Viperslider
Drives: Seat Leon 5F Cupra ST 290
Post by Viperslider »
ciclo wrote: Wed Feb 23, 2022 5:48 pm Hi Viperslider.
Since you mentioned that you did not have the Dimmer installed, I preferred not to encode it until later results. This does not exempt me from being involved and guilty of "0volts" in T73b/4. Forgiveness.🙏🤭
In this Bit I also attribute the discovery, or at least the first to post something about it. We did tests but it is necessary that the ECU (engine) support CCS/ACC - Euro6 -. (not for 6R until some 6R engine of a model sold in russia in 2018/19?)
It came in handy for a few geniuses who retrofitted the ACC on their T5s. If I remember correctly, it includes flashing the ABS unit and ECU with the proper firmware for ACC.
Hi Ciclo,
Well well well, it seems that we both made minor mistakes but with working together, we have come to a great resolution!
I have actioned the new coding changes for T73b4 and re-wired the interior illumination (again) and it is all working perfectly!
This is a great result.
Thank you for sharing your knowledge and information.
With the tail light PWM, this is the coding options I was talking about:
I had these active as my tail lights are T6.1 and not T6 but I have yet to see if there is any difference from the outputs needed.
Today I managed to finish off my B2B install too:
Finding little pockets of time to do my own thing between the many other things ha ha!
Great! T73b/4 is where the dimmer or interior lights for switches without dimmer must work, so the diagnoses will be correct in case of faults. Well done.👍
Ah OK!!!, T6.1 and not T6, use your BCM coding, on T6 LED taillights some lights are not LED.
Nice installation of the charger, thanks for sharing the image, very useful.👌
https://www.victronenergy.com/
Cris-87
Drives: vw golf 6 and vw t5 2014
Post by Cris-87 »
ciclo wrote: Thu Feb 24, 2022 3:45 am Hi Cris-87.
You say this:
- I had already wired as shown in the diagram.
and then you ask this:
- so I have to isolate the cables of the side parking lights from the t10 connector that went to the halogen headlight? in what position is this cable?
¯\(°_o)/¯
T10/10 is side/parking light on both halogen headlight connectors.
If you installed the kufatec adapter wiring (T10-T14) and it is the correct wiring for your T5, this T10/10 wire is already isolated.
Note: I don't have to know how the kufatec wiring is built. 🤭
sorry, maybe I have a bad explanation .. my english fault. I try to make a summary i used kufatec 38753 adapter. I followed this tread from the first page by installing bi xenon headlights, car light control and dimmer. I created the lights harness for h7 lamps (I mounted those) after the encoding you gave me everything works except the drl which are always off. I hope I was clear, at the end of the work I will send you a gift as a thank you for your patience
Hi Cristian.
The last BCM coding that I provided you is totally correct for your Bixenon headlights (LED modules).👌 viewtopic.php?p=589320#p589320
Once the parking/side lights wire issue has been clarified, you need to parameterize the BCM for Bixenon headlights (LED modules).
(2- viewtopic.php?p=589319#p589319)
One way to do it, is with VCP since it has an application to edit the values/parameters ​​of the BCM PQ25. It's really easy. (old video on youtube)
All the parameters are extracted to a text file generated by the program and the necessary values ​​are modified in that text file.
The modified file is loaded by the app and everything should work fine on your LED modules.
It is also possible with ODIS (logically).
Please, use the translator to view and find more info on this page:
https://www.drive2.ru/l/489696641561919499/
The values ​​you need to change:
:arrow: - PWM Value with POS/TFL lights and activited Pos-lights
:?: - PWM Value with POS/TFL lights and activited DRL-lights
Values.
I don't know what are the appropriate values ​​for T5 Bixenon LED modules (and activited Pos-lights), maybe is 40, as I told you, someone posted them in this thread.
The best gift I can receive for your thanks is that you post here the appropriate values ​​​​for your Bixenon headlights/LED modules. 8)
No other type of thanks is necessary.
Thank you very much!!!
Cris-87
Post by Cris-87 »
hi Circo!! today i checked the coding you gave me and i have no errors in bmc.
but I noticed that the lighting of the climatronic and the light switch are always on even with the command set to 0.
all functions are ok except the drl which at this point I will have to parameterize.
when I move the switch to side light position without the key inserted, the cluster turns on.
where am i wrong? I double checked the wiring several times. :cry: :cry: :cry:
Dazzyboy81
Drives: Transporter
Post by Dazzyboy81 »
Hi all,
Ok first of all I’m hoping I can be helped a little of a lost cause lol….
Ok I hope this doesn’t sound like I’m lazy but I have been through this post back to front and too to bottom…. I have confused myself…
Ok so currently I have H7 factory sportline headlights, BCM is 087… no auto lights or rain sensor…. So I have a pair of bi xenon headlights, kufatec looms with the two wires back to BCM, I have a brand new 090 bcm…..
So reading through my only interest is to fit the headlights, have all functions working and drls operating as factory….
I understand the looms will make everything work as soon as installed other than drl function….
So I need some help with if I need to fit new BCM…. Which I have gathered to make work needs new wires from clocks to bcm….
Then basically code the BCM old or new….
Many thanks
Dazzyboy81 wrote: Wed Mar 02, 2022 3:51 am Hi all,
Many thanks
Hi Darren, you have been trying to install your Bixenon headlights since spring 2018.
I think that this installation that you are doing would have taken me a weekend with a few beers in between.
Post a complete and recent Autoscan.
Warning: If you make a single mistake in your following posts, my compassionate character will end.
Dazzyboy81
Drives: Transporter
Hi ciclo,
I actually never completed before, I now have a new van and really want to complete this upgrade
I appreciate you commenting and my confusion is real
I thought a fresh start wise, I will post a full scan as soon as is possible and again thanks
Darren
Ok, ready 2 help you.
