Hi, Can you help me? I own a vw t5 facelift 2011, I replaced the bcm that did not support cruise control and installed 7H0 937 090. After coding, my electrics did not work. Raising the window. I did the CAN lines and they work. My lights work the same but I have error 01516 Terminal 30 and error 00927 Terminal 30 and my dashboard light is on. So I wonder if it would solve the problem with for the two 'Terminal 30: open circuit' errors, you'll probably have to run two wires to your fuse box. 2.5mm2 wire from fuse box terminal 30 to T73a/63 and 2.5mm2 wire from fuse box terminal 30 to T73b/68 Fuse both with 30A
Yes you will need to route some +30 wires to the BCM from fuse box, some wires from BCM to the external lights and some wires from BCM to light switch.
And of course do some coding.
iichel, Thanks for the answer, I completed everything and everything works, but I have a new problem. Error 01504 bulb for license plate licht. The light works
You need to make a new direct connection (single wire) between the BCM T73b/7 and license plate lights.
It will be the new power/feed for license plate lights, this way your 'BCM Max' will be able to recognize your license plate lights.
Code the BCM Byte27 Bit0 to active/enabled if you install license plate lights with LED technology.
Your license plate lights are currently working because they are still powered by the original wiring for BCM High, a 58 signal of generic character.
hi,
installed for my VW T5 2011 bi-xenon.
I did everything according to the instructions and everything works fine, but the light bulb appears on the meter when turning on the lights and the error 03906 is displayed.
I cannot deal with this problem.
I do not have automatic lights installed.
Maybe someone can help me and tell me what I did wrong?
My autoscan:
My autoscan:
Sobota,03,Wrzesień,2022,01:13:20:21977
VCDS -- Emulator VAG/VAS pracujący w środowisku Windows, uruchomiony na Windows 10 x64
Wersja VCDS: AKP 22.3.1.4 HEX-NET CB: 0.4615.4
Wersja danych: 20220606 DS337.0
www.vcds.pl
VIN: WV1ZZZ7HZCH042768 Numer rejestracyjny: POLO FORUM
Przebieg: 174190km Numer naprawy:
Typ podwozia: 7H-VN75 (7E0)
Skanowanie: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: WV1ZZZ7HZCH042768 Przebieg: 174190km
01-Silnik -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
04-Kąt skrętu kierow. -- Stan: OK 0000
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: Usterka 0010
10-Asyst.park./kierow. -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
56-Radio -- Stan: Usterka 0010
Adres 01: Silnik (J623-CAAC) Plik etykiet:. 03L-906-022-CAA.clb
Oznaczenie elementu SW: 03L 906 022 CH HW: 03L 907 309 K
Komponent: R4 2,0L EDC H43 9126
Weryfikacja: 26H43--- Numer seryjny: 00000000000000 CVN: 54486883
Kodowanie: 01194012232400080000
Kod serwisu: WSC 02736 790 50316
Zbiór danych ASAM: EV_ECM20TDI01103L906022CH 002012
ROD: EV_ECM20TDI01103L906022CH_002.rod
VCID: 6D92CCA8BCC427E714-8038
VINID: 9E606AAAA1D8A936001021C6209CCFD8DA
Nie znaleziono błędów.
