Kratosmr
Drives: Polo 1.2 TDI CFWA
Post by Kratosmr »
Hi, It was manual from factory. After upgrading the BCM I added the Remote Key (Center Locking works perfectly with Remote Key, Boot Lock also).
patil
Post by patil »
Check the adaptation addresses 03 &04 in BCM and see what is the stored value.
6R0 937 087 F is this the BCM you've upgraded to according to your scan ? If yes then this BCM won't support Cruise control as it doesn't have necessary pins.
Edit: Check for presence of 4 pins t73b 44 -47 in the BCM you've upgraded.
Kratosmr
Post by Kratosmr »
Hi, That 4 Pins are there. I checked it while buying and only 6RU937087F don't support CC, but 6R0937087F has those pins. I have completed the wiring now. The CC buttons are working I checked using VCDS, And also I have changed the ECU byte 5 bit 5 and it accepted the coding. I will reassemble everything now and will report.
BCM picture: https://drive.google.com/file/d/1AhdB2a ... share_link
Kratosmr
Post by Kratosmr »
Hi, CC is working perfectly. Thanks a lot Iichel and Patil for your kindly replies. Thanks a lot for this forum for all the valuable information from masters.
Well done, good job
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Good to read that CC is working.
patil
Post by patil »
Excellent job... 😎👍
Share the pictures and video of your work done.
Kratosmr
Post by Kratosmr »
Hi, any suggestion on getting the ECU wire through firewall?
Till now I did the tests by running the cable over the door.
Current Wire Run: https://drive.google.com/file/d/1NZvt5v ... share_link
I tried accessing the rubber grommet below the water cowl. But the other side of the hole is full of fabric insulations and pu sheets, whether removing the glove box is the only way?
Edit: Made a hole in insulation which made the cable management possible.
:D :D
Antera
Drives: Polo 6C
Post by Antera »
Hallo
I have a issue with the cruise control on a Up 1.0 TSI. CHYA engine code . I tryed al lot but never find the solution.
I hope someone van give me the solution.
We did the whole wiring and checked and checked. When looking in VCDS we have all the signals when looking in mesauring blocks. 09 we see all and also in 17 for the MFD. This also works. But when looking in de engine the cruise signal it stays on 66. No change when using the handle.
We see alle buttons but we are missing something because we cant get it to work. No light in dash also.
We tryed both engine bcm connectors on pin 29. But without Any result. I tink we have the wrong pin but cant figure put wich we need.
Is there somebody who van tell me wich pin i need on engine module or some other help.
Wiring als follows ( model before 11-2013)
Stalk Pin 31 -> BCM Connector B(white) pin 46 (diode)
Stalk Pin 30 -> BCM connector B(white) pin 44
Stalk Pin 28 -> Fuse 12V SC5(contact +15)
Stalk Pin 27 -> BCM Connector B(white) pin 47
Stalk Pin 29 -> A130 SRS-kabellas
Stalk Pin 26 -> A130 SRS-kabellas
A130 SRS-kabellas -> Engine ECU T56A Pin 29
A130 SRS-kabellas -> BCM Connector B(white) pin 45
Stalk pin 31 -> BCM connector B(White) pin 46
wewuzKANGS
Drives: mk5
Post by wewuzKANGS »
ciclo wrote: Sun Feb 15, 2015 8:58 pm Cruise control system 1.2 TSI
T94/45
VCDS
Engine Byte5
BCM Byte17
hi!
can you please share screen shots off all the long coding info of your ecu?
Antera wrote: Sun Feb 05, 2023 1:49 pm Hallo
wewuzKANGS wrote: Tue Feb 14, 2023 10:46 pm
T94/45
hi!
Hi, Engine?, BCM? ...
What specifically do you want to know? What is your goal? ...
Danish
Drives: Polo 2012
Post by Danish »
Kratosmr wrote: Sat Feb 04, 2023 2:44 pm Hi, CC is working perfectly. Thanks a lot Iichel and Patil for your kindly replies. Thanks a lot for this forum for all the valuable information from masters.
Can you share picture of your car
Kratosmr
Post by Kratosmr »
Hi Danish, you mean the exterior pics?
Buci
Drives: 6R 2011
Post by Buci »
Hello,
I am new in retrofitting on my polo 6R 2011, left hand drive but if can somebody help me with schematic and pins for retrofitting trip computer and crusie control that would be great.
Engine is 1.2 50 kw (70hp). Tenth letter is 'C'. So ciclo if you can help or anybody please do.
I bought the used levers and bcm 937087 and I will change the BCM soon.
Now just to buy vcds and get started.
I will make my own harness but could somebody recomend some links where to buy it from with speedy delivery?
Buci
