigation and restore function comfort electric windows. (user manual)
It seems clear that the failure of the LEDs is related to voltage fluctuation. Checks if after driving more than 20 minutes, the LEDs have the same problem.
Deceiving the lights setup to change the performance of the same, you can enter the following encodings in your BCM:
22B02B3F08E12400923008002D2B0CD0F0C043FF60060000200000000000 Check LEDs, all lights, one by one, and no faults in BCM.
or
22B02B3F08E12400923008002D2B0CD0F0C047FF60060000200000000000 Check LEDs, all lights, one by one, and no faults in BCM.
Although these changes in the coding of the BCM may not solve the problem.
Copy and paste as explained here: http://www.uk-polos.net/view ... 95#p483792
Restore your old coding if nothing is solved:
We hope your feedback. :wink:
98octaneblood
Drives: Blue GT MY15
Post by 98octaneblood »
Sure, I will open a thread as this GT (6C) is the first one arrived at my dealer...but honestly, this version changes less than other versions, at least externally.
You mean that you used satin paint for the black plastic?
:wink:
crosspolo2014
Check LEDs.
Check LEDs.
or
thank you Ciclo for your support :D
i try this today and give a feedback.
what is the difference between
or
many many thanxs!!!
greetings YD
98octaneblood wrote:You mean that you used satin paint for the black plastic?
:wink:
No, are original of factory. :oops: :)
crosspolo2014
Check LEDs.
Check LEDs.
or
Hello Ciclo here's my feedback,
Soft reset DONE
Hard reset DONE
long coding 2x DONE
Drove more dan 20mint DONE
This al doesnt have any change.
Don't no what to do.......
I think leave it like it is............
Greeting YD
Locked