Kody gotowości: 0 0 0 0 X
Adres 03: ABS/hamulce (-----) Plik etykiet: 7E0-907-37x-MK25AXT.clb
Oznaczenie elementu SW: 7E0 907 379 H HW: 7E0 907 379 E
Komponent: ESP MK25A XT H43 0107
Weryfikacja: 00H43001
Kodowanie: 708724AD89A80E9724A99177696610
Kod serwisu: WSC 02736 790 49152
VCID: 373E2EC086185D373E-8062
Adres 08: Klimatyzacja (J301) Plik etykiet:| 7E5-907-047.clb
Oznaczenie elementu SW: 7E5 907 047 BC HW: 7E5 907 047 BC
Komponent: Climatic-T5 H19 0404
Weryfikacja: 00001008
Kodowanie: 0000000002
Zbiór danych ASAM: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 71AAD0D8A0FCC30730-8024
Adres 09: Centr.zesp.elektr. (J519) Plik etykiet:. 7E0-937-BCM-V1.clb
Oznaczenie elementu SW: 7E0 937 090 C HW: 7E0 937 090 C
Komponent: BCM PQ25 Max4 H82 0752
Weryfikacja: B9082001 Numer seryjny: 4000 202170027
Kodowanie: A0A0303A0E61243380284E006E6B0C554290662F60017841320000020000
Kod serwisu: WSC 00001 052 12345
VCID: 2B1602B04A50E9D74A-807E
Podsystem 1 - Oznaczenie elementu SW: 7E0 959 801 HW: 7E0 959 801 Plik etykiet: 7E0-959-80X-V1.CLB
Komponent: J386__TSG_FT 002 3311
Numer seryjny: --------------------
Kodowanie: 000000
Podsystem 2 - Oznaczenie elementu SW: 7E0 959 802 HW: 7E0 959 802 Plik etykiet: 7E0-959-80X-V1.CLB
Komponent: J387__TSG_BT 002 3311
Kodowanie: 000000
Podsystem 3 - Oznaczenie elementu: 1K0 951 605 C
Komponent: LIN BACKUP HO H05 1501
Kodowanie: 000000
Podsystem 4 - Oznaczenie elementu SW: 3C8 959 537 D HW: 3C8 959 537 D Plik etykiet: 3C8-959-537.CLB
Komponent: E221__MFL-TK6 H06 0022
Numer seryjny: 10000000000000127214
Kodowanie: E20000
Znaleziono 1 błąd:
03906 - Sterowanie przekaźnika świateł drogowych
010 - Przerwa / zwarcie z plusem
Ramka zamrożona:
Stan błędu: 01101010
Priorytet błędu: 3
Częstość błędu: 1
Wew.licznik błędów: 245
Przebieg: 174197 km
Wskaźnik czasu: 0
Data: 2017.01.24
Czas: 01:10:49
Adres 10: Asyst.park./kierow. (J446) Plik etykiet:| 7E0-919-475.clb
Oznaczenie elementu SW: 7E0 919 475 D HW: 7E0 919 475
Komponent: PARKHILFE 4K H11 0013
Weryfikacja: -------- Numer seryjny: 47301122400521
Kodowanie: 108001
Zbiór danych ASAM: EV_VW75XParkAssis4K A01006
ROD: EV_VW75XParkAssis4K_A01.rod
VCID: 33261AD09A60B11702-8066
Adres 15: Airbag (J234) Plik etykiet:| 5K0-959-655.clb
Oznaczenie elementu SW: 7E0 959 655 B HW: 7E0 959 655 B
Komponent: VW10Airbag003 H06 0013
Weryfikacja: -------- Numer seryjny: 003HL007FGRK
Kodowanie: 000000000000000000000000000000003033
Kod serwisu: WSC 02734 790 50316
Zbiór danych ASAM: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 352224C89414AF272C-8060
Adres 17: Zest.wskaźników (J285) Plik etykiet:| 5K0-920-xxx-17.clb-SRI1
Oznaczenie elementu SW: 7E0 920 870 E HW: 7E0 920 870 E
Komponent: KOMBI H04 0305
Kodowanie: 160E00
Zbiór danych ASAM: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2B1602B04250E9D74A-807E
Adres 19: CAN Gateway (J533) Plik etykiet:. 7E0-909-901.clb
Oznaczenie elementu SW: 7E0 909 901 HW: 7E0 937 090 C
Komponent: GW-K-CAN TP20 H82 0752
Kodowanie: 042200
VCID: 689CBDBC9B2602CF67-803C
Adres 25: Immobiliser (J334) Plik etykiet:| 5K0-920-xxx-25.clb
Oznaczenie elementu SW: 5K0 953 234 HW: 5K0 953 234
Komponent: IMMO H04 0305
Numer seryjny:
Kodowanie: 000000
Kod serwisu: WSC 00000 000 00000
Zbiór danych ASAM: EV_Immo_UDS_VDD_RM09 A03009
VCID: 6A98C7B48D2A30DF71-803E
Adres 56: Radio
Nie może być osiągnięty
Koniec (Skanowanie trwało: 01:18, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 12.7V/12.7V)
Hi, at first glance it looks like a BCM coding issue. (also depends on how your BCM 7E0 is wired, but not a concern at this point)
Try the following:
Byte11 Bit0 ... enable (this must be enabled yes or yes in all circumstances)
In case the error does not disappear, you should play with the following Bytes:
Byte18 Bit5 (enable is 66 HEX, disable is 46 HEX)
Byte22 Bit5 (enable is 78 HEX, disable is 58 HEX)
Byte23 Bit0 (enable is 41 HEX, disable is 40 HEX)
You must find the right combination. Start by testing Byte23 first, then Byte22, and finally Byte18. Maybe two changes are needed.
Please inform us of your achievements for future users. Thank you very much.
