Cris-87
Drives: vw golf 6 and vw t5 2014
Post by Cris-87 »
Annoyed wrote: Fri Feb 18, 2022 1:13 pm
ciclo wrote: Fri Feb 18, 2022 5:08 am Thanks for sharing the pictures.😎👍
They help when we take a look at the autoscan. :)
Hi Ciclo,
This is Craig (ViperSlider)
The site is refusing to allow me to post under my other username and also refusing to allow me to post my autoscan stating it contains contacts and is classing it as spam.
I also can’t contact any admin as I am “forbidden”.
Not sure what to do. If the admin are reading, could they advise?!
i have the same problem
Viperslider
Drives: Seat Leon 5F Cupra ST 290
Post by Viperslider »
Good afternoon Ciclo (or morning, depending on your timezone!)
Today I have completed the following:
Added new 2.5mm/30a inputs to T73a63 and T73b68
Added new 1.5mm/15a outputs to T73a1/a2 and b1/b2 to fuses 5/6/27/28 including new signal to IC for HB. F5-A2, F6-B1, F27-B2, F28-A1
Added new 0.5mm outputs from T73a5/b3 to fuses 12/14 for DRLs
replaced 17pin light switch (E1) with 10 pin (3C8941431A) and added 6 outputs from T10 to relevant T73a/b plugs and +15/+30/earth feeds for switch
Replaced stalks with 7E0953507F and added new wires for T41/38/39/40/41 to +15, +30, T73a62, T73b8
Additional information that may be useful:
I would like to add a dimmer switch for the interior illumination but not checked what is needed yet, so T10/10 remains disconnected for now.
Originally I had H4 halogen headlights but now have aftermarket headlights that are T5.1 xenon REPLICAS which have LED Drls. I have also added Osram LED headlight bulbs (not pictured). Pic below:
As seen, I have genuine T6.1 LED tail lights too.
The result:
No DRLs
Side lights working
Low beam working (but showing Main beam display in IC)
No main beam control from stalks at all
But I suspect you expected the above results!
Recently added RLS and HBA(FLA) parts/looms but not concerned with those working yet until after the lights are working correctly.
Here is my latest autoscan (or part of, due to forum posting restrictions)
   Revision: B9080001    Serial number: 0771 035161868
   Coding: F9A839BA0A212091012808D02CEB8E50F08043FF60020080320000010000
   Shop #: WSC 12345 210 12345
   VCID: 689C49DB9BB550C9E9-803C
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 030216 05  54  0403
   Coding: 2630AD
   Subsystem 2 - Part No SW: 7E0 959 801 Q    HW: 7E0 959 801 R  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  005 0653
   Serial number: KU0KU022101992950515
   Coding: 1000B3
   Subsystem 3 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU010041991001759
   Coding: 0000B3
   Subsystem 4 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29180000513380048213
   Coding: A4FFFF
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:01
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:02
01504 - Bulb for License-Plate Light (X)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:02
My long term end goal is to replace the front end with T6 including OEM LED headlights and headlight range control sensors/module but in the mid term, I'm looking to get some ground work done in preparation for them, hence the HBA retrofit.
The only part I am finding a barrier is the coding due to lack of information.
I'll look forward to your input on the above!
If you want to discuss payment for your time then I'm happy to discuss :)
Viperslider
I forgot to mention, the headlights are designed for halogen bulbs, not xenon. Just in case there is any confusion. :)
Cris-87
Post by Cris-87 »
ciclo wrote: Fri Feb 18, 2022 12:09 pm Hí.
It seems that you have not done this procedure correctly. Replacement :arrow: http://wiki.ross-tech.com/wiki/index.ph ... eplacement
Please post an old Autoscan with BCM 7H0...087 installed.
edit: Please link me to the guide you have followed for your electrical installation.
this is the guide that i have followed :arrow: viewtopic.php?t=70736&start=30
and this is the scan.
