peter_dk25
- Drives: Blue GT
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Thanks a lot, Ciclo - I will consider the BCM change again
So I decided today was a good day to change the battery. The 105 Ah battery was from 2016 and was showing mild signs of wear.
Since my current setup doesn't require an expensive AGM battery anymore, I decided to go for a 'normal' EFB. The Bosch S5 015.
110 Ah, 920 CC to start my monstrous V12... I mean 1.2L.
Fun fact, the previous battery was an OEM JCB 105 Ah VW battery from a Touareg V10 TDI:
Next to the normal size 60 Ah for this car:
In the car:
Coding is needed for cars with the BDM battery monitoring:
61 - battery Regulator
Long adaptation
Battery replacement information
Changed "VA0 105 1111111114" to "VA0 110 1111111115".
VA0 stands for Varta (since Bosch and Varta are the same battery, just a different sticker), 110Ah and a theoretical serial number 1111111115 (the 5th battery in this car).
1 - OEM battery (4 years, died after a full flat)
3 - Bosch S5A AGM (1 week, replaced under warranty)
4 - Bosch S5A AGM (4 years, died after a full flat)
Then I realised that my heavy modding probably put a bit more strain on the battery... so bigger is better and the battery moved to the boot to allow 353x175x190mm
4 - VW 105Ah AGM (2 years, used battery, in ok condition but sometimes ABS lights show after start/stop and radio goes off)
5 - Bosch S5 015 110 Ah new
So now after 10 years, the 5th battery in my Polo 6R
In the car:
Long adaptation
Wow 110 battery
i didnt know that other polos had foam/ish insulation in the spare tire well.
This is the setup from Polo GTI/WRC
Huge 110 battery, ... something in your 6R is parasitizing power from your batteries.
The original battery from my 6R died shortly after about 8.5 years, but it was installed in the 9N3 which is the car used by my father-in-law, and every now and then he forgot to turn off the light switch.
Haha, well, my car was born with 13 control modules incl slaves but not counting internal modules (like 17 + 25):
01, 03, 04, 08, 09 + 2 WRM, 15, 17, 19 (external), 25 (internal) 44, 56, 61 (internal) +1
In the current state, the car has a little more
it's 33, not counting internals:
01, 03, 04 (internal), 05, 08, 09 + 8, 10, 15, 17, 19 (internal), 20, 25 (internal) 2B, 2E, 37/56, 3C +1, 44, 47, 55, 56, 57 +1, 61 (internal) + 1, 65, 69, 6C, 77
fun fact, the sole surviving module from factory is the 01 controller.
03 -> ESP8.2i to 9.0i
04 -> replaced with 6C steering racks internal sensor
05 -> Kessy added
08 -> upgraded to climatronic
09 -> upgraded to 7E9 090 -> 090B -> 090C + slaves: front WRM replaced with folding mirrors, rear WRM added, MFSW added, RLS added, DWA sensor + horn added
10 -> added 7E0 8K PDC -> 1K8 8K PDC
15 -> upgraded to passenger deactivation
17 -> replaced with MFA+
19 -> removed with BCM 7E0 upgrade
20 -> HBA added
25 -> replaced with MFA+
2B -> ELV added for kessy
2E -> MDI added
37-> upgraded RCD210 to RNS510 -> RNS510 with DAB+
3C -> added SWA (2x)
44 -> replaced electrohydraulic with electromechanical power steering
47 -> added dynaudio
55 -> added AFS
56 -> see 37
61 -> see 09, replaced battery sensor in the engine bay with 6C sensor from GTI in the boot
65 -> added TPMS direct
69 -> added trailer coupling
6C -> added RVC high
77 -> added bluetooth module
and only the 10, 22, 55 and the 3C live on the +15 line, all the other ones live on the +30 line.
05 -> Kessy added
20 -> HBA added
2E -> MDI added
55 -> added AFS
56 -> see 37
Hi, I have a question. I put on the 8P0035503K (GPS; GSM) antenna. I have a Polo 6R in the flap, I have no space for a second antenna (amplifier). Can you tell me where you connected the second amplifier?
yes, also to the rear glass on the other side. there are two places for the amplifiers, left and right.
Thanks for the answer. However, on the right side, I have no place where I can solder this amplifier to the glass.
Yes, you'll need to create your own soldering point but that's not too hard.
New mod: Ibiza 6J 6J0959441A multifuntion module / RNS remote
part: 6J0959441A + 1K0972704G
Wiring:
SA3 -> SC46 is +30
https://streamable.com/mq875g
The only problem is, as soon as 4B is registered in the CAN gateway, the MFSW stops working. Do you perhaps have an idea on this, ciclo?
it is certainly possible to have 4B besides an MFSW:
Wiring:
SA3 -> SC46 is +30
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 17603 003 00000
VCID: 3163E654D15B
No fault code found.The only problem is, as soon as 4B is registered in the CAN gateway, the MFSW stops working. Do you perhaps have an idea on this, ciclo?