Try the following:
HI,
thank you for your interest.
here's what i did:
byte11, bit0 -> enable (I entered it manually because there is no bit 0 on the list, only bit 6,7)
byte23, bit0 -> disable
when i turn on position lights or dipped beam i have bulb indicator but i haven't faut code
if I turn on the high beam, i have faut codes: 01499; 01495.
byte22 bit 5 changed nothing
byte18 bit 5 I can't change to another one because the left lamp starts flashing and i have error 00978. My BCM is supported HEX 00, 41, 43, 60, 66 but not 46.
here's what i did:
Niedziela,04,Wrzesień,2022,13:29:55:21977
www.vcds.pl
Przebieg: 174200km Numer naprawy:
Skanowanie: 01 03 04 08 09 10 15 17 19 25 56 61 0B
VIN: WV1ZZZ7HZCH042768 Przebieg: 174200km
09-Centr.zesp.elektr. -- Stan: OK 0000
19-CAN Gateway -- Stan: Usterka 0010
56-Radio -- Stan: Usterka 1010
61-Reg.akumulatora -- Stan: Usterka 0010
Kodowanie: A0A0303A0E61243380284E016E6B0C554290662F60017840320000020000
Kodowanie: 000000
Kodowanie: 000000
Kodowanie: 000000
Kodowanie: E20000
Kodowanie: 108001
Kodowanie: 160E00
Kodowanie: 042200
Znaleziono 1 błąd:
01304 - Radio
004 - Brak sygnału / brak komunikacji - Sporadyczny
Ramka zamrożona:
Stan błędu: 00100100
Priorytet błędu: 2
Częstość błędu: 1
Wew.licznik błędów: 30
Przebieg: 174205 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 13:25:42
Numer seryjny:
Kodowanie: 000000
Adres 56: Radio
Adres 61: Reg.akumulatora (J840) Plik etykiet:. 1K0-907-534.clb
Oznaczenie elementu SW: 7E0 907 534 HW: 7E0 937 090 C
Komponent: Batt.regelung H82 0752
Kodowanie: 030B1A73
Kod serwisu: WSC 02739 790 00000
2 - ilość znalezionych błędów. Oto one:
00458 - Sterownik układu kontroli akumulatorów (J367)
Ramka zamrożona:
Stan błędu: 01100100
Priorytet błędu: 2
Częstość błędu: 1
Wew.licznik błędów: 246
Przebieg: 174205 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 13:25:59
02252 - Alternator
Ramka zamrożona:
Priorytet błędu: 2
Częstość błędu: 1
Przebieg: 174205 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 13:25:59
Koniec (Skanowanie trwało: 01:22, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 12.3V/12.3V)byte22 bit 5 changed nothing
turn on the high beam:
Niedziela,04,Wrzesień,2022,13:24:00:21977
www.vcds.pl
Kodowanie: 000000
Kodowanie: 000000
Kodowanie: 000000
Kodowanie: E20000
01495 - Żarówka świateł drogowych (M30); lewa
Ramka zamrożona:
Priorytet błędu: 3
Częstość błędu: 1
Przebieg: 174205 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 13:17:37
01499 - Żarówka świateł drogowych (M32); prawa
Ramka zamrożona:
Priorytet błędu: 3
Częstość błędu: 1
Przebieg: 174205 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 13:17:37
Kodowanie: 108001
Kodowanie: 160E00
Kodowanie: 042200
Numer seryjny:
Kodowanie: 000000
Adres 56: Radio
Kodowanie: 030B1A73
Ramka zamrożona:
Priorytet błędu: 2
Częstość błędu: 1
Przebieg: 174205 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 13:09:47
02252 - Alternator
Ramka zamrożona:
Priorytet błędu: 2
Częstość błędu: 1
Przebieg: 174205 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 13:09:47
Koniec (Skanowanie trwało: 01:21, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 12.3V/12.3V)- ciclo
From the information thrown by the Autoscan, the problem is that ALL the appropriate steps for the coding/adaptation of the BCM were not done.
We assume that your T5 is a vehicle without Start/Stop, right?
In that case you have to do this:
- Enable address 61 in Gateway installation list.
- Go to address 61 and code all Bytes to 00.
- Return to GW installation list and disable the address 61.
- Go to Autoscan and Click on Gateway installation list button.
- Click on Clear All DTCs.
The address 61 should no longer be present in the Autoscan.Re: Auto headlight retrofit. VW Transporter. T5 (2010-2015)
Yes you're rightciclo wrote: Sun Sep 04, 2022 7:48 pm We assume that your T5 is a vehicle without Start/Stop, right?