I apologize if it is a bit dirty but the t5 had just come out of the bodywork for a total painting and they disassembled it without then resetting the errors
VIN: WV2ZZZ7HZEH033380 Mileage: 227190km-141169miles
18-Aux. Heat -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 M HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0411
Revision: BO034001 Serial number: 0573 210130420
Coding: F8B0793A4A21201201280E107EEB8FD50080412F60844000320000000000
Shop #: WSC 12345 123 12345
VCID: 3E76BB68A927877973-806A
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
10 Faults Found:
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
03432 - Activation of Right Parking Light
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
00329 - Control Circuit for Unlocking Rear Lid
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
03301 - Response Closing Status of Drivers Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 58
Mileage: 226190 km
Time Indication: 0
Date: 2016.04.21
Time: 20:24:41
03302 - Response Closing Status of Passenger's Door
Fault Priority: 2
Fault Frequency: 3
Reset counter: 58
Mileage: 226190 km
Time Indication: 0
Date: 2016.04.21
Time: 20:24:41
03304 - Response Closing Status of Rear Right Door
Fault Priority: 2
Fault Frequency: 27
Reset counter: 70
Mileage: 225536 km
Time Indication: 0
Date: 2016.02.20
Time: 07:50:29
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 225590 km
Time Indication: 0
Date: 2016.03.05
Time: 10:44:28
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 46
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Fault Priority: 6
Fault Frequency: 6
Reset counter: 46
Time Indication: 0
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 179
Mileage: 223303 km
Time Indication: 0
Date: 2015.11.28
Time: 18:21:22
Hello "Annoyed" ... LOL!
General rule:
You cannot use private messaging or post contacts until you have at least 10 posts.
The problem is that most of the time a contact is detected when posting a full VCDS Autoscan.
Please Craig, keep posting here with ViperSlider until you get those 10 posts needed. Thanks!
edit:
Sorry I didn't see the following posts before posting,
... at least it's already explained ...
Hi Viperslider.
All your post read and understood 👍, ... you should now be able to post a Full Autoscan without any problems.
Hi Cris-87.
Please tell me the GW coding with the BCM 87. Thanks.
Viperslider
ciclo wrote: Fri Feb 18, 2022 8:13 pm Hi Viperslider.
Woohoo!! It has been a long time since I was a "Newbie" on an internet forum :)
Here is my latest autoscan:
Friday,18,February,2022,10:35:17:50827
VCDS Version: 21.9.0.2 (x64)  HEX-NET CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZEH09****   License Plate: L16TRO
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 20 25 37 56 61 77 0B
VIN: WV1ZZZ7HZEH09****   Mileage: 182370km-113319miles
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
   Component: R4 2,0L EDC   X45 5576
   Revision: 26X45---    Serial number: 00000000000000 CVN: 8C42185C
   Coding: 01194012232400080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GH 003003
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: 77BE1AA7CE0BCF3170-8022
   VINID: 9E606AAAA1D8A956002430C50C00D7DA0A
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 708724AD89AD0E9824A59176A96110
   Shop #: WSC 02736 790 49152
   VCID: 3A38C393B59912594F-806E
   Serial number: 28011404650720
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB00F83E131FE7933-802A
   Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
   Component: Climatic-T5   H20 0506
   Revision: 00001012
   Coding: 0000000002
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 7CB4058BF72DEC691D-8028
   Coding: 2630AD
   Coding: 1000B3
   Coding: 0000B3
   Coding: A4FFFF
3 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:01
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:02
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:02
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00MSSRH
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3522D0AF9487FD21A2-8060
   Part No SW: 7E0 920 970 J    HW: 7E0 920 970 J
   Component: KOMBI         H04 0710
   Coding: 760E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 312AE4BF60EFD101FE-8064
1 Fault Found:
13654544 - Databus
          U1121 00 [009] - Missing Message
          [Steuergerät für Telefon keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 61
                    Mileage: 182371 km
                    Date: 2022.02.18
                    Time: 01:28:02
   Revision: B9080001
   Coding: 042300
3 Faults Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:06
01300 - Control Module for Navigation with CD-Rom (J401)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:06
01303 - Telephone Transceiver (R36)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.11
                    Time: 01:28:06
Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
   Part No SW: 1K8 857 511 E    HW: 8J0 857 511 C
   Component: FLA           H03 0012
   Revision: AA002001
   Coding: 0102856B74745D545420363E01
   Shop #: WSC 00020 790 12345
   VCID: 3424EDAB97FDE42995-8060
   Component: IMMO          H04 0710
   Serial number:
   VCID: 6A9833D38DB962D9FF-803E
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 00001A00
   Shop #: WSC 02739 790 12345
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 01:23, VBatt start/end: 11.5V/11.7V. VIgn 11.7V)-----
The radio/nav/telephone related fault codes are expected due to the Alpine head unit.
Kind regards
Thanks Viperslider, let me study the possible codings for your T5.
I'll post them tomorrow (or as soon as possible).
No type of payment is necessary, sharing your experiences in the forum with your T5 is more than enough.👌
Viperslider
ciclo wrote: Fri Feb 18, 2022 8:33 pm Thanks Viperslider, let me study the possible codings for your T5.