Thanks you in advance for your answer
This is my car Autoscan (i clear the faults codes on my engine now) :
Chassis Type: 6N0
Scan: 01 02 03 08 09 10 15 17 19 25 2E 44 4B 55 56 77
VIN: VSSZZZ6JZAR063156
4B-Multifunc. Module -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (------CAVE) Labels: Redir Fail!
Part No SW: 03C 906 027 AE HW: 03C 906 027 AD
Component: MED17.5.5 H10 5034
Revision: L2H10--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM14TSI03C906027AE A01007
ROD: EV_ECM14TSI03C906027AE.rod
3 Faults Found:
4063 - Cylinder 4: Misfire Detected
P0304 00 [096] - Cannot Be Tested at this Time
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 485 km
Date: 2001.14.11
Time: 16:46:07
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - Mechanical Failure
Fault Priority: 2
Fault Frequency: 1
Mileage: 485 km
Date: 2001.14.11
Time: 16:46:07
4655 - Brake Boost Vacuum System: Mechanical Failure
P1479 00 [096] - Cannot Be Tested at this Time
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 047 T HW: 0AM 927 769 D
Component: GSG DSG AG7 402 1310
Revision: 00040024 Serial number: 00000909110492
Coding: 0000020
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 110248DB837300B5882612E7C1D700411700
Shop #: WSC 04941 000 00000
Address 08: Auto HVAC Labels: None
Part No SW: 6J0 820 043 A HW: 6J0 820 043 A
Component: Climatronic H07 0404
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H09 0025
Revision: BF009001 Serial number: 9955A257090788
Coding: 3C8829EF88610100092800007E0B1FC800C0420F608C00002000
Shop #: WSC 64564 324 38760
Part No: 1K0 955 559 AH
Component: RLS 090909 05 54 0402
Coding: 03302D
Part No SW: 6R0 959 801 A HW: 6R0 959 801 A
Component: J386__TSG_FT 001 0248
Coding: 020000
Part No SW: 6R0 959 802 C HW: 6R0 959 802 C
Component: J387__TSG_BT 001 0252
Coding: 020000
Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Coding: 000003
Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 010000
Address 10: Park/Steer Assist (J446) Labels: 6J0-919-475.clb
Part No SW: 6J0 919 475 A HW: 6J0 919 475 A
Component: PARKHILFE 4K H07 0007
Revision: -------- Serial number: 80320926500522
Coding: 000106
ASAM Dataset: EV_SE250ParkiAssis2 S01006
ROD: EV_SE250ParkiAssis2.rod
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA01 H09 0018
Revision: -------- Serial number: 003DW006H6SJ
Coding: 003031
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 801 D HW: 6J0 920 801 D
Component: KOMBI H07 0110
Coding: 110A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0025
Coding: 422000
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H07 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 6J0 035 342 B HW: 6J0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667564470
Coding: 020000
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10121
Shop #: WSC 06402
Coding: 0000002
Shop #: WSC 77005 000 00000
Address 55: Xenon Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 2688036
Part No: 7L6 941 329 C
Component: AFS-Lst.-Modul l 0004
Coding: 00000041
Component: AFS-Lst.-Modul r 0004
Coding: 00000041
Address 56: Radio (J503) Labels: None
Part No SW: 6J0 035 153 HW: 6J0 035 153
Component: Radio H11 0027
Revision: R0000000 Serial number: SEZAZ1I7269434
Coding: 0002040002
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
Component: FSE_2P8x H35 0170
Revision: 00000000 Serial number: 00000005093275
Coding: 0010730
End ---------------------------------------------------------------------Code: Select all
Code:
Saturday,08,June,2019,10:05:09:27911
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.0.2 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: VSSZZZ6JZFR155588 License Plate: IBIZA
Mileage: 400km-248mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZFR155588 Mileage: 400km-248miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GS HW: 03F 907 309 AE
Component: SIMOS10.22AH10 5494
Revision: --H10--- Serial number:
Coding: 002500D6202400080000
Shop #: WSC 00049 770 00189
ASAM Dataset: EV_ECM12TFS02103F906070GS 004007
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 79F9E5A8F8B45587D6-802C
Readiness: 0010 0101
Part No SW: 0AM 300 062 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501504196286
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 397925A87034958796-806C
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BQ HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0002
Serial number: --------------
Coding: 13DD287D412800C5C8191471825900880909
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0E13A674D13A623F13-805A
2 Faults Found:
0018 - Suspension Sensors
C104B 29 [008] - Signal Implausible
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 381 km
Date: 2019.06.03
Time: 01:02:44
0625 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Fault Priority: 2