Dazzyboy81
Drives: Transporter
Hi ciclo,
sorry for delay,
ok below is latest and current autoscan, hope this helps, headlights are installed and wiring looms in and wires back to BCM, all working expect drl's and i have bulb warning as to be expected,
Many Thanks 8) 8)
Sunday,20,March,2022,16:11:15:49033
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.3.0.1 (x64) HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
www.Ross-Tech.com
VIN: License Plate:
Mileage: Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 56 69 0B
VIN: WV1ZZZ7HZ Mileage:
37-Navigation -- Status: Cannot be reached 1100
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JF HW: 03L 907 309 H
Component: R4 2,0L EDC X36 9108
Revision: 22X36--- Serial number: 00000000000000 CVN: E3F39EAD
Coding: 01194012232400080000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20BTD01103L906022JF 002011
ROD: EV_ECM20BTD01103L906022JB.rod
VCID: 72BC2123D424D90BC96-8026
VINID: 9E606AAAA1D8A936001462431CBEE99244
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 H HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0107
Revision: 00H43001
Coding: 708764AD89A90E9B26AB9174A96510
Shop #: WSC 02736 790 49152
VCID: 372AD037FF467C233E8-8062
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BC HW: 7E5 907 047 BC
Component: Climatic-T5 H19 0404
Revision: 00001009
Coding: 0000000002
Shop #: WSC 02757 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 71BE2E2FD122E21330C-8024
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0251
Revision: BO047001 Serial number: 0429 278110512
Coding: A0A0393A0E612011922848106C2B8C540080410F60864000300000000000
Shop #: WSC 02736 790 12345
VCID: 392ED60FC9526A53C8C-806C
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Coding: 010000
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Subsystem 3 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 7E1 951 172
Subsystem 6 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H04 0103
Serial number: 29180000490180038101
Coding: A40000
10 Faults Found:
00967 - Left Turn Signals
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 254
Reset counter: 144
Time Indication: 0
00968 - Right Turn Signals
Fault Priority: 2
Reset counter: 144
Time Indication: 0
03428 - Activation of Left Adaptive Light
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 135627 km
Time Indication: 0
Date: 2016.07.28
Time: 09:46:15
03429 - Activation of Right Adaptive Light
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 93
Mileage: 0 km
Time Indication: 0
Date: 2016.07.28
Time: 09:46:14
03434 - Output for Terminal 30G Interior Lights
007 - Short to Ground - Intermittent
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 136073 km
Time Indication: 0
Date: 2016.08.08
Time: 18:28:32
03435 - Terminal 30 for Interior Light and Parking Light
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 3
Reset counter: 144
Mileage: 136052 km
Time Indication: 0
Date: 2016.08.08
Time: 17:30:57
03301 - Response Closing Status of Drivers Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 144
Mileage: 135593 km
Time Indication: 0
Date: 2016.07.18
Time: 17:43:14
03302 - Response Closing Status of Passenger's Door
Fault Priority: 2
Fault Frequency: 4
Reset counter: 144
Mileage: 135593 km
Time Indication: 0
Date: 2016.07.18
Time: 17:43:14
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 34
Reset counter: 104
Mileage: 135564 km
Time Indication: 0
Date: 2016.07.17
Time: 17:59:12
01331 - Door Control Module; Driver Side (J386)
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Time Indication: 0
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 D HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47301125201182
Coding: 018001
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_VW75XParkAssis4K A01006
ROD: EV_VW75XParkAssis4K_A01.rod
VCID: 3332E427EBBE9003020-8066
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H06 0013
Revision: -------- Serial number: 003HL0084L6.
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3536DA3FE5CA8E332C4-8060
Part No SW: 7E0 920 970 E HW: 7E0 920 970 E
Component: KOMBI H04 0305
Coding: 760A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2C00FF5B3680CFFB43A-8078
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0251
Revision: BO047001
Coding: 042300
VCID: 70B82B2BDAA8EB1B3F2-8024
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 135564 km
Time Indication: 0
Date: 2016.07.17
Time: 10:30:50
Component: IMMO H04 0305
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A8C3943FCF411CB716-803E
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 3038EB2B1A28AB1B7F2-8064
End----------(Elapsed Time: 02:14, VBatt start/end: 12.1V/12.1V)-----------
Dazzyboy81
Drives: Transporter
The turn signal faults are caused by my clifford alarm system when you forget to place pin before driving, so i can account for them, the adaptive light is drl's isnt it?
I have seen the faults concerning door many times on different vehicles and have never understood what its mean
Thanks :lol: :lol:
Dazzyboy81
Drives: Transporter
Anyone able to assist? Thanks
james194zt
Drives: None!
Post by james194zt »
Hi Ciclo,
I have a 2014 VW Beetle Sport running with fogs but NOT Xenon lights, I am looking to retrofit the auto headlights and you seem to be the person in the know! Is it possible, are you still selling your wiring harnesses and could one be adapted? I am currently retrofitting the mirror with rain/light sensor to the car but this was the final part of the install , something I didn't realise was going to be so complicated until I pulled out the headlight switch and saw it was the 17 pin style one and not the 10 pin one used by auto headlights.
James
patil
Post by patil »
Dazzyboy81 wrote: Sun Mar 20, 2022 6:48 pm
No, it's static cornering lights (SCL)
http://wiki.ross-tech.com/wiki/index.php/03428
Regarding these DTC's.....
Check for blown fuse.. usually 15A fuse ( SB 7 ?)
sim0n_parker
Drives: Transporter
Post by sim0n_parker »
I stumbled across this site and glad I did! I’m doing this auto lights and struggling can someone help me out with regards to swapping the 18pin light switch over!?