Thank you Ciclo, if you have any need for more information then not a problem.
On a side note, I have a “D” revision 7E0 BCM here too. I ran into a wall with the keys so opted to get the other BCM to make the upgrade easier. I would think that there is no real disadvantage in having either BCM?
@Viperslider.
Previous clarifications:
- Same meridian, same time zone. :)
- The problem with the BCM 7E0 D is that it is probably parameterized for Kessy, hence that wall to match the keys.
Tip: It is better to buy a virgin BCM, I always recommend talking to firegrafik (forum user), he can help you buy one of the latest D, F models, which will be great for your future original LED headlights and other upgrades...
- You may have to power the license plate lights directly from the T73b/7 BCM pin. (pin dedicated to... if automatic lights).
- This first BCM coding is the starting point, don't panic if there are faults or malfunctions, everything will be solved later.
- Post the results, with your comments and a new Autoscan with the new codings.
Let's go with the first new BCM coding for automatic lights + CH/LH, with Replica headlights (Osram LED bulbs), without Dimmer, with original T6.1 taillights. The starting point.
09
New BCM coding:
F9A839BA0A21209101280E602CEB8E50C0807389600220C03200003D0800
09
Adaptation
54 Channel ... from 0 to 1 (stalks - momentary switch - return spring) https://www.uk-polos.net/viewtopic.php?p=503577#p503577
Note:
You must understand that due to the hardware of your Replica headlights some functions may not be possible. There have always been different versions of Replica headlights for the top selling VW models. The latest versions are better wired.
@Cris-87
If I understand you correctly, you still have the H7 headlights installed (waiting for the Bixenon headlights to arrive)... :?:
In such a case:
09
New BCM coding: (BCM 7E0937090B, H7 headlights + auto lights + CH/LH)
F8B079BA4A21201201280E107EEB8FD50080612F60846001320000020000
19
GW coding:
042200
If I misunderstood you, we re-encode based on your instructions/information.
In this Autoscan :arrow: https://www.uk-polos.net/viewtopic.php?p=589273#p589273, I think that you did not transfer the codings from your old BCM and GW to the new one 090B, as indicated in the link I posted to ross-tech for BCM replacement, that is why I requested the Autoscan with the old BCM 087.
We will code the BCM 090B again once the Bixenon headlights are installed.
Viperslider
ciclo wrote: Sat Feb 19, 2022 6:09 am (Lots of epic help)
Hiya Ciclo!
Thank you for looking into this so quickly!
So I had the chance to blat the coding onto the BCM and we have a great start:
DRLs fully functional including indicator wink - Perfect
Low beams working on “Auto” and Dipped beam - Perfect
High beam working correctly on all functions and stalk positions - Perfect
So the front lights are all working exactly as they should!
As expected, the number plate lights are no longer working but will make the wiring changes for that today (moving to T73b7, which makes sense as I’ll have auto headlights by the end).
I can’t test the full functionality of the auto headlights yet as the day is dramatic but it would appear that they are working. I’ll report back once I am able to test correctly.
Here is a new autoscan:
Saturday,19,February,2022,08:30:13:50827
www.Ross-Tech.com
VIN: WV1ZZZ7HZEH09^^^^   License Plate:
VIN: WV1ZZZ7HZEH09^^^^   Mileage: 182370km-113319miles
   Revision: 00H43001
   Coding: 01
   Revision: 00001012
   Coding: 0000000002
   Coding: F9A839BA0A21209101280E602CEB8E50C0807389600220C03200003D0800
   Coding: 2630AD
   Coding: 1000B3
   Coding: 0000B3
   Coding: A4FFFF
3 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 23:28:25
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 23:28:25
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 23:28:25
   Coding: 760E01
1 Fault Found:
13654544 - Databus
                    Fault Priority: 6
                    Fault Frequency: 11
                    Reset counter: 61
                    Mileage: 182371 km
                    Date: 2022.02.19
                    Time: 01:28:02
   Revision: B9080001
   Coding: 042300
4 Faults Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 01:28:06
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 01:28:06
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 01:28:06
03406 - Control Module for Battery Monitoring
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 03:06:05
   Revision: AA002001
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Coding: 00001A00
Cannot be reached
End----------(Elapsed Time: 01:23, VBatt start/end: 14.4V/14.5V)-----------
Please ignore the battery monitoring faults, that is related to another retrofit that I am testing LOL.
On a side note: I have my own trade account with VWAG for parts so if it will be a big benefit to get a later BCM then I can acquire one. If not then I am happy with the 090
I just wish the rain would go away for another day!