Fault Frequency: 5
Reset counter: 0
Mileage: 380 km
Date: 2019.06.03
Time: 01:00:57
Serial number: 02051504651961
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3F6B4E19A72BFE3-802A
Part No SW: 6J0 820 043 E HW: 6J0 820 043 E
Component: Climatronic H03 0809
Revision: S0000000
VCID: 2643FED4518A0A7FCB-8072
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 0671 119150936
Coding: 24882BE88861250093380EF06FCB9EC80FC063A9608C2049200000020000
VCID: 2F6D1BF07E704B3738-807A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 160415 05 54 0403
Coding: 02242D
Subsystem 2 - Part No SW: 6R0 959 802 AP HW: 6R0 959 802 AP Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 5110
Serial number: 13202558140623154835
Coding: 030000
Subsystem 3 - Part No SW: 6R0 959 801 AM HW: 6R0 959 801 AM Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 007 5110
Serial number: 13202563150303030918
Coding: 030000
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 7 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0036
Serial number: 0211742
Coding: 010000
Subsystem 8 - Part No SW: 6R0 959 811 K HW: 6R0 959 811 K
Component: J388__TSG_HL 006 5110
Serial number: 13202567150504135456
Subsystem 9 - Part No SW: 6R0 959 812 K HW: 6R0 959 812 K
Component: J389__TSG_HR 006 5110
Serial number: 13102566150505065459
1 Fault Found:
03591 - Control Circuit for Horn
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 19
Reset counter: 82
Mileage: 357 km
Time Indication: 0
Date: 2019.06.03
Time: 02:58:33
Address 10: Park/Steer Assist (J446) Labels:| 6J0-919-475.clb
Part No SW: 6J0 919 475 E HW: 7N0 919 475
Component: PARKHILFE 8K H01 0018
Revision: -------- Serial number: 28291510300888
Coding: 100102
ASAM Dataset: EV_SE250ParkiAssis8K S01002
ROD: EV_SE250ParkiAssis8K.rod
VCID: 387F20AC833E8C8F69-806C
Component: VW10AirbagA0D H10 0020
Revision: -------- Serial number: 003GX02AKSUD
Coding: 003044
Shop #: WSC 00049 770 00114
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B6A64EDD20E1F0F-801E
Serial number: 3495RRB405D36OUMDH3B
Serial number: 3505RRB405P36OUMFGT%
1 Fault Found:
9447251 - Seat Occupied Sensor; Passenger's Side
B1027 53 [009] - Deactivated
Fault Priority: 6
Fault Frequency: 1
Mileage: 357 km
Date: 2019.06.03
Time: 02:57:52
Part No SW: 6J0 920 907 P HW: 6J0 920 907 P
Component: KOMBI H02 0805
Coding: 110A01
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 3B753FA0B208A79784-806E
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 022200
VCID: 70EFD88CA3CE14CF61-8024
Component: IMMO H02 0805
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBCAE48D12EE1F2F-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11221
Shop #: WSC 00788
VCID: 306F188CF74E54CF21-8064
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Coding: 0000002
VCID: 31691D88A8445DC72E-8064
Part No SW: 6J0 035 156 A HW: 6J0 035 156 A
Component: Radio H04 0013
Revision: R0000000 Serial number: SEZAZ1R6894021
Coding: 010004080203
VCID: 2541F9D82C8C0167C2-8070
End-------------------------(Elapsed Time: 03:24)--------------------------
Tuesday,30,March,2021,15:00:13:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
Dealer/Shop Name: iichel retrofitting
Workshop Code: 470 31889 031889
VIN: License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 4B 55
56 57 61 65 69 6C 77
VIN:
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: Not registered 0001
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H06 9980
Revision: 12005001 Serial number:
Coding: 00114036033400080000
Shop #: WSC 31889 470 31889
ASAM Dataset: EV_ECM12TDI03103P906021B
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 270B06DDAF6FF1F3EE9-8073
Readiness: 0 0 0 0 X
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Coding: 21DD2885432500C5841A146EC25500521505
VCID: 0F7B4E7D27DF89B3069-805B
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
Shop #: WSC 31889 047 31889
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSY_PQ35GP.rod
VCID: 372BD69D7FCF61737E9-8063
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E0B773-806D
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171327
Coding: 3EB82BBF28EB3400B33807F0BFCB9FF0FF8067EFE08D78D031E400030800
VCID: 2B03FAEDB307D5930A1-807F
Component: RLHS 220816 0 42 0106
Coding: 0214DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027011200011418
Coding: 58BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: None
Part No HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391528804191
Coding: 0031195101
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: N/A
VCID: 55F77C15C583B3638C5-8001
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
1 Fault Found:
12718592 - ROD - Unknown Error Code
- 00 [009]
Address 15: Airbags Labels:. 5K0-959-655.clb
Revision: J234 Serial number: --------
