Buci
Drives: 6R 2011
Post by Buci »
ciclo wrote: Thu Apr 04, 2024 3:45 am I don't think the fault detected is related to the 'new' BCM/GW (09/19 Addresses), I think it is 99% due to the Basic Setting of the G85 slip ring in the ABS unit (03 Address).
Maybe you are not doing it correctly, have you started the engine to do the Basic Setting?
For the 6R Europe 2009-2014, the G85 basic setting is done in Address 03: ABS Brakes and not in Address 44: Steering Assist.
You would have saved a lot of time (which is more valuable than money), problems, and money, if you had followed my advice and already had the Original diagnostic tool.🤷‍♂️
The g85 resolved. But I have an error in vcds for cruise control. Pin 69 in ecu as you said ciclo but there is no light for on the mfd when I drive over 40 km/h.
Vcds
1 fault found. 6118-cruise control switch (e45) P 0568 00 [037] implausible signal
The stalk was used in another car.
What can it be? Also I bought wires on a german web site with instructions. I would share them here but I do not know how so you can see what pins I used. Strange thing that they said in the instructions ( and wire had that option like a spliter ) was to connect new wire with an existing one and the other end to a pin on the bcm. So I did not connect anything to the fuse box.
What can be an error?
Forget the kufatec instructions and focus on installing the wires like in this diagram. Physically check what you already have installed.
viewtopic.php?p=490258#p490258
Autoscan?
Please remind us which engine your Polo has to verify the correct pin for your ECU.
You must make sure that the ECU pin is inserted correctly...
Buci
Drives: 6R 2011
Post by Buci »
ciclo wrote: Tue Apr 30, 2024 5:01 pm Forget the kufatec instructions and focus on installing the wires like in this diagram. Physically check what you already have installed.
Autoscan?
I dont know to insert autoscan here...how?
Cgpa polo engine, you told me the pin 69 before in the posts.
I had a problem with inserting 69 pin in the ecu...a lot...maybe it was not ok inserted...
I will recheck fhe wires. Ciclo it is not kufatec website. I have pdf file with pictures and pins. Is there a way to sent it to you to see if the manual is ok?
... you have to come to the forum/war already cried from home.😄
Two options to post an Autoscan.
- You copy the entire Autoscan that is in the text file and paste it into the text editor.
- Or you can use the 'code' tool of the text editor.
paste autoscan here
I already know the Kufatec instructions from many other times, it is not necessary to post them, they are fine, the problem is that whoever reads them sometimes does not know how to interpret them.
That is why I referred to the diagram, it is impossible to get lost with the original diagram.
It is highly likely that the ECU pin is not inserted correctly, it is a common problem. You have to be precise and meticulous in the way it is inserted, in addition to moving the locking mechanism slightly to be able to insert it correctly and then lock said mechanism again. The locking mechanism is usually purple/pink or similar.
I don't remember telling you what the pin was for the cruise control of your engine control unit...🤷‍♂️
There are two possibilities for CGPA:
- If the ECU has 80 pins, the correct pin is 24.
- If the ECU has 121 pins, the correct pin is 69.
(Ah, ok, I already saw it reviewing your posts, 69, yes, it's 69).
SaurabhVW
Drives: Polo Sedan 1.6 MPI
Post by SaurabhVW »
Siddhants127 wrote: Fri Apr 22, 2022 7:54 pm Hi patil, yes as soon as i remove the 69 pin connection this epc and check engine lights are gone….you are right probably my ecu doesnt support ccs.
So i guess i cnt enjoy ccs in my car alas.
Anyway thanx a lot for this comprehensive search and consequent explaination for this issue.
Will try to return the wiring set and stalk😔😔.
Or can i swap the ecu ….is it possible …is it doable?
Hi Siddants127
I have recently done a cruise control retrofit on 1.2 MPI polo with same CJLA engine ecu, however the ecu pin 69 was empty and were able successfully install and code the ecu for cruise control..
Good info, thanks!👍
patil
Post by patil »
SaurabhVW wrote: Mon May 06, 2024 6:56 pm
Hi Siddants127
Please share the details of your 1.2MPI ecu. Only 1.2 MPI ECU's installed from facelifted model year 2016 (IND) support Cruise control. Eg Govind Sharma's Polo 1.2 MPI. viewtopic.php?p=590415#p590415
I just helped a good friend to successfully install cruise in Polo comfortline 1.2MPI MY 2017. His ECU is updated one, same as Govind's.
And interestingly, I found an updated BCM 6RU 937 086S locally to use for CC retrofit. It has necessary pins to support Cruise control !! This was new for me, I had thought, only from 087 series BCMs have those necessary pins.
8)
SaurabhVW
Post by SaurabhVW »
patil wrote: Wed May 22, 2024 8:06 pm
Hi Siddants127
8)
Sorry I got stuck in work.
so the ECU is 03E906019 CJLA 9971. Continental 5WB11001, I have attached the ECU photo for reference & BCM was 87R. Which I think comes from factory for 1.2 MPI Highline variants.
The problem while doing this I faced is, the Pin used for ECU pin 69 was still unknown which one to put, I did use the PIN use is used in instrument cluster. I chopped a bit and put it into the pin 69.
patil
Post by patil »
Hi sorry for late reply. Your ECU doesn't support CCS function. You need to replace the ECU to updated version or flash the updated firmware in your ECU. Pin 69 is correct pin for 1.2MPI CJLA engine for CCS.
dojerez
Drives: R6
Post by dojerez »
I have followed the tutorial and I have been able to install the CCS on my VW, now, has anyone been able to install the CCS on the MFSW? please help
viewtopic.php?p=567132#p567132
MaDwArLoCk
Tell him what buttons you plan to install.
Works for most VW buttons.
My installation:
viewtopic.php?p=564515#p564515
Buci
Drives: 6R 2011
Post by Buci »
ciclo wrote: Thu May 02, 2024 4:21 am ... you have to come to the forum/war already cried from home.😄
paste autoscan here
Hello,
I was lasy to check the ecu pin and if it was inserted ok.
Before doing all that is there a way to check is the css lever ok and working with wcds (without removing the wheel etc.).
I see that somenone is saying you can to that with measurimg blocks values in vcds?
Thanks.
yes, go to bcm, measurement values, type 'cruise' and tick the four boxes related to cruise control.
Buci
Drives: 6R 2011
Post by Buci »
iichel wrote: Sun Jul 20, 2025 11:17 am yes, go to bcm, measurement values, type 'cruise' and tick the four boxes related to cruise control.
Ok but what rhen? After I tick them? Which value is the buttons on the lever are working? Or which are that the bittons are not worikimg?
After checking the boxes, 'press the CCS buttons' and you'll see if the values change.
If there is change in the values, it is because they work (logically) ... it's just using your/a basic logic.
I seem to remember that you can check the values on both the engine unit and the BCM unit.
If they work but the CCS doesn't, it's because the wire going to the ECU (engine) is incorrectly installed.
Autoscan. :?:
UDS Measuring Values:
https://www.youtube.com/watch?v=xNzkVqlk1S4