Viperslider
Hi Ciclo,
I thought I would add another update as I have now adjusted the wiring for the number plate lights (X)
Saturday,19,February,2022,15:23:46:50827
www.Ross-Tech.com
   Revision: 00H43001
   Coding: 01
   Revision: 00001012
   Coding: 0000000002
   Coding: 2630AD
   Coding: 1000B3
   Coding: 0000B3
   Coding: A4FFFF
2 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:08
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:08
   Coding: 760E01
1 Fault Found:
13654544 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Date: 2022.02.19
                    Time: 06:19:08
   Revision: B9080001
   Coding: 042300
3 Faults Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:12
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:12
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:12
Cannot be reached
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Coding: 00001A00
Cannot be reached
End----------(Elapsed Time: 01:21, VBatt start/end: 14.3V/14.3V)-----------
The keen eye will see that I no longer have a fault code for the number plate lights. Woohoo!
The same keen eye will see that I no longer have comms with my HBA module. However, I am still experimenting with this retrofit (moving CANBUS lines etc) as I had good direct comms with it on the powertrain BUS but reports of no comms fault code stored in the gateway (always showing up after I did the autoscans, hence why they haven't shown up in any of the scans I have posted so far). However, I have now moved it to the correct BUS (same as the IC) and now I have no direct comms with the HBA module but it appears to be functional LOL
So this is still an ongoing joyride. As long as it functions then I'm happy. I will be experimenting tonight under the cloak of darkness!
Cris-87
Post by Cris-87 »
ciclo wrote: Sat Feb 19, 2022 8:40 am @Cris-87
If I understand you correctly, you still have the H7 headlights installed (waiting for the Bixenon headlights to arrive)... :?: thank you very much for the speed in replying, you are really helpful to me. anyway I had the h7 but today I mounted the bixenon. my current situation is this: bixenon installed, RLS sensor installed and blackout mirror installed.
wiring for car switch installed
switch on car goes nothing
switch on positions does not go anything
switch on headlights go the low beams
with the lever I can flash but the fixed high beams do not go
In such a case:
09
19
GW coding:
042200
this is the gateway coding with the bcm 087
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BO034001
Coding: 042200
VCID: 70EA5550A3F32109B1-8024
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042207
Shop #: WSC 02737 534 423142
VCID: 68DA3D309B23E9C9E9-803C
the first thing I did after installing the bmc 090 was to copy the old encoding and re-encode the remote which now works correctly.
I hope I explained myself well, if you need more information I will be more precise/i]
Viperslider wrote: Sat Feb 19, 2022 4:21 pm Hi Ciclo,
www.Ross-Tech.com
VIN: WV1ZZZ7HZEH093353   License Plate:
VIN: WV1ZZZ7HZEH093353   Mileage: 182370km-113319miles
   Revision: 00H43001
   Coding: 01
   Revision: 00001012
   Coding: 0000000002
   Coding: 2630AD
   Coding: 1000B3
   Coding: 0000B3
   Coding: A4FFFF
2 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:08
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:08
   Coding: 760E01
1 Fault Found:
13654544 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Date: 2022.02.19
                    Time: 06:19:08
   Revision: B9080001
   Coding: 042300
3 Faults Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:12
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:12
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 182371 km
                    Time Indication: 0
                    Date: 2016.07.12
                    Time: 06:19:12
Cannot be reached
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Coding: 00001A00
Cannot be reached
If it's any consolation for you today it's also raining around here, but we're looking forward to this rain, we need it to rain for a couple of weeks at least.
Once the matter of the number plate lights has been solved (well done)... have you checked the operation of all the lights included in the tail lights? Once checked, you should verify that there are no related DTCs in the scan.
There is a possible solution for "low beam" faults in your Replica headlights. I suppose that your Osram LED bulbs are without drive unit, which is very low consumption, installing LEDs with a drive unit will not cause these faults.
E.g (just to visualize it, - my wife's Golf -): viewtopic.php?p=563461#p563461
They were tests that I did to know what people were installing in their Golf MK7. It currently has the original MATRIX LED headlights installed.
I also did tests with the Scirocco HBA mirror before installing the T6 HBA mirror.
I recommend installing the T6 HBA mirror (works perfectly or better 👌), please take a look at my 6R autoscan for references (mirror and RLHS). https://www.uk-polos.net/viewtopic.php?p=503577#p503577
I do not know if having activated channel 53 in the BCM your Scirocco HBA mirror will work correctly. You get the symbol on the IC, but...