Coding: 5657313041697262616730314D
Shop #: WSC 01383 785 00200
VCID: 4ACD9F691C3DEC9B117-801F
No ASAM data for: "" (VW25)
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140F01
Shop #: WSC 12345 123 12345
VCID: 3333E28D6BB78D53421-8067
No ASAM data for: "" (VW36 *)
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042200
VCID: 688945E162713E8B273-803D
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 71331 km
Time Indication: 0
Date: 2063.14.08
Time: 13:57:52
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10
Revision: AA001001
Coding: 0404000000000000010000
VCID: 2E05F3F98095A0BB2DF-807B
Address 25: Immobilizer (J334) Labels:* None
Part No HW: 5K0 953 234
Coding: 000007
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4100000000000000
VCID: 2F3BEEFD879FA9B3269-807B
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7666620365
Coding: 010100
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB997845987B65F-8063
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
Shop #: WSC 02756 790 00000
VCID: 2F3BEEFD8B1FA9B3269-807B
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H09 0110
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ÿ
Subsystem 4 - Serial number: H21982ÿ
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 001F00
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
VCID: 79AF10A5095BB703C8D-802D
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE8BE73-807D
Coding: 0000002
VCID: 313FE8859D2BBF4330D-8065
Address 55: Headlight Range Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D4A000001000000
VCID: 3A2DCFA94CDD7C1B817-806F
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 57: TV Tuner Labels: None
Part No SW: 3C0 919 148 B HW: 3C0 919 148
Component: R78 DTV-JP 0250
Revision: R0H14000 Serial number: 80100800042102
Coding: 0000816
Shop #: WSC 01324 020 00200
VCID: 280905E1AEF1FE8BE73-807D
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVKLeser 0010
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030F7A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9B3269-807B
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H08000 Serial number: 525PA8-J060533
Coding: 0030115
VCID: 65974CD5996323E31C5-8031
Address 77: Telephone Labels: None
Part No HW: 3C8 035 730 E
Component: Telefon 025 Telefon 025 0983
Revision: J412 Serial number: 35502105254406
Coding: 00
ASAM Dataset: EV_UHVPremi 002709
ROD: N/A
End----------(Elapsed Time: 02:55, VBatt start/end: 13.0V/12.9V)-----------
I suppose it is the same principle that when the controls for the trip computer are installed simultaneously in the Stalk and in the Steering wheel, it generates a communication conflict.
I know you want to install them because you want to have more modules in the Autoscan
... (since you lost the MFSW reading when installing the CCE)
Ross-tech is going to have to design a new type of Autoscan for you ... like a book or something like that...
You are totally crazy
... that point of madness that makes everything great.
Yes I had the same thought. What is interesting is that there are some Ibiza's with both the MFSW and the 4B module. But the 4B buttons and MFSW do work simultaneously, just not when 4B is checked in the gateway installation list.ciclo wrote: Wed Mar 31, 2021 5:05 am I suppose it is the same principle that when the controls for the trip computer are installed simultaneously in the Stalk and in the Steering wheel, it generates a communication conflict.
So I was sort of slightly hoping that you would perhaps have an idea
Yes, guilty as charged. A gateway installation list is not a listing, it's a to-do list.I know you want to install them because you want to have more modules in the Autoscan... (since you lost the MFSW reading when installing the CCE)
Well, in all seriousness, I've been asking them to make some custom ASAM data records/lists, since some of these modules simply don't belong in a Polo 6R (VW25 platform).Ross-tech is going to have to design a new type of Autoscan for you ... like a book or something like that...![]()
You are totally crazy...
This is modules like the 5c0 47 sound system and 77 3c0 telephone module. But ross tech never failed to help me out
https://forums.ross-tech.com/index.php?threads/26919/
Hmm... what would happen if you enable Byte4 Bit7 in the BCM?
;LC,04,7,"Hotkey" Funktion aktiv (derzeit nur für SEAT)
Ross-tech forum as cool as ever, ... super people!
iichel wrote: Wed Mar 31, 2021 8:42 amYes, guilty as charged. A gateway installation list is not a listing, it's a to-do list.I know you want to install them because you want to have more modules in the Autoscan... (since you lost the MFSW reading when installing the CCE)
Byte 4 bit 7 did not make a difference unfortunately. I'll try to connect the mfsw to the other Lin pin on the bcm, just to give it a try