Niedziela,04,Wrzesień,2022,21:09:32:21977
www.vcds.pl
Przebieg: 174210km Numer naprawy:
VIN: WV1ZZZ7HZCH042768 Przebieg: 174210km
Kodowanie: 000000
Kodowanie: 000000
Kodowanie: 000000
Kodowanie: E20000
Ramka zamrożona:
Priorytet błędu: 3
Częstość błędu: 1
Wew.licznik błędów: 247
Przebieg: 174211 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 21:07:12
Ramka zamrożona:
Priorytet błędu: 3
Częstość błędu: 1
Przebieg: 174211 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 21:07:12
Kodowanie: 108001
Kodowanie: 160E00
Kodowanie: 042200
Znaleziono 1 błąd:
01304 - Radio
Ramka zamrożona:
Priorytet błędu: 2
Częstość błędu: 1
Wew.licznik błędów: 31
Przebieg: 174211 km
Wskaźnik czasu: 0
Data: 2017.01.25
Czas: 21:06:50
Numer seryjny:
Kodowanie: 000000
Adres 56: Radio
Koniec (Skanowanie trwało: 01:17, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 12.2V/12.2V) - ciclo
Tell us something about the adaptation of the wiring for your 'new' BCM '7E0'.
Did you install the wire that goes to T73a/62?
here's what i did:
1) upgrade my BCM 7H0937087H --> 7E0937090D but it didn't work with my key --> 7E0937090C
2) - Left Bixenon headlight : a wire from T14g/12 connector to T73b/3 BCM
- Right Bixenon headlight: a wire from T14c/12 connector to T73a/5 BCM
3) SA2 --> Run two 2,5 mm2 automotive wires from the E-box to the BCM T73a/63, T73B/68
4) Remove & isolate original wires 5a, 27a.
Install
SB5 (15A), 5a --> T73a/2 BCM
SB27 (15A), 27a --> T73b/2 BCM
Use the same fuses.
5) High Beam signal
Remove SB28a wire and add a new 0.5 mm2 wire to the removed wire. Carry this new wire up to T73a/62 BCM
Reinstall the SB28a original wire in its slot/place. Use the same fuse.
6) New 1.0mm2 wire from T73b/12 to T10o/3, beneath the driver's seat.
Remove & isolate original T10o/3.
7) install new wire BCM --> instrumenta cluster
8 ) Light switch with PIN T17/3 removed and isolated
9) Remove & isolate original wires SB 11a,
new wire from T73b/7 to SB 11a (licence plate)
10) I changed the electrical installation of the lamps as in the picture below
https://drive.google.com/file/d/11mV6YZ ... sp=sharing
Install
Use the same fuses.
5) High Beam signal
Thanks for the information.
Only you and me can code any Byte with the HEX value we want, but you must keep it secret.
Please try this new BCM long coding:
A0A0303A0E61243380284E016E6B0C554290462F60017840320000020000
Thank you Ciclo!
there are no error codes
but the bulb light is still on when I turn on the position lights
Poniedziałek,05,Wrzesień,2022,19:50:35:21977
www.vcds.pl
Przebieg: 174230km Numer naprawy:
VIN: WV1ZZZ7HZCH042768 Przebieg: 174230km
Kodowanie: A0A0303A0E61243380284E016E6B0C554290462F60017840320000020000
Kodowanie: 000000
Kodowanie: 000000
Kodowanie: 000000
Kodowanie: E20000
Kodowanie: 108001
Kodowanie: 160E00
Kodowanie: 042200
Znaleziono 1 błąd:
01304 - Radio
Ramka zamrożona:
Priorytet błędu: 2
Częstość błędu: 2
Wew.licznik błędów: 32
Przebieg: 174233 km
Wskaźnik czasu: 0
Data: 2017.01.26
Czas: 19:46:23
Numer seryjny:
Kodowanie: 000000
Adres 56: Radio
Koniec (Skanowanie trwało: 01:16, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 11.9V/12.1V)- ciclo
The bulb light in the instrument cluster is from other light or lights, I'll look at it tomorrow.
Either you have to disable some diagnostic (license plate lights, etc), or something related to the BCM parameterization.
Please, checks and reports that ALL lights are working properly. Do not forget any, rear fog lights, plate lights, reverse lights, side lights, etc ...
Remember that the DRLs are with the light switch position 0 and that they are not the same lights as the side lights (same LED module).
The DRLs shine brighter.
edit...
Hamster, it would be great if you still have an Autoscan with your original BCM 7H0937087H with no faults and all the original bulbs.
Please take a look in the Logs/Scans folders of the ross-tech program.
If you installed any LED bulb in the rear, this is the right time to communicate it.
